Nicolas B.
Steve D.
Dayton spa300-D
Genalex
Loic g.
Stereo Amplifier Class D TPA3251 2x140W 4 Ohm This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high efficiency. It will therefore have no...
Simple et efficace
Marche a la perfection, rapport prix / rendement au top.
Petit b mol pour le knob volume, manque de solidité a l'intégration mais rien de terrible.
Pd: Bornier HP de petite taille (2 mm) à tenir en compte pour l'achat de câble et/ou fiche banane.
Pierre-Yves C.
ALLO Acrylic Case for Raspberry Pi 4 + Allo DigiOne Signature Black This acrylic case designed by Allo is perfectly adapted to receive the Raspberry Pi 4 and Allo DigiOne Signature combo, while maintaining access to the different connectors of...
Would be better with all the screws...
Although people have the tendency to complain about the cheapness of this acrylic case, I think it looks quite nice for the price and has the advantage to let the Wi-Fi signal in and out nicely. Why 3 stars then? Glad you asked. Simply because none of the ALLO DIGIONE SIGNATURE parts (case or boards) comes with the small spacers you need to secure the pi board to the base of the case. I am not the only one to complain about it and yet, still happens. The other star is for cheaping out of providing assembly instructions for the signature version of the the Allo digione board although it is the one that drains the most money out of your wallet... Despite all of this, ALLO support was really effective and I managed to get my 4 little screws before I could even say "quidditch"! The quality of the equipment, I have no doubt that it is decent, but right now my amplifier is a modest Onkyo TX-NR646 and the combo with my B&W 703 S2 is absolutely terrible and I can't wait for my Atoll IN300 to be here...
Bottom line, good product, good support but bad logistics.
Jean-Baptiste M.
Remplace l'alimentation de l'AD18 V3
Indispensable si vous avez l'AD18 V3 avec l'alimentation 5ah, cette alimentation 6.75ah mène à merveille mes Magnat Monitor alors que l'alimentation d'origine était à la traine.
Extrêmement dommage que SMSL ait modifié cette dernière et qu'il faille rajouter 20€ pour un ensemble performant.
Jean-Baptiste M.
Parfait sauf l'alimentation
AD18 adossé à des enceintes Magnat Monitor Suprême 202, résultat très équilibré et polyvalent si et seulement si vous utilisez l'alimentation de l'AD18 V1 cad 6.75ah. L'alimentation livrée avec la V3 n'est pas à la hauteur et c'est bien dommage.
KONSTANTINOS L.
Good performance amp
Pleasant surprise the amplifier. It was difficult for me to decide to buy a class D because I always had class AB amplifiers. The vocals are a bit flat but I pass it with its good dynamics. The only problem is that the amplifier refuses to start from the remote control ! That's why 4 stars instead of 5.
Alain L.
Grande valeur musicale
Après plus d'une semaine de rodage et de tests avec mon gustard p26 modifié avec les aop sparkos,
je constate avec plaisir que le gain en plus est bien là.
Ces aop n'apportent pas de sonorité typée et sont aussi neutres que les LME, c'est excellent pour moi, ce préampli garde son côté "passif".
Sur le plan de la transparence, un voile se lève. Les voix ont un peu plus de grain, les reprises de souffle sont plus perceptibles.
il y a un plus en rapidité, en lisibilité des informations.
La bande passante s'élargit, légèrement dans l'aigu mais surtout dans le grave qui est mieux tenu sans masquer le médium, c'est propre.
D'un point de vue de la spatialisation, je n'ai pas constaté de différence en largeur de scène, par contre un grand plaisir est là de voir qu'il y a
plus de profondeur. Sur mes enregistrements de basses, le haut grave est mieux détouré dû à la notion d'espace.
Tout celà donne un diable de préampli qui peut se comparer à des modèles valant 2 foix son prix, celà donne envie d'investir dans des sources
plus hautes en gamme. Le revers de cette belle médaille reste que les mauvais enregistrements révéleront tous leurs défauts.
Enfin c'est un véritable plaisir pour moi de l'utiliser ainsi, ce préampli comme cœur de mon système me donnera du plaisir pendant très longtemps.
