mats c.
László S.
SMSL PO100
Fantastic sound, low jitter and noise. Highly recommended.
Gérard M.
Très bien. Fait le job.
Customers reviews - There are 20923 reviews.
Sandy Clémence B.
MUNDORF BS100 Copper Wire Ferron Core Coil 2.7mH Mundorf BS100 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal...
self pour filtre haut parleur
matériel de qualité, envoi réalisé soigneusement.
Olivier L.
DAYTON AUDIO DTA30HP Class D Amplifier TPA3116D2 2x15W 4 Ohm The highly effective amplification of the Dayton Audio DTA30HP unveils an incredible scene and sound presence, as well as great clarity and precision. It integrates an amplifier...
Dayton Audio
Surpris par ce petit ampli de qualité, très bien
Olivier L.
Power Plug Adapter Female US NEMA 1-15 / C Type to Male FR C Type This power adapter allows you to use US format power cables on European, Schuko or French plugs. The female part of the adapter can also be used for Type C / Schuko.
Adaptateur
Pratique
françois r.
AUDIO-GD PRECISION 3 2020 EDITION Balanced Class A Amplifier ACSS 2x 70W 8 Ohm Audio-GD is upgrading its Audio-GD Precision 3 by offering this 2020 edition. It is based on the previous model, but with a modified circuitry and adjusted sound performance to...
Ampli
Très bon ampli encore en rodage belle définition et assez de puissance pour moi
daniel f.
support Bornier
oui bonjour, le produit correspond bien aux photos sur le site .
Saphon I.
Magic
Son cristallin
Son claire comme l’eau
Son cuivré et dorés
Conclusion (aucune déformation,son authentique )
Cedric C.
AUDIOPHONICS HPA-Q400ET 4-channel Class D amplifier Purifi 4x400W 4 Ohm We are proud to present AUDIOPHONICS HPA-SQ00ET, a class D 4 way power amplifier based on 4x PURIFI 1ET400A modules.
Parfait pour la multiamplification
les modules purifi sont ce qui se fait de mieux avec les modules Ncore 40à en classe D.
Cet ampli ne chauffe pas (essayé en stéréo 2 voies uniquement) et est très transparent. Seul regret , pas d'entrée RCA (mais il n'y a pas trop la place à l'arrière, il est vrai)
Christophe m.
Très bon produit et très bon conseil de Audiophonics.
Je recommande ce produit ainsi que la qualité de service de Audiophonics
Ivano D.
Filtro antirumore 230V
Sono soddisfatto del prodotto di cui nemmeno sapevo dell'esistenza. Risolve problemi di disturbi provenienti dalla rete di alimentazione. Molto soddisfatto dell'acquisto
Ivano D.
Alps 100k stereo
Ottimo potenziometro professionale che non necessita di commenti. Produttore giapponese che è sinonimo di qualità. Completamente soddisfatto.
Miguel O.
Miguel O.
Très bon amplificateur. Excellent rapport qualité / prix. Construction robuste. Son avec de très bonnes basses, une bonne scène sonore et un excellent timbre.
Très bon connecteur
Concernant ces prises bananes,pour le prix elles font le travail qu'on leur demande : le système de verrouillage permet de bien bloquer sur les enceintes ou amplificateur
Seul chose a signaler,il serait judicieux d'indiquer dans le descriptif la taille du tournevis torx(la il faut un T6) pour serrer les vis.
Hubert L.
Mise en route sans souci, doc bien expliquée. Etre précautionneux pour les sorties HP car elles sont proches les unes des autres.
Pour la mise en route de la télécommande, bien lire la doc car il faut l'initialiser. Le son qui sort dans mes enceintes est tout à fait correct et aussi bon que celui que j'avais avec mon ampli Hifi ancienne génération. J'ai testé toutes les entrées.
Comme en plus, je désire écouter mes disques vinyle, je vais devoir acheter un préampli phono, mais c'est évident car le niveau de tension est insuffisant à la sortie de la platine. Je suis satisfait de mon achat. L'encombrement est réduit et l'utilisation est simple.
François D.
