Jerome L.
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Alessandro C.
IAN CANADA FIFOPI Q7 II FIFO Reclocker Module I2S DSD DoP Syncrhonous The Ian Canada FifoPi Q7 is the new flagship in the FifoPi family of reclockers. It achieves the best performance in terms of jitter and noise by using a number of...
Developed and built at very high levels that allows the DAC ES9038 DUAL Mono II to express itself even better allowing you to reproduce the musical message in an excellent way. Very very satisfied.
Alessandro Catalano
Alessandro C.
IAN CANADA MONITORPI PRO Control Center and Signal Analyzer with Display for Raspberry Pi Ian Canada's MonitorPi Pro is a powerful integrated control center and universal OLED display for all types of Raspberry Pi-based audio applications. To install the MonitorPi...
A real control center very well made and easy to use. I am really satisfied
Alessandro Catalano
Alessandro C.
IAN CANADA DUAL MONO MKII DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD Ian Canada 9038Q2M dual mono DAC HAT is a very high level of DAC for Raspberry Pi. It uses two chips ES9038Q2M SABRE 32-bit each working in mono.
IAN CANADA DUAL MONO MK II ES9038Q2M
Developed and built at really high levels that allows you to process digital audio at the highest levels. I am really satisfied.Dac Studied and built at really high levels that allows you to process digital audio at the highest levels. I am really satisfied.
Alessandro Catalano
Didier T.
Excellente surprise... si on lui donne le temps de s'épanouir !
2 mètres de CS-361B exploités en entrée d'un BADA 6610 alimentant ma box, mon Node 2i (via carte PD Creativ + bloc Shanti) et mes Nuprimes Dac 9X & STA 9X).
Ce CS-361B est très déconcertant pour ne pas dire décevant durant les premiers instants, contribuant à une courbe de réponse "en cloche", très centrée "medium" avec un effet bouché et sans vie aux deux extrémités.
M'appuyant sur les précédents avis, et s'il commence à se réveiller entre 40 et 50 heures, j'ai laissé sous tension l'ensemble des maillons durant près de 100 heures (non sans streamer en boucle) avant d'envisager avis "sérieux".
Arrivé à ce terme, le résultat est fait d'ouverture, fluidité aération sans aucune dureté : c'est très convainquant !
Au-delà de sa très belle texture sur les voix (déjà mentionnée par ailleurs), mais pas que, je lui trouve surtout dans mon cas une homogénéité, pour ne pas dire une intégrité tonale sur l'ensemble du spectre : je constate qu'aucun segment du spectre particulier n'est favorisé au détriment d'un autre.
Guitariste possédant mon propre studio avec plusieurs (jolies) guitares (et leurs amplis), batterie et clavier, mes tympans m'invitent à rendre à ce câble secteur ce qui lui revient, c'est à dire sa capacité à éclairer (étirer ?) la restitution sans écraser la dynamique.
Au contraire, je trouve qu'il contribue très probablement à faire vivre les micro-détails avec subtilité sans rien dénaturer.
De telle sorte qu'il me donne la sensation d'être sinon immergé au milieu des musiciens, du moins au premier rang du concert en pouvant savourer l'effet tri-dimentionnel du spectacle musical proposé.
Surtout, il ne me donne pas envie de découper les décibels en quatre sur "mon aigue ceci, mon medium cela et mon grave machin" : cet ELECAUDIO CS-361B me donne tout simplement l'effet de contribuer à faire passer la musique avec sincérité.
Et, oui, comme le bon vin, il faut lui donner sa chance sans "sur-réagir" dès les première minutes...
Pour conclure concernant sa construction, je lui trouve bcp d'atouts techniques et sa mise en oeuvre, si elle demande un minimum de rigueur et de précaution, ne présente aucune difficulté.
Enfin, sa relative souplesse (ou raideur, c'est selon), ne pose pas de difficulté particulière dans son ergonomie.
Didier
Thierry L.
