Pavel V.
Good and tight plugs
Good and tight plugs, but despite my impression from the pictures, there is actually no grooving to put on a coloured rubber...
Pavel V.
Excellent amplifier with a power-on issue
Excellent amplifier. The only serious issue: it can frequently trip sensitive circuit breakers on start-up. The NC252MP...
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz)...
Customers reviews - There are 19144 reviews.
yann M.
excellent appareil
appareil etonnament bon et pratique
il ne manque rien
la portée du bleutooth est impressionnante
Andrew M.
Power your I-SABRE DAC board & Pi
Bought this to power the I-SABRE DAC
Andrew M.
Great DAC and design
I first bought the complete system with case, pi, dac, etc and was very impressed with the unit and the sound. Having the audio and power on the same side as the I/O on the Pi is a great design and makes for a cleaner config. Wanted the same DAC to use with another piCorePlayer I want to build for another room because the sound quality. Long over due. The fact that it also works with a 2 line OLED display for smaller packages is another bonus.
Petter Jacob L.
Elna capacitors are normally a very good choice.
Have used Elna electrolytic capacitors in several electronic components and have never regretted.
Petter Jacob L.
Seems Solid
The potentiometer seems solid. Rotation of serrated axis is solid and fine. Have not used it as volume control yet.
Petter Jacob L.
Nice and compact size.
Marc F.
Un RQP sans égal ou presque
Comparé - sur mon système, tout est relatif et affaire d'associations - à différents Klotz, Mogami, Grimm, Belden, Hifi-câbles, etc. pour lesquels il manquait toujours quelque chose ou résidait une insatisfaction, ce Canare est un "no brainer" comme disent les anglo-saxons. On ne peut raisonnablement le vanter comme le câble ultime qui efface les références xx-fois plus chères, mais il restera sur mon système comme le juge de paix par lequel les autres seront jugés, en raison de l'homogénéité de ses qualités : équilibre, transparence, douceur, détails, densité des timbres, etc.
Marc F.
Connecteurs faciles à utiliser
Pour faire des essais de câbles, sans avoir à souder-dessouder, ces connecteurs sont très faciles à monter et à défaire. Et bien entendu, à demeure entre lecteur CD et ampli, ils font le job et le serrage sur les prises RCA est efficace.
Encore merci à Audiophonics pour la rapidité de la livraison et surtout d'avoir eu la gentillesse de corriger une étourderie lors de ma commande.
Vincent V.
Bon ampli 12Vdc
J'apprécie le rapport qualité/prix.
Le petit plus : entrées stand by et mute
En moins : tenir le connecteur bornier à visser si serrage fort, la solidité du bornier est un peu en dessous de l'image globale du produit.
Avant de passer aux impressions d'écoute, je voudrais signaler les observations suivantes. Le bouton de volume pour la sortie casque agit également au niveau de la sortie rca . On peut passer de très faible à haut niveau de sortie. Cela peut avoir une incidence au niveau du fonctionnement d'un ampli. Il faut donc trouver le bon niveau de sortie .
Ce récepteur Bluetooth est très séduisant. Il délivre un son chaud et détaillé, à la manière des bonnes électroniques à tube. Distinction au niveau du secteur médium aigu qui est très naturelle et émotionnel ( voix et instruments acoustiques.) Le secteur grave est précis et profond.
Ce récepteur Bluetooth est un produit excellent au rapport qualité surprenant. El plus il est très joli.
aime KP
bon condo, que j'ai mis en entrée sur mon ampli, pour remplacer un vieux fatigué. écoute nettement meilleure, claire, sans perte en aigus, a utiliser sans problème, surtout en audio.
Jean-Claude C.
Très bon !
Utilisé pour confectionner un câble coaxial avec connecteurs bnc d'un côté et jack de l'autre pour relier un digione allo et un chord mojo. Aucun problème pour la soudure des connecteurs, il est assez souple et solide. Il "transporte" parfaitement le signal numérique vers le dac !
Jean-Claude C.
