franck c.
Petit mais ..... puissant
Proportionnellement aussi puissant et musical que sa taille ne le laisserait penser . Raccordé(s) a mes enceintes Martin gamma...
fabio M.
_ELFIDELITY...
franck c.
Excellent petit préampli
3 entrées qui me suffisent largement , mon lecteur CD ma platine vinyle et Fip radio via mon ordi . utilisation d'une...
Customers reviews - There are 19713 reviews.
Stefan D.
XDUOO LINK2 BAL Portable Balanced USB DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a carefully balanced architecture and...
Outstanding! Neutrality and musicality, excellent physical controls
The controls work under Windows 7, the pause button can pause Youtube in Google Chrome. The analog-like audio quality, excellent price that rivals 2x more expensive products...Works under Android 8 with HTC 10. Very unique timbre, tested with Sennheiser HD599 and Focal Listen Pro. The detail does not hit you in your face, unlike ESS DAC. It gave slightly better performance than Arcam rPac (which had an expensive OFC USB cable). Yet, plenty of neutral detail even under Youtube (shocking, I know). Bass is soft and dense (in a good way, controlled, with impact). Best of all, the listen is not tiring. Normally, this level of detail is fatiguing, especially with TI or ESS DAC products. I know of this little gem because of this expert review, see the LINK below (pun intended). There are 2x more expensive dongles that are not better. Audiophonics has unbelievable customer support via e-mail, even late at night, and great price, better than the official Aliexpress shop of Xduoo`s:
https://andyaudiovault.com/xduoo-link2-bal/
Olivier M.
MINIDSP FLEX Audio Processor DSP Balanced SHARC ADSP21489 XMOS Bluetooth The miniDSP Flex is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor used previously with a redesigned input/output...
Un peu compliqué mais bluffant avec DiracLive
Une méthode d'activation de licence DiracLive (à acheter séparément) du siècle dernier. Quelques bugs dans le logiciel DiracLive au moment de la calibration (MacOS, d'où les 4 étoiles uniquement) mais le résultat est vraiment bluffant ! Le son des instrument est plus net, plus précis. Quand on désactive la correction, c'est mou, c'est flasque, ça dégouline. Je recommande vraiment. Et merci à l'équipe Audiophonics pour son support.
john p.
Ultimate cables for me ?
I am running two pairs per channel to my Klipschorns (just to be on the safe side - one is fine too) . This is the best cable I ever tested no matter the price. Looking at the price It was difficult for me to believe the difference it made. I really regret not giving solid core cables a chance earlier on. The only caveat is the gauge of the cable- experimenting with the gauge is critical and that was the mistake I had previously done during tests on solid core cables . These combined 20awg cables are ridiculously good. The bass extension, control and the crystal clear mid-highs imho are usually achieved by major gear upgrades not a few meters of wire!!! and you Know horns don't lie !!!
Philippe S.
MONOLITH M-15 V2 Active Subwoofer THX 1000W Black The THX® certified Monolith M-15 V2 subwoofer delivers deep bass with low distortion. Dropping below 16Hz, the Monolith M-15 V2 unleashes significant volume with the ability...
La bonne affaire !
C'est mon cinquième caisson grave, je peux dire que pour le prix, je n'ai pas été déçu. Puissant, clair avec des graves propres, je n'ai pas regretté le fait qu'il n'y ait pas de correction électronique. Le rapport qualité prix est passé de très bon à bon depuis la hausse du prix.
Philippe S.
La bonne affaire !
Je suis un habitué des câbles hi-fi de qualité, j'ai été heureux de voir que ce rj45 rivalise avec des câbles 3x plus cher. Je recommande.
Philippe S.
Bon rapport qualité prix, il alimente une voie centrale Paradigm founder c90 avec brio, les voix sont claires et charpentés, tous les détails sont là. Évidemment il y a mieux mais bien plus cher. Je recommande.
Philippe S.
La bonne affaire !
