Gilles G.
Pratique
Bastien P.
Epoustouflant !
C'était la première fois que j'achetais des enceintes sans les écouter auparavant, juste en me fiant aux mesures ......
Sherman M.
Great DAC!
I absolutely love this DAC because you can switch between the two chips while you are listening to music to hear the difference.
Customers reviews - There are 20793 reviews.
Laurent D.
pas mal mais peu mieux faire.....
a la comparer avec la FURUTECH FT-SWS NCF (R) elle est au dessous au niveaux qualité sonore mais reste tres naturelle dans son ensemble ,tout depend de votre systeme a vous de voir.....
Laurent D.
the best of FURUTECH FT-SWS NCF (R)
rien a redire prise de tres haute qualité avec une réel amélioration dans l'ensemble du spectre sonore ...tres bon de conseil de l'equipe d'audiophonics et un merci pour son geste commerciale Cdlt......
Ricardo S.
QUALITY Power Adapter :)
This a fantastic, quality heave built cryogenic power adapter that delivers upon his specs.
It's definitely improve the sound quality of my Meridian highly resolving stereo system.
Highly recommended, specially for the price, it's definitely a no brainer!
Ricardo S.
Mean machine!
What a really good ergonomic and quality wire cutter, specially for cable finishing. For the price is a no brainier!
Ricardo S.
Perfect power tester
This accessory is perfect for testing your power distribution circuit, giving you the change for your self to make sure everything is built according to the electrical code!
Ricardo S.
Very good quality and well though trough accessory.
This is a very good quality built heavy bras with gold plated accessory. perfect for 6 plugs + earth box connection + incoming IEC plug C13 or C19 (in my case) connection. Very happy and satisfied with the quality and though around the built details, specially the incoming connection for the incoming IEC power plug connection.
Ricardo S.
Fantastic DIY power distribution case!
This power distribution case is of really high quality, precision built with really good solid and heavy aluminium and very good quality paint, and straight forward to built. Highly recommended.
Patrick C.
Magnifique
Après avoir l'avoir connecté sur mes deux Cabasses Brik 235 M7 de 1983, quel bonheur de découvrir la transparence et la profondeur d'écoute que développe ce magnifique SMSL AD18 et ceci dans tous les genres musicaux. Image Stéréo superbe. D'une simplicité d'utilisation quasi biblique, il fait tout ce qu'on lui demande avec brio, jusqu'à jouer le rôle d'une carte son sur le ProTools 12. Vraiment enchanté. A tel point que j'ai immédiatement souscris un abonnement chez Qobuzzzz....Et là, depuis, ce sont mes oreilles qui me disent merci.
Transaction avec AudioPhonics impeccable, livraison extrêmement rapide. Un tout petit bémol, le bouton de volume et d'accès aux menux paraît fragile sur son axe. Mais, comme tout peut-être fait de la télécommande, on n'a pas trop besoin d'y toucher. 5 étoiles largement méritées
jean claude g.
ters bon rapport qualité prix
très bon rapport qualité prix, livraison au top . Je recommande. JClaude
Très pratique
Très pratique
DAYTON AUDIO DC160-8 Speaker Driver Woofer 50W 8 Ohm 86dB 30Hz - 4000Hz Ø16.5cm The Dayton Audio DC160-8 Classic Series 6-1/2 can be used as a woofer, midbass or small subwoofer.
De belles basses
Utilisé pour une enceinte amplifiée à filtrage actif avec un ampli « WONDOM AA-JA32172 JAB 3-50 Module Amplificateur Class D avec DSP Stéréo 2x50W », ce HP fonctionne très bien. Les basses fréquences sont étonnamment belles et riches, pour le reste dans mon cas, le DSP et le tweeter font le travail.
Le DSP totalement paramétrable avec SigmaStudio est extrêmement appréciable.
Utilisé pour une enceinte amplifiée à filtrage actif, avec un Dayton DC160-8 et un tweeter de récup, de cela fonctionne très bien.
Thierry A.
