patrice f.
Soundcare standard
Dimitrios K.
Neotech usb cable
Pierre H.
Condo Mundorf 22000µF/63V
Wiesław P.
GUSTARD H16 Headphone Amplifier Preamplifier Balanced Black With the DAC, Gustard offers a high-performance headphone amplifier and preamplifier, benefiting from careful and intelligent manufacturing. With its independent symmetrical and...
bardzo dobry
Potrzebowałem przedwzmacniacza do dac i Gustard sprawdził się znakomicie.Może i nie ma dużo funkcji ale oferuje bardzo dobre wzmocnienie,tak do słuchawek jak i monitorów.
Oncu K.
Great improvement on Fosi ZA3
I have purchased these op amp to replace the stock op amps on my Fosi ZA3 and ZD3. These greatly improved the sound quality of ZA3. For ZD3 stock op amps, LME49720 sounds better than Dual OP627.
Alain S.
Fabuleux !
J'utilisais un tda1541 dans mon lecteur de CD et un ess 9018 dans mon Audiolab 6000a.
Et bien ce petit dac les enterre tous les deux !
Le son est plus détaillé que le tda1541 et beaucoup plus vivant que le ess 9018 !
La différence est époustouflante surtout avec le ess9018.
Basses profondes, bas medium charnu, medium clair mais ayant du corps, aigu filé et aéré.
Écouter la musique à bas volume ne change pas la qualité du son ni sa réponse en fréquence.
daniel c.
chauchau
RQP imbattable. Facile à monter. Merci Audiophonics.
Alexandru N.
GUSTARD X30 DAC 4x ES9039SPRO + ES9311Q XMOS XU216 Airplay 2 DLNA 32bit 768kHz DSD512 MQA Black With its X30, Gustard unveils a DAC of exceptional performance and versatility. In fact, this DAC features no less than four ES9039SPRO DAC chips coupled with an ES9311Q linear...
Gustard X30
First of all I would like to thank Audiophonics for the prompt delivery and exemplary packaging! It was delivered to me in Bucharest between Christmas and the 31'st.
This DAC is nothing short of amazing. I haven't heard anything like it before.
I can't find a single drawback to it's sound, the stage is deep and wide, the timbre is spot on, dynamics are off the charts with big swings and a really potent bass. I've always thought that the bass can't be very tight in my room because I have no treatment installed, but this DAC proved that it was the source that was keeping my system back in this regard. I don't mean to say that room treatment wouldn't help further, but to some this is not an option.
All of the aspects I've stated are impressive, however, the separation of instruments and voices is on a different level and this makes music make sense.
With this DAC I found that songs I thought were poorly recorded were just not reproduced well by my previous DAC.
Regarding the burn in period that lot's of reviewers mention, it sounded great right out of the box and I was happy with my purchase, but it did improve in the first three days.
Build quality is impressive, but the remote is of poor quality. Luckily I don't use it since I have a separate preamp. Regarding the preamp, it sounds a lot better with a preamp, but this might be system dependent. Going into my preamp if I adjust the volume from the Gustard the sound quality is not affected at all so the volume control inside it is good, but If I take my preamp out of the chain the sound is downgraded from all points of view. My preamp (Benchmark HPA 4) has no gain in the range that I use it in, but it has input and output buffering and it makes any DAC I connect to it sound better. If you've never tried a preamp you will still enjoy the upgrade compared to other DAC's connected directly to a power amp, but if you want an impressive upgrade further down the line get a good preamp.
Simply amazing!
Laurent P.
BFA Banana Plugs Rhodium Plated Ø9mm (Pair) These banana plugs, although inexpensive, benefit from a nice design quality. The BFA design of these plugs allows a very good contact between the connector and the terminal...
très bon serrage et solidité
Pour l'instant à leur niveau qualité / Prix , je n'ai rien trouvé de mieux Très bon serrage et une solidité bien supérieure à tout ce que j'ai pu avoir précédemment. Je les recommande.
Francis B.
Très propre
Le son est vraiment bon. Isolation et blindage efficace. Réalisation soignée! Prix raisonnable. Formidable.
Francis B.
Male XLR 4 Pins to 2x Mono Male Jack 3.5mm Balanced Headphone Cable Silver Plated Copper 1.5m This high-end balanced headphone cable has an extremely careful design using high-quality components. It consists of silver-plated 7N copper conductors, which are insulated and...
Ben voilà. Enfin!
