Jerome L.
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Customers reviews - There are 19503 reviews.
Laurent T.
Volumio bêta 2
Superbe graphisme et vraiment simple d'utilisation , de plus c'est vraiment du plug and play , on insert la carte ( perso sur un Rasptouch ) et c'est parti !
Anders M.
High quality DAC for Raspberry Pi
Fantastic DAC - this is my 4th Audiophonics DAC; I have never been disappointed. Installed on a Raspberry Pi 3B with piCorePlayer 4.1.0 audio core, it plays high resolution PCM (tested with 352.6k files) and DSD files currently up to DSD128 (5.6M) with the I-Sabre ES9028 dtoverlay/driver - remember to enable the 384k option in Card Comtrol. The DSD option (DSDOUT="-D") needs to be set from outside piCorePlayer using the Audiophonics tutorial (http://forum.audiophonics.fr/viewtopic.php?f=4&t=1952&p=7956#p7956) as piCoprePlayer - to my knowledge - currently does not allow this option to be set from the web interface.
The sound image is naturally rich and very clear with music instruments and voices clearly place in the sound image. Makes it worth listening to good music :-)
Ulrich S.
OYAIDE DC-2.5G Jack DC 5.5/2.5mm Connector Gold Plated Ø6.3mm
Everything worked perfectly with Audiophonics. Very friendly contact to customer service. Very fast information on the current processing status by sending an e-mail. Fast delivery. And the incomparable price complete the perfect purchase.
I like to buy again at Audiophonics. A highly recommended Internet shop.
U. Schulz
Ulrich S.
NEOTECH NEI-3001MKIII
U. Schulz
François M.
Supprime les interférences
Avec le boitier en acrylique je ne passais pas plus d'une journée sans que Volumio plante à cause des interférences.
Depuis l'installation du boitier en aluminium cela fait 7 jours que Volumio fonctionne sans avoir à le rebooter.
A confirmer par d'autres utilisateurs.
Jean-Paul L.
A peine croyable
Gilles C.
André P.
INTERTECHNIK LU32/26-AG Copper / Silver Air Self 0.8mm 0.05mH Air coil wound with 0.8mm diameter copper wire, silver plated and covered with a thermoplastic anti-vibration film. Transparent polycarbonate support. The air coils are, for...
expédition rapide
Elie B.
Selecteur de sources XLR
Je cherchais un sélecteur xlr pour switcher entre 2 sources et une seule paire d'enceintes actives .C'est fait j'ai trouvé
Commande prise en compte très rapidement Livraison impecable Produit très bien emballé
Rapport qualité prix rien à redire
Je recommande sans hésitation
Frederic S.
Excellent pour le prix
Ce câble est vraiment étonnant, il offre énormément de détails sur tout le spectre sans trop en faire aux extrémités mais le plus beau est l'espace qu'il délivre, que ce soit en vinyle ( Rega/PP Cambridge/AT ) ou sur un DAC de haut niveau sensible aux câbles ( Channel Island VDA-2 ), Charnel est le mot qui me vient à l'esprit pour le résumer. Hâte de le comparer avec l'Elecaudio Dark Crystal.
Ludovic T.
Pas de vis de fixation
Bonjour. Dommage qu'il ne soit pas livré avec les vis de fixation. Cordialement.
Pipo G.
Pas de mesures SPL avec Smaart.
Impossible de calibrer ce micro pour des mesures SPL sous smaart Live.
Quand on le calibre au piston à 94db, il affiche dans smaart un 91 db sans aucun bruit émis, alors que la mesure réelle se trouve aux environs de 50-55 )
(Testé avec d'autres modèles, le problème ne vient ni du bonhomme, ni de smaart )
Ce micro ne m'est du coup d'aucune utilité...
Quand c'est pas cher, tu le paie deux fois... J'ai du acheter un autre micro que j'ai pris chez iSemCon du coup, aucun soucis avec le nouveau...)