VIABLUE QTC BLACK Spikes Black (Set x4) Viablue QTC spikes are made of Brass and the parts subjected to pressure (master disc, peak) are hardened with steel. The diameter of a QTC tip is 30mm.
Très bonne facture mais
Ces pointes sont d'une très bonne qualité de fabrication pour un prix qui reste tout à fait abordable toutefois la longueur des tiges filetées fournies (M6) s'est avérée être un peu trop optimisée et il m'a fallu acheter de la tige filetée que j'ai coupé sur une longueur plus confortable pour obtenir une fixation stable sur 2 des 8 pointes placées sous mes Cabasse Galion IV.
Paul P.
Grandes possibilités et petit prix
J'ai déjà posté un avis pour ce même article vendu avec sa carte fille RCA, j'en suis très satisfait. Je voulais juste préciser que le module que j'ai reçu comporte une horloge 12.288Mhz. Je le fais fonctionner en i2s output vers un module DAC PCM5102 (utilisant sa propre horloge).
Paul P.
petit dsp mais gros potentiel
Excellent produit pour le diy. Comparé à un mini-dsp, il faut un peu plus de patience et de connaissances pour le mettre en oeuvre (interface de programmation, cablage, sigma studio, etc...) mais la carte fille RCA permet de sortir du son rapidement pour tester ses filtres. En simple correction de réponse 2:2, ou en filtrage multi-voies il y a de quoi faire.
Pour ma part j'ai réussi à faire fonctionner 1 sortie i2s stéréo en plus des 3 sorties analogiques disponibles, en raccordant un petit DAC PCM5102 . Le son est clairement meilleur sur le DAC externe. Il me reste beaucoup de choses à expérimenter : entrée i2s, configuration de potentiometres ou encodeurs rotatifs pour modifier en live des parametres (volume, preset de filtres..) du DSP , plusieurs sorties i2s simultanées, test en 96kHz, etc... Pour le prix c'est parfait. Merci à audiophonics pour la mise à disposition d'explications de démarrage claires dans le blog.
Paul P.
interface compacte
C'est petit et ça fonctionne bien sur mes 2 pc portables sous windows 7 et 10 en usb 2 et 3 (programmation d'un ADAU1701 wondom). Merci à Audiophonics pour la page de blog avec guide détaillé d'installation de Sigma studio, dans mon cas il fallait effectivement installer les pilotes séparément pour que le module soit reconnu.
David b.
le rasberry
Raspberry 2 + kali + audiophonics td 1387 , le tout monté sur cette box. La partie vide me permet d'y mettre un poids afin qu'elle ne soit pas emporté par les cables. RAS
cedric R.
les polarités...
Bonjour, vous avez inversé les polarités sur l'image du site. attention!
qualité prix au top
Connecté avec un smartphone bas de gamme sur ampli marantz , résultat bluffant pour le prix . Très bon rendu , détaillé et naturel .
JB JFX Premium Met Polypropylene Axial Capacitor 400V 8.2μF These JB JFX audio capacitors with their amazing price/performance ratio will bring you transparency and accuracy at a small price.
En remplacement sur un filtre d'enceinte Mission 761i , ce condensateur est parfait. Plus gros que celui d'origine, mais ce n'est pas la place qui manque.
Farfait
Jacques B.
Bon produit.
A un prix très raisonnable, cette terminaison est de bonne conception, de belle fabrication tant extérieure qu'extérieure et bénéficiant de très bons contacts en cuivre.
Jacques B.
Bon produit.
Robuste fabrication tant de la barrette, des prises schuko que de l'embase IEC. A recommander.
Pierre B.
Enfin une rallonge sans perte , ni mauvais contact.
Rallonge de tres bonne qualite, Assez legere, et flexible, et a prix interessant .Aucune perte de qualite, meme sur un casque a faible impedance (18 ohms). Il manque a mon avis , un manchon en caoutchouc aux connecteurs, afin d'eviter un rayon de flexion trop faible.
Pierre B.