Je l'ai utilisé pour confectionner un câble coaxial bnc d'un côté et jack de l'autre pour relier un digione allo avec un chord mojo avec ce câble FURUTECH FC-62 Câble numérique µ-OFC 75 . Résultat : c'est parfait !
Ce connecteur BNC est facile à souder, il est esthétique et solide. Juste parfait !
Alexey Z.
Perfect!
I like this up-to-date i2s spdif sound card (hat) for my Rpi3. I connected Rpi3 +Digione to multi bit DAC19 by coax cable and then to my tube headphone amplifier. I also connected CXC Cambridge Audio cd transport to DAC19 by optical cable. Made some comparisons in sounding between two systems using one composition (flac from Rpi3 and compact CD ). Finally I couldn't hear any noticeable differences in sounding! Rpi3 with DigiOne and LPS sounded as good CD transport. I was impressed with clarity of sounding as well as microdynamics provided by the DigiOne Spdif card. It is really good device.
PANASONIC FC Low ESR Capacitor 50V 1200μF Panasonic FC capacitors benefit from a high design quality and a low ESR. They will be suitable for most of your projects, whether for DIY creation or as a replacement for...
Condensateur 100 Yf Panasonic
Parfait ; Très faible ESR confirmée.
Fiabilité des expéditions Audiophonics aussi !!!
excellent RQP
je confirme l'avis de David R, quant a la qualité sonore de ce cable, que j'utilise dans mon système triphonique pour le medium. avant j'ai fais l'essai de câble de même section 2x2.5 mm2, mais plaqué argent. la qualité de l'argent, c'est que l'oxydation de ce métal est toujours conducteur, donc de vieux câbles gardent un bon contact. Mais il y a un défaut, le placage argent, donne une surbrillance aux aigus, le son n'est plus , naturel, et devient lassant. je retrouve avec ce sommercable, un son plein,clair, défini, sans rajout,ce qui me convient mieux. pi.r
Yvon C.
GROSSE SURPRISE !
Je possède des câbles HP haut de gamme de ce fabricant dont j'étais très satisfait. J'ai donc commandé ce câble NES-5005 pour un deuxième petit système. Je cherchais donc des conducteurs de qualité à petit prix. L'écoute de ces petits câbles à été une grosse surprise car ils "sonnent" comme des câbles beaucoup plus chers et plus ambitieux. Je recommande donc fortement.
Jean-David G.
Impressionnant
Le dernier né de la gamme NFB 11 affiche des prestations de haut vol. (je l'utilise en tant que DAC branché à mes enceintes)
Pour imager, si le NFB 11.28 m'avait mis une gifle, ce NFB 11.38 m'a mis une grosse claque !
La musique délivrée devient physique , les enceintes semblent disparaître et les musiciens prennent place dans la pièce d'écoute ..
Tout est plus clair, plus précis , le son a plus d'impact , le registre grave notamment affiche une belle présence, sur certains enregistrements ça remue les tripes !
La scène sonore est vaste , chaque instrument est localisable et les timbres semblent réalistes. Les voix paraissent également naturelles avec peu de sibilances.
Amateurs de douceur, de finesse, ce DAC n'est pas fait pour vous.
Si par contre vous aimez écouter la musique comme au concert, avec la sensation d'être proche des musiciens , alors ce DAC devrait vous combler !
Pour comparer avec le Chord Qutest que je possède également, le Chord amène un peu plus de naturel et de musicalité à l'écoute , l'Audio GD semble plus précis et plus analytique. Difficile de les départager réellement, pour le prix l'Audio GD frappe fort.
Je précise enfin que j'utilise un câblage en full OCC cryo , qui permet d'obtenir un son organique , libéré de toute froideur digitale …
Merci Audiophonics pour le service au TOP !
gilbert f.
En remplacement d'une masse de mauvaise qualité
Bonne conductivité, bon produit
Olivier D.
Juste génial pour le prix
Très bon ampli, compact et puissant, utilisé en bluetooth avec plusieurs appareils, androïd, I-pad... sans aucun soucis, un très bon classe D.
Fabrice G.
Je regrette que les contre pointes soient si petites.