Après plusieurs tests, je le trouve aussi bon que mon audioquest carbon à 179 €. Le rapport qualité prix est donc excellent.
Michel V.
KT120 Tung Sol
Bonjour à toutes et à tous.
Ayant débuté en 1967, il y a 55 ans, j'ai construit notamment il y a quelques années un canal basses pour multi-amplification autour des tubes KT90 EH. Le remplacement par des KT120 n'apporte pas une augmentation de puissance, mais procure des basses mieux tenueset dynamiques qu'avec des KT90 EH voire des 6550 Sylvania ou Tung-Sol NOS ni des KT88 GEC. Ce tube est un excellent choix dans les basses grace à une plaque bien dimensionnée et surtout une cathode mieux chauffée que celles des KT90, KT150 ou KT170, lesquelles travaillent à plus basse température de cathode.
Par contre leur rendu en large bande laisse à désirer par rapport aux tubes NOS et même aux KT150.
VAGNER Michel, Moselle.
Johan S.
Provides full galvanic isolation.
This unit provides true galvanic isolation between usb input and the spdif output. It therefore prevents ground loops between PC and DAC (for instance) and that by itself gives a big inprovement in signal to noise ratio. Should be pointed out in the description.
Teddy T.
L'avis d'un cabloseptique
Alors oui ça change, le cable apporte un reel gain, chez moi ça ce ressent surtout sur le haut médium, l'accuphase sort encore plus de potentiel, ça change pas l'ampli non plus ça reste un cable, mais il vaut clairement ces 50 €.
Charles-Antoine L.
TOPPING L30
Livraison rapide en 3 jours. En ce qui concerne le L30 pour ma part je l’associe à un Hifiman Sundara. Casque un peu gourmand pour ce petit ampli il faut donc monter le gain à +9db. Une fois cela fait l’association est fabuleuse avec de belles bases et du détail pour un prix plus que raisonnable.
Thomas K.
Great tube amp for a very reasonable price with minor quirks
Ordered this thing from Germany, it arrived well packaged and without any issues. I will order from Audiophonics again if I ever need something. The prices are more than competetive and the service was nice and answered all my questions about the product.
The amp itself performs very nicely, but keep in mind that some USB ports could carry over some interference issues to your DAC and then to the AMP. Via USB I had some weird electrical buzzing, an optical cable fixed all those issues, so keep that in mind. This is not really an issue of this amp but more an issue that could happen with any computer and an AMP that is sensitive to picking these things up (this includes stuff from your phone too).
About the amp itself. Music sounds fuller with it, I am pairing it with the 650's from Sennheiser and it's pleasant. The transformer of the TA-26 can hum a little, mine does it but it's not noticeable when listening to music, but that's to be expected with a transformer like this (might be fixable so it's completely silent). The tubes are completely silent when not listening to anything, no humming, buzzing or microphonics in my case, so that's very nice.
Vijay Kishan R.
Best price performance ratio
I bought this 6 months ago for my Canton Refence speakers and it has performed beyond expectations. I have A/B ed them against amps 5X the price and this one still holds its own in terms of delivery. others may look flashy with all dancing lights (I'll buy my christmas lights seperately - thank you), but this one delivers. Combined with a decent DAC (like the Topping D90SE or even an SMSL SU-9N) the set up absolutely shines. I just bought another LPA-S500NC one for the centre speaker (another Canton Reference). My application is purely music - stereo, and now multichannel (routed through Okto DAC 8 Pro). Would be a tad much for Movies, but hey, these bad-boys have an RCA switch - now they are connected to my BD-player as well ;-)
Quality and excution is superb (review on Audiosciencereview ) and communication with Audiophonics was crip and clear (in English). No snake oil, no BS - pure delivery.
Audiophonics team - keep up the good work - colour me impressed.
Jean Michel P.
Excellente schuko
Très bonne fabrication et serre câble efficace. A l ecoute spectre large et beaucoup d ouverture. Curieusement s avere nettement meilleure que la Bals73 qui équipe le cable Olflex CY 110
Michel l.
exceptionnel
produit d'une excellente qualité d'écoute très aéré et d'une justesse incroyable merci a audiophonics
Stephane N.
