Jerome L.
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Didier G.
Très bon rapport qualité-prix
A mes oreilles, câble équilibré, transparent, dynamique, sans les excès des câbles utilisant l'argent
Didier G.
Interface très musicale
La MATRIX X-SPDIF 2 avait amélioré la restitution de mon système audio.
L'AUDIO-GD va plus loin et de manière significative : articulation, fluidité, matière, image, caractère chantant.
(utilisée avec un Holo Spring I level 2 - entrée I2S).
A noter un rodage long.
Excellent produit.
Goetz V.
sockets can break
the whole concept, design, finish and shape are nice, and there seems to be no substitute for this distributor. but i experienced one socket to break internally - its plastic parts actually crumbled beyond repair. it is a weakness of the sockets, so i am afraid of further sockets breaking over time. mine right now is an 'ELECTRA 7'...
Alexander D.
Excellent headphone
Thank you Audiophonics for all your support!!
Yngve I.
Superb
If you have the means, buy !!!
stephane s.
bon produit rien à dire pour l instant , je viens de le monter
livraison nickel
Nico V.
Nick
Light weight XLR plug but the materials they use are excellent
Nico V.
Nick
Nico V.
Nick
Nico V.
Good price for top matierial
Gilbert H.
Facilité de montage
Simeon W.
Very nice
Lucien L.
Lucien L.
WINYL STYLUS DUO CLEAN Turntable Needle Cleaning and Rinsing Solutions This Winyl kit contains 2 bottles specially designed to preserve the purity of the cleaning and rinsing solution. These products are a complete and effective solution to...
Efficace et économique
PHILIPPE D.
preampli casque
philippe
Yngve I.
Great
Highly Recommended .
DAYTON AUDIO DSA115-8 Speaker Driver Woofer / Midbass Aluminium 35W 8 Ohm 86dB 63Hz - 11kHz Ø10.2cm This DSA115-8 bass/low-midrange driver supports a power of 35W RMS (70W max) for an impedance of 8 Ohm. It is capable of reproducing a frequency range from 63Hz to 11kHz. Its...
HP DSA115 DAYTONA
alexandre g.
excellent ampli
le lm 3886 est un tres bon petit audiophile moi je l'ai monté avec un dip 8 de chez jrc 5534m et la le résultat est tanscendé je possede encorre ce montage et je m'en lasse pas écoute pleine d"aeration basses profondes et percutantes medium clair image sonore tres charpenté et ample il faut juste le me modifier un peu je lécoute avec des enceintes fostex tres haut de gamme que j"ai monté moi meme le résultat est divin
alexandre g.
ampli tda 7293
je possede cet ampli depuis trois ans c'est un tres bon ampli qui develope une belle image sonore ample l'aigu file tres haut un tweet tissu est requis et il faut le modifier changer le dip8 et on retrouve une machine audiophile qui a surpris plusieurs amis fan de matos trs couteux
Wayne O.
PANGEA PREMIER SE BALANCED XLR Modulation Cable Balanced XLR-XLR 1m (A pair) PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design, the first...
An excellent XLR Balanced cable,properly designed.
Before using this cable I always had a very slight noise
in my right mono block amp/and no matter what I did
I could not eliminate it.With this cable it was instantly gone,
And of course it's construction quality is superior.
Thank you
Wayne AU
Wayne O.
What can I say,that has not already been said.
What I can say that I received,
from Audiophonics.
The Best Deal
The Best Customer service
The Best Shipping
The Best communication
And of course the Best DAC/Preamp
available, this device changes everything
Thank you
Wayne AU
Cédric B.
Très bien à part la sortie casque
Très satisfait de la qualité sonore avec mes enceintes eltax 3 et l'entrée en USB depuis l'ordinateur ou en bluetooth depuis une tablette ou téléphone.
Cependant il y a un défaut sur la sortie casque je pense. Il y a des craquements de volume constant (quel que soit le volume de sortie), faible mais audible dès que la musique s'adoucit. Je l'avais commandé juste avant le début du confinement, donc compliqué de le retourner mais si c'est un défaut déjà observé, j'aimerais en savoir plus sur les origines et les solutions possibles.
Matthew R.
Excellent amp, great value
Great-sounding amp: neutral, clean, effortless. Component-style chassis fits perfectly with other equipment, with ample heatsinks. Speaker connectors are good quality and easy to use. Front-panel power button is smooth. Plenty of power, great modules.