Un contre écrou pour bloquer la pointe en position apres réglage aurait été le bienvenue
Fabrice G.
A recommander
J’etais septique mais après avoir nettoyé l’axe et l’alesage de ma Thorens TD145 j’ai mis quelques gouttes de cette huile et miracle le bruit de roulement à quasi disparue
A recommander pour vos platines
Alex I.
Marche très bien avec mes enceintes Dali Zensor Pico.
Oleg S.
AUDIOPHONICS - The best choice
Delivery to Russia in just 7 days-it's very fast!
Packed well-no damage
Thank you!
Emmanuel G.
LA BASE
Après de multiples tests de câbles en tous genres (marques -section - matières......) j'en suis finalement resté à ce très bon câble MOGAMI.
Il fait en sorte que je ne pose pas de question à l'écoute et me surprend toujours par ses qualités (neutralité - profondeur -présence - et une forme de raffinement) que je ne retrouve dans aucun autre câble testé.
Il n'est pas donné côté prix certes mais lui donne tout ce qu'il faut à ce prix.
Oleg S.
I'm fine!
Delivery from France to Moscow 7 days! Acoustic terminals are beautiful:) thank you very much!
Stéphane B.
Joli packaging dont un câble Premium
Tout d'abord, merci Audiophonics pour la gestion de ma commande, livraison rapide, réponse rapide aux mails. Top.
Concernant ces IT01, que du bon à ce prix. Ils offrent une signature en V avec une belle assise au niveau des basses et un aigu maîtrisé, avec un bon niveau de détail. J'obtiens une belle synergie avec un Cowon Plenue R, celui-ci apporte un son organique, clair avec une bonne dynamique.
Associé à un Cayin N3, le rendu des IT01 est plus sec, moins vivant, et donc moins ma tasse de thé.
Pour moins de 100 € ces IT01 sont une franche réussite, d'autant qu'iBasso ne s'est pas moqué du monde, les IT01 sont jolis, bien finis et livrés dans packaging presque haut de gamme, notamment le câble, superbe.
hubert H.
Un vrai petit miracle !
Aucun équivalent à ce prix ! Simplissime, discret et terriblement efficace, cette petite merveille fait son job et plutôt mieux que beaucoup de concurrents tellement plus onéreux !
A acheter les yeux fermés...
Nicolas K.
materiel ok, emballage inadapté
gaines reçues pliées dans des sacs de 8cm.... donc beaucoup de pertes à cause des pliures..
Alain M.
Bien reçu mais une bille manquante pour un des pieds.
Vincenzo v.
Viborg VF502
J'ai acheté le connecteur viborg VF502, un produit de qualité, il accepte les câbles de grande section.Avec le câble oyaide EE / F-S2.6 V2, il a la sensation d'un son clair avec une grande tridimensionnalité et un excellent placement des instruments. Excellent achat
Bruno S.
FX-AUDIO D802C PRO Amplifier FDA Bluetooth 5.0 AptX HD NFC Class D STA326 2x80W / 4 Ohm Black The Pro version for D802C improves Bluetooth module (QCC3034) and a gains a more efficient USB chip CM6422 than its previous model. This amplifier is a very useful tool that...
Super peitit ampli
Utilisé avec des enceintes Focal 905 et une console nvidia shield tv.
Bon son, pas de soufflement parasite (sur kodi désactivation du paramètre "son inaudible")
paramétre sur flat ou Hifi
Entièrement compatible avec une télécommande Harmony. Les sources peuvent être changée directement, contrairement aux autres fda que j'ai eu précédemment (Aleintek D8, Q5 pro..)
merci à Audiophonics pour le manuel d'utilisation
livraison rapide
Xavier L.
Déçu
Déçu par ce câble
Malgré une qualité de construction tout à fait satisfaisante, résultats décevant chez moi avec clairement par comparaison à d'autres câbles coaxiaux, un manque d'ouverture de la scène sonore.
Dommage
Marco W.
