David C.
Avant de...
Niels G.
Solid performer
Miguel O.
Satisfaction totale
Le gain est...
Customers reviews - There are 19668 reviews.
Hervé B.
SHANLING ME700 In-Ear Monitor IEM Hi Res 106dB 18 Ohm Ultra light in-ear-monitor equiped with 5 transducers with custom Armature drivers. Removable cable with MMCX connecteurs and balanced / single-ended output.
Info complémentaire
La forme des intrus est au top! Enfin pour mon oreille, on dirait qu'is l'ont moulée à mon conduit auditif!
Mathias L.
Gustard DAC-A22 Balanced DAC 2x AK4499 32Bit / 784kHz / DSD512 XMOS Bluetooth 5.0 MQA Silver Gustard Audio DAC A22 makes use of two AL4499EQ DAC chip. This reference component is among today's best digital to analog conversion solution.
Gustard Dac A-22 TOP
Top, Super Dac, the finest technology, very fine resolution,
I've already had a few dacs, but it's the best, thanks to Gustard for this miracle of sound
Highly Recommended
Jens H.
The best RCA plugs
I have tried many different brands of RCA plugs, for my DIY interconnects. These are the best. Easy to work with, easy to solder, beautiful, very well made. Sound quality will not make you dissapointed if your aim is high end homemade interconnects.
I can't praise these enough.
Jens H.
Not my favourite
I don't like these at all. Difficult to solder, no place to attach ground cable, had to drill a hole. Difficult to solder (Tellurium, yes I know..). Fit of outer ring is a bit too tight.
Will not buy again. Instead, will buy the 1877Phono which are absolutely fantastic plugs, easy to work with, beautiful quality.
eric m.
Dans les premières heures d'écoutes, ce Tube est très terne (un peu normal pour un Tube neuf.....) mais après une bonne cinquantaine d'heures, ca va beaucoup mieux. on découvre une scène sonore très impressionnantes, surtout sur des enregistrements "Live". Un Tube qui correspond tout à fait à mon Préampli. SRPP. Tube faible bruit et microphonique un son bien équilibré. C'est un bon choix.
Etienne B.
Excellent ampli
J'ai acheté cet ampli chez audiophonics (service client très bien avec conseils avant et après achat) il y a un an. Il fonctionne avec un raspberry pi comme source numérique, un DAC SMSL Sanskrit, et derrière des enceintes Davis Acoustis Olympia One Master. Le résultat est très bon.
J'ai comparé avec attention avec un SMSL AD18 (qui prend le signal numérique sans avoir besoin de DAC) : le AD18 est plus punchy sur les basses, très "direct" (ce qui est il faut bien dire très séduisant aussi). Mais le Volt+D est plus équilibré, avec des timbres plus riches et nuancés des basses aux aigus, et au final une scène plus réaliste, et c'est pour cela que je l'ai retenu. L e Volt+D reste étonnant sur la propreté des attaques et autres "transitoires" : les percussions sont très présentes, c'est presque troublant sur des cymbales. La fidélité et le respect de tout le spectre me paraît marquante, jusqu'aux aigus. Je n'ai pas comparé à des amplis chers et haut-de-gamme, je peux simplement dire que le son dans mon système modeste me paraît très bon et réaliste. J'entends très bien les différences entre des bons enregistrements, surtout en qualité CD, par rapport d'autres moins bons : la séparation des instruments, la présence dans la pièce des instruments, sont très agréables et réalistes, et en fermant les yeux, on y est... surtout sur des petits ensembles, jazz et vocal (mon petit système reste moins précis et réaliste sur des grands orchestres, mais je ne sais pas dire le rôle des enceintes, de la pièce, et de l'ampli).
Un son simplifié
Je rejoins l'avis de Patrick S. du 24/04/2021. Si ce Canare 4s11 présente un bon rapport Q/P, il offre une restitution trop simplifiée. Ses qualités sont cependant évidentes avec un son ouvert, fluide et aérien, une musicalité communicative et enjouée ainsi qu'une belle linéarité, mais les morceaux complexes et le jeu de certains musiciens sont fortement simplifiés et les styles musicaux ne sont pas toujours respectés.
Hervé P.
Parfait, fais le job ...
Dispositif mis en amont d'un Ampli Audiophonics Hypex 2x250W afin d'éviter tout risque d'exploser mes enceintes à l'allumage (Pas de réglage physique du gain, j'ai juste un "Bluesound Node" qui me sert de préampli donc absence de bouton "physique")
Fabrication super costaud avec Potentiomètre de qualité pour un prix très raisonnable.
