Jean-louis L.
Jean Michel P.
Hervé R.
Pas si bien que ça !
Customers reviews - There are 19012 reviews.
George C.
Best Overall
Excellent again all the transaction with the shop.
Attila R.
XANGSANE DC05 Power Cable Jack DC 2.1mm to Jack DC 2.1mm Gold-plated 0.5m This 0.5-meter jack DC 5.5/2.1mm to Jack DC 5.5/2.1mm power cable features an OCC silver-plated copper core for maximum conductivity. PVC insulation is added before a textile...
OK, but not gold plated
This cable is good quality. I have replaced my old cable from the supercapacitors to my ethernet switch and it brought surprisingly a better sound to the system. I don't know why, but it helped.
The connectors on the end are NOT gold plated, so I cannot give 5 stars. For the money, this is definitely a good buy though.
Attila R.
Transparency!!!
I have replaced my old RCA interconnects with this cable, terminated with ETI Brio (Rhodium plated) connectors. I have used the blue pair as signal conductor, and the solid copper red wire for the grounding connection. I have used a tiny silver cable soldered to the shielding of the cable to SEPARATELY ground the shielding. (I have a grounding terminal on my Puritan power conditioner so it was easy to drain the sheild there.)
It is very very good quality as you might expect. It is also easy to work with, it was relatively painless to build my own RCA cable.
As for the sound, one word comes to mind: TRANSPARENCY. It lowered the noise floor and have brought more separation to the "layers" of sounds, more detail too. At first it sounds like it has a bit less bass but in reality it tightened the bass and have provided more realism. As you can tell I am super happy with this cable and I will buying more to building XLR cables in the future.
I highly, highly recommend the NEI-3001G if you need a transparent, high-end sound.
Attila R.
Perfect!
I use it for grounding connection and it is AMAZING. Easy to bend, can be stripped easily and has amazing quality. I will surely buy more, cannot beat it for the price.
Mathieu S.
Remplace allègrement mes câbles très haut de gamme
Sur les recommandations d'un amis , j'ai équipé tous mes composants avec ce câble , et après une période de Rodage d'une vingtaine d'heure , ces câbles ont tous simplement changer radicalement mon système.
Les graves , le détourage des instruments et la scene sonore ont tous été bonifiés de façon extrêmement significative. Bref mes câbles précédent ont été renvoyés au rang de reliques. Merci à audiophonics !
jean michel G.
Embout de bonne qualité, facile à sertir.
Avis
Câble très bien conçu,et très qualitatif.
Avis
alain F.
FOSI AUDIO M03 Class D Amplifier Mono + Subwoofer TPA3255 120W 4 ohm The Fosi Audio M03 subwoofer amplifier is an affordable, compact and powerful compact device. It features a TI TPA3255D2 amplifier chip delivering 120W power at 4 ohms. It...
Ce petit ampli me donne entièrement satisfaction et vient en complément des Supravox 215RTF qui ne descendent pas très bas dans les graves.Je l’utilise avec un caisson de grave passif.Ce petit plus dans le grave est appréciable notamment dans l’écoute du jazz.
En outre, très facile à trouver les bons réglages.
Wayne M.
evo oil
i must say these really bring the crossover sound to another level, they are precise accurate and fast, down side is the size other than that they sound like new speakers
Wayne M.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 33µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Jantzen
i find the Jantzen caps an all rounder,they make a big differance in the upgrade of speaker crossovers, my fist choice in trust
Wayne M.
Oil caps
i must say these really bring the sound to another level, crossover is precise accurate and fast, sound like new speakers
Wayne M.
Oil caps
i must say these really bring the sound to another lever precise accurate and fast, sound like new speakers
Sandy G.
ENCHANTEE
Très contente de cet achat, la classe A ça s'entend, !..
2x50w sous 8 ohms , garantis en classe A, c'est suffisant .
Même pour maitriser mes enceintes ELIPSON Legacy 3230, qui descendent pourtant assez bas en impédance, et dans les basses.
Associé à un préampli MUSICIAN MONOCEROS, avec utilisation de ses sorties Symétriques et des entrées symétriques, bien sûr, de l'ampli AUDIO GD. C'est peut être le petit reproche à faire à cet ampli, de ne pas posséder d'entrés RCA. Mais AUDIO GD a également une autre entrée "en modulation de courant" ICSS , redoutable parait il...(il faut acheter le préampli associé, de la marque AUDIO GD )pour pouvoir utiliser cette liaison ICSS...Marketing, marketing.!!..)
