Eric H.
Artis R.
Good price performance
Gregory P.
Parfait pour un ensemble TAD
Aucun...
Customers reviews - There are 19427 reviews.
Alain A.
FURUTECH FP-900 (G) Gold Plated RCA Plugs (Pair) Furutech RCA subbases have been developed to satisfy the most demanding consumers. These bases are made of phosphor bronze and are 24k gold plated.
Qualite or
La qualite est palpable, montage facile, rca classieuse
Phillip F.
first impression: exceptional value
I bought this on the strength of a very positive review of this module in a DIY application in Archimago's blog.
It took a long time to get it, thanks to the pandemic, but once in stock, delivery was quick and painless.
The unit is self is incredibly small, runs very cool, is dead quiet, and sounds as good as any amplifier I've used. I despise subjective audiophile descriptions, so will merely say that in terms of detail, dynamics and lack of irritation, I can't fault it. It also looks very good (although the "on" light is a bit bright - that is common these days.)
At the price, even including shipping and Canadian tax, it's a phenomenal bargain.
I'm giving it 4 stars because it has to prove its reliability, and also because I would like to measure its performance first.
Bravo Audiophonics!
Alain A.
Super rca
Facile a installer, bien isolees, excellente connectivite.
Mon vieil ampli en bluetooth !
branché pour relier un mac book air à mon vieil ampli sansui et sortir sur des cabasses sloop.
super connectiques, plein de possibilités. le bluetooth fonctionne vraiment bien et est tout de suite reconnu. pas de coupures de sons, c'est top. l'objet a l'air bien construit et solide.
par contre j'ai fait plusieurs comparaisons à partir d'enregistrements différents et grosso modo en mode bluetooth je n'ai pas noté un gain de qualité d'écoute avec le FX MKII par rapport à une simple liaison filaire partant en mini jack de l'ordi à xlr pour l'ampli. Quand l'enregistrement d'origine est bon il reste bon dans les deux cas et inversement lorsqu'il est mauvais.
bon de toute façon je l'ai choisi pour avoir une connection bluetooth lorsque certains jours j'ai la flemme de brancher mes platines ou lorsque j'ai envie d'écouter une musique que je n'ai qu'en dématérialisée et de ce point de vue je suis satisfait.
livraison et infos audiophonics au top ! merci
Parfait l’extrême aiguë
Ce condensateur offre un filtrage très fin et délicat tout simplement musical.
Il exprime l’extrême aiguë sans acidité, agressivité. Je recommande vivement.
Excellent lecteur en sortie analogique
Ce lecteur est tout simplement excellent, ses performances sont évidentes.
Directement connecté à mon ampli de puissance (sans préampli grâce à son potentiomètre intégré) diffuse le meilleur (ou le pire ) de l’enregistrement gravé.
Serge D.
FOUNTEK NEO CD 3.5H Speaker Driver Ribbon Tweeter 12W 7 Ohm 95dB 1100Hz - 30kHz 9x60mm Fountek innovates in the field of ribbon loudspeakers by adding a roof. The combination of these two technologies allows high frequencies to be obtained with extreme precision...
Sergio
Excellent et conforme à sa description.Beaucoup de précision dans les aiguës au plus fort de sa directivité . Finesse et naturel , peu de distorsions . Une bonne approche bon marché des modèles à ruban professionnels.
Pierre M.
Support casque
L’esthétique et l’ergonomie correspondent à mes attentes. Par contre pour le prix le niveau de finition et le fait que j’ai du le cirer avant de l’utiliser est un peu décevant.
Luc M.
très bon switch. belle qualité, led visible mais pas trop
JOEL C.
ELECTRO-HARMONIX 6H30PI Gold Pin Tube Twin Triode (Unit) The 6H30PI Gold Pin from Electro-Harmonix is a double triode tube. Its low plate resistance combined with excellent linearity and a dissipation of 4W per plate make it a prime...
Remplacement de 2 tubes 6H30 Sovtek
Je viens d'acheter un préampli Audio Research d'occasion équipé de 2 tubes 6H30 Sovtek d'origine. Ces lampes sont sensées durer 10.000 heures. Mon préampli date du début des années 2000 et d'après le précédent et unique propriétaire il l'aurait utilisé moins de 3.000 heures. Mais à l'oreille il ne sonnait pas comme mes autres préamplis Audio Research. C'est la raison pour laquelle j'ai décidé de remplacer les 6H30 d'origine par les EH 6H30PI Gold.