For someone moving from traditional Class A/Class AB to Class D, this amp provides 25dB of gain, very close to the traditional 26-29dB that most Class AB amps provide. This enables this amp to fit nicely into an existing system with nothing more than a minor volume adjustment to your preamp or source component.
Customer service was excellent - personal emails, updates on when it was being assembled and when it was shipped, with full international tracking.
Only things to be aware of are the the RCA/XLR toggle switches on the back are not labeled (down is RCA, up is XLR); and the front power LED is a little bright and not dimmable.
It's currently impossible to beat the price and value here: full-size metal case with two Purifi modules for under 1500€/$1400US. Well done, Audiophonics!
Christian O.
lecteur cd
Lecteur cd qui fait parfaitement son job. Shanling c'est le générique de la hifi : la technique rien que la technique. Comme le disait Léonard de Vinci "la simplicité c'est la sophistication suprême". Je recommande ce produit.
Guy L.
Bonne qualité, correspond à mon attente
Bart V.
Good webshop; fast plus good communications. Only minor caveat I have is the site is only partly in English -technical data etc are in French, but same info in English is easily found elsewhere. Will shop here again.
Pierre P.
excellent régulateur
Son bruit de 40µV est très faible. D'après mes calculs cela correspond à -117 db, ce qui est largement suffisant pour nos applications audio.
Pierre P
Francois B.
Appareil de qualité
Bonne qualité audio avec les lampes d'origine.
Il me permet d'adapter la sortie d'un vidéoprojecteur à l'entrée d'un ampli. Il est juste dommage qu'il ne mémorise pas sa dernière configuration. I démarre systématiquement en mode bluetooth.
Patrick A.
Une bonne approche pour un prix très réduit
Ce produit, indispensable il est vrai, et qui est d'ailleurs proposé sous différentes marques et dont le tarif va du simple au double est du pur made in China. Moulage approximatif qui fait que même avec 4 pastilles caoutchouc pour faire les pieds, la balance n'est pas plane, j'ai du décoller légèrement un pied pour rattraper l'horizontalité. Ensuite, oui, c'est précis à 0,01g près sauf que plusieurs mesures prises à un moment différent donnent 0,05g de différence. J'ai donc refait la tare avec le poids de 5g livré mais qui me semble vraiment trop lourd pour notre usage, pour voir... Pour mémoire la balance Technics, aussi électronique à jauge de contrainte, se tarait avec un poids de 1,5g, plus proche de ce qu'on a à mesurer en force d'appui. Une réalisation donc pas assez fiable malgré la précision de 0,01g sur le papier.
Angelo P.
sceptique
je sais pas, le module fonctionne mais je suis pas certain qu'il ralentisse vraiment la monter en tension ,ou alors c'est tres rapide . a la mesure au voltmetre je ne vois pas la monter progressive de la tension
Angelo P.
impressionnant
vratment tres bien ces petit module, bon son, puissance largement sufisante, facile a raccorder .
Angelo P.
tres bien
parfait, fonctionne tres bien
Andrea C.
XDUOO XQ-50 Bluetooth 5.0 Receiver aptX QCC3008 DAC ES9018K2M xDuoo offers with its XQ-50 a Bluetooth receiver with integrated DAC very practical, qualitative and affordable. It will allow you to stream your music directly from your...
Impressed
I just connected the XQ-50 to my Pro-Ject Stereo Box S2 via Merlin Mozart cables, and it sounds impressively good (aptx, 320k mp3). Clear and extended, with a sense of 'airy' sound. I'm only considering later replacing the JRC 5532DD with a LT1358 for an even richer and smoother sound.
alexis l.
Bon Ampli 2*50
Reçu aujourd'hui. fonctionne parfaitement. Convient parfaitement à mon besoin qui est d'amplifié la sortie casque d'une radio internet vers 2 HP dans plafond d'une chambre. Bon son et largement suffisant en puissance.
Trés content du produit . A voir dans le temps.
SONCOZ SGD1 DAC Dual ES9038Q2M 32bit 784 kHz DSD512 XMOS U208 Bluetooth 5.0Gray Here is a DAC with volume control based on ESS ES9038Q2M SABRE technologies. It has been warmly welcomed thanks to its many features, as well as its thorough integration of high...
Un DAC d'une grande qualité.
Ce DAC est d'une excellente fabrication et esthétiquement sobre. Outre une connectique très complète il offre un son très équilibré avec un grave bien tenu une image sonore précise et large mais sans excès .