Oubliez le câble d’origine Focal pour les casques Focal Clear avec XLR 4 pin. Le câble apportera l’équilibre tonal qu’on attend avec le clear MG par exemple que j’utilise avec. Et tout sera plus transparent, meilleurs basses . Formidable.
Nikolaus N.
Perfekt
Ich verwende den USB-Adapter so, wie er bei cheap-audio-men empfohlen wurde. Er kommt zwischen dem WIIM ultra und einem DAC (smsl d400 ex) zum Einsatz. Er erwirkt ein unglaublichen Gewinn.
Xavier B.
AUDIOPHONICS HPA-Q250NC Power Amplifier Class D 4 Channel NCore NC252MP 4x250W 4 Ohm The Audiophonics HPA-Q250NC is a four-channel amplifier based on two Hypex Ncore NC252MP.
Plutôt bon
L'ampli est plutôt bon, je reconnais que la définition est meilleurs qu'avec mon crown XLS 1502 (plus de micros détails), par contre je ne suis pas bluffé par la différence qualitative, à l'écoute on gagne un peu c'est vrai dans les détails, , mais au vu des critiques et review sur les amplis hypex ncore je m’attendais à un gain qualitatif plus conséquent, je reste malgré tout satisfait de ce nouvel ampli qui s’intègre mieux.
richard L.
XANGSANE XS-LB001 Banana Speaker Cable OCC Copper 2x6mm² 3m (Pair) Xangsane's XS-LB001 speaker cables feature 12 strands of 5N OCC single-crystal copper to ensure perfect conductivity. Each of these 12 strands receives PTFE...
Surprise
Si comme moi vous êtes un adepte du mogami 3103 et bien achetez le xangsane sans hésiter une seconde, il fait tout mieux, et même beaucoup mieux.
Le prix en regard de la qualité est ridicule, bref je suis ravi.
AUDIOPHONICS GXDC-21 Power Cable Jack DC 5.5/2.1mm to GX16 OFC Copper for LHY Power Supplies 1m This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.1mm connector and a GX16 connector. It can be used with LHY power...
Excellent!...
Câble d'alimentation excellent, remplaçant avantageusement celui d'origine fourni avec l'alim. L'amélioration est évidente sur les plans de l'espace, de la densité et des timbres. Indispensable à l'alim pour laquelle il est conçu et construit par Audiophonics.
Mark S.
Really opens up with a better power cable
I bought this LPS to replace an Uptone JS-2 which was powering my Mac mini. (The JS-2 was a bit-underpowered --sometimes the Mac mini restarted during heavy updates-- moved to my UltraRendu and EtherRegen. With this Audiophonics LPS's extra amperes the Mac mini no longer reboots.
I initially noticed little difference in sound quality (which is good -- the JS-2 is more expensive and for my Mac mini this LPS sounded similar). I have since experimented with various power cords in the €50-€250 range. It turns out that this LPS is a very nice match with a shielded €57 OFC copper cable.
I recommend this LPS especially with a nice shielded power chord. Best with 1,5m -2m length, in my experience.
Delivery by Audiophonics to Sweden was quick. The LPS is heavy and feels very solid.
Rik H.
SMSL RAW-MDA1 DAC 2xES9039Q2M Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams...
Great product!
For the price this thing is great! It's well build, looks good and functions as promised.
Menus are very clear and settings are easy to changes according your personal needs.
The remote also works better then the one from the Topping product I had before.
The display is clear and informative. (brightness is high, so you can set it to the lowest level and it is still readable from a good distance)
But better still: objectively it lives up to the specs the manufacturer shows on the product page. (https://www.audiosciencereview.com/forum/index.php?threads/smsl-raw-mda-1-dac-headphone-amp-review.56430/) It does not sound. It just transforms from the digital domain to the analog and amplifies (actually it attenuates) the signal without any audible artifacts.
CASPAR P.
j'ai du mal à comprendre
Bonjour à tous.
J'ai testé ce câble sur mon installation, Naim supernait3, JMR cantaile jubilé, Atoll MS120.
J'avoue avoir du mal à comprendre les nombreux avis positifs sur ce câble. Il est terne, très mou dans le grave et peu définit dans le médium aigu. Les voix deviennent tristes et les timbre voilés dans un flou à la David Hamilton.
J'imagine que sur beaucoup d'installations, il corrige un coté agressif de l'aigu, Pour moi, le but d'un câble est de transmettre, pas de corriger. Démonté au bout de 50 heures d'écoute.
par contre 5 étoiles pour le service Audiophonics, il est rapide, définit, bref, tout l'opposé de ce câble.
