Miklos C.
Miklos C.
Miklos C.
Customers reviews - There are 19510 reviews.
Andreas K.
What an amp!!
I have bought this amplifier after a long and extremely informative exchange with David from Audiophonics. He recommended me this amp as an ideal match for my power hungry KEF LS50. He was so right!! The amp has so much authority over the KEF's, running them with ease. The sound is amazing, detailed, clear and far away from being harsh in any way. It also has a certain warm and deepness to it, you wouldn't immediately expect from a Class D amp. The Quloos has a lot to offer, he would easily compete with far more expensive amplifiers with his specs. The build quality is very solid and for years to last. I love this thing already and I want to say thank you to David and the Audiophonics team for their advice and their patience during my decision making. This amp is an insider tip, for sure!!!
Peter S.
Hello. I'm waiting for this item (and also 'FURUTECH FT-H800 (R) ródiové konektory pre SENNHEISER HD800 pair') .
When we can await delivering?
Thanks.
guy v.
Parfait 5/5!
Ce module compact et auto-alimenté via USB est une interface parfaite pour extraire l'audio d'un PC, dans mon cas un iMac Pro sous MacOS Mojave et sous Windows 10 en bootcamp, afin de disposer de l'entrée TOSLINK de mon ampli SONY 5.1. Ceci permet d'éviter les HP de monitoring lors de mixage/écoute de productions numériques, en mode surround. Quelques difficultés avec drivers Windows, mais résolues ... aucun soucis sous MacOS, mais ne pas oublier de rediriger le son de l'appli vers le module xCore au lieu des HP's intégrés!
Laurent T.
Top produit !
Excellente alternative au embouts à sertir wbt qui ont malheureusement augmenté par deux et même plus ces dernières années ...
Laurent T.
Excellent produit !
Excellente gaine thermo bien épaisse , idéal pour finition de câbles en hp par exemple ...
Laurent T.
Excellent produit !
stephane d.
TINYSINE TSA1110 Volume Control by Bluetooth Android / iOS Compatible This TinySine TSA1110 will allow you to control the volume of your audio system of your choice via the rotary knob on the case or remotely, directly via your smartphone.
Tinysine TSA110 super pratique
acheté pour piloter le volume de mon ampli à tubes qui ne dispose pas de controle de ce dernier, celui ci etait intercalé entre l'ampli, un selecteur audio video vsw41 et enfin un lecteur reseau, après maintes essais infructueux je peux doneravant l'utiliser, c'est vraiment une solution bien pratique et confortable quand on ne peut pas controler le volume de son ampli, utile, pratique et pas cher pour le service rendu, merci.
Emmanuel l.
IPAR 1023A Preamplifier / Volume Controller / Headphone Amplifier / Source Selector The IPAR 1023A is a hybrid device headset amplifier / preamplifier / source selector that displays excellent audio characteristics including a high power level, two isolated...
Bon amplii casque
bon préampli/ampli casque
je l'utilise surtout en préampli sur un atoll in 50 se en by pass très bon son a tel point que je vais m'équiper d'un ampli de puissance de la même marque il a juste un petit ploque au démarrage et a l'extinction
Sandy G.
bornes pour haur haut parleur
super qualité pour ce bornier, si vous utilisez des câbles de section sup ou égale à 2.5 mm2https://www.artisanbeton.fr/chape-flottante.html#:~:text=En%20d'autres%20termes%2C%20la,pertes%20%C3%A9nerg%C3%A9tiques%20de%20la%20maison.
Sandy G.
bornes pour haut parleur
super qualité , pas de souci.
TOPPING D10S DAC USB 32bit/384kHz DSD 256 XMOS U208 ES9038Q2M Silver Revisited version of the D10 from Topping, the D10s is an office DAC with impressive capabilities in its price range. This second version includes an ESS ES9038Q2M 32bit...
Fait parfaitement son travail.
Côté USB: raccordé à une Raspberry Pi 8Go et l’OS Volumio.
Côté RCA: Je l’utilise sur un ampli HiFi Pionneer SA-610 des années 80 et je suis plus que satisfait !
Sandy G.
super qualité si vous devez utiliser des câbles de section de 2.5 mm2 au moins.
Sandy G.
condensateur électrolytique
la qualité MUNDORF n'est pas un mythe, elle s'entend. : très bon résultat en filtrage d'alimentation, sur le petit ampli de jean marie plantefeve 2x30ww
Choisis pour en remplacement d’un câble 4mm2 (plus court) en cuivre uniquement, j’ai étonné de saisir une amélioration de la qualité sonore.
Très subjectif... à chacun de voir!
gilles m.
Trés bon produit
Hat série + horloge monté sur PI4, simple et efficace.
Blaise J.
Câbles
Livré en Suisse en moins d'une semaine avec un très bon prix
Bravo
Maxim K.