La prise en main est relativement facile, les différents programmes et drivers sont à télécharger sur le site. Parfaitement opérationnel sur Windows 10 et immédiatement reconnu par les drivers.
Si j'ai un petit reproche à faire ce serait sur la notice plutôt sommaire et en anglais. Mais bon! avec un peu patience on finit par maitriser "la bête". La télécommande elle et d'une simplicité parfaite (attention aucune piles livrées avec)
Eric P.
Rectificatif sur avis précédant
J'ai finalement retiré les AOP Burson... Ceux d'origine sont très bien !
J'aurai du lire la notice...
au sujet de mes commentaires et des autres concernant le serrage de cette fiche...la notice stipule qu'au delà de 15 mm on insère la seule pièce de serrage principale et non deux...ce qui rend la l'emboîtement de la fiche dans le corps beaucoup plus aisée.Cette fiche n'a,du coup, à mes yeux aucun défaut.
Frederic F.
Excellent preampli très peu coûteux
J'avais laissé un avis concernant l'utilisation du fx-audio tube 01 en tant que buffer puisque le gain était totalement inadapté pour l'utiliser comme preampli branché sur la section ampli de mon Nad c326.
En réalisant un pont diviseur avec une résistance 47 kohms série et une 1.5 kohms parallèle , sur chaque canal en entrée de l'ampli de puissance,
les résultats sont excellents.
Réglage du volume très fin, scène sonore très large et aérée, belle matière, effet stéréo important, bon équilibre tonal ,relief et vivacité ainsi qu'un petit côté envoûtant...
Mohamed-Nour A.
Stabilized AC/DC Switching Power Adapter 3V / 4.5V / 5V / 6V / 7.5V / 9V / 12V 1A DC This AC adapter has the particularity of offering a switchable output voltage. Thus, it will be able to supply devices requiring different voltages: 3V, 4.5V, 5V, 6V, 7.5V, 9V,...
Très bien, très facile d'utilisation, marche parfaitement.
Mohamed-Nour A.
Très sympa
Tout petit, tout mignon. Je l'utilise avec une carte iQaudio Dac Pro+ qui a aussi les bonnes dimensions. J'apprécie aussi la fente pour la nappe de connection de l'écran officiel 7".
Mohamed-Nour A.
Je l'utilise pour alimenter un Raspberry Pi 3 à partir d'une alimentation de disque dur externe. Marche très bien.
David J.
Alimentation propre
Je viens d'acquérir cette alimentation pour remplacer celle d'origine d'un streamer nuprime Omnia.
Je me suis dis que pour le prix, je ne perdais pas grand chose à l'essayer.
Eh bien je ne suis pas déçu du résultat : silences beaucoup plus pronocés ce que fait aussi ressortir les détail avec plus de netteté.
Il y a également plus de fluidité et de dynamique.
Pour le même volume de son, la différence est flagrante...
Merci Audiophonics pour la rapidité et le sérieux de votre service.
Guido P.
Great cables
I was coming from a Sommercable Elephant 4x4 mmq, and I was quite satisfied with the bass response and the spacial imaging I was having out of my system.
David suggested to me these new cables, and I decided to purchase them.
Once I plugged them, I gave a quick listening and I was not completely satisfied, something was missing. Then I let them play over the weekend and wow, the magic happened.
Compared to my old cables, there is a whole layer of information added to the top, the high frequencies are slightly brighter and detailed and the whole thing is much airier. Mids are great as well, female voices are clear and textured. The incredible thing is I have now much more bass response. Bass is more present and more defined. For letting you understanding: previously I thought my little bookshelf speakers were not great for playing electronic music, now I can quite enjoy it.
Just one note, compared to my Sommercable Elephant, I could define these cables as slightly colder, even if I now those are defined as warm sounding by most of the people out there.
Mario J.
MJ23
Excellent!
Renaud O.
Un excellent DAP
Suite à la bonne réception, découverte, prise en main et premières utilisations du baladeur iBasso DX120 et des écouteurs iBasso IT01...un petit retour d’expérience qui peut-être apportera un complément aux divers avis et autres "unboxing vidéos" vus sur la toile ;)
Partant d’un baladeur Fiio X3 (1ère génération, remplissant bien son job mais devenant limité et avec de simples écouteurs semi intra auriculaires plats lambda).. j’ai nulle doute, atteint gros "gap" qualitatif et ergonomique indiscutable.