Pierre
GEORGIOS C.
Remarkable sound for a very reasonable price
The plug has all the attributes that i'm looking for, the most important being the PTFE insulation and the direct silver plating. The surprise came when i compared it with the VIBORG VR106G which has solid silver contacts and costs four times the price of the Elecaudio. To my detailed system (costing 15.000€ that are spent very carefuly) their sound is indistiguisable. This is an exceptionaly good sounding RCA plug, which is allso very well made and, to my knowledge, with the highest value/money ratio.
Jean Louis L.
NEOTECH NC-P303G Connector IEC C13 UP-OCC Copper Gold Plated Ø24mm This IEC C13 Neotech NC-P303G IEC C13 connector will allow you to design your own high performance power cables. It incorporates 99.99999% pure UP-OCC copper contacts with 24K...
Timbres juste et grand naturel
Ce connecteur en cuivre pur OCC vient remplacer un déjà très bon connecteur Viborg en cuivre pur OFC, sur un câble Furutech TCS31.
L'écoute après le rôdage habituel montre un progrès net dans le naturel des timbres et sur la reproduction des voix. En association avec le Furutech TCS31, l'écoute est de toute beauté !
Ce connecteur ne montre aucune brillance, c'est le naturel qui s'impose (attention si ce point est important pour vous à la version Rhodium, mais c'est affaire de goût de chacun).
A son tarif, il permet un réel progrès de l'écoute et représente une valeur sure et une référence, pour qui recherche une écoute juste et naturelle des voix, avec des timbres riches et de toute beauté sur des instruments acoustiques, sans la petite brillance et sur-définition artificielle "hifi" que personnellement, je n'aime pas.
Jose Molina Cuerda P.
Mcap
Sonido natural y refinado
Mcap
Mcap
sonido natural y refinado
Eric J.
SMSL A50 PRO Amplifier 2.1 Class D 2x MA12070 Bluetooth 5.0 HDMI ARC 2x70W 4 Ohm + 100W 2 Ohm The SMSL A50 PRO is a 2.1-channel Class D amplifier featuring two Infineon MA12070P amplifier chips. It is capable of developing power up to 2x 70W 4 Ohm + 100W 2 ohm. One of...
Une bonne surprise, avec du souffle
Ma base de comparaison se fait avec Smsl DA-6, Aiyima T9, Xduoo MT-605, Fosi Za3, Aiyima A08 pro, Topping MX3S.
Et des amplis Kenwood vintage qui sont ma préférence jusqu'à aujourd'hui.
Cet ampli sonne brillant, transparent, sans doute la signature des deux MA12070. J'aime bien. Très expressif, peut être trop pour certains. En tonalité direct, les aigus paraissent excessifs, les basses aussi. La rythmique est bien maîtrisée.
Son défaut, c'est que sans musique jouée, il fait du souffle.
Pour le prix, la sonorité, les entrées, la télécommande, la puissance 2X70W présents, je l'ai vraiment apprécié. Et je le préfère en sonorité aux amplis d'Audiophonics, cités plus haut.
Michel V.
SHANLING EC SMART Lecteur CD Vertical Sanyo DA11 CS43131 Bluetooth 5.4 The Shanling EC Smart is an affordable, high-performance CD player with an atypical, resolutely modern design. With its vertical format, the EC Smart accommodates CDs just...
Elégant lecteur et pratique
Peut se mettre à la verticale ou à l'horizontal. La dynamique est bonne.
Le son délivré par le jack casque et par le BT a de la puissance.
Quand utilisé à plat, les entrées arrières / dessous, ne sont pas très pratiques.
jean-françois v.
Retour d'expérience après rodage - environ 50H
Je tenais à faire un petit retour d'écoute de ces horloges au combien excellentes, cependant après rodage de celles-ci (45 et 49 MHz) installées sur mon Reclocker FIFO PI Q7 II, il apparait ce qui suit :
- Les voix de certains chanteurs étaient auparavant un petit peu sourdes , elles sont bien en place après rodage.
- Tout parait beaucoup plus juste, plus à sa place.
- On gagne de la matière dans le bas médium
- Les graves sont abyssales et très tendus
- Les fins de notes sont hyper silencieuses
Pour finir le plus important, il y a une séparation des canaux et des instruments encore plus marqué, j'ai une stéréophonie qui prend de la largeur comme jamais. Et puis tout ça c'est très naturel, sans crispation ni dureté on en oubli que c'est du numérique !! Produit à acheter pour atteindre les sommets (auparavant j'avais des horloges Accusillicon), le gap est vraiment important entre ces deux horloges !! Bravo à Ian Canada pour le développement de leurs produits qui sont bien au-dessus de la concurrence.
jean-françois v.