Le résultat est sans appel : mon "nouveau" préampli chante beaucoup beaucoup mieux !
Tout de même un léger bémol : les tubes ne sont pas appairés.
Le tarif Audiophonics est excellent et la livraison très rapide.
Un grand merci !
David G.
Conforme à ce que l'n peut en attendre.
Derek W.
Topping A90
Well-made and compact. Switches have a solid ‘click’ feel. Volume knob is a little shallow in depth and easy to move. Very clean sound with totally silent background.
The power gives my hard to drive headphones (set to ‘Hi’ at 12 O’clock on the dial) a feeling of ease of being driven and more detail. The extra detail was more than I expected.
A90 bought for Bedroom use and initially bought the Topping DX7Pro; good DAC yet I felt struggled with my headphones. Adding the A90 was the answer. DX7Pro as DAC + A90 and amp provides great sound quality and betters my main system which is 8x the price (main system has better DAC yet the combo overall is better). The A90 made the DX7Pro sound better as a DAC I perceived!? (assume a power supply thing!) Also bought the Topping RCA short cables, good value for money and well made. I heard zero differance between RCA and XLR.
4 Stars only as the first unit was supplied ‘dead on arrival’; that said merci beaucoup Audiophonics.fr for the fuss free return and replacement.
Hélas me suis trompé de diamètre. Trop grand
Ces fiches bananes sont nickel
Amélioration sensible du spectre audio.Pus net
Reçu très rapidement
Damon A.
A 'must have'
If you're purchasing the SC-6 cable, the SC-AIR splitter will organize the many individual wire bundles and look really nice. A simple shrink wrap will not look nearly as good. The splitter would otherwise be too big for most other cables.
Damon A.
Hard to beat features.
I purchased four meters of SC-6 for two 2 meter cables. I also got T6s forks, SC-AIR Spliters and Viablue sleeve to complete the set. Ironicaly, Viablue does not sell a 2 meter pair (1.5m, 3m, etc). All were delivered to me in the U.S. without problems.
The features of this cable are as good as anything you'll find, if you like silver-plated OFC copper, air pipes, and litz configurations. Preparing, dressing and terminating the cable will be a long, tedious process because of the cable's complexity. However, it's not difficult at all for the avid DIYer. With that in mind, I think purchasing a 'ready-made' pair would be a better value given the amount of time it takes to prepare it's many individual conductors for termination.
Damon A.
I love these beauties.
Thanks to Audiophonics for fast, trouble-free shipping to the United States.
Two sets of 4 connectors were purchased for use with NeoTech NEI-3004 cable. The connectors were very nicely packaged in a well padded tin, and are of excellent quality. Mounting the cable was trouble free with my ordinary soldering skills. The Audiophonics web site implies the maximum cable size these connectors will take is 10mm. It will actually take much larger which is a huge plus if you like big cables. I would have purchase the 10.5mm NEI-3001 cable if I knew it would fit. It wasn't until I got the connectors that I saw (in the description) it would take up to 13.5mm.
Damon A.
Great Bargain
As always, Audiophonics was excellent with fast, trouble-free shipping. So far all of my orders have been delivered to me in the U.S. with no additional fees or duties.
I purchased four meters of NEI-3004 cable to make two 1 meter balanced pairs. Preparing and mounting the high quality cable was easy using NeoTech NC-06612 XLR connectors. My initial impression is very detailed and neutral sound, as good as any cable I currently have (including recently purchased ViaBlue NF-S6)
Michel p.
Arrivé en bon état, emballage soigné.
Fonctionnement parfait pour l'usage.
Alastair P.
TOPPING D90 Balanced DAC AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Black A direct successor to the D70 Topping, the D90 benefits from the same refinements as its big brother while updating its DAC with a newer and more efficient version, the AK4499...
Compact Gem
This is a very good DAC and significant step-up from my previous DAC. The sound is very clear, detailed and has good dynamics and bass extension, but it will show-up any flaws in your streamer. USB and S/PDIF inputs are both very good. I have not tried I2S and AES inputs or AES output yet.
Catalin I.