Excellent cable blinde a prix interessant.
le cable est de bonne qualite, il est assez souple, malgre la section des fils (2, 5 mm2 ). Connecteurs de bonne facture. Il est tres efficace, a condition, bien sur d'avoir un filtre efficace en amont. A tres fortement reduit des interferences radio , sur des blocs amplificateurs mingda mc 845 C. . prix tres correct. Je le recommande.
Pierre B.
Excellent, et a prix tres interessant
Petit amplificateur casque en classe A veritable, bien construit, mais , sans fioriture. Assez puissant, tres dynamique, transparent, , bruit de fond imperceptible, capable d'alimenter sans probleme des casques a haute comme a basse impedance. Qualite sonore exceptionnelle . les plus petits details , comme les plus forts niveaux sont rendus sans distortion , ni coloration. Excellent rapport qualite / prix exceptionnel.
ASSOCIATION EXCEPTIONNELLE.
Mon dernier achat ( ampli audiophonics N CORE ) s'intègre au niveau des éléments suivants : récepteur Bluetooth CRS 8675, préampli audiophonics PGA 2310, et dac X3 Fx Audio. La restitution sonore se fait par le biais d'une paire de Q Acoustics 3020i câblée en Viard hd 12 et modulation canare. Les fichiers audios sont tous en flac hd. Que dire de la restitution: " exceptionnelle". Cet ensemble n'a rien à envier à des systèmes que l'on qualifie haut de gamme. Tout le spectre sonore est restitué avec une qualité surprenante. La tessiture des voix est riche en émotion. Les aigus files très hauts avec matière et subtilité. Tous les types de musique sont restitués avec une véracité surprenante. Le secteur grave n'est pas en reste. Il est surprenant non seulement par sa spontanéité, mais également par son exploration des infras graves. Bluffé par cette déferlante sonore, mon ami aux système haut de gamme, reconnaissait avec fairplay la qualité exceptionnelle de ces nouvelles électroniques.
Sandras Z.
DAYTON AUDIO ND105-4 Speaker Driver Midbass Aluminium 30W 4 Ohm 87dB 60Hz - 10kHz Ø10cm A midrange bass driver in a compact and sturdy format. Able to produce faithful sounds with a significant dynamic impact.
DAYTON AUDIO ND16FA-6 Speaker Driver Dome Tweeter Silk Neodymium 10W 6 Ohm 88dB 3500Hz - 27kHz Ø1.9cm
PETIT PAR LA TAILLE,GRAND PAR LE SON
Le PGA 2310 a été comparé chez un ami à des préamplis ( Mark Levinson, Classé Audio, Bel canto, préampli passif schéma Sonic Frontiers). Grosse fut notre surprise de voir le PGA 2310 tenir la dragée haute à ces préamplis d'exception. La qualité des timbres, la dynamique, la définition, l'espace sonore tout était présent. Mon ami n'en revenait pas, bluffé par ce petit préampli qui paraissait minuscule à côté de ses appareils HDG. Notre conclusion était celle du titre. Petit par la taille mais grand par le son.
Philippe A.
fais le boulot
boitier commandé et arrivé très rapidement comme d'habitude avec vous. permet de visualiser un lecteur de laser discs en hdmi, le convertisseur fais ce qu'il peut, et selon le disque les résultats vont de passable à bien. simple à utiliser.
Thierry B.
nickel sur mon caisson
reçu rapidement, trs pratique pour la connexion du gros caisson HC
Jean-Christophe M.
Beau boitier mais impossible à travailler
Le boitier correspond très bien à la description belle finition rien à dire de ce côté là, le problème avec l'aluminium c'est q'un DIYeur du dimanche ne risque pas de monter quoi que ce soit avec il vous faudra faire appel à un professionnel tôlier ou métallier pour le perçage
Jean-Luc M.
Très bon câble de qualité juste la gaine un peut trop rigide,très belle qualité d'image et de son.
Jean-Marie A.
C'est une solution intéressante de correction acoustique
Commande et Livraison chez Audiophonics rapide et bien faite.
Le Dirac est simple (mais attention, précis pas à pas) à installer.