Commençons par les écouteurs iBasso IT01 : l’appréhension sur l’inconfort que j’avais vis-à-vis de la pénétration nécessaire des écouteurs intra-auriculaires s’est rapidement dissipée.. grâce notamment aux multiples disponibilités d’embout mis à disposition et les possibilités de pouvoir changer à sa convenance ces derniers.. Après les avoir tous essayé, mon choix a retenu la paire "à mémoire de forme". Côté restitution sonore, à chaque fois que j’utilise ces écouteurs le rendu est chaque fois meilleur !) À ce titre, un rodage est évidemment nécessaire (comme pour tout HP.. quelque soit sa taille et ici, cela se vérifie aussi ;).
Concernant le baladeur lui-même, le fait qu’il puisse lire tous mes fichiers (wave, flac, DST et DSD) sans difficulté et respect qualitatif est très très bon et bien évidemment, excellent sur du DSD ;)
Les sorties audio dédiées : "casque" (ainsi qu’une mini 2,5 que je n’ai pas pu essayer), "Line out" et "coaxial" sont également bien pensées.
Toutefois, si la sortie casque et la sortie coaxiale sont excellentes voire magistrales, je mettrais un certain bémol quant au niveau du volume de la sortie "Line out", que je trouve assez faible.
Là pour le coup, le niveau de cette même sortie, sur le Fiio X3 (qui dispose des mêmes sorties) est supérieur. J’en suis assez surpris.. je ne l’aurais pas cru, surtout vis-à-vis des autres sorties.
En effet, lorsque je relie la sortie "Line out" du iBasso sur un ampli ou une enceinte nomade (par un câble mini jack-mini jack ou par un câble mini jack-cinch) il faut augmenter significativement les niveaux des volumes, aussi bien du baladeur que celui de l’ampli (essais effectués sur divers amplis, sur une entrée aux d’un auto-radio ainsi que sur une enceinte portative). Mais le rendu qualitatif sonore est heureusement toujours bien présent !)
La coque de protection du iBasso fournie en PVC, transparente, est assez bien conçue malgré qu’il n’y ait pas de protection pour le dos.. c’est dommage. Toutefois, après m’être dirigé vers une "coque MITER" certes d’aspect assez classe, j’en suis revenu ; car celle-ci reste fine et moins protectrice contre d’éventuels petits chocs que la coque d’origine du iBasso, qui, bien plus "dure", a l’avantage de bien envelopper et protéger la totalité externe (côtés, angles et toutes les entrées & sorties) du baladeur.
Côté câbles fournis, je me pose toujours un peu la question de la pertinence du l’utilisation du (joli) petit câble de rodage (..?) visiblement sur le site du constructeur la chose est prévue, mais bon..
Le câble de la sortie coaxiale (se terminant en sortie femelle) est de toute beauté, de bonne facture, mais un peu court et implique donc une "rallonge" nécessaire ;) À noter toutefois que pour lui associer, il faut un câble coaxial avec un embout RCA femelle - mâle (ce qui n’est pas évident à trouver).. Par ailleurs, le diamètre du trou de l’entrée coaxial de la coque d’origine se révèle toutefois un peu petit pour accueillir l’adaptateur fourni par iBasso.. à moins bien évidemment de retirer la coque. Pour ces deux raisons j’utilise donc un autre adaptateur et un bon câble coaxial avec RCA classique (mâle-mâle).
Le iBasso se révèle être un baladeur vraiment "audiophile" de qualité, simple d’utilisation, pouvant lire des fichiers wave, flac DST et DSD (.dff).. et allant à l’essentiel : le SON !)
Je ne souhaitais pas les "gadgets" du wifi, du streaming et autre Bluetooth..(pour cela, mon portable me suffit amplement..).
Outre les trois sorties dédiées, le baladeur dispose aussi d’une bonne capacité de stockage car ici, avec 2 logements distincts pour insérer deux mini cartes sd à forte capacité on est plutôt bien servi !) À ce propos, le constructeur confirme la possibilité de lecture de deux cartes de 2 To...! (mais quand on regarde déjà le prix de celle de 1 To, ça calme..). Toutefois j’ai pu y introduire une carte de 64 Go (en FAT32) et une autre de 512 Go (en EXFAT), toutes deux fonctionnent sans soucis !). Ne pas hésiter de choisir des mini cartes sd de qualité.
