Banana Plugs Gold Plated Ø4mm (Pair)
These banana plugs are gold-plated for optimal resistance to corrosion and erosion. They also feature an extremely convenient mounting system that requires no tools. Simply insert a stripped cable and press the lever to lock it in place. This innovative mounting system can accommodate cables with a maximum diameter of 4 mm.
Reference : 21116
3,50 €tax incl.
2,92 € tax excl.
Shipping date: 24-11-2026.
Banana Plugs : Front view
These Speakersnap -type banana plugs are gold-plated for optimal resistance to corrosion and erosion. They also feature an extremely convenient mounting system that requires no tools. Simply insert a stripped cable and press the lever to lock it in place. This innovative mounting system can accommodate cables with a maximum diameter of 4mm.
Product typeBanana plugs
Contact materialCopper alloy
Contact platingGold
Body materialPA6 nylon plastic
Mounting typeBy pressing a lever
Max cable diameterØ4mm
Dimensions22 x 14.5 x 8mm
PackageSold by pair
Max cable diameter (mm)4.0
Mounting typeWith lever
ConnecticMale
ConnectorBanana
These banana plugs are gold-plated for optimal resistance to corrosion and erosion. They also feature an extremely convenient mounting system that...