SUPER PRODUIT.
Patrice P.
LHY AUDIO OCK-2S Master Clock OCXO 10MHz Black The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams. This clock features six...
Génial !!!
Connectée sur mon streamer RS130 et Dac RD160 de chez Hifi Rose, le gain est significatif. J'utilise des câble coax Amphenol PMR400, c'est tellement mieux que certains câble plus chers que j'ai essayé. Si utilisation en mode sinusoïdale, je conseille de mettre des filtre pas bas BLP-10.7+ au niveau des équipements connectés, l'apport est incroyable.
Patrice P.
Vraiment une bonne prise secteur
Aussi bizarre que cela puisse paraitre, elle remplace sa grande sœur NCF, qui n'était pas du tout "compatible" avec mes câbles Audioquest Hurricane ou Firebird. J'ai retrouvé du calme, plus de sibilances dans les aigues, un bien meilleur équilibre tonal et un son très chaleureux.
La version NCF doit convenir à d'autres câbles, mais certainement pas Audioquest et ses prises en argent
Anthony S.
Great service
Exellect comms, first class delivery (2 days to the UK!), product quality also very good, easy to complete purchase simple GUI, would definiately purchase again
LINDY BLACK LINE Male USB-C 3.1 to Male USB-A 3.1 Cable Gold Plated SuperSpeed+ 10Gbps 5A 0.5m Lindy's Anthra Line cables are high quality products, ideal for professional installations. It is a USB-C male to USB-A male cable. The new USB standard has the USB 3.1 standard...
Excellent câble, 50 cm et 5 ampères c'est parfait
Fini les câbles inutilement trop longs. De plus les audiophiles apprécieront son rapport qualité prix pour relier leurs précieux disques durs aux DAC's et autres streamers.
Frantz G.
IFI AUDIO UNO USB DAC Headphone Amplifier ES9219MQ 32bit 384kHz DSD256 MQA The iFi Audio Uno is a compact DAC and headphone amplifier that easily and efficiently enhances the sound quality of a standard digital source such as a smartphone, tablet or...
IFI AUDIO UNO DAC USB
Ce petit boitier est vraiment indispensable pour écouter de la musique dans de bonnes conditions à partir d'un PC standard, c'est à dire équipé d'un carte son native (ou bien ordinaire). En ce qui me concerne, j'ai l'impression de m'approcher de la qualité CD. Personnellement, je ne replacerai jamais mes CD et vinyles par de la musique en ligne dans le cadre d'une écoute "de salon", mais lorsque je travaille dans mon atelier, c'est vraiment top et ça change vraiment tout !
michel m.
Dac SU-1
Quand même ça marche bien, sous Linux, rien à installer en bit perfect .
Après quelques mois, à l'écoute les basses sont charpentées avec un medium exaltant et un aiguë très naturel.
- Essai avec hiface 1 (que je n'arrive pas à me séparer) sous XP et oui... en kernel streaming, écoute engageante.
Mais une préférence pour l'usb ...
Thomas L.
MINIDSP ADEPT ADC ES9842 Phono Preamplifier with DSP 32bit 192kHz miniDSP ADept is an ADC with phono preamplifier and DSP. It is based on an XMOS interface and an ESS ES9842 Pro conversion chip. This enables it to convert analog signals up to...
Using it with Audacity on Linux to transfer from MD. Care to be taken to have project sample rate matching the source, and the system not loaded with other tasks during recording.
Balázs A.
SMSL DO200 PRO Balanced DAC 12x CS43131 XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA/MQA-CD With its DO200 PRO, SMSL breaks new ground and unveils an ultra-high-performance DAC incorporating no less than twelve Cirrus Logic CS43131 DAC chips and an XMOS XU316 USB...
Had a Topping E50 before. This is way more natural sounding, especially in the highs and the mids. Instruments have a realistic timbre. Also has better details and a bigger, more precise soundstage. This is the sound that I wanted. Fantastic DAC!
Gérard M.
DAYTON AUDIO H6512 Wave Guide High Frequencies 16.5 x 30.5cm This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and low expansion rate. It ensures...