Sc Pure après rodage d'environ 50h00
Etienne c.
Dommage
Ampli bon son avec très bonne dynamique.
Problèmes : écartement bornes hp pas normalisées.
diamètre passages de câbles hp très petits.
Bouton power on / off capricieux.
Ampli reçu pas neuf, modèle d'expo ?
Etienne c.
Dommage
très bon ampli neutre et très bonne dynamique .
Les problèmes : espacement des bornes hp pas normalisées .
le diamètre de passage câble hp très petit.
bouton marche arrêt capricieux
Le produit que j'ai reçu n’était pas neuf , modèle d'expo ?
Teddy A.
MUNDORF MLYTIC AG Capacitor 100V 1000μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Le meilleur des meilleurs
Utilisé pour upgrader les composants existant dans un DAC déjà excellent (ERATO DAC100V1) c'est incroyable de constater combien les autres condensateurs manque de transparence !!!
david h.
DAYTON AUDIO HDN-8 Speaker Driver Exciter Bodyshaker Full Range Weatherproof 50W 8 Ohm 40He - 15kHz Ø10.2cm A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is...
haut parleur
les meilleur pour un pincab et le service audiophonics du tonnere
Emmanuel A.
Bien meilleur que d’autre très cher
J’ai essayé de nombreuses grammes de Câble pour des connexions modulation sur mon système Attol in 300 Avec streamer et lecteur, ainsi que Dac, de très bonnes factures sur l’ensemble, des cables testés du commerce et ce que j’ai fait fabriquer ce modèle m’a donné la plus grande satisfaction, il est supérieur À l’autre modèle de cette marque, le l2-t2s a beaucoup plus de détails, je trouve le moins montant que le L-4E6S
Pour les avoir tous les deux testés en alternance
Bruno C.
BERRYBAK BEA 1 R2CEPTEUR BLUETOOTH
Excellent rapport qualité prix. Facile à installer , facile à mettre en route!
Paulo A.
This is a tiny, cheap pre amp phono that i bought to replace a broken NAD ... and it sound very very clear and cristal. For the price it is a great product! Love fosi brand.
Paulo A.
TUNG-SOL 12AU7 / ECC82 Tubes (Unit) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
I put this new tube in my Xduuo 605 amp and the sound is fantastic... very good. It's an huge upgrade from the original tube at a very nice price!
Paulo A.
XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a...
Fantastic little amp
This is a great little amp. I love tube amps and the warm sound ...this one is a super budget hifi piece. I roll to a new tube (thanks for the tip) a Tung Sol and it just sound amazing. Great mids and highs, bass is very smooth but present. The sound is vey neutral and warm ... just fantastic
iouri C.
PSVANE EL34-Z Power Tubes (Matched Pair) PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture...
Superbes !
Ces tubes sont magnifiques ! Je ne parle pas du coffret, de l'écrin grande classe dans lequel ils arrivent. Acheté en deux fois deux appairés pour mon primaluna prologue one. J'ai des el34 jj versions 1 et 2, des Mulard 6450, des lion gold KT 88... J'ai débuté avec psvane sur deux 12ax7 puis deux 12AU7 qui ont remplacé des mulards et jj la aussi. Maintenant tout est en psvane. Si j'aime le son des kt88 je les trouve trop "modernes" en son. Avec lrs psvane el34z, je retrouve le grain des el34 série 2 de jj mais avec un son plus analogique et surtout une présence et détails dans les voix, des harmoniques... C'est assez fabuleux alors qu'ils n'ont pas encore tourné plus de 25 heures environ. A voir ou plutôt entendre si ils se bonifient encore !
hugues O.
Ethernet to Optical Fiber Converter (Pair) IEC Power Supply This device converts a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the Ethernet network to limit...
Fibre
C’est le premier et le moins cher des convertisseurs optique qui fonctionne chez moi. Je ne sais pas si c’est dû à la fibre monomode. Ne pas oublier de commander une fibre monomode si vous n’en avez pas et des câbles IEC. SHUKO
Hocine H.
Sceptique, mais...
