KIWI EARS ORCHESTRA II In-Ear Monitors IEM Silver
The Kiwi Ears Orchestra II in-ear headphones are designed with ten balanced armature drivers to deliver immersive sound and deep bass, covering a frequency response of 20Hz to 20kHz. For ease of use, a detachable silver-plated monocrystalline copper cable is supplied with 3.5mm and 4.4mm jack connectors.
By buying this product you get 36 loyalty points
Reference : 21888
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 12-11-2026.
Kiwi Ears Orchestra II In-Ear Monitors IEM 10x Balanced Armature 15 Ohm 110dB 20Hz-20KHz Silver
Miniature depicting the Kiwi Ears Orchestra II
The Kiwi Ears Orchestra II in-ear monitor are designed with ten balanced armature drivers to deliver immersive sound and deep bass, covering a frequency response of 20Hz to 20kHz. For ease of use, a detachable silver-plated monocrystalline copper cable is supplied with 3.5mm and 4.4mm jack connectors.
Kiwi Ears Orchestra II: Internal Design and Performances
The Orchestra II is equipped with ten drivers per ear, enabling it to deliver clear sound with powerful bass and rich mid-range tones. The transparent subwoofer drivers produce deep, punchy bass. All of this results in a frequency response ranging from 20Hz to 20kHz and a sensitivity of 110dB.
Photo of the Orchestra II in-ear headphones
Graph showing the frequency response of the Orchestra IIs
Image showing the Orchestra II worn on one ear
Kiwi Ears Orchestra II: Ease of use
To allow you to immerse yourself in the sound, the Orchestra II features a design that completely blocks out ambient noise thanks to its housing filled with acoustic resin. This same transparent acrylic housing minimises acoustic resonance. For even greater convenience, the silver-plated monocrystalline copper cable is detachable and features two 0.78mm pins (CIEM), and can be adapted to suit your needs with 3.5mm and 4.4mm jack adapters.
Product typeIn-ear monitors
Speakers10x Custom balanced armature
4x Way Crossover
Headphone plug0.78mm 2 Pin (CIEM)
Impedance15Ω
Sensitivity110dB
Cable termination connectors3.5mm Jack
4.4mm Jack
Cable conductor materialSingle crystal copper silver-plated
Cable length1.22m
ColorSilver
Weight51.28g
Package1x Kiwi Ears Orchestra II
1x Single crystal copper silver-plated cable
1x 3.5mm Jack Connector
1x 4.4mm Jack Connector
12x Pairs of ear tips
ColorSilver
Impedance (Ω)15
Efficiency / Sensitivity (dB)110
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionYes
KIWI EARS ORCHESTRA II In-Ear Monitors IEM 10x Balanced Armature 15 Ohm 110dB 20Hz-20KHz Silver
The Kiwi Ears Orchestra II in-ear headphones are designed with ten balanced armature drivers to deliver immersive sound and deep bass, covering a...
