Banana Plugs Rhodium-Plated Ø8mm (Pair)
These affordable Rhodium-plated banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers. The rhodium-plated contacts provide good conductivity and resistance to oxidation and corrosion.
4.5 / 5
Reference : 18130
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 24-11-2026.
Banana Plugs
Banana Plugs BFA Rhodium-Plated Ø8mm (Pair)
These affordable rhodium-plated banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers. The rhodium-plated contacts provide good conductivity and resistance to oxidation and corrosion. The transparent plastic body reveals the wiring connection for a beautiful aesthetic effect. The cable connectors are screw-type, and another screw holds the cable firmly to the connector. These BFA banana plugs accept cable diameters up to Ø8mm.
Product typeBanana plugs
Contact materialPure copper
Contact materialRhodium
Max. cable diameterØ8mm
Mounting typeTo screw
Total length43mm
Connector length20mm
Max. body diameter17mm
Identification rings
ColorTransparent and silver
Weight6g/Banana plug
PackageBanana plugs (Pair)
Max cable diameter (mm)8.0
ConnecticMale
ConnectorBanana
2 reviews
Beware this plug has a pin in the center of it.
I ordered these to connect my loudspeaker wire to my amplifier by a Rhodium plated plug. I already had connected my loudspeakers with a set of Banana Plug Rhodium Plated OFC Copper Ø5mm. This was a step forward from the gold plated plugs I had before. Very clear and natural.
But these BFA Banana Plugs I bought now have a pin in the center. You can see it on the picture if you look closely.
My Linn amplifier has also a pin in the center of the loudspeaker terminals. So it doesn't match. A male to male connection. I have send them back.
This review has been posted for Banana Plugs Rhodium-Plated Ø8mm (Pair)
Fiche banane
Je ne recommande pas ce produit.
La fixation du câble ne me paraît pas très bonne en conductivité.
Ou alors peut être pour du gros câble.
Pas pour moi.
These affordable Rhodium-plated banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers....