Je devais changer la double prise qui alimente mon système, je me suis dit cher, mais pourquoi pas. J'étais sceptique, voire je n'attendais rien de particulier ; et pourtant quelle claque. Ce n'est pas le jour et la nuit, mais tout est plus limpide, détaillé. Alors comme j'ai une double prise juste à côté, j'ai pu faire la différence et non je ne rêvais pas, il y a bien un avant et après avec cette prise Furutech et si je devais tout recommencer de 0, c'est la première chose que je changerai, n'hésitez pas, vous ne le regretterez pas, cette double prise change votre perception de la musique.
Sylvain M.
Super streamer. Je ne suis pas audiophile, mais je peut dire que le son est très bon, détaillé, les basses profondes. Un appareil qui s'oublie (avec une bonne application) : pas d'affichage superflu, et une petite taille parfaite pour le cacher dans un meuble. Je recommande !
stoica r.
Neotech 3200
Best cable for the money.
I have exchanged my 3200 with mogami. I lost a sens of 3d on the super lowe frequency. Overall I gained in naturala musical dimension . I have a audio gd master 11 Singularity with audio gd master 1 he vacuum and 2H monoblocs. Speaker go to 2 ohms
Antonio D.
Três bom cable. Bonne construction et trés neutre au niveau son.
Juha T.
Excellent quality
Build quality really good, excellent sound. Although the case is small and lots of power, amplifier case heats only little during modest levels of listening.
George A.
SHANLING CR60 CD Player Ripper Sanyo HD850 Silver With its CR60, Shanling unveils a relatively compact, space-saving Audio CD player/ripper. The CR60 is based on a Sanyo HD850 laser head and a Philips drive mechanism for smooth...
Τα αρνητικά ... είναι η μικρή οθόνη δεν βλέπεις αριθμό κομματιού και χρόνο από θέση ακρόασης, και δεύτερον δεν έχει πλήρες αριθμολόγιο 0 έως 9 πού έχουν τα cd players. Επίσης αργεί λίγο να πάρει εντολή στο πάτημα των κουμπιών του. Δηλ. δεν προδιαθέτει για εναλλαγή κομματιών με το γνωστό τρόπο, σταμάτα ξεκίνα κτλ. Προσωπικά δεν έχω θέμα με όλα αυτά... μπορεί για κάποιον να είναι αρνητικά...
George A.
Shanling cd transport cr 60 + musical fidelity v90 dac. Είχα rotel cd 965, cabridge cd azur 640; Τα ξεπερνάει εντελώς! Υπέροχη στερεοφωνία, ανάλυση αβίαστη απεικόνιση, αθόρυβο εκτός και ο δίσκος είναι άκκεντρος; (Σε ελάχιστα cd). Αρκετά βαρύ (Φούλ αλουμινένιο κουτί και παχύ!!) βλέπεις τα χρήματά σου με το παραπάνω. Με ποιοτικό τροφοδοτικό είναι το κάτι άλλο!
le meilleur de fosi
achetés puis revendus pour fosi v3 mono, je regrette cet echange. Meme si v3 mono est plus propre sur le signal, le plaisir d' écoute( spacialisation, detail, relief) est bien meilleur sur les za3
nickel
cet etain allié a l' argent est super a travailler et les soudure sont propre et brillantes. Apres plusieurs essai de marque, je retiens en definitive celle ci.
tout simplement le meilleur rapport qualité prix en matière de fiche xlr.
bien et jolies
bonnes fiches bananes mais suivant le bornier, on peut être ennuyé pour les enficher.
MUNDORF ACS1150GY ANGELIQUE Wiring Cable Copper / Silver / Gold 1.5mm² Grey Mundorf ACS1150GY ANGELIQUE is a high-end wiring cable with conductors made from a mix of copper, silver and gold for maximum conductivity. This model,...
usage bien précis
J' ai voulu essayer ce câble pour un câblage interne de 'un ampli en liaison HP, a lui seul, il ne convient pas pour cet usage . En effet, il excelle dans le haut médium et les aigus mais trop maigre pour des basses dignes de ce nom.
parfaite
Tout comme les fiches bananes de cette marque présentes sur ce site, ces fourches sont de très bonne qualité, je les recommande.
tres moyen
J' ai essayé ces fiches de qualités moyennes voir en dessous. le signal est assez passant mais la qualité de serrage et de fabrication n e fait pas honneur a Viborg même à ce tarif.
top
ces fiches rca sont parfaites en tous points. faciles a souder, légères et peu encombrante et transmission du signal intègre.
elles font souvent partie des choix des grandes marques de câbles.