SABAJ D5 DAC ES9038Pro Headphone Amplifier Balanced XMOS Altera 32bit 768kHz DSD512 The Sabaj D5 is a solution that acts as both a DAC and a headphone amplifier. It ensures excellent performance, thanks to a careful architecture and components selected for...
Très bon Dac qui pilote une paire d'ampli mono NCORE en mode symétrique.
Beaucoup de détail, très droit, voix superbes.
Je recommande.
Etien K.
GUSTARD LINE-02 Cable HDMI 2.0 I2S OFC Copper Gold Plated 1.5m This HDMI 2.0 Gustard Line-02 cable allows to make I2S connections via HDMI on devices with this connectic. It benefits from a nice design, with OFC copper conductors and pure...
Un bon câble
J'ai deux câbles HDMI différents qui me servaient pour l'informatique et j'obtenais un son assez semblable avec les deux en connectant mon PI2AES à l'entrée I2S de mon DAC R2R, the Musicien Pegasus.
Avec ce câble de Gustard, j'obtiens un son un peu plus clair dans mon système.
Le câble, lui-même, est de très belle facture.
patrick a.
Utilisé sur des bibli un poil montantes tout est devenu meilleur : aigu agréable et basses plus présentes, merci aux précédents commentaires qui m'ont aiguillé. Sur un deuxième système plus pointu face à des Qed révélation un léger manque de subtilité et d'élégance mais très honorable pour le rqp. Câble pas universel s'il en existe ! Mais ramène le sourire dans un système au son montant et basses réservées.
patrick a.
Utilisé en modulation rapport qualité prix exceptionnel , n'est que très très peu distancé par un QED signature 9 fois plus cher.
Jerome V.
TOPPING A90 DISCRETE Discrete Balanced Headphone Amplifier Preamplifier Black Topping returns with the A90 Discrete, an improvement of the previous A90, this time equipped with discrete components. Both a headphone amplifier and a preamplifier, it...
Compte rendu d'utilisation après quatre jours d'utilisation quotidienne.
Le titre résume mon impression auditive.
C'est excellent.
Les basses sont présentes et ne sont pas TROP présentes.
Les voix et les aigus sont aussi bien détaillés mais ne sont pas TROP détaillés (utlisation couplée avec DAC Audio-GD, des Denon POA 6600 et JMR offrande supreme V2)
Le gros avantage du Topping A90 par rapport au PRE 90 est, d'après moi, la possibilité de l'écoute au casque. Mes références à ce propos étant proche du néant, je ne me permettrai pas de définir si c'est mieux ou moins bien mais dans tous les cas, ce que j'ai pu entendre et "au regard" de la joie de mes oreilles, encore une fois, c'est excellent.
Deux petits bémols néanmoins.
L'absence d'un réglage possible des basses et aigus comme, malheureusement, dans de plus en plus de préamplificateurs.
Une télécommande dont la progressivité est surprenante. Cette dernière a tendance à faire augmenter ou diminuer le son par "saut" très important si vous avez le doigt lourd sur elle. Méfiance dans les premiers temps.
Enfin, en bref et en résumé, c'est super bon, nonobstant le prix, que d'aucuns trouveront élevé et d'autres, "pas assez cher mon fils".
Bluffant
Monté sur une barrette Furutech alimentant un système déjà bien soigné en câbles secteurs, le gap est immédiat. Le son est plus propre, plus précis, plus transparent, plus truc, plus machin, bref plus tout. Son prix n'est pas si élevé comparé au gain apporté ou à un bon câble secteur. Très conseillé ++
Philippe A.
bon matos
multiprise de qualité, seul le montage du câble est vraiment peu pratique mais avec un peu de patience, c'est réalisable. sinon la possibilité de pouvoir la visser sur un support bois est un plus. pour le son à voir avec l'usage.
Jerker M.
Well built and plenty of power.