C'est fort !!!!! Pas besoin d'avoir un DAC de 3000€. J'utilise sur un Android avec HF-Player de Onkyo. Mes fichiers sont's des FLAC's de 16/24 bits, avec la sortie DOP 5.6Mhz (crée le streaming DSD) le résultat est incroyable.
Jean--Louis A.
Bluffant
Pour la taille et le prix, c'est à peine croyable.
Il m'a fallu quelques jours de rodage (électronique, oreilles??..) mais maintenant c'est un vrai plaisir d'écoute.
Seul bémol en utilisation nomade, la batterie du device se vide à vue d'oeil (il faut bien prendre le courant quelque part!)
vincent c.
testé et approuvé
Le FX 01
je l'ai acheté pour tester sans trop de frais les possibilités musicales avec mon PC qui tourne sous Linux Mint.
Branché, ça  marche tout de suite, déjà meilleur qu'en entrant la sortie écouteur du PC sur un ampli classique de bonne qualité (Dual 6030 2x50w classe A)
Toujours sur le même ampli, en adaptant un peu avec un logiciel qui permet d'envoyer directement le signal digital sur la sortie USB ça devient carrément bon avec  de la musique qualité CD non compressée.
Ca reste correct avec du MP3 320Kb/s, mais même à mon âge j'entends la différence.
En clair, pas de la hi-fi de haut vol mais ce DAC permet d'avoir de la musique tres acceptable depuis un PC
En comparaison, J'avais testé sur le même ampli DUAL un Dragonfly "black" à 100 euros, la qualité est quasiment identique.
Le Dragonfly était un peu meilleur en écoute directe au casque sans ampli, ce que ne permet pas le FX01.
J'ai acheté ensuite "pour voir" le petit ampli classe FX audio D302 .
- en entrée numérique , soit optique (lecteur CD SONY XDP CE530) soit  coaxiale (Yamaha CD X570) c'est carrément très bon .
Pour l'instant Je n'ai testé que sur de petits baffles Dual qui étaient "libres",(quand même 3  voies 50w)
je vais voir ce que ça donne avec mes autres jeux de bafflles (Siare, Sony et 3A)
- en entrée USB , testé sur PC Linux et sur MacBook c'est bien sûr un peu moins bon, mais meilleur que j'avais en analogique avec le DAC FX01
- En entrée ligne testé avec le lecteur Yamaha c'est un peu moins bon qu'en coax mais ça reste confortable .
- Testé avec un Ipod classic (MP3) ça baisse d'un cran, comme avec un baladeur minidisque Sharp. Par contre je n'ai pas trouvé de souffle même sur cette entrée.
Je vais jouer encore un peu avec mes différents baffles, car j'ai vu qu'il y a intérêt à optimiser les réglages de tonalité, et sans doute à "roder" un peu la machine (ou mes oreilles?) :
Sortie de boite c'a m'a paru assez criard, avec deux heures d'écoute et un peu de patience pour reprendre les réglages j'arrivr à un résultat intéressant pour moi :
la qualité est du même ordre qu'avec mon système analogique précédent, avec un plus assez net au niveau "relief sonore".
je précise que j'écoute surtout du Jazz, les voix sortent très bien. Guitare, contrebasse et saxo sonnent  aussi assez naturellement.
PS : niveau de sortie relativement faible (dans une pièce de 12 Mcarrés). Je ne prétends pas être un expert en HI-fi, je n'ai pas non plus les moyens de me faire un auditorium.
Mais pour moi ces matériels nouvelle génération donnent déjà une qualité correcte à prix doux. reste à voir la fiabilité dans le temps? (mes amplis DUAL de 20 ans fonctionnent
toujours parfaitement avec un nettoyage de temps en temps).
A B.
Conforme
Produit conforme, à première vue solide. A vérifier à l'usage. Manque un peu de hauteur car certains pcb ne passent pas.
Jean Paul E.
peut mieux faire
pour la connexion (matières, vis etc...), c'est du sérieux. Habillage carbone léger et mal fixé.