Belle qualité de fabrication avec un insert en laiton pour le filetage. Aspect de surface très agréable et bien fini.
Résultat très probant. Utilisé avec une compression Perless pas d'effet de projection.
Je recommande !
ISOACOUSTICS GAIA III Vibrations Absorbers Isolators 32kg Ø43x39mm (Set x4) IsoAcoustics Gaia III vibration absorbers improve clarity and soundstaging for speakers or subwoofers weighing 32kg or less. They feature a machined stainless steel body with an...
Depuis que je les ai Installés sous un caisson SVS 3000 la fusion du registre grave avec les enceintes est absolument parfaite , sans aucune modification des réglages ,on peux dire qu'ils ont fait disparaitre le caisson !
robert m.
Robert M
I bought this product for the HDMI-ARC connection. With this SMSL box I could not control the volume level with the remote control of my LG TV. When I checked the small user manual, it is indeed stated that it is not possible to control the volume level with this box. It would be nice if Audifonics could give a more complete description of the products they sell.
Daniel M.
TOPPING PRE90 Balanced / Single-Ended Preamplifier NFCA Black Topping's Pre90 is a high-performance preamplifier based on a fully balanced circuit and high-performance NFCA modules. It also benefits from a high quality volume attenuator...
Pre90
Transparent, dynamic, neutral and easy to listen to with nice strong bass.
One thing that gets in the way is the remote control
Vadim P.
Amazing, unique device
The Topping LA90D amplifier impresses with its excellent sound quality and solid construction. With its powerful features and precise sound reproduction, it is a real asset for every hi-fi enthusiast. What is particularly impressive is the wide sound space and the clear bass reproduction, which takes the listening experience to a new level. It is truly one of the best amplifiers in the world. Recommendation !
DIMOKRITOS D.
Dynamic and very detailed but excessively bright in midrange and highs
It’s a very good option for powered subwoofers, due to its powerful and very well controlled bass, and that is the only reason I gave it three stars. Otherwise, it is a disappointment. Overly bright in the midrange and high frequencies, in an unnatural and unpleasant way, even after long braking-in period. For general use, better go for the Elecaudio CS-361B which remains the emperor of the affordable power cords, being much more balanced, very detailed but in a natural and pleasing way and with phenomenal 3D imaging.
Marcus L.
SMSL DO100 PRO Balanced DAC 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a...
Amazing value
The performance of this DAC is exceptional for the price - amazing value! It beats most of the DAC’s I’ve either owned or auditioned with the previous generation ESS 9038 Pro. Gone is the hardness in the treble and flat soundstage the held many of them back. Superb!
Just a couple of years ago the performance of this SMSL DO100 Pro would have been associated with exclusive DAC’s from established ”audiophile” brands. If you have a high performance system but with an older DAC or CD you owed to yourself to try this SMSL DO100 Pro. ;-)
Konstantinos L.
TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Black The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and Bluetooth receiver. An ideal model for...
Another happy customer
After 30 years of enjoying my father's premium JVC amplifier for my home PC setup, I finally decided it was time for an upgrade. After about a week of researching products, reading reviews, and watching videos, I settled on the MX3s. It offered exactly what I was looking for at a great price.
The package arrived in-time and well-protected in a larger box with extra-thick paper cushioning, and everything was in perfect condition. Once installed, the difference in sound quality was immediately noticeable! I could hear details in my favorite tracks that I had never noticed before—the audio quality truly feels like a whole new level.
I'm using it with my two 4ohm 30Wrms diy monitor speakers in a nearfield setup, and it’s simply perfect. The MX3s not only delivers exceptional performance but also looks sleek and stylish. I couldn’t be more satisfied with this upgrade!
LHY AUDIO LPS-A8 230V Linear Power Supply Module for EverSolo DMP-A8 The LPS-A8 linear power supply module, developed by LHY Audio, has been specially designed to improve the power supply stage of EverSolo DMP-A8 network players by replacing the...
Aide au montage kit
Une (voire plusieurs) vidéo de montage existe sur YouTube dont celle-ci : https://youtu.be/EMOg57Ogp2M?si=zPhZQrFUvQWlmw92
Laurent M.
Protection modules for stereo speakers 12V 16A (Pair) This double mono protection module consisting of two cards will allow you to properly protect your speakers.