Cable Pangea Premier XL 0,5m
Excellent rapport qualité/prix. Je ne suis pas tout a fait convaincu par cette séparation DATA/ ALIMENTATION mais le son est très bon, une très bonne spatialisation et définition.
Hélio R.
Entry level DAC/AMP combo
I've bought this to replace my onboard sound card, on the laptop - it's miles ahead in sound quality. It's good enough to make it possible to hear the difference between low quality MP3 and good ones.
This unit is a excelent entry into this hobby of sound. It's got almost every connection you need at this level: USB, coaxial, optical, and bluethooth 5.0. It also has a RCA output, and that means that it allows you to upgrade in the future, since you could use this unit as a DAC only. And a pretty good one at that too.
The bottom line is, at this price, is not possible to have a better sounding unit. It´s the perfect entry-level unit: it won't ruin the bank even if you don't like the sound of it, and it is a clear upgrade from every pc/laptop onboard sound card.
Mathieu F.
Bel objet
Bien plus gros que je ne pensais sur la photo (en profondeur). Le joystick de commande est très pratique et efficace. La télécommande moyenne. le son très bon.
Grzegorz B.
Very good cable for XLR connection
I use them between preamplifier and amplifier, they are better than QED an few others cable. Rather sweet and smoth than bright and sharp, but very detailed and aligned.
Grzegorz B.
One of the best power connector
I tried almost all power connectors for better audio equipment, the are almost the best. You can mount with or without crimp sleeve (better and safer with), in Schuko up to 6mm in IEC up to 4mm. In can is enough space to prepare cable comfortable (much better than Furutech 46/48/50 and cable holder is better than in Furutech, because don't damage cable like jaws in Furutech. Screws that merge both halves are screwed in aluminum, not like Furutech in thin plastic.
Grzegorz B.
Frederic S.
Crystal
Je commençais à avoir des doutes sur mon DAC fait main made in US et l’encensement autour de celui ci, en bref; un « giant killer » détaillé avec une douceur analogique.
Je n’ai jamais eu ce ressenti jusqu’à l’arrivée de ce préampli; micro détails en open bar, séparations entre instrus, fins de notes, un flot d’info parvient enfin à mon STA-9 qui me glisse à l’oreille qu’il voudrait bien un petit frère pour travailler en double mono, comme ce préampli le suggère avec une alim par canal. À ce propos, l’écartement entre mes enceintes (Elipson Planet L) est passé de 2M à 3M, pour une belle scène bien ample et plus profonde.
Bonus: bypass tona, réglages de tonalités convaincants, n’envois pas de basses boueuses par exemple, c’est efficace sur les trois bandes, bon dosage et parfait durant le rodage, parois bien épaisses, connections de qualité...Prix.
Malus: les diodes rouges en façades vraiment fortes et d’autres en interne pour faire croire qu’il y a des tubes.
En résumé: le bon coté de la transparence si le reste de la chaîne suit. Un rodage d'une centaine d'heures est primordial pour gommer une tendance un peu clinique et un manque d'assise dans le bas.
Alain V.
RQP imbattable
Il a remplacé un câble de marque beaucoup plus cher... Son apport: dynamique, séparation des instruments, effet stéréo, aigu mieux perçu.
Je le conseille sur le bloc ampli, pas en DAC mais à voir selon son matériel.
Pour le prix vous ne risquez rien de l'essayer!
Vasileios S.
SMSL SA300 clean sound
Amazing sound from this small size amp. Great seller all perfect. Thanks
F. M.
First Impression
a first look at.
Since there is no case yet, I tinkered a paper case to put the mainboard in and the display at the side.
Mounting the RPI 4 is very easy and the drilling holes are exactly at the right place to mount it to the main board.
Power on gives a red glowing on/off button at the front.
Push it and the AUDIOPHONICS logo appears on the display (nice!), filter setting is displayed for a while and the volume setting in %.
Finally you see: unlock.
Now RPI must know what DAC is used.
In Moode: (Moodeaudio.org)
Go to M (menu, upper right)
Configure - audio - I2S audio device
A bunch of AUDIOPHONICS dacs appear:
I selected 2 of them where ES9038 is listed, both work!
Then you can edit the chip/device options: choose 7 oversampling filters, ofcourse all works!
But listening tests will determine which suits you best.
Starting playback in the browser window on my phone.
Immediately the frequency in KHz. is displayed, and the music is playing.
All sound well on my headphone.