RK
Le meilleur câble que j'ai trouvé pour faire une installation audiophile à partir du disjoncteur. Facile à travailler dans les murs (3.3mm2) avec une très bonne qualité de cuivre. La qualité du blindage assure un excellent silence de fonctionnement des appareils. A recommander ***
Jean-François B.
Que dire de plus, ce produit est excellent et de très haute qualité. Installation facile et utilisation ultra simple. Bravo !
Philippe H.
AUDIOPHONICS OBSIDIAN Interconnect Cable RCA-RCA Pure Silver 0.75m (Pair) Optimal audio signal transmission without any defects is what we offer you with the Audiophonics Obsidian premium RCA interconnect cable. Its pure silver conductors and...
Une ouverture remarquable …
J'ai attendu 10 jours de rodage quotidien pour partager cet avis ; je suis allé vers le "tout argent" à reculons, sur la seule confiance en M Aubert. Et j'en suis juste ravi ! Comme prévu, ce câble est bien du côté "ouverture / rapidité / détail", mais sans aucune dureté comme je craignais, au contraire : je trouve que le gain très conséquent en définition se fait sur toutes les fréquences, dans une forme de plénitude inattendue, avec un étagement des plans superbe … Et le plus étonnant, c'est dans la zone haut-médium : ce qui fâche régulièrement, les chuintantes des voix ("s", "ch"), le violon ou le saxo alto passent avec une aisance rare. L'impression subjective est que la rapidité est non seulement dans l'attaque mais aussi (surtout ?) dans l'extinction de note, comme si l'énergie était bien là, mais sans surcharger la reproduction … Aspect peu évoqué concernant les câbles argent, le grave est impressionnant, en clarté et impact (réglage du sub à refaire !). Bref, je suis conquis par ce câble, dont le rapport qualité/prix frise l'insolence. Merci M Aubert pour votre clairvoyance
Tres bien
Colis reçu rapidement
Premières impressions très bonnes
Pour l'instant je ne m'en sert que comme transport est c'est nickel.
Impression d'un appareil aboutit et de très belle esthétique
Pour accéder a un transport CD a ce prix est a conseiller.
Stéphane V.
Après une longue période de rodage, la justesse, la spontanéité de cet appareil impressionnent. La scène est bien plus large qu’avec les autres amplis casques essayés ou conservés (même bien plus chers). Il n’y a pas de duretés, les placements sont aisés à repérer, les timbres sont expressifs et posés. Cela aide beaucoup pour la composition musicale. Il aide aussi à bien choisir l’ampli opérationnel du Dac, quand c’est possible. Cet ampli casque a été livré avec des OPA 2604 (après réassortiment) plutôt que les Muses 8920 annoncés : mieux ou moins bien, je ne sais pas, en tous cas c’est très beau.
Je continuerai à demander conseil à l’équipe d'Audiophonics pour d’éventuels compléments ; d’autres amplis opérationnels ou d’autres câbles.
Le Dac et l’ampli sont reliés avec un câble symétrique Canard, TRS 6,35 M vers XLR M. La sortie est reliée au casque pour l’instant avec un câble asymétrique Syrnarn.
Je tiens à dire que le produit ne me gène pas sur le plan de la radiosensibilité : ce qui est une aubaine. Merci !
François M.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Silver Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB...
RQP exceptionnel
La qualité des dacs ne cesse de s'améliorer.
Utilisé sur ses sorties symétriques(meilleures que les asymétriques) il a remplacé avantageusement mon "vieux" Bel Canto 3.7 et tout ça pour 229 €. L'écoute avec une excellente alimentation à découpage MONACOR est remarquable.
Seule contrainte en symétrique, il faut se confectionner un câble Jack 6.35 vers RCA ou XLR. A moindre frais avec du canare L-4E6S on peut se fabriquer un très bon câble de modulation.
J'avais envisagé dans un premier temps le modèle D90 III mais il est 5 fois plus cher.
Seules différences majeures avec le d50, une alimentation faisant partie du produit et donc non remplaçable, le MQA et des sorties symétriques en XLR au lieu des jacks. Mais rien de plus musicalement parlant je pense.
claude D.
AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 Ohm The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home...
Ampli class D
j'ai attendu un moment pour donner mon avis.
Ce qui ne va pas : à quoi sert l'inter M/A l'appareil est toujours sous tension sifflement dans les tweeters dès la coupure du bouton M/A , j'ai été obligé de mettre une barrette avec inter M/A
A par ça le son de cet appareil est magnifique un pur régal pour moi le meilleur amplificateur que j'ai eu jusqu'à présent et j'en ai eu beaucoup classe AB, classe A et tubes mais jamais de class D.
j'écoute de la musique maintemant je me pose plus de questions
claude D.
SILKLINE ZUKI I Balanced preamplifier / DAC 32bit / 192kHz USB XMOS Silkline's Zuki I combines the functions of preamplifier and DAC . The preamplifier function has a balanced and unbalanced output and a v oltage gain of 12dB ....
Préampli
Très surpris par ce préampli convertisseur avec un très bon son
beaucoup de détails.
Acheté pour un second systeme, mais branché sur mon installation principale à haut rendement juste pour voir, aucun bruit très beau mariage avec mon ampli NCORE 6 canaux en amplification active à haut rendement
Incroyable à ce prix. Merci AUDIOPHONICS pour trouver des produits de cette qualité et toujours aussi rapide pour l'expédition et le suremballage.
Ravis de mon achat
Krešimir F.
MOONDROP MOCA Dynamic True Wireless In-Ear Monitor IEM 20Hz-20kHz Grey With the Moca, Moondrop offers us wireless in-ear monitors equipped with a dynamic 10mm driver with a ceramic and titanium nitride membrane, ensuring a sound experience that is...
Very solid sound and build quality
It's probably the best buy in this price category. It has very clear and transparent sound and solid build qualility.
Fast and reliable order processing and shipping.
Aleksandar C.
Fantastic headphones
I can safely say that these headphones will gain cult status. Great sound, the bass is excellent, which I like the most. From the equipment you get with the headphones themselves to the quality of construction and comfort. For this money, you can't do better. You even get a lot more. All recommendations for this model.
And of course I would like to thank the people from Audiophonics, for the quick realization and sending of the product.
Le magicien !
Pfuuuu, c'est raffiné, spatial, chaud, la musique coule sans stress, la trompette de Clark Terry est dans mon salon comme jamais ...et pourtant monté avec de simples Amphenol. C'est une belle découverte pour moi qui connaissais déjà et appréciais le 3004 et le nemoi 3220. Tout est remis en question...Et merci Audiophonics pour toutes ces pépites que vous proposez. Un audiophile connecté.
Raymond L.
Hub USB 2.0 OTG Micro USB USB-A This USB hub has a total of 4 ports: 2 female USB-A connectors and 2 female Micro USB connectors. The interface is via a male Micro USB connector, ideal for connection to a...
Erreur de Cde
Sans doute bien mais je me suis trompé dans le modèle. Il me fallait le hub normal a 4 branchements. R.L.
Hubert K.
Je suis un vieil audiophile dont la "chaîne hifi" ne comportait qu'un lecteur CD et un DAC Audiphonics associé.
M Aubert d'Audiophonics m'a parfaitement guidé dans les méandres de la musique dématérialisée, incluant son conseil pour la mise en place d'un CPLwifi dans la dépendance où ma pièce d'écoute dédiée est installée
Depuis, ce petit et mignon streamer WIIM PRO relié à mon préampli par le cordon fibre optique fourni et un abonnement Qobus studio enchantent mes oreilles, avec une qualité d'écoute extraordinaire.
Encore merci M Aubert!
Hubert K.
Christophe l.
XANGSANE XS-DIY1 Pure Silver Wire 99.99% FEP Ø0.8mm The Xangsane XS-DIY1 is a high-end cable with 99.99% pure silver as the conductive material. This ensures maximum electrical conductivity for optimal audio signal transmission....
Très bien dans mon cas
Câblage interne Ampli cochet transfo vers borniers .
