Lacking
The best
These are a little difficult to work with due to the hollow pins, but they are the best sound wise. Have used Viborg and others...
Astonishing- finally
I rated this cable before a few years ago when using fairly budget RCA connectors. I terminated it today with Neotech NEX GD...
Customers reviews - There are 19516 reviews.
Hendrik W.
OPA1622 nice improvement
Decided to replace the JRC4556AD in my Denon AVP-A1 phone amp stage. What a good improvement this was (using Qobuz), vocals crystal clear, highs more sparkling and a bit more bass (but much more tight). I didn't use the pramp for headphone listening because it was dull, lifeless and floppy bass with 4556, now I enjoy it again.
While I was at it also replaced most resistors, capacitors and installed opamp socket for easy opamp rolling.
Emin U.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.2μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
fantastic
sound quality, scene creation, softness,detail, i loved the all. i liked it more than dayton mpts
Emin U.
fantastic
Dhafer D.
DAC unique dans son genre
Je l'ai acheté pour un systeme composé de hauts parleurs focal chorus 5 et d'un ampli marantz pm5005 afin de calmer
les twetter des focal. Et bien c'était pil poil ce qu'il fallait pour ça. Donc je confirme bien que c'est un dac qui
n'est pas brillant et qui n'est pas fatigant.
Mais en meme temps il y a beaucoup de justesse et de neutralité sur les autres plages de fréquence. Il est assez transparent je trouve car il n'amplifie aucune plage par rapport aux autres.
Tout fonctionne correctement, meme le DSD avec moode audio, du premier coup sans intervention de ma part.
La télécommande est meilleure que les anciens modele, il suffit de la pointer vers le dac et ça marche sans soucis
J'aime ce dac franchement.
Frederic G.
FERRUM HYPSOS Hybrid HiFi Power Supply 5V-30V Adjustable The Ferrum Hypsos is a high-end power supply, offering exceptional technology and performance to give your HiFi audio system an extremely clean power supply for optimal sound...
Cette alimentation est très bien construite et ne pose aucune difficulté à paramétrer mais il faut faire attention à ce que l’on fait. Il faut bien vérifier ses choix de tension et ne pas risquer d’inverser la polarité…Un large éventail d’appareils est déjà dans sa base de données. L’hypsos alimente mon Chord Mscaler de manière impeccable. Le son est plus neutre et plus musical qu’avec l’alimentation d’origine, plus posé, plus normal. Elle est « Meilleure » également que la Sbooster qu’elle remplace. La Farad super 3 que j’utilise sur un Emerson digital est très proche mais peut-être un poil moins neutre, moins « rapide ». Le gros avantage de cette alimentation est de ne plus avoir à la remplacer à chaque changement d’appareil! Je suis très satisfait de cet achat même si cela représente un certain investissement.
William G.
MUNDORF MCAP SUPREME EVO SILVERGOLD OIL Capacitor 1000V 1µF Since 2015, the MCap Supreme EVO SilverGold and MCap Supreme EVO SilverGold OIL capacitors have been the undisputed top-of-the-line products from Mundorf. It combines all of the...
Supreme capacitors
Used these to replace coupling capacitors in a Plinius M16 Preamp- simply stunning improvement - These provide detail balance / neutrality and depth with very realistic spatial imaging
Christian L.
ampli TDA7294
bien reçu, et installé, tout marche à merveille !! nickel !
R A S
Commandé dimanche, reçu mercredi. Et ben........................ rapport qualité/prix pour moi c'est parfait ! Ce câble est monté en liaison ampli, pré ampli marantz 140/ 3200 en remplacement des anciens : Analogue interconnect qui devaient avoir au moins 20 ans. Bien construit, la connexion se fait normalement, même dans les rca rapprochées. Je pense équipé toute mon install avec ce câble. Quand à l'écoute ? Difficile à dire, mais meilleur qu'avec les anciens .
Nikolaos R.