Délai de livraison 2 jours ouvrés dans mon cas, bravo !
Hervé B.
Prestigieux!
Cette paire d’intras est à la hauteur des plus grands fabricants reconnus dans le monde de l’audio pour 3 fois moins chers!
Le son qui se dégage de ces écouteurs est un orgasme auditif, et pourtant je viens de les recevoir, et ils sont même pas rodés.
Bref, une grosse claque sonore sur mon Fiio M11. Des micros détails jamais perçus se révèlent majestueusement lors de l’écoute.
A titre de comparaison, je possède en sédentaire un RME adi2 dac couplé à un Focal Elear, et ces shanling les surpassent allègrement!
Les accessoires de très haute qualité et très nombreux viennent parfaire cette acquisition. Les paires d’embouts silicone sont dignes
De marque comme JVC spiral dots ou Sedna. Et les 2 adaptateurs 3.5mm et 4.4 viennent parfaire le tout.
Voila, vous êtes maintenant informés pour ne pas dépenser 1500 euros pour des marques prestigieuses. Et oui, la rétro-ingénierie Chinoise fait un knock-out aux ténors!
Je vous garantis que vous ne le regretterez point. Bien à vous.
Philippe L.
Excellent produit !
Très bon contact et parfait ajustage des matériaux pour un tarif acceptable; à noter une mention spéciale aux vis Tox qui permettent des démontages / remontages sans se coincer, ce qui n'est pas le cas de toutes les fiches bananes.
Sébastien S.
MA-LM02 Stereo Amplifier board LM3886T Class AB 2x 68W This Class AB Stereo Amplifier is renowned for its clarity, dynamics and excellent low frequency handling.
bon ampli, mauvaise presta de vente.
Ampli très correct pour le prix.
MAIS Audiophonics n'en a rien à faire de l'état de réception de nos commandes:
Emballages pitoyables, les circuits roulés dans un bout de carton avec systématiquement les CI écrabouillés sur leurs pattes. Condos bosselés, pattes rompues...
Beaucoup de clients ont déjà fait la remarque et rien ne change,
Conclusion : l'intérêt d'Audiophonics est ailleurs!
didier D.
Très bonne qualité, assez facile a connecter une fois que l'on a compris qu'il faut tout sortir. un mode d'emploi un peu plus détaillé ne serait pas du Luxe.
Monté avec un in wall 3x 3.5mm diam total 12 mm, a mon avis c'est la limite haute a ne pas dépasser car cela pourrait devenir difficile.
Excellent produit.
didier D.
un peu cher mais très bonne qualité
Très bon produit, facile a serrer avec une bonne tenue.
Un petit peu cher mais avantage de pouvoir les avoir a l'unité.
didier D.
bon produits mais caractéristiques affichées fausse
la qualité de ce produit est irréprochable, le rapport qualité prix est bon.
Cependant, il n'as pas convenu a mon besoin. Les caractéristique annonce diam 295mm et épaisseur 5 mm.
Il se trouve que le plateau de ma platine vintage est creusé et les 295 correspondait .
Hélas, quand je l'ai posé, cela ne rentrait pas, je donc du le retailler.
une fois posé surprise, pas assez haut, après mesure... épaisseur 3 mm. Je ne peux donc pas l'utiliser.
didier D.
connectique de mauvaise qualité
aprés avoir du reconnecter 3 fois les cables, le pas de vis de serrage de la terre a foiré.
22 € la prise shuko plaqué or, c'est pas cher, mais si c'est pour les mettre a la poubelle, ce n'est pas interressant.
Michel V.
Vraiment top , se connecte au Bluetooh de mon Iphone instantannément , je peux envoyer sur l'ampli de ma chaine hifi le son de l'application Deezer qui est sur mon Iphone, distance de réception super suffisante et aucune coupure.
Belle finition de ce petit récepteur et la livraison ultra rapide et bien emballé.
Merci à Audiophonics !
l evidence de la musique enfin!!!!!
iec fi c15 ncf sur ma platine cd , d une finition moyenne ,
pour cable pas trop epais,mais en sonorité c est vraiment excellent , dynamique generale ,basse tres tenue rapide,precise,medium ouvert ,propre ,douceur ,ça chante !!!! NCF je pense est le meilleur traitement pour les connecteurs
Christophe E.
