Patrick H.
Peu à dire
Profitant du débit de la fibre et d'un dac de la même marque mon installation délivre un son bien supérieur à mes...
fabrice d.
pareil
Idem pour moi
Deux casses
Malheureusement une fois sous garantie et pas la deuxième
Dommage
Comme je l'écris...
Customers reviews - There are 19541 reviews.
HIDIZS SD2 Portable DAC Headphone Amplifier USB-C to Jack 3.5mm ES9270 32bit 384kHz DSD128 Black The Hidizs SD2 is a versatile, high-performance USB-C to 3.5mm jack portable headphone amplifier and DAC dongle. Equipped with an independent ESS ES9270 DAC chip, it supports...
Good...
Good sound, strange shape (and you have to put it in the right position...) but good.
Luka Š.
As described top quality nice to cut, easy-to-use and install for self built very good and after testing showing it's purpose. Very nice. Recommend
Luka Š.
Top product
Connection good and firm easy to connect solid build gives nice look and small improvement with cable over all sound was deep and bass tight specifically on low volume listening. Nice product for the money. Recommended
Luka Š.
ATAUDIO AT-FR008 RCA Male Connector Ø6mm (Pair) This ATAUDIO AT-FR008 male RCA connector has a carbon-fiber body and gold-plated pure copper contacts. Its carbon body provides insulation against interference, while the...
Ok for the money
Good quality for the money bottom diameter is little bit smaller than on scheme so with designated cable need little force than you should be fine. For connection they are solid and tight but no sonic difference from cable direk connection.
Luc V.
MUNDORF MLYTIC AG Capacitor 25V 10000µF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Très belle qualité
Ces condensateurs m'ont permis de sauver mon DAC Fostex HP-A8C, dont les condensateurs d'origines, trop vieux, généraient des gargouillements.
Le scotch double face permet de fixer solidement le condensateur et facilite vraiment l'installation.
Quant aux qualités musicales, si j'ai clairement un son de très grande qualité, je ne saurais dire dans quelle proportion je peux l'imputer à ces condensateurs et pas au reste du DAC.
Je retiens surtout que sans ces pièces de rechange, mon petit FOSTEX était bon pour la casse !
Giuliano P.
TAD 6L6GCM-STR REDBASE Power Tubes Pentode (Matched Pair) The TAD 6L6GCM-STR Redbase is TAD's latest design and production, claiming to be the best 6L6 tubes ever made.
OK
Les Tads ont remplacé les 6L6 sans marque qui équipaient mon amplificateur classe A single ended et le résultat était très bon. Ils doivent encore être rodés mais on perçoit un meilleur contrôle des basses fréquences, des médiums plus définis et des hautes fréquences plus étendues. , le léger bourdonnement que l'on pouvait entendre lorsqu'on approchait son oreille du woofer a pratiquement disparu. Donc extrêmement satisfait.
Jean-Baptiste G.
Suite AD18
Pour moi cet ampli fait chanter des Magnepan MG12 complété d'un caisson REL T Zéro.
Et des ATC SCM7...
Jean-Baptiste G.
Ampli Fda SMSL AD18
Que dire...
Il a tellement d'éloges.
C'est le troisième que j'achète.
Un pour moi deux que j'ai recommandé à une personne et un quatrième que j'ai fais acheté à mon frère.
Pas cher petit rapide pas de souffle diaboliquement précis assez puissant pour alimenter beaucoup d'enceintes à volume modéré.
Ça joue de la musique sans coloration sans transformation.
Tout ce que j'aime.
Ha ce petit AD18...
Il a du en envoyer au grenier des gros amplis 20 fois plus cher que lui.
Jean-Baptiste G.
Banana Plugs Rhodium-Plated Ø8mm (Pair) These affordable Rhodium-plated banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers. The rhodium-plated contacts...
Fiche banane
Je ne recommande pas ce produit.
La fixation du câble ne me paraît pas très bonne en conductivité.
Ou alors peut être pour du gros câble.
Pas pour moi.
Jean-Baptiste G.
Câble argenté.
Très bon câble argenté.