DAYTON AUDIO PC68-4 Full-range speaker 20W 4 Ohm 86dB 120Hz - 17kHz Ø6.3 cm A compact wideband loudspeaker with beautiful finishes. Ideal for building/repairing a small audio system.
The sound is clear, but it does not have any low frequencies due to its size. Good choice without much demands on its sound!
Nikolaos R.
Excellent quality. Extremely clear sound, but poor in low frequencies due to its size. Excellent choice!
Jose l.
XDUOO TA-22 Tube Headphone Amplifier 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA xDuoo unveils with its TA-22 a beautiful headphone amplifier and DAC combo with a neat design. This one embeds quality components in order to provide a sound restitution both...
très bon son
j'avais oubliés les 5 etoiles .
Jose l.
très bon son
je l'ai acheter pour sa sortie tubes , car mon ampli rotel manquait de matière dans les medium sur les voix , problème résolu avec ce préampli très bien fini . Et comme toujours depuis plusieurs années un très bon service de la part de toute l'équipe audiophonics. Compter toujours un rodage plus ou moins 100heures , attention quand un appareil ne fonctionne pas pendant quelques jours il faut refaire un petit rodage de quelques heures surtout en hiver.
M A.
IAN CANADA FIFOPIMA V1.5 Reclocker Master Clock Mode for Raspberry Pi The Ian Canada FifoPiMa is an audiophile I2S/DSD/DoP reclocker for the Raspberry Pi running in Master Clock mode. Its functionality is equivalent to that of a FifoPiQ3 combined...
top product from ian canada
nice addition to the sound, works great with a raspebrry pi.
highly recommended.
Stephane B.
KHADAS TONE2 PRO DAC Headphone Amp ES9038Q2M 768kHz DSD512 MQA Full Decoder Black Meet the famous digital to analog conversion circuit (DAC) based on 32 bit ESS ES9038Q2M chip with PCM support up to 768 kHz and native DSD512 and even MQA. New headphone...
Fantastique DAC
Petit, mais inspirant confiance, je ne l'ai jamais fait tomber, mais il ne semble pas craindre les chutes qui peuvent arriver dans le quotidien.
Il répond parfaitement à mes besoins de "nomadisme" sédentaire, c'est-à-dire de pouvoir le déplacer facilement entre plusieurs lieux d'écoute, en le raccordant à divers matériels tels qu’ordi et smartphone en USB et ampli en RCA Balance.
Aucun souci avec un casque à 300 Ohm.
En utilisation intensive, il chauffe un peu, rien d'alarmant. Même si c'est une évidence, il faut simplement le disposer à un endroit qui n'entrave pas la dissipation de la chaleur
. Le son est une affaire personnelle, il sonne plutôt large à mon oreille, sans aller trop loin, réaliste et plutôt neutre.
Stephane B.
Optical Fiber HDMI 2.0 Cable HDCP 2.2 4K HDR ARC 10m This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low...
Ce câble remplace avantageusement un ancien câble hdmi, certifié 1.4, qui ne permettait pas de faire passer correctement de la 4k, Dolby vision/HDR10+.
A présent c'est fluide et parfaitement reconnu par la TV, qui applique ces paramètres les plus poussés sans soucis, également dans le cas du Gaming à 60fps.
Ce câble HDMI 2.0 est 3 fois plus fin et souple que mon précédent câble 1.4
Commande passé un mercredi soir, livré le vendredi midi, dans un colis bien protégé.
Oliver S.
Just brilliant... :)
This amp replaced an Audiophonics MPA-S250NC which already was a steal for its price. The LPA-S400ET is better in every aspect, it´s even quieter, more resolving & liquid, greatly enhanced authority and control in the bass region. I bypassed the gain stage, the source is a DAC with 200 Ohm output resistance, driving the amps´ symmetrical inputs. Since I am using horn speakers, the too low output voltage of the DAC is no problem. BTW, volume control is done in the digital domain (MiniDSP), something I would have never expected to be a good sounding alternative, yet it is. All in all I am very happy, thanks a lot Audiophonics for this really great offering - these are wonderful and affordable times for open-minded listeners not only looking at brand names but end results... ;)
Christoffer H.