Trés bon cable.
Essayé à la suite du 321b, celui-ci va plus loin sur tous les plans ! Il fait chanter mon Atoll DAC200.
Honnêtement je suis bluffé par la qualité de restitution de ce cable ! C'est un veritable up-grade de mon équipement.
Rapport qualité pour moi très bon. Je viens être convaincu par le bienfondé de l'apport qualitatif des cables d'alimentations.
Je pense que je vais équiper mes amplis avec .... à voir
Merci pour Audiophonics et son service super efficace !
Charles M.
IAN CANADA RECLOCKPI Double I2S / DSD Reclocker Low Noise / Low Jitter Ian Canada's ReClockPi is a high quality, low noise, low jitter dual reclocker module. It is designed to work with the FifoPi or any other digital audio device in synchronous...
Clearly makes a difference
Very nice improvement to the FifoPi MK3. Highly recommended.
fabrice v.
RQP imbattable
Bons câbles , neutres et transparents plus cristallin qu un câble bon marché et peut être même meilleur que certains beaucoup plus cher
Loic g.
Stereo Amplifier Class D TPA3251 2x140W 4 Ohm This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high efficiency. It will therefore have no...
Simple et efficace
Marche a la perfection, rapport prix / rendement au top.
Petit b mol pour le knob volume, manque de solidité a l'intégration mais rien de terrible.
Pd: Bornier HP de petite taille (2 mm) à tenir en compte pour l'achat de câble et/ou fiche banane.
Pierre-Yves C.
ALLO Acrylic Case for Raspberry Pi 4 + Allo DigiOne Signature Black This acrylic case designed by Allo is perfectly adapted to receive the Raspberry Pi 4 and Allo DigiOne Signature combo, while maintaining access to the different connectors of...
Would be better with all the screws...
Although people have the tendency to complain about the cheapness of this acrylic case, I think it looks quite nice for the price and has the advantage to let the Wi-Fi signal in and out nicely. Why 3 stars then? Glad you asked. Simply because none of the ALLO DIGIONE SIGNATURE parts (case or boards) comes with the small spacers you need to secure the pi board to the base of the case. I am not the only one to complain about it and yet, still happens. The other star is for cheaping out of providing assembly instructions for the signature version of the the Allo digione board although it is the one that drains the most money out of your wallet... Despite all of this, ALLO support was really effective and I managed to get my 4 little screws before I could even say "quidditch"! The quality of the equipment, I have no doubt that it is decent, but right now my amplifier is a modest Onkyo TX-NR646 and the combo with my B&W 703 S2 is absolutely terrible and I can't wait for my Atoll IN300 to be here...
Bottom line, good product, good support but bad logistics.
Jean-Baptiste M.
Remplace l'alimentation de l'AD18 V3
Indispensable si vous avez l'AD18 V3 avec l'alimentation 5ah, cette alimentation 6.75ah mène à merveille mes Magnat Monitor alors que l'alimentation d'origine était à la traine.
Extrêmement dommage que SMSL ait modifié cette dernière et qu'il faille rajouter 20€ pour un ensemble performant.
Jean-Baptiste M.
Parfait sauf l'alimentation
AD18 adossé à des enceintes Magnat Monitor Suprême 202, résultat très équilibré et polyvalent si et seulement si vous utilisez l'alimentation de l'AD18 V1 cad 6.75ah. L'alimentation livrée avec la V3 n'est pas à la hauteur et c'est bien dommage.
KONSTANTINOS L.
Good performance amp
Pleasant surprise the amplifier. It was difficult for me to decide to buy a class D because I always had class AB amplifiers. The vocals are a bit flat but I pass it with its good dynamics. The only problem is that the amplifier refuses to start from the remote control ! That's why 4 stars instead of 5.
Alain L.
Grande valeur musicale
Après plus d'une semaine de rodage et de tests avec mon gustard p26 modifié avec les aop sparkos,
je constate avec plaisir que le gain en plus est bien là.
Ces aop n'apportent pas de sonorité typée et sont aussi neutres que les LME, c'est excellent pour moi, ce préampli garde son côté "passif".
Sur le plan de la transparence, un voile se lève. Les voix ont un peu plus de grain, les reprises de souffle sont plus perceptibles.
il y a un plus en rapidité, en lisibilité des informations.
La bande passante s'élargit, légèrement dans l'aigu mais surtout dans le grave qui est mieux tenu sans masquer le médium, c'est propre.