Je prends toujours de l'argenté pour privilégier les aigus.
Fin et flexible gaine tendre assez fragile à prendre en compte.
Jean-Baptiste G.
Banana Plugs Silver Plated Ø5mm (Pair) These low-cost banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers. The contacts are silver plated to ensure excellent signal...
Fiches bananes.
Excellent produit et pas cher.
Petit fin pratique pour les petits amplis avec peu de place connexion du câble parfaite et connexion au bornier également.
Prix la paire déjà 3 achats.
Michel l.
superbe
après avoir eu depuis 4 ans le MPA-S250NC qui me convenez très bien est a comparer à d'autres ampli de classe A il n'avait pas a rougir . ce à quoi j'ai jeté mon dévolu sur le purifi LPA-S400ET en comparaison du MPA S250C UN GAP significatif de maitrise de la musique d'une justice insoupçonnée de micro Details très aéré qui en fait en parti un produit exceptionnel merci a vous pour tous les conseils avérés des produits audiophonics
Yves G.
Placé entre un tuner fm/dab dont le volume de sortie est très élevé et un preampli dont la télécommande fonctionne par increméments assez larges il me permet d’atténuer le niveau et de ne plus passer de 0 à un son trop fort en un appui sur la touche de volume. Avec du matériel haut de gamme dont l’écoute à bas volume est excellente cela permet de gérer les sources pêchues. Evidemment il faut encore deux câbles et quand on y met le prix… en tout cas je n’entends pas de perte de qualité.
Female RCA Connectors Gold Plated Ø6mm (Pair) These good quality and low cost female RCA connectors are ideal for designing RCA extension cables. Their gold plated contacts ensure very good signal conductivity and excellent...
Qualité médiocre
Je pensais avoir des connecteurs de bonne qualité, mais après réalisation de mes câble je me suis rendu compte que la continuité de la masse n'était pas garanti avec ce connecteur. La partie doré et la partie argenté ne font visiblement pas bien contacte et après soudure l'intérieur du connecteur avait diminué de diamètre rendant impossible son utilisation.
Dommage, mais vu le prix, on pouvait s'y attendre !
Pourquoi faire plus chère
Coté blindage, c'est je jour et la nuit avec les câbles d'origine de ma platine vinyle. Plus aucun ronflement.
Pour ma part j'ai joint le rouge et le jaune au point chaud, le blanc et le bleu au point froid, la tresse de masse à la masse de ma platine, le fil de masse reliant la masse de ma platine à mon ampli.
La qualité est trés bonne malgré les 3 mètres de câble entre mes deux appareil.
Soudure facile et de qualité.
Arrivé dans un simple sachet plastique, la quantité de fils et largement suffisant pour réaliser 1, 2, 0 câble.
les soudures sont de bonne qualité sans avoir à chauffer à l'extrême.
Belle finition, mais attention à la mise ne place.
Je pensais que ce serait les soudures qui me poserait le plus de problème à la réalisation d'n bon câble phono, mais c'est bien la mise en place de cette gaine qui à été une vraie difficulté (pour moi novice du DIY en câble audio).
Mais la qualité de finition est à la hauteur du temps passé à enfiler les trois câble dans cette gaine.
Petit bémol toute fois, le début et la fin de la gaine partent en morceau, prévoir un mettre de plus pour être vraiment tranquille.
Très Agréablement surpris
Très bon rapport qualité prix pour ce produit que je pensais tout en plastique.
Le corps est bien en métal, la finition et des plus agréable à l'œil et coté fonctionnement, rien à redire.
Pour le prix, allez y les yeux fermé, enfin si le prix ne vous semble pas trop bas!
David C.
FIIO R7 Audio Player DAC ES9068AS Headphone Amplifier 2x THX AAA-788+ 32bit 768kHz DSD256 MQA The FiiO R7 is the brand's first ever digital audio player featuring a high-performance ES9068AS DAC chip, two high-power THX-788+ headphone amplifier chipsets and a beautiful...
Fantastique !