Excellent et implantation ingénieuse pour projet dual mono
Pratique à installer sur la face arrière de votre boitier DIY
Moi j'utilise une carcasse d'amplificateur en panne ey donc les orifices des anciens borniers HP. Pour utiliser les borniers proposés par Audiophonics il faut les démonter complètement, ils sont faciles à adapter sur les cartes ensuite. Je suis très satisfait de mon acquisition. Laurent
Laurent M.
Excellent registre aigu
Par rapport aux L20V10 d'Audiophonics je trouve un manque de basses flagrants et un medium trop dans la retenue. Par contre l'aigu est fabuleux ! Les essais ont été faits exactement dans la même configuration en interchangeant les modules avec la même alimentation. Peut-être qu'un amateur éclairé pourra m'expliquer comment compenser le manque de basses en modifiant des composants... Laurent
Marko M.
AP310-PREAMP
The preamplifier is simple and practical, the design matches the rest of the AP300... series. I am satisfied with the functionality and connection options, perfect for those who need a bridge between the sound source and the power amplifier...Excellent service, fast processing and delivery of the product. Heartily recommended!
Marko M.
AP300-M450ET
Excellent service, fast processing and delivery of the product. Hearty recommendation for anyone looking for a simple, powerful, high-quality amplifier without unnecessary philosophy ;).
norman p.
Top ;)
fonctionne bien pour un canapé 3 places
David S.
Excellent cable interconnect RCA
Associé à des connecteurs NEUTRIK NF2CB2 et soudé à l'étain avec 4% d'argent, enterre mon câble RCA à 350 EUR soit disant audiophile. Un exemple de neutralité sur toutes les fréquences. Attention un peu rigide et très long à dénuder pour retrouver proprement les 3 petits conducteurs à chaque fois, mais l'effort est mérité. J'ai utilisé le fil rouge pour l'âme centrale, le blanc pour la masse et le blindage connecté coté source. De plus le câble est fléché donc je reconnais facilement le coté ou le blindage est branché sur la masse. Du coup je vais remplacer 1000 EUR de RCA par ces câbles DIY!
Jean Pierre b.
Excellent !!!
Après écoute , ce câble remplace avec brio un câble HP 7x plus cher, d'une marque américaine dont je ne siterai pas le nom et qui sonne à côté de lui comme "légèrement plus étouffé" avec une bande passante plus large, plus propre, plus réussit en faveur du Ludic.
Ce qu'il y a de rassurant, c'est que dans les 2 cas nous sommes dans la même esthétique sonore mais désolé le Ludic va plus loin.
J'entends plus de détails aussi.
Pour moi, le rapport qualité/prix est juste bluffant.
Je conseille vivement!
Michel V.
FOSI AUDIO T3 Amplificateur à Tubes Class AB 2x 6F2 Bluetooth 5.0 2x50W 4 Ohm The Fosi Audio T3 is a small tube amplifier allowing to enjoy the sound signature of this round and warm type of amplification at a low price. It is thus equipped with two 6F2...
Surprenant petit ampli.
Il est léger et a une puissance moyenne.
La réception BT est de bonne qualité.
Comme audiophile, en général je ne choisis pas des amplis qui ont des réglages de tonalité. Mais, là je m'y retrouve en l'utilisant avec avec mes HP large-bande que j'ai fait avec des Alpair. Ils ne font que 88dB, mais j'arrive quand même bien à sonoriser mon séjour avec ce Fosi T3.
FX-AUDIO TUBE-02 PRO 5725 Tube Preamplifier / Headphone Amplifier Class A With the Tube-02 Pro, Fx-Audio offers a small tube preamplifier and headphone amplifier in a compact and affordable format. Its preamplifier stage uses a pair of 5725 tubes,...
EXCELLENT PREAMPLI A TUBE
Ce préampli est très bon, il donne un son typé tube mais non caricatural. La rigueur est de mise, la transparence excellente et l'imagerie vraiment spacieuse. On peut changer les tubes si on souhaite plus de chaleur (accepte les 5654 et le 6J1).
Yannick S.
LQSC Class AB 4.0 Amplifier Board TDA7850 4x50W 4 Ohm This high quality Class AB amplifier module with 4 channels is capable of developing a power of 4x80W under 4Ω, thanks to a TDA7850 chip offering what is more a rich and...