Améliore nettement les détails . le haut du spectre est mieux .
le bas moins présent , mais plus précis et rapide .
facile a souder , j'ai double le câble.
sur mon système c'est mieux .
Christophe l.
Super petit câble
J'ai utilisé ce câble argent doublé sur sortie transformateur d'un ampli cochet vers bornier avec de la soudure argent en 4 % .
J'ai gagné en détails et l'image sonore est plus précise cela réveille le haut du spectre .
Dans mon système c'est mieux.
Impeccable!
Le transformateur est livré avec les tensions attendus et avec la forme attendu. Petit bémol: deux mois de délai pour la livraison! Le fait d'avoir le choix et de dimensionner son transformateur comme on veux est une grande chance, alors on peut pardonner sans peine Audiophonics si le délai de livraison n'est pas très bien contrôler...
gerard p.
DAYTON AUDIO SPA300-D Class D Amplifier for Subwoofer 300W 20Hz-200Hz The Dayton Audio SPA300-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in...
correspond à mon attente. Livraison très rapide. 48h. Site à recommander. Date livraison, respectée, colis très bien conditionné. Site à retenir pour prochains achats. Ampli mis en place dans mon caisson de basse, fonctionne très bien .Vraiment pas déçu!!
Laurent Olivier M.
O-NOORUS D3 Class D Amplifier TPA3255 Bluetooth 5.0 2x130W 4 Ohm Red With its D3 class D amplifier, O-Noorus offers a compact, powerful amplifier with the essentials. The D3 features a TPA 3255 amplification chip and an output power of around...
Très bon ampli polyvalent
J'étais à la recherche d'un ampli 2.1 pour piloter deux enceintes extérieures Focal et un caisson de basses. Utilisation : regarder des films en plein air, et mettre l'ambiance pour les soirées entre copains.
Objectif atteint : la puissance est suffisante (les focal ont un rendement plutôt faible), le son de grande qualité quelle que soit la source. Un bon point aussi pour l'affichage, très lisible.
Ce qui lui coûte une 5e étoile : les 2x300w annoncés dans le descriptif sont tout à fait fantaisistes (2x75w des spécifications sont plus réalistes, mais pas avec l'alimentation fournie), même si la puissance est plus que suffisante pour mon usage, et la fréquence de coupure du caisson n'est pas annoncée ni réglable.
Richard P.
Équilibre !
Utiliser en câble ampli/enceintes et en interne pour le grave/médium des 2 voies que je restaure, il s'avère très naturel, dynamique et équilibré.
Pas de surprise. Ça marche à tout les coups. (Elipson, Focal JM Lab, SIARE)
Une référence pour moi à ce prix.
Sur des 3 voies, je l'utilise pour le grave et je préfère en médium l'Athom Zef mini mais c'est un autre tarif 3 fois plus cher.
Pour les aigus de toute mes restauration, mon chouchou est l'Oyaide explorer.
En conclusion l'Orbit 225 est un très bon câble pour 4€/m.
Patrick M.
OYAIDE PA-2075 RR V2 Phono Cable RCA-RCA Pure Copper OCC Shielded with Ground Wire 1m The OYAIDE PA-2075 RR V2 is an RCA-to-RCA phono cable featuring a high-end design that transmits a stable signal faithful to the original.
Un must
Aigu lumineux, médium souple, grave ferme et bien détouré.
Système d'écoute: platine vpi classic 1,cellule Dynavector xx2, préphono Aurora Vida Phono.Un excellent rapport qualité prix.
Alain L.
LHY AUDIO LPS-A6 230V Linear Power Supply Module for EverSolo DMP-A6 The LPS-A6 linear power supply module developed by LHY Audio has been specially designed to improve the power supply stage of the EverSolo DMP-A6 and DMP-A6 Master Edition...
Pas de chauffe.
Pierre L.
Qualité du son au top.
Bruno P.
Très bon préampli
Roudoudou
Rendu sonore doux et rond.
Multi-Strand Litz Wire PU Insulated 30x0.1mm 0.236mm² Litz wire is a conductor whose strands are insulated from each other by a layer of varnish to eliminate the skin effect. This copper conductor also provides excellent electrical...