Le FIIO R7 et un superbe élément hi-fi extrêmement bien construit. Ce petit boîtier regroupe 3 fonctions : DAC, streamer et amplificateur pour casque. J’ai été très impressionné par sa qualité de restitution et sa musicalité, utilisé avec un Meze Audio Classic 99 avec Qobuz en HI-RES c’est tout simplement une dinguerie!!!! Ont plus envie de ce décoller le casque des oreilles ! Je n’irai pas dans l’argumentaire audiophile car chacun d’entre nous doit se faire son propre opinion, mais j’estime que cet appareil peut parfaitement trouver sa place dans une installation hi-fi de bonne facture ! Bref cette petite boîte m’a franchement épaté
Tamás S.
increased headphone system
i used this cable before my power strip, and it helped me increase my headphone sound quality (after titanex power cable).
Thanks.
Hocine H.
Super câble
Utilisez en monobrin pour un câble symétrique, il dépasse toute mes espérances au point que j'ai mis au rebus mes anciens câbles NEOTECH. Le seul bémol c'est qu'il aiit augmenté de 40% en 1 semaine!
Rémi D.
1877PHONO OCC Silver Dart Shielded Power Cable 3x5.26mm² 1.5m Here is the OCC Silver Dart power cable by 1877Phono, having OCC Crystal Copper conductors of 3x5.26mm². The latter is the culmination of 3 years of development and testing...
Câble à Privilégier pour les équipements à consommation constante
Je peux certainement me tromper mais je dirais que les câbles d'alimentation très isolés comme ce câble, ont un effet négatif sur la dynamique de la musique si vous alimentez un ampli de puissance ou intégré : il y a comme un effet passe-bas, un amortissement très audible (augmentation des graves, diminution des aigus). La musique perd en vie. L'ampli n'arrive pas à suivre fidèlement les sollicitations de la musique.
Par contre, il peut s'avérer intéressant pour alimenter une source (transport) ou un Dac, éventuellement un préampli dont les besoins en courant sont quasi constants.
Remarque : c'est un câble de bonne facture.
Rémi D.
C'est un excellent câble :
- J'ai gagné en aigus, en graves, en détail, en ouverture,...
- selon loi, ce câble vaut des câbles d'autres marques 2 à 3 fois plus chers
Si vous recherchez une écoute audio transparente, sans coloration, ce câble est un bon candidat pour faire partie de votre chaîne.
Viktor S.
IFI AUDIO GND DEFENDER Main Power Supply Ground Loop Filter 90-240VAC The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can create low frequency hum. The GND Defender intelligently detects the...
Exellent
Used it directly on my PC's power supply, i have Topping E30/L30 stack and my speakers were noisy, now i don't have the problem anymore. You only need 1 of those if you have a ground loop.
Michel B.
DENAFRIPS PONTUS II 12TH-1 DAC R2R NOS Balanced 1536kHz DSD1024 Silver The Denafrips Pontus II 12Th-1 NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering ececption sound performance. Here,...
Étonnant ce Pontus
Il a pris la suite d’un Schiit Yggdrasil de 5 ans à la sonorité qui me convenait mieux que celle des ESS et autres…
J’avais déjà goûté au DAC R2R avec un DAP Hiby RS8 cela m’a décidé .
Le Pontus est sidérant!
J’écoute au casque ( Utopia) avec un ampli à tubes, le Prautes et un lecteur réseau Aries G1. Il n’y a pas de mots pour exprimer mes nouvelles sensations musicales .Essayez, vous verrez …
Je vais changer de lecteur réseau, j’attends avec impatience un Aries S1 qui me promet encore un peu plus de plaisir musical.
Quel bonheur ces nouveaux appareils…
C'est le 3e de ce type que j’achète , c'est dire qu'il me satisfait !
Pas fait pour du multibrin .
Le système de serrage des câbles n'est pas génial pour du multibrin, étamage obligatoire.
Correct pour le prix
Quelques précisions : les câbles internes sont aux couleurs standard : marron , bleu et jaune-vert , pas de drain il faut le fabriquer a partir de la tresse , aucun marquage sur la gaine indiquant un sens de branchement , la structure des câbles multibrins semble identique à ceux que l'on trouve en magasin de bricolage . Donc si vous avez besoin d'un câble standard avec un blindage , c'est parfait !