FIIO M15 Digital Audio Player DAP Android Hi-Res 2x AK4499EQ Exynos 7872 XMOS Bluetooth WiFi 32bit 768kHz DSD512 The FiiO M15 is a resolutely high-end portable audio player (DAP), integrating the best of today's components to ensure unbeatable sound reproduction. Whether you are at home or...
The FiiO M15 DAP and Audiotechnica ATH-AP2000Ti
The FiiO M15 DAP and Audiotechnica ATH-AP2000Ti headphones deliver great, reach, beautiful sound. It looks like they made for each other.
P.K. S.
1877PHONO FUSION PURE RCA MKII Modulation Cable PC-OCC RCA-RCA (Pair) 1.5m The Fusion cable series is the perfect integration with pure silver strands and Japanese monobrin PC-OCC copper. Designed with rigour and great precision, this Fusion series has...
1877 PHONO FUSION PURE RCA MKII modulatiekabel PC-OCC RCA-RCA (paar) ...
Cher Monsieur / Madame
Le câble est très agréable et donne une très belle restitution des aigus et des basses, surtout avec la basse et la guitare.Les voix sont très claires dans le salon et les câbles ne fatiguent pas après une longue écoute. Les câbles sont soigneusement rangés dans une jolie boîte et de bonnes informations sont incluses. Bref ... un câble très sympa et fortement recommandé ....
Cordialement, Pieter Sol.
Yann J.
Conforme
Produit reçu en 2 jours
Toujours au top chez audiophonics
Le cordon secteur est solidaire du boîtier pas de câble à acheter séparément
Pierre Z.
Pas mieux
Très pratique pour une finition propre
Harry H.
connectors for switchlink cable
I use these connectors for the cable between the linear power supply and the silent angel ethernet switch, connectors are of high quality compared to the standard ones.
Harry H.
Switchlink cable for silent angel switch
Very good cable, I use it as a power supply cable between my silent angel bonn n8 ethernet switch and the 5v. linear power supply.
Way better than the standard cable
GILBERT C.
LPSU100
Bel objet bonne qualité mon intel nuc chante mieux avec cet alim juste cette led rouge trop brillante qui me gene mais ce n'est qu'un détail...
Huy T.
Excellent Amp for the price
Nice clean sound. It's transparent. More than enough power for a stereo system or for a receiver to boost secondary speakers. It never gets hot and only stays slightly warm.
The switch in the back turns the amp into standby mode and the button on the front turns it on. The light surrounding the button is white. It came with a EU power cord and no adapter for US buyers. It was packaged well and was delivered in 4 days to the US.
Tim C.
Excellent compact class D amp
Been using this for a number of weeks now. No issues - good build quality and a seemingly uncoloured amplification.
As usual with class D amps, I'd question the power ratings, but it is driving a pair of q acoustic 3020s well enough: 12 O'clock is about as high as you can comfortably go. Between 9 and 11 O'Clock offers up a comfortable volume level. Given this, it's probably similar to a Class AB amp rated at 50 to 60 watts. Powerful enough.
I have not noted ANY 'hiss' commented on by reviewers on other websites. Very clean amplification.
For the money, this is an absolute bargain and highly recommended.
jean noel B.
Qualité de fabrication et sonore.
Posées en remplacement d’ anciennes prises banane WBT, le gain musicale est très net.
Aigu plus détaillé, précis, plus clair, on gagne sur tout l’ensemble du spectre sonore, tout paraît plus défini . Ces prises sont d’une grande transparence et laissent semble-t-il passer l’intégralité du message sonore sans coloration ou altération.
Guy H.
Bon Matériel !
Matériel de bonne facture.
Qualités :
Bonne finition.
Bon poids par rapport aux prises connectées.
Bon espace disponible pour les différentes prises.
Interrupteurs en fasade efficaces et anti "Plop".
Défauts :
Je cherche pour l'instant et ne trouve pas...
Je recommande.
Guy H
Guy H.
Bon produit !
Ce cordon est de bonne facture.
La section du câble est bonne et il a une bonne souplesse.
Le rapport qualité prix est au rendez-vous.
Je recommande.
Guy H
Joao s.
Worst ever!
I forget this product is so bad that after I receive I m thinking not to buy from audiophonics anymore , because if the product is bad and have error , audiophonics must confirm before send.
Joao s.
The worst product ever!
This product is the worse thing I ever see, the machine work , is horrible , I receive 3 damaged, on the outside , and the only not damage , the conc work in the inside but the place that contact with , there’s no cnc, I don’t recommend this product ever .
Jean O.
OPA1612 Dual OPA DIP8 (Unit) The TI OPA1612 dual operational amplifier benefits from excellent technical characteristics, allowing very good electrical and audio performance. It ensures a very low noise...