Very well built, sounds great, generates little heat and uses little power, very happy.
My one wish is that I would like the input above the speaker terminals.
Philippe K.
2 cables de 4mm2 connectés en parallèle.m
Je suis très content de mon achat :
J’ai commandé 28 m de cable 4mm2 que j’ai coupé en 4 longueurs égales. Ensuite j’ai connecté chaque longueur de 2x 7 m en parallèle maintenue par une gaine thermo transparente tous les 30 cm. Les cables on été terminés par des fiches bananes en cuivre argentée soudure argent et gaine thermo pour la finition.
Par rapport à mes Supra Classic 4mm2 sur enceintes Dynaudio excite X38, je gagne en précision de l’image stéréo lorsque j’écoute dans le triangle stéréo . J’ai aussi plus de détails. Au final 200€ dépensés ce qui est une somme… mais pour un résultat excellent.
Je ne suis pas sûr q’un câble plus cher sois nécessaire dans ma configuration.
Je recommande !
Robert C.
Very good upgrade
I'm very pleased with the cable. It is OFC but very good one. Definitely worthy upgrade to any low cost cable from computer or audio/video store.
Cable is neutral and natural in presentation.
william l.
Livraison au top, alimentation qui fonctionne parfaitement !
George R.
TOPPING NX7 Portable Headphone NFCA Amplifier Balanced Black The Topping NX7 is a compact and powerful portable amplifier, offering a beautiful precision and richness of sound. It is equipped with a new NFCA amplifier circuit specifically...
Excellent - will beat many desktop amplifiers
Very impressed with this portable headphone amplifier which will easily beat many desktop amplifiers for sound quality & power. It easily drives my HiFiMan Sundara planar magnetics & Sennheiser HD600s. The sound quality is fractionally behind my Topping A90 desktop amplifier which is amazing given that it is portable. The battery life claims are totally realistic - I measured 20-hours listening at reasonable levels using my HD600s on medium-gain and just under 10-hours using my Sundaras on high-gain. If only it had an on-bord DAC, it would be a no-brainer. However, even using an Apple Lightning to 3.5mm cable and streaming Tidal from my iPhone, the sound is neutral (not boring), detailed, powerful and enjoyable. I consider this to be a bargain and is highly recommended. If you need the on-board DAC, the Chord Mojo remains the one to beat - until Topping launch their own (NX7+on-board DAC).
Bouexiere c.
BLUESOUND NODE 3 (2021) Multiroom Streamer WiFi Bluetooth 5.0 24bit 192kHz MQA Black The BlueSound Node 3 opens up the world of remote control, network playback, streaming and multi-room. Easily integrated into an existing HiFi system, it will allow you to...
Node 2021
Pas d’amélioration sonore à mes oreilles par rapport au combo audiopro link 1 + DAC project head box digital. Donc renvoyé. Sinon appareil semblant solide, bonnes finitions, appli intuitive
Luc B.
Round Vumeter Yellow Backlight dB Ø45mm (Pair) This round vumeter has a beautiful yellow backlight, ideal for use with an amplifier from 3W to 50W. A controller is already present at the rear, allowing simple wiring.
Vumètre parfait
Bon fonctionnement bien rétroéclairé
Erik J.
Amazing dac, highly recommend
A different kind of presentation compared to smsl m400 or topping, Sabaj a20d.
With tube amp it sounds awesome the other chips like sabre or akm haven't been this good in my system.
Hope they will develop an even better 2 chip design I will buy it emidtaly.
Harry P.
What a Journey
Having had the Asus Essence One DAC for a long time I thought its getting time to try something new.
First I tried Topping´s E50 and yes there was a wow-factor, in comparison the resolution and overall presentation was much better. Later on, I got to hear SMSL M500mk2 and the D300. As E50 and M500mk2 (both ESS Sabre) had been a clear stepup to the Essence One and everything sounded a bit clearer and more open the D300 did something very special, the instruments and voices sound so natural in comparison that its a real joy to listen to music.