D'un point de vue de la spatialisation, je n'ai pas constaté de différence en largeur de scène, par contre un grand plaisir est là de voir qu'il y a
plus de profondeur. Sur mes enregistrements de basses, le haut grave est mieux détouré dû à la notion d'espace.
Tout celà donne un diable de préampli qui peut se comparer à des modèles valant 2 foix son prix, celà donne envie d'investir dans des sources
plus hautes en gamme. Le revers de cette belle médaille reste que les mauvais enregistrements révéleront tous leurs défauts.
Enfin c'est un véritable plaisir pour moi de l'utiliser ainsi, ce préampli comme cœur de mon système me donnera du plaisir pendant très longtemps.
RQP top
j'ai fais l'essai de ce câble, pour l'écoute, il est bien ,très défini, présent, je dirais, très live. Les brins de cuivre sont un peu plus gros que le sommercable,sc orbitt 2x2,5,et c'est sans doute ce qui fait son écoute, plus directe. pour mon système il ne me convient pas, mais vu la différence de prix entre les 2 câbles vous pouvez faire un essai sans vous ruiner.
Eric O.
These immediately bend open when you tighten the screws...?
These banana plugs are open on the sides, when you screw down on the cable, the sides immediately bend open and your cable isn't hold tightly in place.
I guess they are open on the sides to allow you to use larger cable diameter and spread out the wires through the openings... But using screwed connections without crimp sleeves is just really bad practice. I don't understand why they have the openings... Jantzen Audio's spade plugs don't have this "feature", why do these?
They are nice and short; low profile. Which is why I bought them, but I definitely wouldn't recommend them...!
Christophe P.
4 ans de bons et loyaux services
Déjà 4 ans que j'écoute ma musique via ce DAC FX-Audio et un câble USB Audiophonics. Depuis un an et demi je profite de Qobuz sur Audirvana (version achetée, pas l'abonnement). La qualité est meilleure que sur l'application ou le site (moins de basses, plus de détails). Je n'ai aucun souci de déconnexion, ça marche très bien. J'ai installé Asio4all sur Audirvana et j'ai une question : les titres enregistrées en 192 khz sont-ils vraiment lus à cette fréquence ? (comme l'indique Audirvana) vu que le FX-01 ne dépasse pas 96 khz ? (sauf sur tablette d'après le test de Qobuz). Autre question, ASio4all règle-t-il les problèmes de jitter avec Audirvana (c'est de l'USB adaptatif) ? Peut-être qu'un responsable d'Audiophonics a la réponse. Merci.
Axel A.
No Voltage Drop?
As already mentioned in some forum there is no voltage drop (!?) Adjusting the blue spindle trimmer does not change anything. Ripple comes down
from PSU: 2,5 mV
to CM: 0,5 mV
(@12,6 V, no load, Multimeter).
Any Idea?
Predrag K.
Predrag
I bought Matrix Element H and external LPSU Audiophonics 12V.
The sound of my Pegaus DAC improved, less sibilance and digital glare, more musical.
Audiophonics are very cooperative and friendly as usual.
Gilles s.
facilité de mise en oeuvre, fait le job.
Gilles s.
fait le job, amélioration de la réponse dans le grave sur quart d'onde LII-audio fast8
Gilles s.
Inutile ?
Sur mon système, pas entendu de différence d'aucune sorte avec ou sans le IFI DC purifier. Essai sur SMSL DP1 (démat) sortie optique sur convertisseur CD Cairn fog3 modifié, ampli tube Kalipso baffles plan supravox + ligne acoustique supravox pour extrème grave (la cave aux tubes). Très inférieur à la lecture cd par ailleurs.
Bartosz S.
Superb power amplifier
Small box but really big sound. It has plenty of power and great control. In my music system it works with Atoll CD100SE2, Audio GD NFB 1 AMP and Paradigm SE3. I am really satisfied with the sound.
AUDIOPHONICS MPA-S250NC XLR has my strong recommendation!
Gismy T.
Excellent câble HP
Essayé sur mes systèmes hifi il se marie très bien avec mes enceintes Harbeth M30.1 et mon ensemble Airtight à lampe ATM1S+ ATC2HQ.
Aucune agressivité, très musical c'est fluide.
Sur mon ensemble Accuphase (DP510; E370) + Proac D28 même ressenti transparent, neutre. Dynamique sa vie
Comparé à mes Nordost HP Red Dawn qui vont un peu plus loin dans les détails, plus analytique.