Publicité qui tente a induire en erreur le consomateur
Je viens de recevoir ma commande, et oh surprise, je n'ai reçu qu'un métre. Et je viens aprés reception, et uniquement dans la fiche technique que ce produite est vendu au métre, alors que sur la photo du produit, ont peut voir une belle bobine. Et même sur ma commande la longueur du cable n'apparait pas. Je crois que je vais rechercher un site, qui ne vous induit pas en erreur. Adieux Audiphonic.
Thierry C.
MINIDSP IR V2 IR Remote Control NanoSharc / MiniSharc / Open DRC / DDRC88/22/24 / NanoAVR-HDA / SHD This MiniDSP IR Remote V2 is pre-programmed for use with the brand's devices. No configuration is therefore necessary.
Excellente
Je l'utilise avec un 2x4 HD qui est disposé latéralement donc récepteur caché, aucun problème, peu directive et répond bien. Agréable en main aussi. Côté Audiophonics, je précise que l'expédition a été immédiate et rapide, bien emballée, cela concerne aussi le miniDSP commandé en même temps. Merci !
Thierry C.
Je l'utilise configuré tel que fourni c.a.d. 2 voies par canal. 1er essai sans rien changer donc partage à 1000 Hz/48dB/oct. sans réserves question distorsion, bruit de fond, transparence, ouverture, on l'oublie, la séparation est d'une efficacité parfaite (j'avais un filtre actif analogique). Ensuite passé à 200 Hz/24dB pour mes large-bande + grave sur baffles ouverts, encore mieux. Réglages faciles, pas de distorsions audibles, pas de clipping, en sortie 2 amplis stéréo pot. entre 25 et 30%. Mesures avec R.E.W. et Umik1 partagé avec un ami, export/import fichier facile aussi, mais c'est là que ça se corse, il faut apprendre à ne pas en abuser. A ce stade mon impression est que la recherche d'une courbe vraiment linéaire est peut-être une fausse piste mais je n'ai pas assez de recul, il faut expérimenter et il y a de quoi faire, surtout si on s'aventure du côté des filtres F.I.R.! . En tous cas je ne regrette pas, c'est un outil sérieux, pratique, efficace. Un petit bémol, je comptais lui dédier un mini pc Asus avec Windows XP et je n'ai pas pu faute de compatibilité du logiciel fourni avec je crois Adobe AIR (nécessaire en version récente refusée par XP), dans les fichiers fournis il y a pourtant un pilote pour XP-Vista ce qui induit en erreur, mais ce n'est pas grave. L'interface de commande/synchronisation est un peu rustique mais fonctionne très bien. Donc je suis très satisfait et aussi très conscient du chemin à faire pour en exploiter les possibilités. Très intéressant !!!
Sylvain R.
Etonnant vu son prix
Préampli acheté pour remplacer un volume passif avant une paire d'enceintes actives Bang & Olufsen Beolab 6000.
Je cherchais à avoir les corrections grave/aigu qui me faisaient défaut, la présence des tubes était la cerise sur le gâteau.
Une fois branché, quelle surprise !
Avec les tubes 6K4 d'origine, le son prend une spatialisation étonnante, il n'est plus "projeté" par mes enceintes, mais se matérialise dans mon salon avec une foule de détails, notamment les réverbérations des salles de concert. C'est bluffant.
La contrepartie de cette reproduction "holographique", ce sont les voix qui sont reléguées en arrière plan et qui manquent de vie, avec un aspect limite synthétique.
J'ai un son qui me correspond mieux avec les tubes 6J1 vendus sur le site. Les mediums reviennent, les voix reprennent leur place, avec la rondeur qu'on attend d'un préamp à lampe. On perd pas mal de cette spatialisation étonnante des 6K4, mais c'est plus polyvalent tout en restant détaillé et vivant.
Les 6J1 sont très sensibles à l'environnement électromagnétique, éloignez votre box internet ou votre mobile qui peuvent parasiter le son.
Prochain test : les tubes GE 5654 que j'ai hâte de recevoir !
Jacky P.
Amplificateur à tubes.
Transformateur pour un amplificateur à tubes 4 x EL84 et 2 x Ecc83.