Eric z.
très pratique
je confirme connecteur très pratique avec assemblage sans outil et de qualité pour du DIY dans mon avec câble CANARE RJC6-4P-SFM
c'est du sérieux !
Rupert S.
La version 2 SVP
Bonjour, ce DAC est bien noté partout ! Je l'utilise depuis qu'il est sortie et ne m'en lasse pas. Il est directement connecté à un amplificateur Audiophonics avec des modules Hypex via des connecteurs XLR.
J'aimerais voir une version II de ce DAC! Les améliorations et corrections devraient être faciles à implémenter avec le recul que nous avons à présent.
Aussi, une plaque arrière compatible Raspberry Pi 5 serait très bien venue.
Merci pour ce produit unique qui réunit tous ce qu'on peut souhaiter pour un streamer/DAC dans un boîtier compacte et à un prix abordable.
Benjamin W.
Utilisé dans une voiture ancienne
Je l'ai détourné de son usage principal Maison en le mettant dans ma voiture ancienne.
Branché en 12V (fusible impératif), connecté à deux HP de 40Wx4ohms chacun, c'est parfait !
Seul bémol, le son de la voix lors de l'allumage de l'ampli est un peu fort au niveau medium du son de l'ampli.
Hocine H.
DD BC30XLR XLR Interconnect Cables Stereo Silver OCC Copper Gold Plated 75cm (Pair) DD HiFi's BC30XLR is a 3-pin XLR to 3-pin XLR cable that can be used for all your balanced output connections, such as, for example, a DAC to an amplifier or active drivers. The...
Un très bon câble à prix abordable. Très souple, bien fini et très musical. Je l'ai démonté pour regarder la conception et c'est du travail de pro, très bien isolé. Pour ce prix difficile de faire mieux
Vincent W.
Value for money
This is a nice, truely neutral cable. With clean, clear highs and lows, but a bit lean and dry in the mids. Overall nothing spectacular, but good value for money.
Le top qualité prix!
Bonjour, j ai acheté cette alimentation pour mon phono limetree 5v , j ai testé avec cable standard , c est deja bien ,puis avec un cable belden,iec iego or et bals schuko , c est encore mieux . Avec cable standard je mettrrais 4 etoiles et avec un cable meilleure 5 etoiles .belle finition , on gagne en silence ,donc details ,precision, en timbre,douceur,tenue, basse plus punchy , un bas medium plus epais , je la recommande vivement avec un cable digne !
Christophe G.
HYPEX NILAI500DIY Amplifier Kit Mono Class D 1x525W 4 Ohm This kit, based on a Nilai500DIY amplifier module and a PS500DIY power supply board, will enable you to design your own 525W (under 4Ω) mono Class D amplifier. As the...
Hypex Nilai 500 DIY kit - Blocs Mono en Classe D
J'ai commandé 2 kits pour amplifier une paire d'enceintes colonne françaises (des Kelinac 714 MG pour ne pas les citer).
La livraison s'est faite dans le délai prévu.
Mon choix s'est porté sur ces kits pour profiter des connexions natives XLR du module d'amplification Nilai 500.
Le montage est relativement facile, la notice est très claire et bien détaillée.
Le châssis est de bonne facture, je ne m'attendais pas à ce qu'il soit aussi épais.
En prenant tout mon temps, il m'a fallu une heure de montage par bloc.
Impression générale d'écoute après trois semaines, ce sont des modules qui proposent une écoute très naturelle,
aucune emphase ni dans le grave ni dans le médium comme on peut en rencontrer (et même apprécier) avec nombre d'amplificateurs à transistors ou lampes.
Sur les chants, la diction est claire sans aucun voile.
Sur les timbres d'instrument, rien à redire, pas d'appauvrissement ni d'embellissement artificiel.
Sur de l'orchestral, la scène sonore tant en profondeur qu'en largeur est parfaitement en place.