Je recommande d’ailleurs pour accéder aux contenus, d’utiliser le menu "Répertoire" qui débouche ensuite sur le choix de "SD 1" ou "SD 2", où l’on peut retrouver SES différents dossiers et fichiers.. tels que l’on les a téléchargés SANS que le baladeur par un autre menu, scanne lui-même les cartes et décline un certain "désordre à sa sauce". J’ai essayé une fois de scanner une carte SD par le menu pour voir.. je déconseille !
La fonction "Répertoire" est simple, directe et respectueuse de son propre ordre, c’est beaucoup plus cool d’utilisation pour la navigation ;)
Pour chacun des dossiers (si c’est bien sûr pas une compilation qui ne reprendra pas forcément les "tags" des différentes pochettes) une fois dedans, après avoir enclenché la lecture d’un fichier apparaîtra comme il se doit, la pochette de l’album joué (quelque soit le format du fichier).
De plus, on a la possibilité d’ajuster le rendu sonore par certaines fonctionnalités. Par un "Égaliseur" d’abord, à 10 bandes personnalisables ou bien utiliser les modes pré-enregistrés (Classique, Pop, Dance, Rock et Basse) mais à ce moment-là, on perd un peu de volume et je trouve que l’enregistrement perd un peu de son authenticité.. je ne l’active donc pas. Par contre, le baladeur propose d’intéressants "Filtres numériques" (dont le très qualitatif "Filtre à pente très douce") et enfin, de différents "Mode sonore" parmi lesquels le mode "Original" est très convaincant :)
Dernier point, la batterie : ne disposant pas de "chargeur rapide", j’utilise pour l’instant le simple chargeur de base d’un iPhone. Le temps de charge du baladeur met un certain temps.. notamment lorsque la batterie est à vide (à 0%) celle-ci comptabilise bien 5 heures pour une charge complète (à 100%). Je déconseille la charge en mode usb reliée à un ordi (à moins de le laisser tourner toute une nuit..!)
Une fois chargé, j’évalue plutôt l’autonomie à 12-13 bonnes heures d’écoute, plutôt que 16 (plébiscitées par le constructeur).
Enfin, je préconise le transfert des dossiers/fichiers sur la micro carte sd en l’insérant dans un ordinateur, ce qui est beaucoup plus rapide, plutôt qu’un transfert via le cordon usb relié au baladeur qui reste une pratique très chronophage.
Pour donc une utilisation simple, allant à l’essentiel, de très bonne qualité, en mode "nomade" comme "sédentaire" et d’un bon rapport qualité/prix, ce iBasso DX 120 rempli avec pertinence mon cahier des charges !)
Je suis globalement très satisfait :)
hilaric j.
MATRIX ELEMENT I DAC Network Player ES9028PRO XMOS WiFi DLNA AirPlay 32bit 768kHz DSD512 The latest addition to Matrix's Element range, the Element I naturally takes up the design basis of the other models, taking advantage of the excellent performance and numerous...
Matrix Element I
Fonctionnalités : 4,5/5, j'ai tout testé sauf le Wifi
Qualité sonore : 4/5 Très bon, mais j'ai écouté mieux. A noter une supériorité de la sortie casque VS la sortie ligne asymétrique, et une meilleure qualité sonore avec Tinysqueeze
Facilité d'emploi : 4/5 (association telecommande / appareil assez délicate)
Appli Matrix Audio : 5/5. A souligner car j'étais un peu inquiet vu certains commentaires sur le net. Fonctionne impec.
Rapport qualité/prix (indépendamment de la note 4/45 intrinsèque) ; 5/5
Il reste à confirmer cet avis en fonction de la durabilité et de la fiabilité de l'appareil au fil des ans.
NB : Je posterai peut être une modif de cet avis dans quelques semaines si la qualité sonore évolue après quelques centaines d'heures d'écoute (bien que je n'ai jamais décelé à l'oreille le 'rodage' des électroniques dont tant d'articles parlent)
Hugues P.
Musicalité.
Possédant plusieurs amplis, tous diy, je dois dire que ce " petit" ampli est très musical. La bande passante est large et maîtrisée. Que ce soit en association avec du haut rendement ou bas rendement cette ampli est un régal. Au dessus du TA2022 en terme de musique charnelle, tout y est. Je le recommande fortement. Actuellement je pars sur un montage ponté, pour alimenter des Jbl 2241h.
Clement L.
Très bon matos , entièrement satisfait du smsl A8 ainsi de la qualité de l’emballage et rapidité d’envoyé merci audiophonics
PHILIPPE D.
Très bon transformateur sur mesure.
PHILIPPE D.
Rempli parfaitement mon besoin.