Réalisation professionnelle et conforme aux spécificités indiquées à la commande:
- sortie 1 HT 230/0/230. 150mA x 2. + Ecran.
- 2 sorties BT séparées: 6,3 v. / 3A. chaque.
Surprenant pour le prix
Je l'utilise en mono cablage (donc 2 câbles par polarité),et a ma grande surprise c'est bien mieux que le modèle monocablage 2S11F:le son est moins crispé,l'image steréo est plus large et profonde si l'enregistrement est bien fati,le grave moins "pneumatique".
Pour ma modeste installation, c'est parfait.
Fabrice D.
Boîtier recommandé à 100 %
J'ai passé pas mal de temps sur le site d'Audiophonics pour trouver LE boîtier qui conviendrait à mon projet d'ampli classe D DIY.
Quand j'ai vu celui-ci et qu'il correspondait à mes critères (dimensions intérieures et extérieures, qualité des matériaux et de construction, aspect esthétique, prix), je n'ai pas hésité.
Au déballage, la première impression est très bonne : çà sent la qualité à tous les étages ! Lors du montage (attention, pour les moins bricoleurs, il n'y a pas de notice mais il n'y a rien de bien compliqué en même temps), on s'en rend compte immédiatement car tout tombe en face, les fraisages pour les vis sont parfaites, il n'y a pas de jeu et rien ne force.
Si l'aspect esthétique vous convient, que vous cherchez un boîtier 100 % aluminium et qu'il rentre dans votre budget, alors foncez !
La cerise sur le gâteau serait peut-être de revoir la couleur de la visserie. Celle qui est livrée est de couleur argent, je pense que le boîtier serait encore plus joli avec une visserie noire... mais c'est une histoire de goût !
Ioannis P.
Excellent cable from an excellent retailer
Furutech Powerflux is indeed a step up from lesser models. The detail and ambience increase is not at the expense of tonal balance.
hugo g.
+ 1 pour la facilité d'implantation
Très bon DAC, presque plug and play avec RPI, configuration en deux clics.
Niveau audio une belle qualité mais qui nécessite de pousser un peu le volume, commun pour deux nombreux DAC. Couplé avec Moode et un ampli rega +dali zensor. La 5e étoile sera lorsqu'une solution de shutdown du RPI sera intégrée, et la 6ième lorsqu'il sera possible de ne pas lancer automatiquement le RPI. En effet, si vous utilisez le bluetooth par exemple, la dernière source est mémorisée, mais le RPI sera lancer quand même avec l'alimentation de la carte. Le paramètre idéal serait que le RPI soit alimenté uniquement lorsque la source RPI est sélectionnée. A suivre
Denis Gabriel G.
Apres un an toujours plus jouissif , mais...
Après un an d'écoute, je remets mon grain de sel.
La qualité du Quloos m'a amené à changer : mon steamer, mes enceintes et mes câbles.
Comme le souligne Jean-François C. une mauvaise association peut lui être fatal. Dans mon cas, le changement d'un câble audio USB a rendu les aigus agressifs. C'est seulement avec l'arrivée d'un nouveau steamer (ALLO USBridge Signature) que j'ai pu utiliser le câble.
Donc vigilance, car l'incroyable précision du Quloos peut être aussi son pire ennemie.
Mais avec de bonne associations, je n'ai pas trouvé une tel qualité sonore (j'aime l'ultra précision) dans d'autre système (ampli+dac) qui coute jusqu’à 10 fois plus chère.
Frédéric M.
HIFIMAN SUNDARA V4 Planar magnetic Open Headphone High sensibility 94db The Sundara Hifiman offers many benefits with its lightweight diaphragm, 94dB efficiency and 32 Ohm impedance for a wide range of use for nomadic or sedentary High Fidelity...
Pourquoi payer plus cher quand on frise le parfait
Ayant en ma possession un AKG K-702, j'étais à la recherche d'un casque moins analytique et pas des aigus "métalliques". C'est désormais chose faite avec le Sundara. A la première écoute, j'ai eu la sensation d'un scène sonore plus réaliste et une plus grande proximité avec les musiciens. C'est un casque assez remarquable sur tout le spectre avec un mention spéciale pour le bas médium qui est excellement restitué. C'est un casque qui s'accommode avec tous les styles musicaux, peu de casques peuvent se targuer d'une telle qualité. J'écoute essentiellement du jazz et du classique, un pur bonheur! Je continue de faire des écoute comparatives avec le K702 mais le Sundara le surpasse sur tout les plans. Bref, un casque d'une très grande qualité et dont la concurrence à ce prix a de quoi frémir.