Graves sous contrôle absolu, ce qui évite en montant le volume une saturation précoce dans une petite pièce.
A noter au niveau du gain : le gain maximal correspond à une sensibilité d'entrée de 1,9 Vrms (valeur maximale)
A noter au niveau montage : il y'a des vis identifiées MS-3 dans la notice (noires 3x6 avec têtes fraisées) servant à fixer le socle de l'alimentation et le module d'amplification à l'épaisse plaque inférieure,
j'ai eu une des vis qui était un peu juste pour atteindre un des pas de vis du socle de l'alimentation, pas de problème pour fixer le module d'amplification.
Par précaution, pour la fixation du socle de l'alimentation j'ai remplacé par des vis 3x10 (c'est que j'ai trouvé en magasin, des 3x8 auraient convenu, attention des 3x12 sont trop longues) avec têtes fraisées.
Adam S.
works very well but its not silver plated
the same cable as the sommercable mercator cat 7 cable that cost 20% of the price of this cable
Adam S.
works very well
it is identical with the viablue solid core rj45 cable
are 99,9% sure its the same cable viablue sells for almost 15 eur
the sound from tidal is the same with both cables
very good top performance
Richard P.
Très bon câble.
Merci à Audiophonics pour vos précieux conseils.
Avec des connecteurs RCA ELECAUDIO TE-RC85S le son est très aérien avec une belle assise. Pas fatigant sur de longues écoute.
Très bon câble.
Maciej Z.
MUNDORF ACW115BK Wiring Cable Copper / Silver / Gold PTFE 1.8mm² This top-of-the-range Mundorf ACW115BK cabling wire offers excellent manufacturing quality for maximum conductivity. Its conductors are made of high-purity copper, silver and...
I purchased 1.8mm and 0.79mm Mundorf Angelique to rewire my Snell E3 speakers.
Original Snell cable is nothing special, possible 12AWG twisted multi strand copper.
Mundorf is very stiff and hard to work with, and very hard on speaker connectors, so care ash to be taken while moving drivers with soldered cable.
It's also very hard to domestically twist 2 runs of the cable, as it twist more at the start and then further it become uneven, while if you twist more, you will apply to much pressure on the PVC so it breaks.
After 20h of initial listening I was hoping for more, but nothing changes.
The sound is dull, lacking definition and resolution, with poor soundstage. Everything became closed in. There is not much air and ambience, or textural richness. Tones are ending quicker then they should be without any pleasant overtones.
I like smooth sound too, but it must not lack definition, and clarity. This is nowhere near smoothness. It's too polite. Perhaps it would work slightly better on extremely bright, and harsh system, but if your system is neutral you should choose something else in my opinion.
When it comes to Audiphonics service, its one of the best, as usual. Great communication, great choice, reasonable pricing and fast delivery. 5 stars for the service. 1 - 2 stars for this cable.
christian w.
XDUOO TA-66 Headphone Amplifier / Tube Preamplifier 6N2 6N5P With its TA-66, Xduoo presents a headphone amplifier/preamplifier with tubes. The TA-66 features two tubes, a 6N2 tube for the...
Great value tube amplifier.
Super fast delivery to the UK. Actually quicker than me ordering in the UK
Daniel D.
super cable secteur
J'ai tiré 2 lignes séparées de mon tableau électrique à chacun de mes blocs mono avec ce Tornado sans me ruiner. Gain évident à tous niveaux et superbe musicalité avec prises Iego 8085 pour un son un peu chaud, rapport qualité/prix hors norme. Il me restait quelques mêtres de chute que j'avais remisé à la cave. Venant de recablé différemment toute mon installation, je me suis dit qu'il ne coutait rien de faire un essai avec ce reste de Tornado pour alimenter une source (ce que certains déconseille). J'ai constitué un CS avec d'un côté une schuko Viborg cuivre/or/argent et de l'autre une IEC Oyade C004. EH bien!!! après 60 à 70 Heures de rodage le mariage fonctionne à merveille avec toujours cette superbe rapidité/musicalité et belle ouverture. Je valide à 100% la polyvalence de ce cable. Une vraie réussite, à ce tarif ce câble et une vraie pépite... foncé!