RQP top
j'ai fais l'essai de ce câble, pour l'écoute, il est bien ,très défini, présent, je dirais, très live. Les brins de cuivre sont un peu plus gros que le sommercable,sc orbitt 2x2,5,et c'est sans doute ce qui fait son écoute, plus directe. pour mon système il ne me convient pas, mais vu la différence de prix entre les 2 câbles vous pouvez faire un essai sans vous ruiner.
Eric O.
These immediately bend open when you tighten the screws...?
These banana plugs are open on the sides, when you screw down on the cable, the sides immediately bend open and your cable isn't hold tightly in place.
I guess they are open on the sides to allow you to use larger cable diameter and spread out the wires through the openings... But using screwed connections without crimp sleeves is just really bad practice. I don't understand why they have the openings... Jantzen Audio's spade plugs don't have this "feature", why do these?
They are nice and short; low profile. Which is why I bought them, but I definitely wouldn't recommend them...!
Christophe P.
4 ans de bons et loyaux services
Déjà 4 ans que j'écoute ma musique via ce DAC FX-Audio et un câble USB Audiophonics. Depuis un an et demi je profite de Qobuz sur Audirvana (version achetée, pas l'abonnement). La qualité est meilleure que sur l'application ou le site (moins de basses, plus de détails). Je n'ai aucun souci de déconnexion, ça marche très bien. J'ai installé Asio4all sur Audirvana et j'ai une question : les titres enregistrées en 192 khz sont-ils vraiment lus à cette fréquence ? (comme l'indique Audirvana) vu que le FX-01 ne dépasse pas 96 khz ? (sauf sur tablette d'après le test de Qobuz). Autre question, ASio4all règle-t-il les problèmes de jitter avec Audirvana (c'est de l'USB adaptatif) ? Peut-être qu'un responsable d'Audiophonics a la réponse. Merci.
Axel A.
No Voltage Drop?
As already mentioned in some forum there is no voltage drop (!?) Adjusting the blue spindle trimmer does not change anything. Ripple comes down
from PSU: 2,5 mV
to CM: 0,5 mV
(@12,6 V, no load, Multimeter).
Any Idea?
Predrag K.
Predrag
I bought Matrix Element H and external LPSU Audiophonics 12V.
The sound of my Pegaus DAC improved, less sibilance and digital glare, more musical.
Audiophonics are very cooperative and friendly as usual.
Gilles s.
facilité de mise en oeuvre, fait le job.
Gilles s.
fait le job, amélioration de la réponse dans le grave sur quart d'onde LII-audio fast8
Gilles s.
Inutile ?
Sur mon système, pas entendu de différence d'aucune sorte avec ou sans le IFI DC purifier. Essai sur SMSL DP1 (démat) sortie optique sur convertisseur CD Cairn fog3 modifié, ampli tube Kalipso baffles plan supravox + ligne acoustique supravox pour extrème grave (la cave aux tubes). Très inférieur à la lecture cd par ailleurs.
Bartosz S.
Superb power amplifier
Small box but really big sound. It has plenty of power and great control. In my music system it works with Atoll CD100SE2, Audio GD NFB 1 AMP and Paradigm SE3. I am really satisfied with the sound.
AUDIOPHONICS MPA-S250NC XLR has my strong recommendation!
Gismy T.
Excellent câble HP
Essayé sur mes systèmes hifi il se marie très bien avec mes enceintes Harbeth M30.1 et mon ensemble Airtight à lampe ATM1S+ ATC2HQ.
Aucune agressivité, très musical c'est fluide.
Sur mon ensemble Accuphase (DP510; E370) + Proac D28 même ressenti transparent, neutre. Dynamique sa vie
Comparé à mes Nordost HP Red Dawn qui vont un peu plus loin dans les détails, plus analytique.
Après tous dépendra de l'écoute de chacun.
Pour moi c'était d'avoir 2 systèmes d'écoute différente une à lampe et une à transistor.
Mogami reste un très bon câble Hp pour son rapport/prix excellent.
Anthony L.
Tlg
Update on a veview in 2018.. recently built some fabulous speakers from IPL .. thought I may benefit from more expensive amp so auditioned both NAD 3020D v2 and NAD 3045. Very smooth but neither were close .. no dynamics . No 3G . No hologram sound stage. Sound was in the speakers . With ad18 sound us projected outside (digital optical input the best) .
This is an amazing device for the money myind is not changed.
TLG
henry N.