2 entrées - 4 canaux
je l'ai pris pour Alimenter les tweeter et medium d'une paire d'enceinte 3voies à 3ampli avec filtration active par DSP. Ne chauffe pas en 12V.
le rendu sonore me parait meilleur qu'avec les 2 ampli 2x50W de class D qu'il remplace.
Michal D.
AUNE S17 PRO EVO Discrete Class A Balanced Headphone Amplifier Preamplifier 7500mW 32Ω Silver With its S17 Pro EVO, Aune unveils a powerful Class A headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features...
I like it
This + ESS dac + brighter linear (studio, reference) sounding mid-high end 300/600 Ohm brighter headphones:
Powerful (300Ohm upto volume 40, 600Ohm upto volume 55 is very loud from 60 total). Detailed. Clean sound - not bright, not cold, with just touch of added warmth, but I would not say it sounds warm. It adds some body to sound (perfect amount). It has smooth sweet lush mids. It does not increase fastness of music - it is touch on the slower relaxed side of sound presentation, but not too much - speed is almost in perfect middle.
Highs are not muffled - they keep the lushness of mids. Bass is nicely shaped and increasedly dynamic. Bass is not too soft. Slam is nicely defined. Bass does not bleed in mids. All frequencies are well balanced but listening attraction goes to mids and later to the balance of everything. Highs are as nicely defined as bass, but everything is lush. You can focus on music itself, not on aspects of sound. The lushness means that it is not overly analytical, but meant for enjoyment.
Space is nicely drawn. Seems natural and wide. Sound placement is nicely recognizable and it is not flat but there is sense of depth. Not too tall.
Canzar V.
Good value cable
after I changed the location of my hifi system, I needed a long speaker cable and I wanted to try Mogami.. considering that I use over 100 times more expensive silver cables from renowned manufacturers, I did not expect any spectacle in the sound. Mogami turned out to be a great cable for the value and I am pleasantly surprised by the sound quality.. after all we are talking about a wire that costs 11€/m..
Adrien B.
DAYTON AUDIO PC105-8 Speaker Driver Full Range 40W 8 Ohm 86dB 80Hz - 15kHz Ø10.7cm A full range speaker, compact and beautiful finishes. Ideal for building / repairing a small audio system or as a building block for more complex assemblies requiring multiple...
Ok
Bon haut parleur. Utiliser en médium dans un 3 voies. Fait le boulot mais un vrais médium aurait été plus performant. Attention pas top dans les aigu. Bon pour un 2 voies avec tweeter mais ne le remplace pas.
Adrien B.
DAYTON AUDIO DC25T-8 Speaker Driver Tweeter 50W 8 Ohm 93dB 3000Hz - 20kHz Ø10cm The Dayton Audio DC25T-8 is a dome tweeter with a ferrofluid-cooled aluminum coil and rubber suspension. The 1" titanium dome and precision phasing lens ensure very natural...
Bon tweeter
Aigu très distinct. Remplace mes jamo. Rien à voir avec les précédents. Parfois un peu "piquant" mais pour le prix je suis content du résultat
Adrien B.
DAYTON AUDIO DC160-8 Speaker Driver Woofer 50W 8 Ohm 86dB 30Hz - 4000Hz Ø16.5cm The Dayton Audio DC160-8 Classic Series 6-1/2 can be used as a woofer, midbass or small subwoofer.
Très bon HP. Remplace mes jamo défectueux. Belle différence. Grave beaucoup plus clair et moins brouillon. Je suis agréable étonné.
Guy L.
FURUTECH ALPHA 4.1T
Pour les personnes qui hésitent encore, allez y , j’utilise ce câble depuis plusieurs années et il est tout simplement incroyable. Ça marche de partout grave, médium, aigu. Des micros détails incroyables, un grave ferme et qui descends très très bas . Le vocal est également magnifique.
J’ai déjà conseillé ce câble à des collègues et l’avis est unanime.
J’ai même recablé plusieurs enceintes avec la version 2 x. 2,5 carré, pareil , les enceintes littéralement méconnaissable dans le bon sens.