Matthieu L.
PUISSANCE, DOUCEUR et TRANSPARENCE
Voilà quelques semaines que mon Master19 "tourne" tous les soirs, à raison d'une ou deux heures à chaque fois, exclusivement pour alimenter mon casque orthodynamique Kennerton Thekk (et ponctuellement un très modeste AKG K702 par curiosité). L'ampli est alimenté via les XLR par un dac RME ADI2 FS, lui même alimenté par un streamer SOTM SMS200 Neo qui reçoit un flux issu soit de Qobuz soit de mon NAS Synology. Le tout est connecté avec des câbles blindés Pangea. Pour le moment mon Thekk est connecté en asymétrique au Master19 via la 6.35.
Je ne vais pas rentrer dans les détails et vais essayer d'être synthétique, sachant que mes 2 amplis sédentaires que j'ai en parallèle et qui me servent ici de référence sont un Sugden Masterclass HA4 et l'ampli du RME ADI2 FS. Donc ce qui prédomine à mes oreilles avec ce Master19 c'est une grande douceur générale, qui je crois est assez typique des VRAIS appareils ClassA (comme mon Sugden). Le rendu, sur l'ensemble du spectre est pleine de matière, organique et douce, voire suave. On est à l’opposé du rendu de l’ampli du RME ADI2, qui lui est très sec, chirurgical, hyper détouré mais sans élégance, et peut même devenir fatigant bien que mon casque ne le soit pas du tout. Ce que j’entends également, c’est un très grand équilibre général avec le Master19 et mon Thekk. Je ne ressens pas une mise en avant d’une partie d’une spectre, ou au contraire un retrait d’une autre. Tout semble a sa place, c’est transparent. Cette électronique me semble retranscrire fidèlement les scènes sonores que j’ai écouté, avec beaucoup d’espace dans les 3 dimensions. Les timbres que je connais bien me sont apparus très réalistes, et très beaux. Les voix sont absolument superbes, autant les voix féminines que les voix masculines. Alors que l’ampli du RME laisse facilement entendre des “tssssss” et autres sifflements pas très agréables, le Master19 donne beaucoup plus de matière. Finalement, cet ampli ne s’éloigne pas tant de mon Sudgen, mais je crois qu’il apporte un petit plus d’espace dans les scènes sonores, et encore plus matière sur les voix.
Alors sur l’appareil lui-même, vu de l’extérieur ça respire le sérieux, la solidité. C’est un ampli qui progressivement chauffe fort. Au bout de 2 ou 3 heures, la surface atteint les 40°C. Il semble avoir une forte réserve de puissance, un peu comme mon Sugden dont la puissance n’est pas annoncée par le fabricant. Mais difficile de comparer les 2 amplis car les 2 potentiomètres ne fonctionnent pas de la même façon (celui du Master19 n’est pas linéaire). Avec mon Thekk qui est à 100dB et 35Ohm, en gain faible, j’écoute autour de 55 (sur 99), ce qui donne un niveau d’écoute déjà assez “confortable”. La précision du réglage du volume est excellente. Le cliquetis des relais du système de potentiomètre est curieux, mais pour moi pas gênant.
J’ai tout de même un reproche ou un souci à signaler: avec mon Thekk, un “hum”, un bruit de fond à peine audible, est perceptible à vide. C’est une sorte de bruit de transformateur, indépendant de mon installation tant audio qu’électrique. Audiophonics a constaté ce phénomène également sur un casque à faible impédance lorsque j’ai signalé le souci au SAV. J’ai fait de mon côté des essais avec des IEM à très faible impédance: le bruit est effectivement encore plus fort qu’avec mon Thekk qui fait 35Ohm. Mon K702 qui fait 62Ohm n’émet aucun “hum”. La solution, d’après Audiophonics, serait une connexion du casque en XLR. J’ai donc commandé un cable symétrique XLR que j’attends. Je referai un retour ici une fois les essais réalisés, en croisant les doigts pour que ce léger défaut lié à l’impédance faible de mon casque disparaisse en symétrique.