What I noticed after using D300 for around a month now is that I listen to music longer or that I listen through whole albums again.
Good job SMSL/Rohm.
Claudio c.
SHANLING M3X Digital Audio Player DAP 2x ES9219C Bluetooth MQA 32bit 384kHz DSD256 The Shanling M3X is a high quality portable music player with a well thought-out and optimized design. It is based on a powerful Qualcomm Snapdragon 430 processor, an Open...
Tres bon lecteur
Coupler à un campfire audio dorado 2020, juste un commentaire, excellent. Pour ce prix rien à redire.
Claudio c.
KBEAR Headphone Cable Jack 4.4mm to CIEM 0.78mm Balanced Silver Plated OFC Copper 1.2m This cable allows the connection of a balanced headphone. With a length of 1.2m, it is composed of two 0.78mm CIEM connectors and a 4.4mm jack connector. Taking advantage of a...
excellent produit et bon prix
Très bon câble à un très bon prix.
Ioannis P.
Well built
Used to power a Melco server. Solid performance.
hubert b.
efficace, mais un rien agressif
J'ai acheté cet ampli pour remplacer un vieux machin hifi que j'avais acheté en brocante et qui m'a laché.
J'écoute souvent de la musique, je ne pense pas pouvoir me qualifier d'"audiophile", mais je suis mélomane, musicien, et j'écoute tres souvent de la musique, avec un esprit critique tout de même. au niveau du matériel, je n'ai simplement pas encore investi dans des articles de luxe.
J'écoute donc ma musique sur des anceintes colonne de bonne facture (un hasard des brocantes aussi), mais j'ai jusqu'à présent été frustré de la dynamique, particulièrement dans le registre grave, en les testant avec les 3 différents ampli -hifi que j'avais à la maison (genre 300€ neuf, amplis de grandes marques habituelles). Avec le FX50, aucun doute, ça envoie, il va fort, et même à volume contenu on sent les coups de grosse caisse, c'est tout ce qui me manquait ! Si j'ai bien compris la classe D donne ces résultats en général. Sans pour autant devenir oppressant, c'est assez aéré, et j'ai entendu plus de détails qu'avec mes autres amplis. Donc c'est plutot bien.
Par contre c'est agressif aussi sur le reste du spectre. avec la musique que j'écoute ( un peu de tout mais particulièrement du rock et du métal progressif), ça devient vite fatiguant. Je n'ai pas eu cette impression sur d'autres enceintes bibliotheque, certainement de moins bonne qualité, avec lesquelles le rendu est très sympa.
Je vais très probablement garder le FX50 pour amplifier les graves de mes colonnes, et utiliser un autre ampli plus "doux" pour les médiums et aigues (les colonnes sont bi-amplifiables). J'ai commandé le MOS 120 d'audiophonics. En classe A/B cette fois-ci, et qui reçoit de bonnes critiques... On verra, et je vais essayer de donner un retours après...
En gros, pour le FX50 : Super, pas cher, puissant, détaillé, dynamique, mais pas pour une écoute trop fine (je ne sais pas comment le dire, mais à mon avis avec des baffles de la même game de prix le résultat doit être vraiment bon)
Très recommandable
Sa fonction ampli pour casques électrostatiques a motivé mon achat.
Un ami m'avait conseillé ce M-03.
Je vais commencer par les défauts: la sortie casque classique sur jack 3,5 est à oublier. Souffle important, mauvaise progressivité du volume, rendu audio décevant.
La prise entrée ligne en façade n'est pas placée idéalement j'aurais préféré en face arrière. L'esthétique générale n'est pas incroyable, si l'on regarde l'ampli portable Stax.
Mais si l'on n'a pas le plumage avec le M-03, sur la sortie électrostatique on a bien le ramage! et avec une autonomie importante.