I shut the power down.
At the RCA connectors I plugged in 2 monoblock amplifiers, which are under my floorstanding speakers.
For safety I did not power them on.
Again I pushed the red glowing button on the front.
Exactly the same happened at above.
Then I see: 100%. That is the volume setting! So I put the volume knob down to 10% and powered the monoblocks.
All sound well and the remote control works fine for the volume.
Additional knobs are for RPI commands like play/stop and next/previous.
I have to get lirc (Linux Infrared Remote Control) on the RPI, so it communicates directly with the infrared led at the front!
The first impression of the sound is that the speakers seem to disappear and the sound is very broad, even outside left and right.
Connecting my TV to optical toslink shows that the latency is very low, and that is Top Class!
So far, so good. Today the case is visible on the website, its a beauty! I have it on my wishlist already.
Henri F.
confirmation !
après quelques mois d'utilisation, et pris de l'expérience dans les distrib linux je confirme que cet appareil est fantastique alimenté avec l'alim Shanti. Pour moi quasiment imbattable à un prix défiant toutes concurrences ! Je conseille la distribution Gemtooplayer. Gratuite et la plus aboutie sans aucun doute. J'en ai essayé pas mal (volumio, runeaudio, moode, picore, max2play avec LMS, archphile, dietpi, collybia). Pour moi Gemtooplayer est bien au dessus tant pour sa stabilité, les possibilités de réglages, sa flexibilité (lecteur MPD, LMS, squeezelite R2...). On active le player de son choix. On peut faire tourner le système en RAM. La solution la plus aboutie !!! Et elle est gratuite !!! Je vous parle même pas de la qualité de son fantastique associé avec l'allo usbridge sig... Au dessus de toutes. Vraiment ! Je le fais tourner avec squeezelite R2 la meilleure de toutes..... Je les ais toutes essayés... Il y a pas mieux à ma connaissance. Donc j'invite et recommande fortement à tous d'installer Gemtooplayer en lieu et place de Dietpi. Vous ne le regretterais pas. Croyez moi ! Et à tout ceux qui cherchent un fantastique lecteur réseau et qui pensent qu'il faut mettre plus de 1000 euros pour cela.... Non non l'allo usbridge signature à 468 euros avec son alim shanti fait au moins aussi bien et je dirais même mieux. Et en plus on a le choix de sa distrib linux... Donc foncez, et essayer avec Gemtooplayer.
Mladen J.
Unbalanced and Balanced Preamplifier
The quality of a professional device for just over € 300, I really don't know how it pays off for the manufacturer! Nothing is missed by chance, multiple stabilized power supply with audio graded electrolytic capacitors, printed circuit board from edge to edge of the chassis, no wires, anti-oxidation coating, premium JRC AOP with the possibility of easy replacement according to taste on stabbing sockets, low noise metal oxide resistors , aluminum housing circa 5 mm thick, and all for a little over € 300! Wow! Congratulations to the manufacturer!
Van Truong N.
Truong
Excellent tube , qualité équivalente à un nos , combiné à 4 Tung sol 120 sur jolida jd 505 c’est une merveille !
Toujours imbattable
Aujourd'hui c'est l'anniversaire de mon R8....tous les jours c'est un bonheur immense d'écouter la musique en Streaming convertie par ce Fabuleux DAC R-2R.
Entre temps, j'en ai écouté des systèmes avec des lecteurs réseau ou Dacs à des prix stratosphériques dans des magasins HIGH- END ... Chaque fois j'avais l'impression qu'il y avait une couverture sur les enceintes.
Ne cherchez pas, AUDIO-GD n'est pas vendu en magasin.
Et comme cadeau d'anniversaire, j'ai offert à mon Dac l'interface numérique AUDIO-GD DI20... et là ne me demandez pas ce qui se passe sur le plan électronique, mais j'ai eu l'impression d'avoir changé de DAC.
https://www.audiophonics.fr/fr/interfaces-digitales/audio-gd-di-20-interface-digitale-amanero-accusilicon-32bit-384khz-p-14191.html
C'est tout simplement magique, c'était parfait avant et là c'est incroyable ...il faut écouter pour comprendre.
Hervé N.
OYAIDE FOCUS 1 XLR
Produit fidèle à l'image de la marque.
Qualité de la fabrication et des matériaux.