Excellent ampli OP
Utilisés en remplacement des NE5532 dans le kit préamplificateur Velleman K 8084, ils donnent d'excellents résulttats : plus de transparence et moins de buit de fond. Très recommandé.
Jean-Marc H.
1877PHONO COVE-RA Cable RCA to 90° DIN High purity OFHC for turntable 1.2m This cable has been specially designed for analog applications and is intended to significantly improve the input signal of your board.
Utilisé pour remplacer le câble d'origine d'une Sanyo TP1000.
RAS, ça marche bien. Bonne qualité de cuivre et surtout excellente isolation du câble. Très important car les platines de cette époque son alimenté en direct par le câble secteur en 230v qui génère pas pas de fréquence parasite...et comme le câble de modulation n'est pas très loin.
Ce câble est la meilleurs option entre une platine vinyle et un ampli. Inutile de dépenser plus ça ne changera rien en de qualité
Par contre avant de commander, vérifier l'accès au bras de la platine. Sur la Sanyo TP1000 par exemple, le connecteur DIN coudé s'impose Un connecteur droit ne passe pas.
Jaap B.
HYPEX SMPS1200A400 Switching Power Supply Module 1200W 2x64V The SMPS1200 switched-mode power supply is a very high efficiency model capable of developing a nominal power of 1200 Watts in an extremely small footprint. It has been...
Great
Works very well. No pops or clicks through speakers. Manual is not easy for an amateur. But all info is there.
Jaap B.
Beautiful case
Easy to assemble. Very sturdy. Good looks.
Francis L.
Francis L.
Sheath Natural cotton for cable Ø 5 - 8mm Red 100% natural cotton cable insulation for cable insulation.
Belle couleur, parfait à l'usage.
Francis L.
RAS
Souple et facile à travailler mais fragile mécaniquement, du plus bel effet une fois gainé coton.
Francis L.
Mitigé
Belle qualité de fabrication mais gros problèmes de faux contacts avec le port femelle... la fiche male nage trop là où une fiche standard marchait parfaitement.
Francis L.
Excellent pour class D
Couplé à un SA300, à une paire de Klipsch RP et un caisson, la différence dans le spectre des basses fréquences est flagrante, reste trop cher pour une alim mais l'effet wahou est bien réel.
Denis B.
passer votre chemin
je tiens le weller wsd 80 depuis 40 ans a 12.90 euros je n ai pris le bas de gamme non plus et la couronne de masse s est désolidarisée du corps de la prise, j ai pris une panne très peu épaisse genre aiguille et je soude a la mundorf supreme. alors vous voulez mon avis achetez vous un câble tout fait.ce n est pas les premières que j achète non plus et les autres étaient excellentes.aujourd’hui hui ce n est pas du tout la même qualité!!!!!.
Michael A.
Top quality at a very fair price !
Michael A.
Simple, such as excellent solution for the separation of signal and power supply.
Very Clean process tool, increases the flexibility when using between an SMPS or battery operation.
The length is sufficient for many combinations, but should be a little longer for a personal.
Top product !
Luis f.
MONOLITH LIQUID SPARK DAC AK4493 XMOS 32Bit 192kHz DSD128 The Monolith Liquid Spark DAC is a compact digital/analog converter developed by Alex Cavalli. It offers excellent audio quality and is especially designed to work in...
Smooth
Smooth sound with good soundstage, not sounding digital and analytical like others dacs at this price.
Recomended :)
dominique w.
Tres bon produit - livraison parfaite
Sebastien L.
idéal et parfait pour vos enceintes
Pointes Soundcare idéales et redoutables. Sous des enceintes Cabasse, l'ensemble est top et le son précis. Et quel confort et sécurité de se dire que l'on abimera plus son parquet.
Et Audiophonics assure toujours autant avec un délai de livraison plus court qu'annoncé. Service de qualité et communication parfaite. Un grand merci à toute l'équipe !
dominique w.
Parfait bon produit
tim c.
NEOTECH NES-3004 MK2 Speaker Cable UP-OCC Copper Silver plated 8x1.3mm² Ø 13mm This Neotech speaker cable features an 8-core StarQuad architecture with central insulation to lower the capacitive effect. The 1.3mm² conductors are equipped with strands...
Neotech
Very detailed, open clear sounding cable, excellent service from Audiophonics.fr
Jean-Michel D.
Bonne fabrication; difficile à trouver et une bonne alternative de qualité à ces mauvais produits en plastique. Le prix est justifié.
Jean-Michel D.
Pratique et efficace
Module pratique, pas cher, basé sur un schéma simple. Les LM1875T doivent être isolés du refroidisseur car portés à la tension d'alimentation négative.
Puissance suffisante pour la majorité des usages.
Jean-Michel D.
Fabrication impeccable. Ce produit n'est PAS une copie à bas coût.
Toujours satisfait des produits Neutrik.