Olivier R.
EXCELLENT
Très bonne qualité de soudure mais quand on n'est pas habitué à souder de l'argent ce n'est pas évident du tout, rien à voir avec la soudure à l'étain
Olivier R.
EXCELLENT
Très bonne qualité de fabrication, qualités mécaniques excellentes, le son n'est pas dénaturé par leur présence.
Olivier R.
EXCELLENT
Sylvain D.
Moins bon que le câble nu
Joli câble avec une très belle finition, qui inspire la qualité.
Le système d'insertion des fiches bananes est original et bien pensé, mais pas toujours très efficace (des fois, les bananes tiennent mal alors qu'elles sont vissées pour rester fixes), mais ce n'est globalement pas grave.
J'avais une version en câble nu du Mogami 3103 et je désirais avoir une version avec fiches pour plus de facilité de manipulation.
Ce Mogami doté de fiches Elecaudio conserve globalement les qualités du 3103 nu avec un son plutôt calme dans le haut du spectre et un grave plutôt charnu. En revanche, il est moins onctueux, moins "gras" et un peu plus pointu dans l'extrême aigu. Bien sûr, cet avis est formulé après la période de rodage qui s'impose.
Certains préféreront peut-être, j'ai pour ma part une préférence pour le câble nu.
Néanmoins, ce câble fournit toujours une belle performance largement à la hauteur de certains modèles de marque extrêmement chers.
Sylvain D.
Sonorité charnelle
Sebastian L.
Sebastian L
Sebastian L.
Sebastian L
Hugo V.
ESS ES9038PRO DAC Module I2S XLR 32bit 384khz DSD with Screen This excellent DAC module is based on a high-end ESS ES9038Pro conversion chip. This ensures exceptional audio performance. The whole is supported by a set of components of high...
Gilles H.
Grand merci à vous
Gilles H.
Rapport qualité prix très bon
Jean-Jacques D.
Led bleue
Michel C.
Superbe...
Fabuleux
Jean-Philippe C.
bon DAC
Jean-Philippe C.
Hugues B.
Thierry b.
Conforme à sa description
Johannes g.
bluffant !
Patrice V.
magnifique et bluffant
Etienne L.
Sastisfactions totale
dac fx-audio
préampli fx-audio (tube nos)
ampli yamaha
enceintes jm lab
arnaud D.
Tout est dans le titre.
Gregory P.
étonnant !
montés sur une carte audio asus XONAR STX, ils offrent un registre sonore naturel d'une grande beauté sans agressivité.
une belle réussite pour burson.
Claude Z.
Super DAC
Un peu sceptique au départ, mais à l'écoute vite rassuré voir enthousiaste. La spacialisation est remarquable, les instruments bien nets et différentiés, et le son excellent.Les aigus extrêmes sont peut-être un peu "criards", mais c'est vraiment pour pinailler. L'impression d'ensemble est étonnante de précision et plein de petits détails que je n'avais pas remarqués sur mes albums préférés sont présents. La dynamique est également au rendez vous. Bref un super achat à un prix somme toute abordable et je pense que cet ampli dac a des qualités qui sont présentes sur des modèles beaucoup plus chers.
Un tout petit bémol cependant, l'appareil siffle un peu ( du au transfo intégré ?) si il est posé sur du bois; Mettre un peu de feutrine sous les pieds et tout rentre dans l'ordre.
Jacques H.
remplace aussi parfaitement l'alim d'un cabasse stream 1
le 32 volts c'est pas courant :-)
je suis content d'avoir trouvé cet adaptateur, qui de plus possède un voyant.
andy r.
baladeur
super baladeur , qui offre une excellente qualité audio pas la peine de mettre de volume très fort pour apprécier sa musique , bien meilleur que beaucoup d'autres baladeurs du même genre , il est facile d'utilisation , c'est tout ce qu'il me fallait .
Jan D.