Résultat sonore à la hauteur :
+ de définition, + de dynamique,
+ de transparence,...
Attaques de notes réalistes.
Au final, + de musicalité.
Pour systèmes haut de gamme qui
feront entendre leur apport.
Roland B.
Bravo Soundcare
Résultat formidable du maintien du grave et une nette amélioration du médium aigu avec les Soundcare pour mes enceintes Martin Logan je ne pensais pas que le problème venait de mes pointes et contre pointes d'origine pourtant sur une dalle en granit et un acharnement sur les changement de câble de modulation et Haut-parleur sans résultats probant et voilà mon problème réglé et beaucoup de temps perdu et d'argent .
Merci a toute l'équipe d'Audiophonics .
kees V.
Good quality cable
Good quality cable and packed really well!
Thierry A.
Dac externe.
Achat à l'aveugle. J'ai fait confiance aux caractéristiques de ce modèle. Alors oui c'est risqué. Mais ma recherche était d'avoir un Dac très récent avec indicateur de niveau et l'indication de l'échantillonnage à placer entre un lecteur Node 2 et un préamplificateur Hifi.
je ne suis pas déçu de cet achat.
attention à ne pas casser la télécommande, elle pilote le DAC
Michael T.
Franchement pas déçu, mise en œuvre ultra simple même pour un ignorant comme moi. Le son est franchement bon, Qobuz fonctionne à merveille, l’accès aux radio web est d’une simplicité enfantine.
Super produit livré en 48h!
Merci audiophonics.
Philippe L.
Pour piloter une freebox revolution v6
Marche parfaitement avec télécommande Essence 4 de One in All.
philippe j.
MONACOR DTM 104/8
Remplacement des tweeter dans des enceintes MARTIN
Des années 70 bon produit livraison efficace
Vincent P.
Ce câble sert de lien entre le Rasptouch édition Kali et l’alimentation linéaire Audiophonics : très bon câble qui fait le taf. L’ensemble est très cohérent.
Je mets 4 étoiles pour un tout petit souci de finition : la gaine a un fil noir qui n’est pas bien enroulé autour du câble. Ce n’est pas visible sur l’installation car derrière le meuble, mais c’est dommage sur ce produit (sans pour autant justifier un échange car tout fonctionne).
Vincent P.
Alimentation bien finie et apport immédiatement perceptible
J’utilise le Rasptouch édition Kali d’Audiophonics depuis janvier 2020 et ce produit fonctionne très très bien.
Je lorgnais sur cette alimentation depuis quelques temps, un peu septique cependant.
J’ai sauté le pas, après réflexion et en interrogeant l’équipe d’Audiophonics. Et là surprise, l’apport de cette alimentation est perceptible immédiatement : meilleure tenue des basses qui sont moins baveuses, et plus de micro détails.
Ce n’est pas la révolution tant le Rasptouch se débrouillait très bien sans, mais maintenant je ne me vois pas me passer de cette alimentation. Le plus apporté est indéniable et j’ai été scotché d’entendre la différence. Effectivement cette alimentation devrait être proposée en option à l’achat.
Encore une fois, Audiophonics propose un produit bien fini, avec des matériaux qui ont l’air solide.
Et les conseils éclairés de l’équipe qui a répondu à mes interrogations sans jamais pousser à la consommation.
Bref, un produit et une équipe 5 étoiles.
Paul E.
ingénieur-technicien
parfait. très bien fini, et bien emballé
Paul E.
parfait pour placer les transfos toroïdaux autrement.
Attention différentes photos montrent des perforations différentes de l'embase de fixation au chassis. Ce sont 4 trous de 4mm et non une encoche en U.
Gilles J.
Câble USB Pangea
Bon produit et fabrication excellente. A recommander pour une liaison CD / DAC par exemple.
Stéphane B.
Communication
Le relais de livraison a été très long , certes c'étais sans doute explicable en cette période mais un ou deux mail de temps en temps pour me tenir au courant auraient été les bien venu
Stéphane Brégeat
Alexandre B.
Très bon ampli, aucun bruit de fond, le silence total. Que dire de plus que toutes les reviews que l'on trouve sur le net ? Il arrive très bien à alimenter des casques gourmands tel que le heddphone. J'en suis content à 100% Il est actuellement couplé à un dac Smsl M400 et c'est une tuerie !