Clé allen petit modèle pour le serrage non fournie : c'est mesquin et même peu professionnel.
embase rca
je rajoute un détail, je préfere les DG car elle n'ont pas de nickel, pour moi inutile,le placage or sur le ce/tu est preferable,facile a souder,pas de problème
rca cu/te
dans la continuité de mes aménagements de mon système vintage, j'essais de faire une ligne sonore avec les mêmes matériaux, et ça fonctionne. donc sortie préampli rca tellurium, entrée ampli rca ce/tu identiques, et cable modulation neotech nei 3004 et connecteurs cu/te elecaudio aussi. cablage interne du circuit imprimé aux embases rca avec du neotech soct-20 OCC. resultat: presence, clarté, définition, ça ne rajoute rien, c'est transparent, l'impression d'avoir changer mon préampli. que du bonheur, je vais continuer...
fil de cablage OCC
excellent fil de cablage,qualité OCC neotech,gaine ptfe; clarté, presence sans projection, définition, les présentateurs de radio,ou sur disque live tout a fait clair . son seul défaut c'est qu'il n'y a que du rouge, qui plus est avec la gaine ptfe, aucun feutre n'ecrit dessus. petite rectification en dimensionnel: au pied a coulisse numérique, le diamètre du cu est de 0,70 mm, ce qui fait en section ou surface: 0,3848 mm2, et dia ext gaine 1,49 mm.
cailloux
c'est la première fois que je suis déçu par ce site.... aucun aigu
que du grave . mes enceintes Quad ESL2905 font vraiment un bruit de boite a chaussure, même si je ne l'avais pas acheté pour écouter de la musique avec ces enceintes. je vais voir avec audiophonics pour le retourner
Si la sonorité de cet amplificateur ne vous convient pas, vous pouvez bien entendu nous contacter pour effectuer une demande de retour.
Merci.
pierre a.
tout d'abord un grand merçi a luc du sav,en effet le 1er modele reçu avait un petit probleme, le sav a reagi avec rapidité pour m'envoyer
un autre ampli
que dire d cette merveille : petit ne chauffe pas et qui ne consomme
que tres peu d'energie
le rendu sonore est vraiment tres bon avec mes focal chorus 706
David R.
AUDIOPHONICS RASPDAC I-SABRE ES9038Q2M V2 Streamer Raspberry Pi 3 B+ With RaspDAC, Audiophonics offers a ready-to-use, simple and efficient solution combining both network and DAC players. In this V2 version, the device embeds an ES9038Q2M...
Nice little box but software bugs or a hardware issue giving me trouble
It sounds good so far, but I haven't had much of a chance to listen carefully yet - I've spent the last week trying to figure out why the front display ceases to function after ~15-45 minutes of activity and requires a restart to reactivate - frustrating for the price!
The quality of the build is very nice otherwise.
Jean Paul E.
Sidérant
Après un essai satisfaisant du FURUTECH FP-TCS31 (voir mon avis), j'ai essayé ce Tunami V2 sur mon streamer en lieu et place d'un Transparent Reference (2200€). Résultat, plus de micro-informations, plus d'aération, plus de relief, un silence de fonctionnement "irréel", le tout dans un constant respect des timbres.Moi qui croyait qu'un câble secteur influait peu sur la qualité de restitution, j'en suis encore ébahi.
Paul B.
Super petit ampli
Utilisé d'un coté avec un Raspberry et la carte Allo DigiOne, de l'autre coté avec un lecteur de CD en SPDIF sur des enceintes électrostatiques Quad ESL63, le rendu est exceptionnel. J'avais essayé pas mal d'amplis avant sans être très convaincu mais là c'est vraiment bien. Seul petit bémol, l'alim qui siffle mais échangée sans problème sous garantie.
Edwige K.
D802C
parfait !
Fabrice C.
Des améliorations possibles ...
Pas de problème de fonctionnement, mais des problèmes pour fixer le Circuit imprimé, car les têtes de vis butent sur les connecteurs.
La documentation est un peu limite ...Rien à dire sur le rapport qualité/prix.
Denis B.
TUNAMI V2
bon cable cuivre de qualité . RAS.
Denis B.
goupille a sertir furutech
bonne qualité .R A S .