Just perfect!
It replaced a broken Schiit lyr 2 and I'm amazed how much better the Little Dot is.
Dominique V.
J'ai commandé 2 câbles pour un magnéto à bandes Akai des années 70, et à peine installés, que la différence , par rapport aux câbles traditionnels, se fait immédiatement, de part la qualité du son qu'il en sort et de la fabrication. Je les recommande sans hésiter.
De plus, commandés le Lundi reçus le lendemain, si ça c'est pas le top...
Merci Audiophonics.
Andrea T.
Bought to power the Sotm 200 streamer, it increases its performance in all fields...
Robust construction and excellent materials.
Recommended
Laurent M.
Doux
J'en ai essayé des câbles anglais, français.
Parfois très chers .
Celui ci n'a pas de verdeur dans l'aigu , pas de medium qui crie .
L'écoute est d'un naturel, d'un confort .
Superbe.
Martin A.
DD MFI09S Male USB-C to Male Lightning Cable Silver / OFC Copper 10cm The USB-C to Lightning DD MFi09S cable benefits from a perfectly mastered design, using very high quality components in order to offer excellent conductivity and...
Bad quality
I'm writing this, because this is the second DDHIFI item that quit working after some months of use. The lightning part will come loose from its socket, very disappointed of DDHIFI build quality, the sound was great though.
Martin A.
DD TC28I Male Lightning to Female USB-C Adapter OTG This TC28i Lightning male to USB-C female adapter will allow you to convert the Lighnting connection of an Apple device to standard USB-C. You will be able to use, for example,...
Bad quality
This product quit working after a couple of months, not recommended!
Sebastien S.
AUDIO BASTION SPIKE X PLUS Spike Stainless Steel M10 (Set x4) These Audio Bastion Spike X PLUS spikes effectively dampen the vibrations generated by your audio system. They are made of 304 stainless steel, both robust and durable....
Test à faire - conseil de montage
MONTAGE SUR ENCEINTE COLONNE DALI DE 37 KG avec pointes
Intérêt :
Remplacement des pointes d'origine en mauvaise état
Conseil d'installation :
J'ai déplacé une enceinte et une pointe s'est tordu légèrement.
Ce produit est à installer sans aucun léger déplacement !
Dommage qu'il n' y a aucune mise à garde à respecter.
La pointe n’est pas logé dans un trou et il y a un léger déplacement de celle-ci dans le galet de la contre pointe AUDIO BASTION X-PAD PLUS II
Suite au montage j’ai une image sonore précise et une importante stabilité des enceintes exclusivement avec des contrepointes perforées au centre.
Résultat moins stéréophonique pour des enceintes avec les AUDIO BASTION X-PAD PLUS II Contrepointes Aluminium Acier Inoxydable.
Elles seront placés sous une platine Vinyle, test à suivre
Simple et efficace, dommage juste qu'elle ne soit pas pré-étamée. Pour que ça "pompe" bien, ne pas hésiter à mettre le fer à 350°, et tremper la tresse dans du flux décapant. Pour les vieilles soudures, il vaut mieux les "recharger" avant avec de l'étain neuf. Et vous verrez, ça marche très bien !
THOMAS R.
LINDY CROMO LINE Digital Cable Coaxial SPDIF Copper Gold Plated 0.5m The Lindy Cromo Line SPDIF Coaxial cable benefits from a beautiful design quality. Its conductors are made of Copper for a very good conductivity and its connectors are plated...
Câble trop fin
Belle qualité de fabrication mais j'ai été très surpris par la finesse et surtout la souplesse "caoutchouc" du câble qui laisse imaginer qu'il n'y a pas beaucoup de métal dedans et donne une impression de fragilité. Il fonctionne bien et je ne doute pas de la qualité audio mais je m'attendais à autre chose sur un site spécialisé.
