MENNEKES SCHUKO SCHU-FC230/16PSW Power Connector Schuko Type F
This robust and durable Mennekes female Type F Schuko connector allows you to design high-quality extension power cables at a low cost. Compatible with cables up to 13mm in diameter, it ensures easy installation thanks to its screw-on system, with no soldering required.
Reference : 21904
17,91 €tax incl.
14,92 € tax excl.
Shipping date: 01-12-2026.
Mennekes SCHU-FC230/16PSW Power Connector Schuko Type F 16A Ø13mm
Schuko connector Mennekes SCHU-FC230/16PSW
Product typeFemale schuko connector
Country of manufactureGermany
Body materialPlastic
Ground connectionYes
Type of assemblyScrew-in
Voltage / Current230V 16A
Max. cable diameter13mm
Max. conductor cross-section2.5mm²
Dimensions109x61.7mm
Weight114g
PackageSold individually
Max cable diameter (mm)13.0
Mounting typeTo screw
ConnecticFemale
ConnectorSchuko
Contacts Plating (Connector)Nickel
Rated current (A)16.0
MENNEKES SCHUKO SCHU-FC230/16PSW Power Connector Schuko Type F 16A Ø13mm
This robust and durable Mennekes female Type F Schuko connector allows you to design high-quality extension power cables at a low cost. Compatible...