IL faut tout de même être à l'aise avec l'Anglais. La notice est sur le net et la site de MiniDSP est très complet pour explorer les possibilités de correction acoustique d'enceinte et de pièce, avec ce matériel. On peut récupérer un fichier fait avec Rephase ( en 1024 tags seulement et en 32 bits ce qui n'est pas mal) , ce qui est déterminant pour travailler la correction plus précise. L'ergonomie du logiciel de réglage est très bien.
seule chose que je regrette, est le manque d'un inter On/off externe, voire d'une liaison d'alimentation en 12 volts sur carte d'ampli par exemple. ET la télécommande pour driver sans l'ordinateur est en option en plus, il faut penser à l'ajouter à la commande. Bon produit qui fait l’essentiel et sans dépenser des sommes folles en matériel redondant.
Dirk S.
AUDIOPHONICS PA-S125NC XLR Class D Stereo Amplifier NCore 2x75W 8 Ohm The Audiophonics PA-S125NC XLR integrates a Hypex NCore NC122MP power amplification module. This is a solid basis for building a high-performance stereo HiFi system, capable of...
perfect smal amp's
I use this amp's in the high / mid section of my active speaker
pierre c.
Produit conforme, bien fabriqué, malheureusement les délais affichés sur le site sont exacts(Environ 2 mois entre la commande et la reception).
Antoine E.
Mon ampli retrouve ses couleurs ! c est vraiment nickel, les les sont biens calibrées, ni trop blanches ni trop sombres!
c est re parti pour longtemps !
bon produit...
après avoir lu les autres avis je me suis lancé et il sont réellement amortissant. le visuel sur le cite ne le permet pas mais on peut en juger en les écrasant entre les doigts. pour des HP DIY c'est parfait ainsi que pour ma platine cd plutôt imposante ( sony 300 cd ) que je réutilise aujourd'hui grace à ces absorbeurs EVA. bon rapport qualité-prix.
Dominique L.
Coaxial canare
Excellent câble avec une bonne qualité de fabrication
Meilleur définition dans lespercussions et dans la tenue du grave
Rapport qualité prix remarquable j'aimerai pouvoir faire une comparaison avec des câbles beaucoup plus cher
Achat recommander
Elisabeth J.
Très utile !
Ayant remanié moi même mon circuit électrique, j'ai trouvé cet article très utile pour vérifier la réussite du montage de chaque prise.
Valery S.
Belle connectique de qualité, ça faisait un moment sue je voulais essayer un produit sans soudure afin d'avoir "un intermédiaire" de moins, et le résultat est fructueux, sur le câble haut de gamme que j'ai dépecé (Burmester Silver) en enlevant ses prises de qualité soudées j'ai eu un petit gain for t sympathique à l'écoute :)
Valery S.
Valery S.
Valery S.
EIZZ EZ-206 XLR Gold Plated 3 Way Female XLR Connector PTFE Ø9mm Red (Unit) This XLR EIZZ connector with PTFE insulation allows the design of XLR balanced quality cables. Its gold-plated finish and seamless screw terminal blocks ensure first-rate contact.
nicolas s.
DYNAVOX 3 Way Female XLR Connector Ø8mm Black (Unit) This affordable XLR connector will allow you to design good quality cables at a contained price. It is also dressed in a black shell for easy cable identification.
Très bon matériel conforme à mes attentes
nicolas s.
Cezary C.
Wall Plate Aluminum base plate Schuko for FURUTECH FI-E30 Black We designed this all-aluminium wall plate to cover the Furutech plugs FI-E-30 (G) and FI-E-30 (R) and thus transform it into a complete wall socket.
A great alternative, and the price ... I heartily recommend.
Dominique M.
Efficaces
Livrés en packaging avec la clé allen,serrage efficace,bon contact .Fait le travail que l’on en attend !J’espere qu’il s’agit réellement de cuivre doré.
Vismantas B.
best amplifier in 1500+ euro range , for only 500 eur:)
better what gustard a20h.
im using it with HD800S headphones +balanced cable
awesome combo !!! no need for tube amps... this amplifier delivers smooth midrange, clear highs, bass a little weak, boot acceptable,and 3D soundstage is very good. My best invested 500 euros :)
Mehmet B.