ARYLIC UP2STREAM AMP V4 Amplifier Board Bluetooth 5.0 WiFi 2x50W 4 Ohm The Arylic Up2Stream Amp V4 is an extremely practical stereo amplification module. Taking advantage of Bluetooth 5.0 and WiFi connectivity, it allows you to broadcast your music...
Up2stream amp v4
Super ampli. N'hésitez pas à le refroidir avec un ventilateur si vous le mettez dans une boîte grâce à ces connecteurs +5v et GND
Je n'ai pas reçu le connecteur vers pour brancher les baffle donc je vais devoir faire de la soudure. N'hésitez à acheter la télécommande avec car elle permet de faire plein de choses sans sortir son téléphone
jean-jacques D.
Unique
J'ai eu l'ancien modèle et j'ai apprécié ses qualités audio et son confort qui le rendent unique. Dans mon souvenir seul l'AKG K1000 se comportait aussi comme deux petites enceintes.
Je retire 2 étoiles car les mousses sur le dessus du casque et derrière les oreilles se sont délitées au bout de 2 ou 3 ans et comme elles étaient collées, impossible de les changer. J'espère que le constructeur a amélioré le système sur ce nouveau modèle.
claudio c.
IBASSO IT01X In-Ear Monitors IEM 16 Ohm 108dB 10Hz-40kHz iBasso offers with its IT01X audiophile in-ear earphones, taking advantage of a beautiful internal design to reproduce the smallest details of your music.
Tres bon intra comme d'habitude chez ibasso
Première écoute vraiment la grosse déception, après une centaine d'heures l'écouteur se révèle avec un son vraiment détaillé, une belle scène sonore et des aigu vraiment bien fait. Un son très holographique, un pure plaisir pour les oreilles.
gwen G.
DYNAVOX RCA Stereo Cable OFC Copper Gold Plated Connectors 1.5m This Dynavox RCA cable incorporates a 99.99% purity OFC copper conductor to ensure excellent audio signal conductivity and ensure that your system is soundproof.
attention, cable non blindé!!!!
en effet, non blindé, à ne surtout pas installer entre une platine vinyles et une entrée phono.....!!!
gros buzz avec ce cable, disparu avec "vrai" cable blindé......!
ALEXANDROS M.
SMSL SH-8S Headphone Amplifier Balanced OPA564 2x6W 16Ω SMSL offers with its SMSL SH-8s an affordable and efficient headphone amplifier. It uses OPA564 AOPs to deliver, with great precision, a power of 2x6W under 16Ω. It will...
SMSL SH-8S
Excellent for the money,good quility, very-very precise , beautiful airy treble, lacks a bit in bass, mids are a tone up, but with all amps you can fix with eq.
Most important that can listen to hours without fatigue
Flora B.
ASTELL&KERN A&NORMA SR25 Digital Audio Player DAP HiFi 2x CS43198 Bluetooth WiFi 32bit 384kHz DSD256 MQA The SR25 is the second model in Astell&Kern's A&norma range, a high-end DAP that fully embraces the brand's philosophy and technology, now available to the general public. The...
Cher et prise en charge carte sd pas au niveau
Sans doute très bon niveau au son - je n’ai pas eu loisir d’en profiter tant la prise en charge de carte sd et des métadonnees est laborieuse.
Je suis retourné sur un ancien baladeur iBasso certes moins « hype » et plus rustique mais qui, lui au moins, sait lire ce qu’on lui donne !
Sans doute est-ce l’OS qui est mauvais mais à ce prix là c’est le genre de détail qui est peu acceptable !
Kévin R.
TI LME49720NA/NOPB Operational Amplifier OPA Class AB 2 Channel DIP8 (Unit) The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8 package. This ultra low...
Volée de bois vert
Pas d'avis sur cet AOP ?
/ ! Si vous recherchez des basses lourdes et très profondes, passez clairement votre chemin.
La dimension, la fidélité et la justesse sonore qu'offre cet AOP est vraiment incroyable !
Vincent B.
Un super ampli
Ampli extra, conception de qualité, ampli puissant et qui drive tout parfaitement et clairement.
Une fois qu'on installe cette bête, il ne reste plus qu'a améliorer le reste de la chaine lol (la source, le préamp, les enceintes, etc) pour pouvoir bénéficier de toute son ampleur et de toute sa qualité.