Jean-Philippe C.
tres bon module. J'avais précédemment un DAC allo katana. J'ai surtout testé l'entrée RPI. Je trouve ce DAC légèrement meilleur que le katana bien qu'éventuellement moins précis/analytique (le katana était a cet égard surprenant mais fatiguant). Ici la sonorité est douce, enrobée, mais le son de chaque instrument rest bien distinct. Certaine personnes pourraient éventuellement lui reprocher un leger manque de percutant (probablement le prix a payer pour avoir un son si velouté). Les sorties XLR ont un niveau sonore bien plus important que les sorties RCA et limitent ce manque de percutant.
J'ai essayé le BT en lecture video, je pense que ce n'est pas aptx car il y avait un décalage important. Je n'ai pas essayé de regler volumio ni de passer sur mood pour regler cette latence. C'est peut etre faisable.
Jean-Philippe C.
belle qualité sonore pour une solution tout en un. Son chaleureux, une scène sonore d'une amplitude époustouflante. Le seul défaut selon moi est un son légèrement brouillon.
Frédéric A.
Les meilleures pour moi !
J'ai passé beaucoup de temps à faire du tube rolling pour mes ECC83 et c'est bien celles-là qui sortent du lot, NOS compris ! (meilleures que des Baldwin black plate !)
Elles sont très fines en haut avec des graves parfaits, profonds et tendus. (sur mon ampli Cayin MT45 mkII)
A essayer absolument avant d'investir plus dans du NOS...
Pierre L.
Pierre L
Superbe production de Furutech. Par comparaison à d'autres produits de la marque , pour d'autres applications, il est vrai, ce produit ci est celui qui m'a le plus impressionné. Il est bien supérieur à la pièce d'origine Sennheiser qu'il remplace (pour casque HD 650) en n'amputant pas le message audio. La scène sonore est respectée avec les divers instruments en place, dans la totalité de l'espace. Les micro-détails de la prise de son initiale sont restitués entièrement et sans impression de filtrage.
Schématiquement les trois registres s'ouvrent et gagnent en clarté et précision . Chez moi le médium vient se placer davantage en avant....mais ceci est une caractéristique du HD 650 et pour l'instant une écoute réalisée avec ce casque sur un seul matériel, ROTEL préampli RC 1590.
Acheté et testé en même temps que l'adaptateur Hicon (ce dernier équivalent à la pièce d'origine Sennheiser) ,
compte tenu des sommes engagées ,
l'adaptateur FURUTECH F35 s'avère être le produit que je peux vous conseiller, si comme moi, vous avez besoin de retrouver ce genre d'adaptateur.
Sebastien w.
super !
Construit comme un tank , ce petit contrôleur de volume m'assurera des années de bon et loyaux service .La qualité sonore est au rendez vous assurer par un potentiomètre de marque ALPS haut de gamme . Merci Audiophonics !
Galeb S.
Perfect case for DAC
I've received this case in perfect condition. As described. Perfect for headphone preamp or DAC.
Gaetan g.
IBASSO DX150 DAP HiFi Music Player DAC 2x AKM AK4490EQ 32bit 384kHz DSD The new iBasso DX150 is a high end DAP based on a solid structure. Dual DAC AK4490EQ, symmetrical design, USB XMOS, interchangeable amplifier. A must have!
qualité de son parfaite mais ergonomie fait défaut
J'ai un ibasso DX90, d'un autre age , sauf que le constructeur n'a pas amélioré son soft pour le rendre accessible à l'utilisateur. C'est franchement dommage, je voulais changer mais changer pour avoir un appareil qui me permette d'avoir tout ce que peuvent offrir les appareilss de ce type en 2020: android accessible, bt fiable, wifi , connexion sur spotify etc ..L’équipe audio phonic m'a aide pour paramétrer le dx 150 et je les remercie. J'ai du demander un retour.
Carel v.