THOMAS R.
SMSL Remote control for amplifier FDA AD18 / Q5 Pro This infrared remote control is dedicated to the exclusive use of the main functions of the FDA SMSL AD18 amplifier and Q5 Pro. It is ideal as a replacement for the original...
Mieux que la télécommande d'origine
Fonctionne parfaitement avec l'ampli/DAC SMSL Q5 pro, en remplacement de la télécommande d'origine peu fiable.
Elle mesure 15 cm, et on y retrouve toutes les fonctions, y compris la sélection des modes Equalizer qui ne peut se faire que par télécommande (touche FN ici).
Alexandre p.
En utilisation désormais régulière sur un "linux". Alsamixer propose 4 niveaux PCM. Je me sers de pipewire pour exposer toutes les interfaces proposée par l'appareil. Je peux donc laisser le cran à 0 pour le gain. Fortement suggéré. Ensuite pour la granularité du volume on peut effectivement binder n'importe quel recepteur.
Concernant l'écoute et la perception musicale, je peux juste conclure que l'habituation psychoacoustique demande encore une période de rodage. Pour le moment le rendu semble en faveur d'un son extrêmement dynamique mais froid. Selon le positionnement dans la pièce d'écoute on s'aperçoit que la structure du son rentre en faveur de certaines gammes de monitors et pas d'autres.. En ce qui me concerne le son manque un peu de chaleur sur des monitors Adam (classe D), mais les outils de masterisation sous linux me permettent de corriger la pièce selon les positionnements. mid field / near field. Bravo à l'équipe pour la conception. (Je ne me suis pas servi de l'alimentation proposé en 5volt optionnelle)
Lionel B.
A recommander sur des systemes à bonne resolution
Produit tres efficace (comme tous ceux de la gamme Furutech). Attention cependant au placement. En premiere approche je l'avais plaqué sur la prise murale avec des effets difficiles a cerner.
Je l'ai ensuite installé à l'entrée du mon filtre secteur Gigawatt et là, superbe! Vient accentuer les effets du NCF Clear Line.
Lionel B.
Produit tres efficient a utiliser sur des systemes à forte resolution.
Affaisse le niveau de bruit. Les micros details de la musique sortent de l'ombre pour apporter de l'air, de l'ampleur, de la dynamique aux enregistrements.
La video y gagne bien sur aussi.
Akkrawat W.
Audio extractor HDMI / MHL to I2S
This brings my old stuff Pioneer bdp-150 to life
olivier P.
b&w cdm1 améliorer
Remplacement des condensateurs électrolytiques 5,3 µF 70V b&w dont un avec un gonflement de son enveloppe, et l'autre avec une fuite d’un liquide surement toxique.
Remplacement également des selfs à noyau ferrite pour des sels à air Jantzen .
C'est la première fois que je faisais un remplacement et par la même occasion une mise à niveau le changement est radicalement positif ! je me suis satisfait . de toute façon les condensateurs d'origine de 20 années étaient morts. je pense qu'avec des condensateurs électrolytiques bipolaires j'aurai également eu une amélioration de cette ampleur ça je n'ai pas la réponse .
A voir si dans quelques mois je serais pas tenté par des condensateurs supérieurs afin de juger sur le rôle de la qualité d'écoute.
En résumé génial
véritable +
Je valide ce qui est dit dans le descriptif du produit
Nikolaos R.
Very reliable for its price. The sound is clear and I was impressed with the channel separation. Of course, no comparison should be made with expensive amplifiers.
Nikolaos R.
Excellent quality.
Nikolaos R.
Excellent quality.
Nikolaos R.
Nikolaos R.
Excellent quality.
Nikolaos R.
AMP case
Excellent quality. It's small but the end result, if you choose things that fit inside, is incredible!
Michał W.
Very good opamp
I have changed my original dual OPA2604 to OPA 627 in my DAC and I am quite impressed. Sound improved significantly. Scene has more depth, bass is stronger, and overall sound is richer
Jean-François A.