Ma seule critique est ailleurs que dans le produit : le carton de suremballage était litérallement foireux et mal scotché (1 pauvre bande de scotch qui laissait le carton entreouvert...). j'ai eu une petite frayeur que les cables en vrac dans le carton ne manquent à l'appel. Le service colissimo ne semble pas au top au vu des coups pris aussi sur les coins du carton de suremballage. Quand on a 1000 euros de commande dans un tel carton on s'attend à ce que de plus amples précautions soient prises (par l''expéditeur, par le livreur).
Sinon je le répète : le produit est fantastique et de très bonne facture par audiophonices ! vous pouvez foncer !
Théodore E.
Hautement recommandé!
Utilisé pour alimenter un ampli AIYIMA A07, cet adaptateur délivre sur tous les aspects. Un chassis tout métal, très solide, d'une finition de très haute qualité -- les photos du site ne lui font pas justice. Il fournit toute la puissance nécessaire sans chauffer. Son poids non négligeable fait qu'il reste solidement en place, ce qui n'est pas le cas des transformateurs avec chassis en plastique qui sont menés par le fil d'alimentation. A ce prix, ce produit mérite une note de 20/20.
Christopher R.
Furutech dps 4.1
J'ai en ma possession le câble Furutech dps 4.1 depuis maintenant 4 mois. Ce que je peux vous dire dessus c'est que c'est un câble secteur de folie. Le mien est couplé aux connecteurs Furutech fi 50/fi e50 r NCF. Le son est d'une pureté sans équivalent. Tout est très équilibré, l'image sonore est très ouverte sans être envahissante. La transparence frôle la perfection, tous les micro détails passent et engendrent un son que vous ne retrouverez pas même avec l'excellent Furutech fps 55n. J'ai conscience que le tarif au mètre peut être un frein financier et/ou psychologique mais l'écart de tarif est proportionnel à l'écart d'écoute qu'il y a entre ce câble et le fps 55n, croyez moi !!!
Je l'utilise sur un dac Atoll dac 300 mais je l'ai également testé sur mon ampli Octave v80se. Les 2 électroniques font vraiment un grand pas en avant avec l'apport de ce câble. Il se passe plus de chose en le branchant sur la source que l'amplification, en tout cas me concernant.
Je l'ai également testé sur les électroniques Accuphase e800, Audio analogue, Cambridge audio cxn v2, Atoll ph100 et à chaque fois c'était une évolution considérable. Pour conclure j'ai possédé des câbles haut de gamme chez Audioquest (hp William Tell, secteur Tornado) ils ont tous été remplacés par des câbles Furutech et clairement sans regret.
Musicalement.
henri g.
pas toute la meme couleur 1 sachet 9 VIS dorees 1vis a tete ronde et 1 sachet 10 VIS cuivrees
henri g.
pas toute la meme couleur 9 DOREES
RENE R.
THE MAJESTIC
APRES PLUS D'UN MOIS D'ECOUTE LE CABLE S'EST OUVERT LE MEDIUM EST PLUS PRESENT ET LE SON EST ENCORE PLUS COHERENT. IL S'AGIT VRAIMENT D'UN TRES BON PRODUIT, SUR MA LINN IL REMPLACE UN CABLE VAN DEN HULL QUE JE TROUVAIS AGRESSIF ET SANS NUANCE. DE PLUS J'AVAIS POSSEDE AUPARAVANT LE MODELE HIGHLANDS DU MEME FABRICANT MAIS JE PREFERE CELUI-CI PLUS COHERENT ME SEMBLE T-IL. DONC UN TRES BON CABLE AU TRES BON RAPPORT QUALITE PRIX ET QUI CONSTITUE UNE TRES BONNE AFFAIRE.
Nicolas Q.
TOPPING BC3 audio reveicer Bluetooth 5.0 aptX HD LDAC DAC ES9018Q2C 24Bit/96kHz Black Battery-powered Bluetooth 5.0 Wireless High-Res receiver with integrated ES9018Q2C DAC. Offers line out, headphone out and even mini-toslink optical out. Compatible with...
Questionning manufacturing quality
I had to return my BC3 after 5 months of operation as it suddently stopped functionning. Audiophonics provided me with a new product (thanks for a good ASS process) but one can wander if the manufacturing quality is at rigth level.