Donc sur e-stat aucun souffle, puissance très confortable. Un DAP utilisé en sortie ligne attaque avec un bon niveau l'entrée du Kingsound, aucune saturation audible. J'utilise un Stax L300, et un autre casque électrostatique DIY qui a moins de rendement, le M-03 les pilote parfaitement. Le rendu audio est excellent, comparé à mon ensemble sédentaire. Sur le L300 j'utilise la sortie variable du DAP pour avoir plus de progressivité sur le volume du Kingsound, et en début de course déséquilibre entre les canaux.
Olivier b.
1MII LAVAUDIO B03PRO Receiver Transmitter Bluetooth 5.0 aptX HD CSR8675 ADC DAC ES9018 The 1Mii B03Pro is an extremely versatile and high-performance Bluetooth transmitter and receiver at an affordable price. Its intelligent and careful design allows it to ensure...
Efficace et simple
Récepteur efficace et très facile à installer. Je l’utilise uniquement en récepteur Bluetooth, en entrée d’un DAC Benchmark. Le résultat est excellent, aucun souci de connection, très bon rapport qualité prix pour ce récepteur qui passe inaperçu grâce à son petit format.
Carlos M.
petite boite... grand son!!
J'ai du un peu attendre suite à la rupture de stock du PI4... Une fois le colis arrivé le montage est simple et sans difficulté la notice étant claire. Par contre c'est côté soft que j'ai eu des problèmes. Après de multiples essais infructueux je ne suis jamais arrivé à avoir la moindre image sur l'écran. Que ce soit Volumio ou Moode. Contacté le SAV m'a envoyé rapidement un lien pour télécharger une autre version de Volumio. Cette fois tout fonctionne! mais ce n'est pas fini... Impossible de monter mon lecteur NAS (SYNOLOGY DS416) dans la configuration Volumio. L'UPnP fonctionne mais je n'ai pas l'accès direct au NAS pour gérer l'audiothèque. Aucun des modes opératoires de Volumio ne fonctionnait. Alors si comme moi vous êtes bloqué , voici le lien vers le forum Volumio et la solution:
https://community.volumio.org/t/unable-to-mount-the-nas/52054
Après ces épreuves le résultat est là un très beau son, bonne assises des basses, aéré avec bon placement des instruments, dynamique et équilibré. Par rapport à ma chaine peut être un peu moins de rondeur dans les médiums...encore un peu sec, mais après quelques heures ce point s'est déjà amélioré. Assez bluffant au final par rapport à la dimension de l'engin. POur info ma config hifi Cyrus + enceintes Dynaudio. Avec le Raspdac j'ai pris une alimentation faible bruit 5v iPowerX . Cela doit avoir un impact mais je n'ai pas comparé sans elle.
Merci au SAV Audiophonics pour leur aide (rapide!) et bonne écoute à tous!!
marco g.
Game changer
Wow!
Bought this DSP board just for fun...and...it's really a game changer for any DIY project!
I'm using it swapping an Audiocontrol 6XS electronic crossover and driving one of my old DIY speakers (SBAcoustic SB17NRX-C35 + ScanSpeak D2010).
Results are astonishing, not only for the price...
It's really like to play a game setting up serious things like:
All levels +
24dB Linkwitz-Riley Filters +
Baffle Step loss compensation (curve choice via potentiometer) +
Notch Filters +
Time Delay...
Sigma Studio works perfectly and is quite intuitive (from my personal point of view).
Well, for this price it's an incredible product giving Hi-Fi sound quality and...unique DIY freedom!
I hope that in future we can buy also an evolution of this concept with more powerful DSP, direct SPDIF input (+output), different DACs, 2x6...etc.
Great purchase, thanks!
Marco
David S.
MUSICIAN DRACO Balanced R2R DAC NOS I2S The Musician Draco is a fully balanced, high end R2R DAC with high quality components. Versatile thanks to its complete connectivity, it can also work in NOS (Non Over Sampling)...
Approuvé
Préférant le son vinyle, la technologie R2R me réconcilie enfin avec la musique numérique.
Sortie branchée en RCA sur mon ampli hybride, le son est précis, très équilibré, naturel et rempli l’espace de la pièce, contrairement à mon dac ESS Sabre précédent.