Excellent quality and value
Sound is very clean and detailed. Quality and workmanship seems to be top-notch.
Très bonne sécurisation du fil dans la fiche (2 vis) et verrouillage simple et efficace dans le bornier ampli.
Correspond en tous points à la description. Très bon produit!
Solide et sécurisée
Belle prise dans laquelle le câble est totalement sécurisé. Prévoyez une petite clef Allene pour le montage.
Michel S.
Pas mal du tout.
Contrairement aux petits modèles à pattes, ceux-là se révèlent performants , bon niveau sonore, même un peu de basses. Très clair, manque un petit peu d'aigus en haut dans le spectre mais la partie mobile étant assez lourde pour avoir un bon rendement c'est logique. Bon achat.
Michel S.
Pas du tout à la hauteur
Acheté pour remplacer les exciters de mes Soundpax qui ont 15 ans, ils semblent identiques. Erreur, bande passante ridicule et niveau sonore bien faible. J'ai remonté les anciens qui en ont vu de toutes les couleurs c'est sans comparaison. Imitation mal faite ou défaut, je ne sais pas en tous cas mauvais achat.
Êtes vous sur que ceux d'origine étaient en 8 ohm ?
evangelos t.
highly recommended
highly recommended
Jan D.
Pretty good case
This is a decent case for khadas board. Parts fit together pretty well. The washers do their job to place the board and back plate in correct position but seem bit flimsy. Printing on the top of case is backwards, as one other reviewer stated.
Ibon S.
Excellent dac/amp combo
Paired perfectly with my m1060 planar headphones. Very musical package, It doesn't analize the music, it plays it in a very enjoyable way.
Alain T.
Parfait, pour ce prix
Acheté suite à la panne d'un Asus Xonar Essence STU, je m'attendais à la même qualité. Mais j'ai redécouvert une nouvelle fois mes albums. La spatialisation y est étonnante et la dynamique assez incroyable eu égard au reste de mon équipement.
Excellent dac
ma source est un Mac Mini late 2009. Relié directement en usb, aucun bruit d'alim, impossible de dire si le Khadas est sous tension ou non, même sur des pavillons + 100db. Idem au casque.
D'après différents forums français et US, le Khadas alimenté via USB sous PC Windows peut transmettre des bruits d'alim avec souffle et buzz, parfois avec un son sale et étriqué : si c'est le cas, la source audio et la liaison usb à revoir d'urgence avant de l'attribuer au dac (même si cela fonctionne sans problème avec d'autres dac).
La première qualité dans ma configuration est une ouverture sonore assez peu commune, tant au niveau des ambiances perçues (détails bien intégrées, reverb), que de l'image sonore, bien étagée, large mais sans emphase type cinémascope.
Globalement ce dac à une bande passante très large, un excellent équilibre et finalement une très grande transparence (un vrai caméléon), la signature sonore des prises de son est vraiment palpable. C'est un dac qui n'a pas de personnalité propre donc qui ne compensera pas d'autres éléments audio, il en révèlera plutôt les défauts.
Toujours en liaison USB standard, l'ajout d'une alim externe via la carte (pin1/21) ne change strictement rien qualitativement : il semblerait que l'alim USB tant qu'elle véhicule du signal garde la main.
Dans ce cas il faut prévoir un câble USB en Y : signal d'un côté, alim de l'autre et là curieusement la sonorité des alims essayées s'entend très distinctement.
Il y a forcément mieux en dac, mais bien utilisé dans un système transparent (non compensé), cet appareil est vraiment d'un très haut niveau de qualité. Sans même parler du tarif très abordable.
Je le recommande sans réserve !
Vincent M.
Fabrication correcte pour un produit chinois. Malheureusement aucune des vis fournies avec le boitier ne correspondaient aux filetages présents. Dommage
Vous avez peut-être reçue les mauvaises vis.
Notre notre SAV est à votre disposition via votre espace client, afin de faire le nécessaire.
Merci à vous.