Sebastien C.
Esthétique mais défaillant
Câble très esthétique, mais ce n'est malheureusement pas le premier critère à prendre en compte. Les connectiques sont mal calibrées, les contacts ne font pas correctement, ce qui rend totalement inutile le plaquage Or, et le câble en lui même. Le prix est donc très surestimé pour un câble "Made in china" fonctionnant plus mal qu'un câble RCA acheté chez Carrefour en 1998. Concrètement, la connexion de la voie gauche ne ce fait pas avec ce câble, mais fonctionne avec mon vieux RCA de grande surface. Je suis d’ailleurs intéressé pour connaitre votre politique de retour sur ce type de matériel.
C'est anomal, nous n'avons pas de problème avec la marque.
Votre câble est de toute évidence défectueux.
Contactez mes collaborateurs du SAV qui feront le nécessaire.
Alain L.
une perle rare , un RQP HORS NORMES.
J'ai osé placer ce préampli au coeur d'un système dont les éléments valent trois fois son prix. Et bien quelle surprise de l'écouter chanter au même niveau. De par sa transparence , sa neutralité et son silence de fonctionnement, ce préampli fait curieusement penser à un modèle passif.
l'image est large, il y a de l'air entre les pupitres. Il faut cependant bien lui laisser une période de "réveil" ou rôdage comme vous l'entendez. Il chauffe beaucoup pour un préampli, bien le laisser aéré est quasi indispensable. lui laisser le temps d'arriver à pleine temporisation sera également un plus musical. En conclusion : une petite merveille INCONTOURNABLE pour son prix.
Toute la différence avec un découpage basique
Cela fonctionne parfaitement bien; On a de la finesse en plus vu le recul phénoménal du bruit ! Bien supérieure à une alimentation à découpage à résonance qui sont très puissantes mais n'atteignent pas la finesse réalisée par la marque Ifi sur ses Power alimentions audio.
Excellent distributeur en Aluminium
J'en avais déjà un avec moins de prises. C'est le même en plus grand, avec les mêmes qualités. Je recommande.
Un raccord jack qui reste plaqué au piano qu'il relie au pédalier. On supprime le risque de l'accrocher en se déplaçant et de forcer les contacts dans l'embase qui l'accueil. Super !
Excellente fiche secteur
Produit excellent s'adapte à différentes inclinaisons surtout lorsque le câble est gros et ne se courbe pas trop facilement: il est bien rangé ainsi grâce à cette disposition. Juste trouvé la vis manquante qui retient la liaison terre schuko. Ne m'en suis pas aperçu tout de suite, mais un jour d'orage violent, en débranchant mes équipements, les broches de terre sont restées dans la prise. J'avais heureusement de la visserie compatible et j'ai pallié le défaut sans avertir le SAV. Il y avait trop de d'écart entre ma commande et le jour où je m'en suis rendu compte. Donc excellent produit, mais lorsque vous le recevrez vérifiez bien que la petite vis est présente pour le signaler dès réception à Audiophonics. Je donne 5 étoiles au produit, sachant que dans les cartons de production et d'emballage ce type de vis peut facilement s'égarer si elle n'a pas été suffisamment serrée par le fabricant.
Christian N.
Excellent petit DAC. Donne sa pleine mesure sur le HiRes et en particulier en DSD sur l'entrée USB avec Foobar (ne pas oublier de télécharger le pilote ASIO chez SMSL), son très équilibré, détaillé et neutre. Les filtres ne me paressent pas franchement nécessaires, peut-être sont-ils utiles sur un système plus ambitieux que le mien, j'utilise principalement ce DAC en sortie casque avec un HD600. La télécommande est un peu capricieuse et l'utilisation pas franchement intuitive, J'aurais apprécié quelques commandes en face avant pour éviter l'arborescence des menus par franchement intuitive pour un usage famillial. Je recommande vraiment ce produit.
Luis V.
Great Versatility
I bought 2 modules of these amplifiers to be able to power a dual 4 Ohm coil 1000 Watts Subwoofer, the results are surprisingly good, the combined amplifiers work perfect and at warm temperatures even in heavy loads.
I am amazed, by the incredibly reduced size, of the power and sound quality this units can provide.
Luis V.
Screw-in Rubber Foot 38x20mm (Unit) This rubber foot will allow you to guarantee your HiFi equipment a great stability. They also allow you to dampen the vibrations of your system.