Je n’ai pas vraiment compris la différence avec le grand frère Pegasus, j’avais lu sur un comparatif anglophone qu’il est très difficile d’entendre les différences. Peut-être au niveau du DSD, Musician restant visiblement flou sur les spécifications DSD du Draco.
Je l’utilise principalement avec un transport CD Audio Note révisé par mes soins ou un Macbook avec Qobuz .
(Attention pas de télécommande, c’est un dac et rien d’autre!)
En tous cas, à ce prix, il est impossible de se tromper en vu de la qualité de fabrication et du son.
Merci Audiophonics !
Freddy D.
U-Sabre
Reconnu avec difficultés après bien des bidouillages par Windows10 , impossibilité de profiter des meilleures résolution sur Quobuz , reste sur 48K , un peu déçu par le produit ...
Aucun driver n'est nécessaire pour ce produit.
Ce type de problèmes n'existent qu'avec un câble USB trop long et / ou de mauvaise qualité.
Pour une lecture bitperfect il convient de régler le lecteur :
https://www.qobuz.com/fr-fr/info/qobuz-vous/les-modes-de-lecture-du-desktop179381
dans le cas contraire c'est le mélangeur de Windows qui détermine la résolution maximum.
JEAN-MICHEL E.
Exceptionnel
Ce DAC est une merveille ! Combiné à mon Meze 99 Classics Noyer Gold équipé d'un câble symétrique, j'obtiens une restitution sonore de mes fichiers Qobuz on ne peut meilleure. C'est la perfection absolue. Mais je voudrais surtout souligner l'accompagnement technique que m'a fourni Audiophonics pour m'aider dans mon choix (Salut David). Je n'ai jamais rencontré un service technique aussi avisé, consciencieux, patient, réactif et compétant ailleurs. De plus, sitôt commandé, aussitôt expédié. Livré en Belgique en un temps record. À défaut de pouvoir mettre mille étoiles, j'adresse mille mercis à Audiophonics.
Philippe f.
Une valeur sûre
Testé cette semaine sur mon système, ce câble est très musicale.Je recommande.
Jean-Claude G.
CONNEX SMPS300REh Power supply Module 300W +/-30V SMPS300RAh is a switching power module for audio amplifiers requiring high power for extended periods
Super SAV
Je rajoute une étoile à mon avis précédent !
Moins d'1 heure après la rédaction de mon avis où je signalais l'absence de fusible, j'ai reçu un mail du SAV me proposant l'envoi d'un fusible adéquoit.
SUper réactivité. Par ailleurs, les performances de l'alim sont très bonne. Le rapport qualité/prix est excellent
Martin M.
Bluetooth 5.0 Receiver Board QCC5125 LDAC aptX HD aptX Adaptive to I2S This Bluetooth 5.0 receiver module is equipped with the new Qualcomm QCC5125 chip, which supports the high-quality transmission codecs LDAC and aptX HD, as well as aptX...
USB Communication
Search for SJR-BTM525, this is the name of the blue module and find module pinout
To enable USB communication you need to solder "USB_DP" and "USB_DM" to your preferred connector and you must solder/connect "VCHG" to your power voltage, without this the USB is disabled.
I connected "VCHG" to +5V currently working but not sure, maybe you should use +3.3V
PLEASE REFER TO CHIP DATASHEET (not module) TO AVOID ANY DAMAGE!!!
No-one takes responsibility for how you modded this module ;)
Leceur de qualité audiophile
Topping, j'adore et suis leurs produits depuis les débuts.
Look élégant, sobre et efficace.
Ecran certes petit mais pas déplaisant.
Je l'utilise en mode lecteur de fichiers sur clef usb par usb otg ou la microsd.
Il est gapless, mode à activer dans un menu. Il lit un album de façon continue. Lit mes flac avec superbe. Aucun plop.
Sortie puissante sans volume, à raccorder à un dac ou ampli fda ou ayant une entrée coaxial ou optique. Rapport signal/bruit élevé.