Ok
Male Jack DC 5.5/2.1mm Connector Gold Plated Ø6mm This DC 5.5/2.1mm male jack connector will allow you to design your own power supply cables. It offers a nice design quality, with a metal body and gold-plated contacts ensuring...
Joli mais ...
EXCELLENT TOUT SIMPLEMENT...
Derrière ce petit DAC de quat’sous qui ne paye pas de mine se cache un vrai potentiel musical. Je possède 5 DACs différents (Fostex HPA8, Rod RainD1, Akliam D1, Aiyima A05 pro, SMSL SU-1). Et ce dernier tient la dragée haute aux précédents. Question qualité de fabrication on ne peut bien sûr pas comparer le coûteux Fostex HPA8 avec le petit SMSL mais franchement côté musical le petit SU-1 tient la comparaison. Mon premier conseil sera d’utiliser l’entrée USB C exclusivement pour l’alimentation 5V cc et d’injecter vos fichiers musicaux sur l’entrée COAX, de loin la meilleure. Pour ma part j’utilise de SU-1 connecté sur un lecteur CD car je reste et resterai fidèle à cet excellent format (Wave codé sur 16 bits) qui est un format authentiquement haute définition capable de retranscrire les timbres instrumentaux et vocaux dans leurs plus fins détails ; le streaming dit HD (96, 192, 384 kHz) étant à mon avis un non-sens n’apportant pas de plus-value musicale, ces formats devant plutôt leur existence à des considérations commerciales. Mais revenons au SMSL SU-1 ; par rapport aux DACS à puce(s) ESS 9038 que je possède, le SU-1 est plus doux dans le haut du spectre, excluant toute fatigue auditive, et cette douceur n’est pas le résultat d’un manque de résolution, les contours instrumentaux restant d’une très grande netteté. C’est par l’équilibre spectral que le SU-1 étonne le plus: je ne ressens aucun registre prenant le dessus sur un autre, le grave est consistant, sans traînage, le médium expressif et bien timbré et l’aigu ne vrille pas les tympans. La dynamique est bien contrôlée, sans exagération artificielle mais sans nonchalance non plus, tout est expressif et musical. Les atmosphères des lieux d’enregistrement sont admirablement reproduites et l’image stéréo bien développée en largeur et aussi en profondeur à condition bien sûr qu’aucun des maillons de votre chaîne ne la limite (soignez vos câbles !). Ce SMSL Su-1 est vraiment étonnant et révèle les progrès constants en matière de conversion numérique/analogique et la compétition que se livrent les deux fondeurs en vogue (Sabre et Asahi Kasei). Mes seuls doutes iront à la fiabilité, car d’expérience, ces petits systèmes chinois peu coûteux ont la fâcheuse tendance à ne pas dépasser leur deuxième anniversaire ( ?).
IFI HDMI ISILENCER HDMI Female to HDMI Male EMI Noise Suppressor iFi Audio's HDMI iSilencer is an HDMI filter designed to reduce noise and jitter in your signal and protect your equipment from surges that can be caused by electrostatic...
ALAIN A.
très bon mariage avec FURUTECH NAS 4.1
ALAIN A.
FURUTECH DAS-4.1 Balanced Interconnect Cable OCC DUCC Copper Ø10mm This Furutech DAS-4.1 balanced interconnect cable offers an absolutely outstanding design quality that will allow you to design your own high-end audio cables. It features two...
Magnifique de vérité et qualité dans les timbres: super produit
TUNG-SOL 12AX7 Tubes Triodes (Matched Pair) The Tung-Sol 12AX7 are high-gain dual triode tubes of superior quality with ultra-low microphonic effects and ensuring a wide soundstage and warm, musical sound reproduction....
Client satisfait :-)
M'ont permis de redonner vie à un préampli pour basse Peavey du début des années 90, avec à la clef une excellente réserve de gain, un son transparent et profond, et un overdrive doux et très musical.
Expédition sans souci dans un emballage soigné.