Great Product
Awesome product to elevate and isolate subwoofers from the floor, the rubber is very soft and very well finished.
Bruno l.
Extraordinaire !
En décembre 2019 j’ai acheté un ifi Audio AC iPurifier.
Comme je l’ai écrit à l’époque, j’ai pris une claque monstrueuse ! Cet appareil fait un boulot extraordinaire. Comme tous les appareils de la marque IFI, il a transformé ma chaîne hifi comme jamais pour un prix ridicule par rapport aux éléments HIFI traditionnels.
Depuis j’en ai acheté un deuxième, La position de l’appareil sur les nourrisses peut donner des résultats légèrement différents, il faut trouver l’optimum, mais c’est grandiose !
De mon expérience, il en faut un plus près de la source et un au niveau de la prise murale. Les amplis doivent être en tête de nourrisse.
Je m’amuse très souvent à prêter à des amateurs de HIFI mes filtres secteurs actifs. Des personnes qui pensaient avoir optimisé parfaitement leurs installations à plusieurs milliers d’Euros,
A chaque fois c’est le même scénario ! Tout est mieux ! Les aigus sont plus propres, la position des interprètes devient évidente, le suivi rythmique est bien meilleur, on a l’impression d’avoir plus de grave, plus de medium, plus d’aigu, bref plus de musique,
Pour vous donner une idée, les deux dernières chaînes utilisées étaient composées de :
Chaîne Linn complète ampli + prérempli + lecteur CD avec une alimentation Linn séparée pour chaque élément et des enceintes PMC
L’autre encore plus haut de gamme, lecteur Wadia, convertisseur dCS, amplis Cello et enceintes Martin Login.
A acheter de toute urgence, même 10 fois plus cher ce serait encore une affaire par rapport à ce que cela apporte. Merci à Audiophonics de proposer tous ces produits abordables et réellement efficaces .
Jean-François T.
J'ai commandé ce kit en Novembre 2020 pour remuer les vieilles JBL L36 qui me servent à la restitution sonore de la TV, via une FreeBox Mini 4K et sa sortie TOSLink. Ces excellentes enceintes se caractérisent par un faible rendement et nécessitent de ce fait un ampli puissant. Les recommandations de JBL allaient en gros de 50W à 125W. Le précédent ampli (un Sure basé sur le TAS5630) avait cramé au bout de 3 ans environ...
Parmi les modules proposés par Audiophonics, rares sont ceux accompagnés d'une documentation aussi détaillée (un peu trop verbeuse d'ailleurs). Ce kit est de plus un des rares ne mettant pas en avant des performances "impressionnantes" sur charge de 2 ohms. Non, il est ici question de 8 ohms, et la doc précise son domaine d'utilisation : la vraie audio, pas la pleine puissance RMS avec un facteur de marche de 100% qui n'est utile que pour piloter un moteur par exemple ! Peu d'informations sur le web, mais tout de même un test avec des équipements de labo bien plus évolués que les miens ; conclusions élogieuses.
Moins cher qu'un T-Amp, très proche sur le papier, pas d’esbroufe dans la datasheet, kit complet ampli + alim, entrées différentielles permettant un câblage anti-pompage sans ajout d'un AOP inverseur = décision d'achat.
Premier test sur banc, avec charges résistives réglées sur 8 ohms. Sinus 1 KHz en sortie de géné BF, et recherche de la puissance maxi. Résultat absolument conforme : ça coupe à 35V RMS en sortie, soit 153W et un gain d'environ 55 (mesuré un peu à la louche, trop pressé pour affiner !). Le radiateur est alors brûlant ! (ces conditions sont totalement irréalistes, très éloignées d'une utilisation réelle)
Ensuite conditions réelles cette fois : un block buster, à très haut volume sonore. Aucun souci. Aucune fatigue auditive. Scène sonore précise et détaillée. Je veux dire par là absence de saturation, de compression, pas de variation gauche droite selon le volume, les chuchotements des acteurs restent parfaitement intelligibles au milieu d'explosions, et grande dynamique. Cette fois très peu d'échauffement, ce qui est logique (je n'ai pas mesuré la puissance RMS lors de ce test).