Stefano P.
Addicting!
I just replaced with it the FP-3TS20 power cord feeding my pre, with immediate results! Dead silent, with a simply unheard clarity over the full range of frequencies. Unexpected and addicting.
Hocine H.
Incroyable.
J'étais un peu sur la réserve concernant le monobrin, je l'ai utilisé pour recâbler le woofer de mes enceintes et ce câble après une dizaine d'heures est d'une précision et d'une délicatesse que je n'aurai imaginé. Très belle surprise.
Hocine H.
Belle découverte
Utilisé pour recâbler le tweeter des enceintes, ainsi que le bornier, ce câble est une grande révélation. Facile à travailler et d'une précision redoutable, les tweeters on une nouvelle vie.
ANTONIO M.
3E AUDIO 480-1-29A PFFB Mono Balanced Class D Amplifier Module TPA3255 1x480W 2 Ohm This 3E Audio 480-1-29A amplifier module is a class-D balanced mono amplifier module based on a TI TPA3255 chip. This module delivers up to 480W into 2 Ohm (@ 1% THD+N, 1kHz)...
baja corriente
Es mucho peor que la 3e PFFB stereo que conservo, compré 2 mono PFFB con fuentes de alimentación lineal de 300va cada no reguladas...un desastre, no tenia ni graves ni dinámica, creo que esta internamente puenteada mal el mono de manera que si la impedancia mínima de la 3e estéreo PFFB ya son 4 ohm y necesita cajas muy facules tipo mark audio, Klipsch...la monk es para IMPEDANCIA MINIMA de +8ohm (si) por tanto con casi todas las cajas sonara sin graves ...pero si tus cajas son de impedancia mínima 8ohm, compralas, mide genial
ANTONIO M.
mejor que purifi
Tuve una PURIFI con la desastrosa SMPS hypex y sonaba estéril y enclenque. La devolví. -purifi con fuente de alimentación lineal hubiera sido perfecta sin embargo pero no se hacerlo porque es multivoltaje - . Encargué este módulo por sus buenas medidas aprebachando que la impedancia mínima de mis cajas no es demasiado baja -este no es estable a 2 ohm como purifi- pero como es un solo voltaje se le puede meter fácil un toroidal y una fuente no regulada lineal...resultado: con un previo realmente cálido/transparente como el perfecto Glasshouse TVC, la resolución es infinita el detalle el realismo , calida valvular sin ruido pero con cuerpo con grip emocionante ¡Mucho mejor que la típica Purifi o NCORE con SMPS hypex -probablemente con una SMPS Meanwell hubiera sido mucho mejor+! Brillante suena mejor -con un previo TVC - que la clase A
florent n.
SHANLING MTW200 PLUS True Wireless Dynamic In-Ear Monitors IEM Ø10mm 32Ω 112dB 20Hz-20kHz With the MTW200 Plus, Shanling presents us with wireless in-ear earphones. The brand has opted for a dynamic 10mm driver with a titanium membrane, coupled with a special...
impressive
remarkably light, side independent (left can be right and vice versa, and once you take them out of the box, it resets the earbud put in the left socket as the main earbud), they sound great. Great bass extension while keeping great clarity. No buzzing sounds from bluetooth. Compared to quality wired iem, they sound just as good. The transparency/ANC modes while "available in the voice menu" do not work but who cares? Cherry on top, a beautiful case
Valéry H.
AMPLI DAC CASQUE
Excellent ((petit)) Il lui manque juste une tél.
Comme ampli approchant les " AUDIOPHILE " Il a bien sa place.!..
michel f.
DC 15V Jack Filter with Supercapacitor to Jack DC This DC 15V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 6 supercapacitors 5F - 3.0V and an...
Attention
filtre qui ne convient qu'à une tension strictement de 15v
Maurizio I.
Avevo Cardas, ho ricablato le mie magnepan con Neotech e la differenza è disarmante! piu volume,piu profondità d'immagine,più naturalezza,più armoniche,non credo ci sia cavo migliore di questo!