Very happy
I combined this unit with the Khozmo passive amplifier. The result exceeded all my expectations.
Sandras Z.
San
Sounds good, but lacks high frequency. Not the whole spectrum. Rather already middle and bass
Gabriel A.
Un produit absolument génial
Je dispose de deux Sonos Port et ces lecteurs réseaux disposent de sorties trigger 12v.
Cependant, mes enceintes actives n'en possèdent pas.
Je cherchais une solution pour les piloter sans bouger du canapé et ce boitier a résolu avec brio cette problématique.
J'ai modifié la prise électrique de la multiprise avec une prise IEC C14, et tout fonctionne au poil.
Au final, ça reste un "interrupteur", ce n'est pas donné, mais le produit est très bien construit et est relativement unique sur le marché.
Note pour les futurs acheteurs qui ont des Sonos Port: inutile de prendre un cable jack mono, les cables jack stéréo fonctionnent parfaitement.
Frederic P.
IBASSO CA01 Female Balanced Jack 2.5mm to Male Single-Ended Jack 3.5mm Adapter OFC Copper Gold Plated 10cm The iBasso CA01 is a jack adapter composed of a 2.5mm balanced female jack connector and a 3.5mm unbalanced male jack connector. Its 4 twisted conductors are made of high purity...
arf dommage
Dommage c'est exactement l'inverse qu'il me fallait..2.5 symétrique male vers 3.5 asymétrique femelle..la loose. J'ai acheté un adaptateur sur vos site mais ça ne marche pas avec tout les connecteurs 3.5.. avec certains ça ne doit pas bien tomber en face
Jean Luc B.
Bon coffret pas cher
Deuxième coffret de cette gamme que j’achète, pas si "Eco" que ça, le rapport qualité très bon malgré tout.
les deux parties noir sont bien rigides, les rails interne aussi, seules les façades alu gagneraient à être un peu plus épaisses, au moins 1,5/2mm, car au perçage elles peuvent se déformer.
En plus on peut facilement leur faire un habillage bois.
JL
YARBO SP-FE003 Speaker Cable OFC Copper 2x1.27mm² Ø3.5mm This Yarbo speaker cable with an excellent price-performance ratio will provide you with excellent transmission thanks to its structure composed of many OFC copper strands. It...
pourquoi pas ?
il n est pas mauvais ce câble mais quand on a entendu le jentzen du catalogue audiophonics on trouve que ca partie medium est bien moins transparente .
pour le reste et au prix bravo , ce câble n est pas ridicule .
mais au prix proposé à tester quand-même .
quel câble !
dans ma configuration et au prix proposé ce câble est terrible et du niveau de certains modèles ésotériques à x milliers d euros, mais je confirme les autres commantaires son petit frère va plus loing en terme de transparence , ce qui lui coûtera la récompense ultime .
il trouvera tout de même sa place au sein d une installation haut de gamme sans problème.
impressionnant !
LAURENT G.
Rapport qualité prix exepionnel.
Excellente prise rca,de très bonne qualité. Finition laquée de bonne facture.a recommander sans réserve pour le prix proposé.
Hans S.
Ampli of high quality
I replaced my 35 years old Technics amplifier with this Hypex Ncore endstage in combination with the Loxjie DS30 as preamplifier. Connected to speakers from TEUFEL UL40-MK2. I read some articles and test reports a few month ago. I really don't regret this purchase. One word only, WOUW, what a difference. What a gain on low frequencies, strait, dynamic, ...etc. A real pleasure to listen to my music.
Bruno l.
A essayer en parallèle avec le Mogami W3103
Cela fait plusieurs semaines que j’ai acheter les câbles HP qui sont le plus plébiscités sur audiophonics, le Mogami w3103 et l’Elecaudio HP-25O OCC / OFC.
J’ai déjà laissé des commentaires sur le sujet, et après plusieurs semaines, je confirme mes premières impressions,
L’élecaudio n’a pas le coté velouté du 3103, mais il a l’articulation et l’absence de tonique propre aux câbles OCC. Ce câble est très neutre, mais il laissera passer les toniques désagréables de certains enregistrements et il manque un peu de matière en bas.