Steve D.
Wow!
Commande reçu rapidement, super service.
Alors que dire de ces blocs mono..... Envoutants, musical et détaillés. Pour l'instant qu'une journée de rodage. En attente de mon préamplificateur, branché directement à la sortie d'un WiiM Pro avec contrôle de volume. Vraiment super simple, beaucoup de réserve. Prenez les 2 alim séparées.
M'a permis de réparer le préampli d'une basse active dont le connecteur d'origine avait rendu l'âme.
Patrick s.
Remarquable
Ecoute très linéaire et détaillée mais avec une légère perte de dynamique. Peut être est ce du Dia total. Il a suffit d'ajouter un fil plein de 0,8 mm2 de CU/PTFE et la dynamique était de nouveau là dans rien retirer aux qualités du câble. Très satisfait, surtout compte tenu du prix. Service Audiophinics au top comme toujours.
Achat E1DA 9038S GEN 3
Toujours aussi efficace, commande livrée rapidement et plein de bons conseils.
Le E1DA 9038S GEN 3 est vraiment bon, super qualité.
Roberto G.
OYAIDE DST-75R V2 Coaxial Cable RCA SPDIF 75 Ohm 102SSC Rhodium Plated 0.7m The OYAIDE DST-75R V2 cable is a very high quality 75Ω RCA coaxial cable with a unique architecture and assembled with high-end connectors. These RCA...
Profond, précis, aéré !
Excellent câble coaxial Oyaide. Je l’ai connecté à un lecteur CD Tonewinner TY-30 en utilisant le dac de l’ampli après avoir essayé un dac externe (je n’entre pas dans le détail des marques car j’ai essayé plusieurs amplis). J’avais d’abord essayé divers câbles RCA mais malgré une belle sonorité les basses n’étaient pas assez détourées et se fondaient un peu avec le bas médium. C’est un peu la tendance du lecteur TY-30. Aigus et médiums très lisses et aérés mais à mesure que l’on descend dans le spectre, le son semble devenir de plus en plus analogique. Je trouve que c’est un atout pour un lecteur CD mais il faut trouver le bon câble pour mettre en valeur ses particularités. J’ai donc essayé un câble coaxial Mogami avec connecteurs Canare, la sonorité est devenue légèrement plus vive avec des basses un peu plus tendues et précises. J’ai ensuite essayé le câble coaxial Oyaide DST-75R V2. Avec ce câble la scène s’est ouverte en largeur et surtout en profondeur avec de l’espace entre les instruments. Une sonorité plus aérée dans l’ensemble du spectre. Des aigus fins, détaillés sans dureté ou acidité. De beaux médiums distincts et des basses un peu plus tendues, précises et profondes. Rapides et percutantes. Finalement, ce câble Oyaide est vraiment très bien conçu car il met parfaitement en valeur la musique et, dans ce cas précis, les qualités du Tonewinner TY-30.
Markus H.
A great amp, unbeatable for the price
Extremely clean, crisp and analytical sound. No discernible noise, even if you hold your ear directly to the tweeter. This also speaks in favour of the high quality of the power supply unit. Its treble is a little too strong for me personally, but I easily reduced it using the tone control. Operation is very simple and the workmanship is very high quality. Thank you, Audiophonics, for the fast and safe delivery.
Didier a.
Beau boitier
La fabrication est soignée mais c'est vrai que des équerres de soutien au milieu pour un meilleur maintien seraient un plus (j'ai dû également les fabriquer). Un mode opératoire serait également un plus pour ceux qui ne sont pas familier avec les fixations dans des profilés. A noter également qu'une méthode plus simple de fixation de la face supérieure faciliterait la fermeture du boitier en fin de projet.
jean michel G.
Wiring Cable Silver Plated OCC Copper PTFE Sheath 0.2mm² Ø1.1mm Transparent This Ø1.1mm wire has a silver-plated OFC copper conductor with a cross-section of 0.2mm². This ensures high conductivity. The entire assembly is...