Gaine thermo en assortiment
Excellente Gaines Thermo Rétractables, en assortiment de multiples tailles, très utiles. Recommandé
Jean-François A.
Filtrage enceinte
Condensateur Mundorf Mcap 630V 0,10 uf placé en lieu et place d'un Chimique NP sur la section aigu d'une enceinte JVC de 1990.Excellent résultat avec clarté et punch retrouvé ! Recommandé
Il remplace un lecteur RaspDIGI Digipi+ V2 qui n'est d'ailleurs plus dispo chez Audiophoncs, la différence est audible, finesse et détail sans pour autant provoquer de fatigue auditive. Le faible Jitter est sans doute le facteur déterminant. De fait, après comparaison, j'ai abandonné (définitivement ?) l'amplification classe D à précision chirurgicale pour revenir à du plus classique (Classe A/B de bonne facture et DAC à puces AKM) sans perdre de détail et avec la scène sonore de l'enregistrement . Ce n'est que du plaisir, mes fichiers numériques sont tous une redécouverte. Audiophonics propose toujours d'excellents produits qui ne sont pas nécessairement couteux. Ce n'est pas parce qu'il faut suivre la "révolution numérique" qu'il faut partir dans du matériel à 4 000 € et plus, proposés par certains vendeurs...
Christian R.
Excellente à tous points de vue
Excellente dès qu'elle est reliée à mon Node 2i,, utilisé comme transport, elle révèle toutes ses qualités après une bonne période de rodage (chez moi 30 heures) : douceur, précision, silence. Je pourrais regretter les câbles de liaison solidaires de l'appareil, mais tant pis, je me suis consolé avec un câble secteur de marque. Cette alimentation vaut largement son prix. Encore merci à Audiophonics qui me l'a conseillée !
Mike F.
Un casque compétent !
Les + : Un son clair et détaillé, confortable, un bon rendement et facile à alimenter.
Les - : Qualité du similicuir des coussinets.
Le son de ce casque se rapproche de la neutralité des casques de studio, mais avec un plus de chaleur dans le bas du spectre, et des aigus moins agressifs.
Appairé avec un Fiio BTR3, je modifie l’équaliseur pour lui apporter un peu plus de kick dans le bas du spectre, les basses sont alors tendues et rapides, un régal !
Dans les films, cette configuration apporte un plus dans les explosions qui deviennent plus percutantes.
En mode bureau, je le l’utilise avec un le zen dac (ifi) et la sortie symétrique 4.4 pentaconn.
Ici la scène sonore s’ouvre un peu plus. De temps en temps j’active l’option truebass du dac qui enrichi les basses sans excès.
J’habite en région tropicale et le similicuir des coussinets a commencé à se désagréger au bout d’un an est demi, je les ai changé par une paire de (très bon) coussinets trouvé chez DEKONI audio
Derrick S.
Excellent amp for the price
You get what you pay for. They are succeeding my old mono's from '97 and do all things for music better! I like the tiny case. All feels solid and is playing for week now and no issues and the sound is great! My fear was that things could get lean but non of that. Highly recommended!
Très bonne qualité, supporte même les soudures, le plastique ne fond pas facilement, et les contacts sont de très bonne facture.
Excellent produit !
La qualité est au rendez-vous, très pratique pour souder les minuscules composants !
Excellent produit !
La qualité est au rendez-vous, très pratique pour souder les minusvules composants !
Qualité très correcte, et pratique !
Eric R.
DAYTON AUDIO MA1260 12 Channels Multizones Amplifier 89W 4 Ohm The Dayton Audio MA1260 12 channel amplifier has been designed to provide a custom multi-room sound distribution. Its intelligent and versatile architecture easily integrates...
J'alimente 10 hauts parleurs de 20cm encastrés dans le plafond, démarrage et extinction automatique très pratique, une seule entrée alimente tous les canaux avec un super son.