Et pour les plus septiques et médisants, oui ce câble nécessite un rodage , je n’y croyais pas lues de l’achat de mon premier câble il y a plusieurs années de cela, et j’étais tellement dessus à la première mise en route que j’avais arrêté de suite l’utilisation du câble. Un jour pour rôder une paire d’enceintes je l’ai réutilisé afin de ne pas piquer celui de mon installation, j’ai laissé tourné sans être présent pour faire le rodage des enceintes, 8hoo après en rentrant je suis allé écouter, surprise Ça marchait vraiment bien avec ce câble sur une enceinte même pas rodée. Afin de vérifier cette impression, j’ai branché ce câble sur mes enceintes que j’écoutais habituellement, et là, magique , ça marchait très fort. Depuis ce jour, je n’ai plus jamais utilisé d’autre câble et j’ai Récemment encore acheté ce câble pour équiper une deuxième installation .
Alors au démarrage, par pitié, laissez tourner quelques heures vos nouveaux câbles, n’écoutez pas, allez faire autre chose en attendant que la magie opère. Alors ne me demandons pourquoi ces câbles sont tellement brouillons au démarrage et que ces derniers évoluent de façon incroyable en les rôdant.
Voilà, j’arrête là mais encore une fois , oui il est très bon après rodage.
Laurent M.
Bon rapport qualité prix.
Le Jantzen bleu me sert de base pour mes filtres dans le médium aigu depuis longtemps.
C'est une assurance d'un son équilibré avec des timbres naturels.
On peut bypasser l'aigu avec un petit condensateur de qualité supérieure pour peaufiner.
De part sa taille compacte il remplace avantageusement les condos parfois agressifs d'origine dans les enceintes du commerce.
Il y a un temps de stabilisation de quelques jours afin que le son soit vraiment agréable .
FILIPPO A.
SPARKOS GEMINI Hybrid Headphone amplifier / Preamplifier Tube 6922 and AOP SS2590 This Gemini headphone amplifier/preamplifier from Sparkos is a jewel of hybrid technology, whose main feature is the possibility of customizing it to suit your listening...
Ottimo amplificatore e altrettanto ottimo venditore!!
Ho alle spalle curca 45 anni di passione per l'ascolto in cuffia e ho avuto tantissimi sistemi dedicati. Ascolto prevalentemente musica classica. Ho voluto provare questo piccolo amplificatore e sto notando che è veramente apprezzabile, sia per l'aspetto e il senso di affidabilità costruttiva che incute, ma soprattutto per le sue prerogative soniche che lo pongono a un livello ben superiore rispetto a quello che la fascia di prezzo lascerebbe prevedere. Inoltre è ampiamente versatile dando la possibilità di cambiare la valvola di pre con agilità ed efficacia.
Consigliatissimo!!
Marc S.
AUDIOPHONICS HPA-Q450ET Power Amplifier Class D Four Channel Purifi 1ET6525SA 4x450W 4 Ohm The Audiophonics HPA-Q450ET power amplifier is based on a Class D architecture, using four Purifi 1ET6525SA amplifier modules, two Hypex SMPS1200A400 power supplies and an...
Superbe ampli
Enfin les sensations que je recherchais depuis un moment pour le Homecinéma. L'ampli révèle des performances que je ne soupçonnais pas de la part de mon Processeur Marantz 8805A : les impacts surtout avec beaucoup de micro détails et nuances et le tout avec une grande finesse et placement des objets dans l'espace.
En Hifi ? Pour l'instant le passe par mon Marantz pour écouter Qobuz via Audirvana. Je vais évoluer avec un DAC dédié mais pour le moment c'est déjà très bien. Impressionnant cette foultitude de détails à bas volume et un silence parfait ! Sans oublier cette maitrise totale des basses ! Attention du coup à la source car c'est très transparent et "sec ?" mais j'atteins là surement les performances du DAC du Marantz en mode Hifi qui n'est pas sa vocation première.
En comparaison, j'avais acheté cet ampli 4 canaux pour mes surround, centrale et une seule surround Back (mode 6.1) mais finalement je l'utilise sur mes colonnes principales au lieu des surrounds à la place de mon Denon PMA 110. Ces colonnes sont des Dynaudio Evoke50 pilotées sans problème. J'ai connecté une colonne par alimentation du HPA comme si j'avais 2 blocs séparés.
Pour finir sur Audiophonics, beaucoup de choses on été dites et je confirme leur sens du service client et les échanges quasi instantanés avec leur service support. Merci !