Occ ou Ofc
Dans le descriptif il est indiqué que c'est du fil occ, puis vous stipulé ofc.
Quelle est la vraie nature de ce fil svp ?
L'OCC (Ohno Continuous Cast) est une technologie et l'OFC une pureté (Oxygen Free Copper), un conducteur peut parfaitement être les deux à la fois.
Jean-Baptiste G.
SMSL VMV A2 FDA Amplifier Bluetooth aptX-HD LDAC UAT Subwoofer 2x200W 4 Ohm SMSL offers with its A2 a high-end full digital amplifier, integrating only audiophile quality components in a robust and design chassis made of CNC machined aluminum. Complete,...
Ampli FDA Smsl VMV A2
J'avais un ampli Atoll in 200 élément principal d'écoute avec des magnepan MG12.
Je voulais tester le FDA et comme ce sont des enceintes à bas rendement j'ai pris le plus puissant.
Après quelques minutes d'écoute j'ai été d'abord surpris presque déçu hésitant et j'ai compris que la source d'enregistrement était très importante.
Il reproduit avec justesse et rapidité le morceau enregistré s'il est de qualité.
Donc transparence sans coloration neutre.
Il chauffe peu très silencieux.
Beaucoup de connexions.
Sortie sub parfaite.
J'ai revendu l Atoll.
J'en suis très satisfait.
A noter que je n'écoute que du numérique mais il est fabriqué pour ça.
Le FDA est vraiment formidable.
J'espère une version à venir encore plus puissante.
Au 3/4 du volume il coupe.
Mais bon 86 db en 4 ohms c'est normal.
Je n'ai pas encore testé avec le caisson de basses à volume élevé pour voir si la coupure se fait au même niveau.
J'ai remplacé les pointes pas très esthétique je trouve par des pieds ronds plus sympa au visuel et pratique à déplacer.
Les pointes sont sur des petites coupelles aimantées.
Rapport qualité prix excellent.
Un grand merci à monsieur David Aubert toujours disponible et réactif aux milles questions que l'on se pose pour nos oreilles jamais rassasiées.
Konstantinos M.
NEOTECH NEI-1002 Interconnect Cable UP-OCC Silver Triple Shielding Ø11.5mm The Neotech NEI-1002 is a modulation cable consisting of two single crystal UP-OCC silver conductors. These conductors are maintained at equidistance thanks to the use of PE...
Neotech nei1002
EXCELLENT.....Thank you.!!!!!!!
Jerome D.
Très bon complément
Mis en sortie de mon routeur, c'est un très bon complément de l'IFI AUDIO iLAN purifier Pro, placé à l'entrée de mon streamer. Aucune réserve.
Jerome D.
Mis à l'entrée de mon streamer, il apporte une amélioration très notable et immédiate sur TOUS les critères d'écoute. Recommandé sans réseve
Chan Pong I.
AUDIOPHONICS HC TRIGGER SWITCH MKII Home Cinema Power Trigger Symmetrizer / Desymmetrizer The Audiophonics HC Trigger Switch MKII is a pilot-controlled source selector whose main purpose is to enable you to use your Hi-Fi system as the front channels of your home...
Quick and Auto switch No noise from Symmetrizer
At first, I am only aiming to get the auto/trigger signal function, not expecting the Symmetrizer is an upgrade from no brand aliexpress Symmetrizer.
The device build is great, I did not try the audio sensing mode but only RCA trigger from AV amp.
The switch is so instant without any pops or noise when switching.
I have not encounter any distortion or strange noise from the Symmetrizer function from this device( I notice some noise with aliexpress Symmetrizer). When comparing to what I used before ( actually 2 different Symmetrizers and both from aliexpress) the noise floor is so much more lower on audiophonics. Excellent job from audiophonics to release such perfect device.
If you are going to merge a Hifi system ( XLR output ). and another system with RCA Out to a XLR Poweramp with auto signal switching, this will be the device you are looking for!
Zdenek B.
I didnt expected this quality for this price! Didnt used it yet, but just by holding in hand everything looks great. No cold solder points, connections are straight.