Après tous dépendra de l'écoute de chacun.
Pour moi c'était d'avoir 2 systèmes d'écoute différente une à lampe et une à transistor.
Mogami reste un très bon câble Hp pour son rapport/prix excellent.
Anthony L.
Tlg
Update on a veview in 2018.. recently built some fabulous speakers from IPL .. thought I may benefit from more expensive amp so auditioned both NAD 3020D v2 and NAD 3045. Very smooth but neither were close .. no dynamics . No 3G . No hologram sound stage. Sound was in the speakers . With ad18 sound us projected outside (digital optical input the best) .
This is an amazing device for the money myind is not changed.
TLG
henry N.
ARYLIC UP2STREAM AMP V4 Amplifier Board Bluetooth 5.0 WiFi 2x50W 4 Ohm The Arylic Up2Stream Amp V4 is an extremely practical stereo amplification module. Taking advantage of Bluetooth 5.0 and WiFi connectivity, it allows you to broadcast your music...
Up2stream amp v4
Super ampli. N'hésitez pas à le refroidir avec un ventilateur si vous le mettez dans une boîte grâce à ces connecteurs +5v et GND
Je n'ai pas reçu le connecteur vers pour brancher les baffle donc je vais devoir faire de la soudure. N'hésitez à acheter la télécommande avec car elle permet de faire plein de choses sans sortir son téléphone
jean-jacques D.
Unique
J'ai eu l'ancien modèle et j'ai apprécié ses qualités audio et son confort qui le rendent unique. Dans mon souvenir seul l'AKG K1000 se comportait aussi comme deux petites enceintes.
Je retire 2 étoiles car les mousses sur le dessus du casque et derrière les oreilles se sont délitées au bout de 2 ou 3 ans et comme elles étaient collées, impossible de les changer. J'espère que le constructeur a amélioré le système sur ce nouveau modèle.
Claudio c.
IBASSO IT01X In-Ear Monitors IEM 16 Ohm 108dB 10Hz-40kHz iBasso offers with its IT01X audiophile in-ear earphones, taking advantage of a beautiful internal design to reproduce the smallest details of your music.
Tres bon intra comme d'habitude chez ibasso
Première écoute vraiment la grosse déception, après une centaine d'heures l'écouteur se révèle avec un son vraiment détaillé, une belle scène sonore et des aigu vraiment bien fait. Un son très holographique, un pure plaisir pour les oreilles.
gwen G.
DYNAVOX RCA Stereo Cable OFC Copper Gold Plated Connectors 1.5m This Dynavox RCA cable incorporates a 99.99% purity OFC copper conductor to ensure excellent audio signal conductivity and ensure that your system is soundproof.
attention, cable non blindé!!!!
en effet, non blindé, à ne surtout pas installer entre une platine vinyles et une entrée phono.....!!!
gros buzz avec ce cable, disparu avec "vrai" cable blindé......!
ALEXANDROS M.
SMSL SH-8S Headphone Amplifier Balanced OPA564 2x6W 16Ω SMSL offers with its SMSL SH-8s an affordable and efficient headphone amplifier. It uses OPA564 AOPs to deliver, with great precision, a power of 2x6W under 16Ω. It will...
SMSL SH-8S
Excellent for the money,good quility, very-very precise , beautiful airy treble, lacks a bit in bass, mids are a tone up, but with all amps you can fix with eq.
Most important that can listen to hours without fatigue
Flora B.
ASTELL&KERN A&NORMA SR25 Digital Audio Player DAP HiFi 2x CS43198 Bluetooth WiFi 32bit 384kHz DSD256 MQA The SR25 is the second model in Astell&Kern's A&norma range, a high-end DAP that fully embraces the brand's philosophy and technology, now available to the general public. The...
Cher et prise en charge carte sd pas au niveau
Sans doute très bon niveau au son - je n’ai pas eu loisir d’en profiter tant la prise en charge de carte sd et des métadonnees est laborieuse.
Je suis retourné sur un ancien baladeur iBasso certes moins « hype » et plus rustique mais qui, lui au moins, sait lire ce qu’on lui donne !
Sans doute est-ce l’OS qui est mauvais mais à ce prix là c’est le genre de détail qui est peu acceptable !
Kévin R.