J’avais beau essayer toutes les combinaisons de câble, je suis en tri-câblage et quadri-amplification, je n’étais jamais pleinement satisfait.
Et puis un peu en désespoir, j’ai fais ce qu’on ne fait jamais, j’ai mis le Mogami W3103 en parallèle du HP-25OCC.
Dès le premiers morceau j’ai pris une grosse claque. Ce câble mixte n’a pris que les bons cotés des deux câbles et aucun des défauts!
Avec ces deux câbles en parallèle, on a une bande passante hyper large, des graves chaleureux mais tenus, des médiums magnifiques avec une image en cinémascope, des aigus sublimes, de l’articulation, de la richesse et du rythme. On peut écouter très bas et monter le volume très haut sans avoir mal aux oreilles.
Bref je touche plus à rien, c’est sublime. Ok ça fait un câble de 9 mm², ça rentre un peu au chose pied dans les borniers et personne ne fait cela ! Mais je vous encourage à faire l’essai, vous ne risquez rien, chacun de ces deux câbles est déjà un très bon câble. Mais en parallèle ils sont sublimés.
Le prix au mètre, revient à 27€, ça commence à faire, mais c’est bien moins cher et bien plus efficaces que les câbles ésotérique qui découpent la musique en rondelles au lieu d’en faire.
L’idéal serait qu’Audiophonics fabrique ce câble sous gaine en montant des fiches ou des fourches, parce que le dénudage / montage n’est pas forcement facile pour tout le monde. Mais quel résultat !
Bruno l.
A essayer absolument en // avec l'Elecaudio HP 25 OCC
Cela fait plusieurs semaines que j’ai acheter les câbles HP qui sont le plus plébiscités sur audiophonics, le Mogami w3103 et l’Elecaudio HP-25 OCC / OFC.
Bart B.
MEAN WELL RS-50-24 Switching Power Supply SMPS 50W 24V 2.2A This switching power supply from Mean Well offers a power of 52.8W, a voltage of 24V DC and a current of 2.2A. With a universal connection system, it will fit easily into a...
top
top delivery and top quality!
I'll be back!!
Gilles V.
A vrai dire pas assez de recul. Fait le job mais ne sait pas si 40 euros se justifient par rapport au modèle à 20 euros (voir un autre modèle moins cher). En tout cas la construction semble sérieuse.
Dominique D.
avis positif
produit solide et bien construit. A l'écoute, ce dac transforme radicalement la qualité de la musique. Le test avec et sans en sortie du Mac vers mon casque Focal est édifiant comparable l'écart GO et FM sur une radio. La différence est peu perceptible sur mon système HI FI avec ampli Onkyo. Le prix contenu est la cerise sur le gâteau
Chantal T.
FX-AUDIO DAC-X6 MKII DAC Headphone Amplifier Bluetooth 5.0 aptX ES9018 QCC3008 24bit 192kHz Silver FX-Audio X6 MKII is an ideal solution for your compact, affordable and high-performance audio systems. It works both as a DAC with volume control and headpthone...
OK
Produit correspond parfaitement à mes attentes (peut-être niveau de sortie analogique un peu faible....).
délai de livraison excellent
charmeuse
Bonjour , schuko furuetch fi 38 mis sur ma murale oyaide or , douceur exquise, medium lisse et plein, aigu doux filé, basse precise et dynamique ,tonalité chaude je dirai pour moi la meilleure schuko que j ai testé ( viborg or ,rodhium,iego or,neotech,charlin, ) bonne construction sans plus, pour systeme un peu dur ou froid le top. Franck
pierre h.
Exellent Fonctionne niquel
J'ai acheté ce produit pour remplacer des condensateurs de filtrage de mon ampli Marrantz , rien a dire je n'ai aucun parasite.
Je recommande.
bon transfo mais...
bonjour
Je l'ai déjà signalé mais ça n'a pas été corrigé , si on le branche comme vous dites le transfo va grogner.
D'une part il n'y a pas de fil orange mais rose ( en tout cas sur le mien) et c'est ce fil rose qu'il faut connecter avec le gris.
L'alimentation se fait sur les fils rouge et noir tout simplement comme d'habitude.