Autonome, discret, ne chauffe pas, alimentée par un jack usb vers 54v celà permet d'utiliser un chargeur usb ou une alim de son choix.
Facilement pilotable en bluetooth avec hibylink, c'est stable.
le wif ou mode dlna ne permet pas au lecteur de piloter directement vos fichiers du nas, il faut passer par un smarphone android sur le même réseau et monkey ou autre app dlna. C'est un peu dommage que la pub puisse faire croire autre chose. Courage pour entrer le passe wifi, tout le monde n'y arrivera pas.
On peut lui envoyer des fichiers par bluetooth, il peut envoyer la lecture vers tout dispositif bluetooth, casque, enceintes. Le choix du recepteur bluetooth est rapide par le menu.
Pas exploré le mode dac usb ni airplay.
Un très bon produit à prix contenu par rapport à la concurrence.
PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 3m If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its...
RQP exelent
Essais fait entre se cable occ pl a 6% Ag pangy et le vialube ofc etamé argent et telegardner metal. Apres ecoute de trois semaine donc bien rodé ils en ressort qq difference. Pangy sais plus naturel et les instruments voix sont plus realiste. Il y a un peit plus du cpté analogique du son, par contre le grave descend un chouilla moins que sur le vialube et est moins aeré et aerien. Je vais essayer de monter des telegardner cat 7 sur les pangy car je pense que les prise du pangy sont bc moins performante dansble blindage se qui pourais etre la seul raison du grave et aeré. Bref en abaissant le bruit. Cela devrais supplenté ée vialube dans ses deux paramettre. Reste que sais une question de goût musical. Question prix ils sont tous les deux exelent. Chaque fr le vaut. J aime bien le vialube entre le modem et le filtre bonn n8. La co entre le bonn et mon streamer se fait avec un neotech neu up occ cuivre. La sais plus cher mais ont touche le ciel. Apres essai via etbpang. Il y a pas photo. Le neo depasse les deux en terme musicalité transparence naturel dynamique et aucun bruit. Extinction de note et un aigus d une douceur devtoute beauté. Le choix se faitbuniquement via le porte monnaie, quoi que pour un suppl de prix acceptable. Je pose pas la question
Changed mind!
I've had the powerstation for 6 months now and have gone back to running power through just a DC blocker. Ultimately, the sound is very refined with the powerstation, but at the expense of dynamics and agility
Jean-Claude G.
Bien mais serait encore meilleure avec un fusible !!
L'alimentation en elle même semble fonctionner parfaitement (je viens seulement de la recevoir) mais ce serait encore mieux si elle arrivait fonctionnelle, ce qui n'est pas le cas car il manquait le fusible secteur que l'on voit pourtant bien sur les photos... Ce serait encore mieux si la valeur du fusible était indiquée sur le PCB ou la description !
Heureusement j'avais de quoi me dépanner, j'ais mis un 3,5AT que j'avais sous la main mais je pense qu'un 2AT serait plus adéquoit. Cependant ce n'est pas très critique pour moi car j'ai des fusibles en amont.
Sinon parfait pour l'expédition : commandé dimanche reçu mardi avec GLS
C'est anormal, contactez mes collaborateurs du SAV qui feront le nécessaire pour vous fournir la pièce manquante au plus vite.
Yi Z.
ROSE HIFI RS250 Lecteur Réseau Audio DAC ES9038Q2M 32bit 768kHz A true audiophile network player, the Rose Audio RS250 combines versatility with high performance, thanks to its high-end DAC and optimized power supply stage. A jewel of design...
Lecteur superbe
C'est un très bon lecteur réseau, son adorable, un joli écran. Une sortie hdmi nous permet de regarder des vidéos sur YouTube sans pub. J'ai mis 4 étoiles parce qu'il a un OS pas vraiment stable, on rencontre souvent des petits bugs, parfois faut le redémarrer. Et il a toujours pas tidal connect c'est nul quoi..... -.-