TI LME49720NA/NOPB Operational Amplifier OPA Class AB 2 Channel DIP8 (Unit) The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8 package. This ultra low...
Volée de bois vert
Pas d'avis sur cet AOP ?
/ ! Si vous recherchez des basses lourdes et très profondes, passez clairement votre chemin.
La dimension, la fidélité et la justesse sonore qu'offre cet AOP est vraiment incroyable !
Vincent B.
Un super ampli
Ampli extra, conception de qualité, ampli puissant et qui drive tout parfaitement et clairement.
Une fois qu'on installe cette bête, il ne reste plus qu'a améliorer le reste de la chaine lol (la source, le préamp, les enceintes, etc) pour pouvoir bénéficier de toute son ampleur et de toute sa qualité.
Ma seule critique est ailleurs que dans le produit : le carton de suremballage était litérallement foireux et mal scotché (1 pauvre bande de scotch qui laissait le carton entreouvert...). j'ai eu une petite frayeur que les cables en vrac dans le carton ne manquent à l'appel. Le service colissimo ne semble pas au top au vu des coups pris aussi sur les coins du carton de suremballage. Quand on a 1000 euros de commande dans un tel carton on s'attend à ce que de plus amples précautions soient prises (par l''expéditeur, par le livreur).
Sinon je le répète : le produit est fantastique et de très bonne facture par audiophonices ! vous pouvez foncer !
Théodore E.
Hautement recommandé!
Utilisé pour alimenter un ampli AIYIMA A07, cet adaptateur délivre sur tous les aspects. Un chassis tout métal, très solide, d'une finition de très haute qualité -- les photos du site ne lui font pas justice. Il fournit toute la puissance nécessaire sans chauffer. Son poids non négligeable fait qu'il reste solidement en place, ce qui n'est pas le cas des transformateurs avec chassis en plastique qui sont menés par le fil d'alimentation. A ce prix, ce produit mérite une note de 20/20.
Christopher R.
Furutech dps 4.1
J'ai en ma possession le câble Furutech dps 4.1 depuis maintenant 4 mois. Ce que je peux vous dire dessus c'est que c'est un câble secteur de folie. Le mien est couplé aux connecteurs Furutech fi 50/fi e50 r NCF. Le son est d'une pureté sans équivalent. Tout est très équilibré, l'image sonore est très ouverte sans être envahissante. La transparence frôle la perfection, tous les micro détails passent et engendrent un son que vous ne retrouverez pas même avec l'excellent Furutech fps 55n. J'ai conscience que le tarif au mètre peut être un frein financier et/ou psychologique mais l'écart de tarif est proportionnel à l'écart d'écoute qu'il y a entre ce câble et le fps 55n, croyez moi !!!
Je l'utilise sur un dac Atoll dac 300 mais je l'ai également testé sur mon ampli Octave v80se. Les 2 électroniques font vraiment un grand pas en avant avec l'apport de ce câble. Il se passe plus de chose en le branchant sur la source que l'amplification, en tout cas me concernant.
Je l'ai également testé sur les électroniques Accuphase e800, Audio analogue, Cambridge audio cxn v2, Atoll ph100 et à chaque fois c'était une évolution considérable. Pour conclure j'ai possédé des câbles haut de gamme chez Audioquest (hp William Tell, secteur Tornado) ils ont tous été remplacés par des câbles Furutech et clairement sans regret.
Musicalement.
henri g.
pas toute la meme couleur 1 sachet 9 VIS dorees 1vis a tete ronde et 1 sachet 10 VIS cuivrees
henri g.
pas toute la meme couleur 9 DOREES
RENE R.
THE MAJESTIC
APRES PLUS D'UN MOIS D'ECOUTE LE CABLE S'EST OUVERT LE MEDIUM EST PLUS PRESENT ET LE SON EST ENCORE PLUS COHERENT. IL S'AGIT VRAIMENT D'UN TRES BON PRODUIT, SUR MA LINN IL REMPLACE UN CABLE VAN DEN HULL QUE JE TROUVAIS AGRESSIF ET SANS NUANCE. DE PLUS J'AVAIS POSSEDE AUPARAVANT LE MODELE HIGHLANDS DU MEME FABRICANT MAIS JE PREFERE CELUI-CI PLUS COHERENT ME SEMBLE T-IL. DONC UN TRES BON CABLE AU TRES BON RAPPORT QUALITE PRIX ET QUI CONSTITUE UNE TRES BONNE AFFAIRE.