J'avais quelques doutes à propos de la dissipation de chaleur, et de l'extrême miniaturisation. Et bien ça marche parfaitement. Les radiateurs de l'alim et de l'ampli sont vissés au capot en alu du boitier Galaxy Slimline 1U, conformément aux recommandations. C'est à peine un peu tiède.
Une critique cependant : l'épaisseur du PCB : 1.6mm ; 2mm auraient étés préférables pour deux raisons. Un PCB de 2mm aurait donné une hauteur totale de 39.90mm au lieu de 39.50 mm après montage sur colonnettes de 10mm (mesure faite sur marbre avec une colonne de mesure). Avec 39.5mm, soit on ajoute des rondelles de 0.5mm sous les colonnettes puis de la pâte thermique, soit on place un conducteur thermique silicone de 0.5mm entre dessus des radias et dessous de la face supérieure du coffret 1U, ou alors on accepte de surcontraindre le montage ce qui n'est pas vraiment top pour les PCB... Je n'ai rien lu à ce sujet dans les docs, les modules ne sont pas livrés avec un conducteur thermique adapté, et Audiophonics n'en propose pas à son catalogue. J'ai été obligé d'en commander sur Ali...
Très satisfait donc.
Qualités sonores exceptionnelles.
Ce circuit SPARKOS Pro est encore très supérieur musicalement à la version de base pourtant déjà remarquable.
Il transfigurera n'importe quel montage utilisant un AOP.
Bien alimenté on peut comparer sa qualité audio à celle des circuits discrets des préamplificateurs audiophiles les plus haut de gamme.
Un réglage d'offset de sa sortie ajoute encore à son universalité d'emploi.
Excellente alimentation
Cette alimentation à prix très modéré est excellente!
Elle est à la fois silencieuse et très stable sur les tensions CC choisies en sortie.
( transfo Rcore 2 X15V ou 2x 20 selon le besoin).
Elle peut sans crainte être utilisée pour tout circuit classique et même audiophile même de très haut niveau.
Vincent b.
bon découlpeur
sous un dac R2R, le meilleur découplage que j'ai pu obtenir,
tout est plus net
Vincent b.
excellent cable : RQP imbattable
comparé à des câbles plus cher, celui ci s'est avéré très homogène, équilibré et détaillé... donc , d’emblée un bon choix
Honnête DAC
Pour un tarif inférieur à 100 euros,appareil très complet en possibilité de connection:utilisé en coaxial sur platine ,en usb pour écouter de la musique en streaming:son agréable, belle image stéréo
Essaye en Bluetooth : forcément c'est très moyen,pour ma part sans interet
Gros point negatif:le bloc d'alimentation 12 volts de qualité très médiocre,avec en plus un câble très court
J'ai pour ma part récupére une alimentation avec un transfo classique à enroulements:plus de précision et de clarté
ARYLIC S50 PRO Lecteur Réseau Multiroom WiFi Bluetooth Apt-X HD DAC ES9023 ADC AK5720 The S50 Pro from Arylic is a concentrate of functionalities that will allow you to realize a complex audio installation at an affordable price.
Préampli et lecteur réseau intéressant mais perfectible.
Déballage : belle présentation, discret, télécommande même format que alientek d8 auquel il est branché. Petite alimentation. ecran sobre et dimmable.
veille reglable.
on aurait aimé un cable optique ou coaxial.
installation : après allumage il faut se connecter par wifi à l'appareil depuis l'application 4stream, en selectionnant sur le telephone le reseau du s50, bien penser à accorder droits à 4stream pour tout et permettre la connexion même sans acces internet. Si cela bloque, changer de telephone (mon 1er ne me demandait pas assez vite les droits à accorder ou blocage). Ensuite 4 stream vous demandera le mot de passe du routeur ou box wifi pour s'y connecter. Le lecteur reseau me propose de telecharger et d'installer un update, c'est fait en 2 minutes.
essai 1 : le nas, ici c'est juste un disque ssd sur mon routeur netgear, partage smb ou dlna. Parfait, acces sans aucune coupure, tous les fichiers visibles, navigation par dossier. les pochettes sont visibles sur le telephone avec 4stream (qui est connecté au routeur maintenant), sur l'appareil on a le titre et l'artiste, un peu comme l'afficheur d'un lecteur rasptouch. 4stream permet la navigation, le volume, les favoris (12) d'accès rapide.
sortie optique, rca ou coaxiale essayé vers l'alientek. très léger souffle, c'est l'ampli. Je vais l'utiliser en optical out.
treble et bass seulement, pas de balance, lecteur non gapless.
Pas d'accès à grand chose comme parametres, la possibilité de changer de nom multiroom. pas d'egaliseur.
Qualité sonore c'est très bien après quelques morceaux, il faut surtout eviter de toucher de trop aux sources, sinon coupe, pareil pas trop toucher aux menus de 4stream, si on commence à vouloir naviguer sur d'autres sources musicales, celle jouée va se couper. Il y a un léger bip quand on aumente ou baisse le volume par la telecommande, choix discutable non modifiable.
essai 2 clef usb : le site arylic le previent c'est pas le point fort, en effet, s'il va reconnaitre une clef de 256go il n'a scanné que 889 morceaux de la clef, c'est 1000 max. ils sont rangés par navigation de dossier depuis 4 stream, le son depuis la clef est moyen, certains morceaux sont manquants en fonction de leur codec et qqfois cela saute. Pas de pochettes lues par clef. Egalement quand on branche une clef la lecture en cours se coupe.
essai 3 : bluetooth, c'est bluetooth entrant, par exemple pour l'acces du xduoo XIII, touche bluetooth de la telecommande puis appairage classique. nickel, pas de transmission vers un casque du s50+.
il me reste encore à essayer de brancher par exemple un lecteur cd pour voir sur aux in ou optical in.
essai radio : depuis 4stream recherche de france inter dans netradio, on peut lire les rubriques. marche très bien.
essai lecture des fichiers audio presents sur le smarphone par 4stream, pas de souci particulier, on peut lire sans appairer par bluetooth.
essai service en ligne type spotify ou autre, je n'ai pas de services payants cela devrait marcher sans probleme.
Au final lors de ce 1er branchement, plusieurs heures qu'il tourne, sans chauffer, il est agreable, j'aime la telecommande, l'ecran qui diffuse le morceau, le son est très bon. Aucune coupure en wifi depuis le routeur. Apres des tentatives de lecteur rasperry pi avec moode et runeaudio qui ne voyait pas mon dlna , je suis satisfait de cette partie.
j'aurai aimé avoir un selecteur de source defilant avec choix de la source en 2 fois, ici si on branche une clef usb, si on connecte un cable ou si on change sur 4stream de rubrique la lecture en cours se coupe brutalement. On peut alors difficilement le conseiller à des gens trop exigeant, et aussi le manque du gapless. c'est le gros point noir du tableau.
Drole de choix ce port usb pour clef qui n'accepte pas les disques et qui sert à rien au final, sauf a depanner si quelqu'un vient avec quelques fichiers car vaut mieux connecter un telephone par le bt à ce moment là. on aurait preferé une entre asynchrone pour un pc.
il manque cruellement plus de personalisation de l'appareil, ainsi choix du bip telecommande, un acces par navigateur en http (à venir peut etre d'apres le site ? oui car l'appareil a une ip, non fixe pour l'instant mais n'importe quel routeur peut fixer l'ip en fonction de son adresse mac. On a un egaliseur trop pauvre.
on a quand meme la mise en veille reglable, ainsi qu'une fonction reveil pas essayé encore.
pour un bricoleur avec de multiples sources, possedant plusieurs ampli fda ou classe ab analogique, des sources numerisées ou analogiques, c'est quand même un outil perfectible mais intéressant.
Acheté pour essais,convaincu que des câbles hp "pas cher" provenant du monde pro sont au niveau de câble ésotérique vendus à des tarifs exagérés...bref sur mon système très très bien,grave étendu,médium aigu naturel.je les préfère aux canare qui du coup paraissent plus sec avec un grave moins profond
Ce ampli ,plutôt bien fini,ne dispose que d'une seule entrée,s'apparente plus à un ampli de puissance avec un potentiomètre qu'a un intégré.
Peut importe, connecte à un dac le résultat sonore très bon:plutôt neutre, mais pas fatiguant même en montant le volume.
J'ai apprécié le mariage avec des câble hp sommercâble 240 mk2 qui apportent un peut plus de veloutée de chaleur.
Dès que possible,je vais rajouter un vrai preampli séparé, je pense gagner en dynamique et clarté
