Rastislav K.
Nice
Marc A.
Un bon cable...
David m.
une super prise hifi
Customers reviews - There are 19554 reviews.
Petit mais costaud
Acheter pour mettre sur un Eepc as us ou j'ai installé Daphile
Ben je reste sur le c......
Petit la,bébête mais fait très bien son boulot
Bref je suis scotché pour la taille et le prix
Bref je recommande et livraison rapide et soigné
Donald B. B.
RaspTouch Open Source Player ES9018K2M DAC / Raspberry Pi 3 Black / RuneAudio
I apologize for writing this review in English, but I am in the United States.
I have received my RaspTouch Open Source Player ES9018K2M DAC / Raspberry Pi 3 Black from Audiophonics. The packing and shipping was flawless. The unit was well packaged and no damage occurred during its' trip from France to Texas. I had the unit up and running quickly, connected to my LAN and my audio collection on USB memory card.
Instead of using the supplied 12 VDC switch mode power supply, I opted to use a 9 VDC Linear Power Supply, braded "Jay's Audio." The instructions supplied with my RaspTouch specified the input voltage to be 7.5 - 12.0 VDC, so my 9 VDC Linear supply fit right in the middle of the range.
For other users in the USA, please note that the supplied 12 VDC switch mode power adapter is supplied with the European style 2-Pin plug. This can be easily switched out with a US style plug (not included). These are easily available on-line.
I easily connected my RaspTouch with my Android device using the RuneAudio App. This gives complete control of the device using your LAN.
I am very impressed with the build quality of the RaspTouch. The black CNC machined aluminum case is amazing! The quality of the fittings is great and the integrated Touch-Screen is very elegant.
There were a couple of adjustments that needed to be made inside the case, however. I contacted Audiophonics Customer Service and they gave me complete instructions on what had to be done. The Flashing Rainbow Icon on the touchscreen appeared. This means that the voltage coming to the Raspberry Pi 3 was too low. The voltage regulator on the Power Management board had to be adjusted to bring the voltage going to the Raspberry Pi up to specification. I found the setting at 4.7 VDC. This had to be raised to 5.1 VDC by a few turns of the adjustment potentiometer. Customer Service sent me complete instructions that illustrated what screw had to be turned and where to measure the voltage.
Also, the LED in the lighted Power Switch did not illuminate. Customer Service guided me with finding a loose cable fitting.
With these two adjustments, my RaspTouch is working perfectly. I cannot say enough about how I appreciate the quick response from Audiophonics Customer Service. They are very professional and were very well prepared to converse with me in English instead of French.
I am using my RaspTouch to supplement my hobby of collecting antique radios. I have a collection of Old Time Radio shows in MP3 format. I have the RaspTouch loaded with the shows and connected to my LAN as well as a low power radio transmitter. I use it to broadcast the shows across the house to my antique radios. In this way, I have armchair and bedside control over the programs to which I listen,
I cannot say enough about how impressed with the RaspTouch. It is an elegant but practical solution for listening to your audio collections. Some minor adjustments did have to be made, but Audiophonics Customer Service was right there to help with lighting-fast response. I highly recommend this device to anyone!
Sébastien T.
Excellent Cable il correspond tout à fait à mes exigences et Dieu sait qu'elles ne sont pas petite. Un 10/10 à audiophonics pour la qualité de ses services. Merci
Sébastien T.
Produits de très bonne facture. Je voudrais remercier audiophonics pour l'accompagnement de grande qualité et à une livraison très rapide.
jean-pierre v.
Bouleversifiant! :-)
que ce soit en coax ou en USB, j'entends des choses que je n'avais pas encore perçues auparavant! le tout avec douceur, précision et transparence...
P.S. le service Audiophonics est rapide et efficace, merci bcp
David G.
J'ai tenté le coup et sincèrement ce "petit" ampli est surprenant. Il a une sacrée pêche et se montre très détaillé si la source et les enceintes sont de qualité. Après l'avoir essayé avec des JM lab de bonne facture il a intégré mon bureau et mon tout petit système secondaire : Lecteur raspberry sous runeaudio et enceintes Eltax Monitor III. Un ensemble qui suffit à prendre pas mal de plaisir et qui n' excède pas 350 euros câbles et module de contrôle du raspberry compris !
David G.
Très bon produit.
Utilisé pour la mise en route de mon lecteur réseau sur base Raspberry Pi3 tournant sous RuneAudio, ce petit module ne nécessite pas le moindre script. Attention, il chauffe pas mal et doit être manipulé avec doigté car un peu fragile. Si le raspi manque de jus un tour sur la vis du potentiomètre règle le problème. Mais j'en commande un second par précaution tant il est efficace.
David G.
J'ai installé ce petit préampli entre mon DAC audiophonics u Sabre es 9023 et mon ampli de salon (Denon pma520) car le volume de sortie du dac était un peu faible. Je règle le volume par le préampli. Je ne note pas de différence en termes de rendu (enceintes chorus 707) mais il fait le boulot et est original. Livraison très rapide comme d'habitude.
Jean-Marc B.
Bof ....
J'ai des reproches semblables à ceux de Gilles D., à savoir un niveau de sortie très faible, et des crachements quand on tourne le volume de l'ampli (mais seulement sur la voie gauche pour moi) d'autant plus insupportables qu'il faut pousser le volume bien fort. Pour le reste, ça irait, mais je vais retourner ce DAC à Audiophonics
Steven H.
Arrête ta frime...
Pas de frime et de clinquant ici. Par contre de l'excellent matériel qui fait très bien fini. je ne regrette pas les fiches alu !!
Je les ai associées au câble VIABLUE NF-S1 pour faire un très bon câble phono. Résultat sobre mais très efficace.
Les fiches tiennent très bien sur les bornes de mon préamp phono.
Steven H.
Câble Phono nickel
Utilisé avec des fiches Elecaudio TE-RC85S pour faire un câble Phono, ça fonctionne parfaitement bien (avec bien sûr le petit fil de masse supplémentaire).
Je ne sais ce qu'a voulu dire précédemment Philippe G par "il renferme le signal", en tout cas dans mon cas, avec le montage Audiophonics masse flottante, c'est parfait. Mieux articulé qu'avec le câble d'origine.
Platine project Début carbon Ortofon 2M Red, Préamp Project Phono Box DC et ampli Hegel H100.
Patrick s.
AUDIO-GD DAC-19 2017 PCM1704UK & DSP USB AMANERO 24bit 192kHz TCXO BNC The DAC19 of Audio-GD, here in version 2017, achieves performances rarely equaled by a converter PCM1704UK. KEY POINTS: PCM1704UK DSP Altera Cyclone 24bits 192kHz USB...
Plénitude
associé à un Sony CDP 557 es transformé en drive pur (sortie spécifique 75 ohm ajoutée), je combine la dynamique et les timbres du transport de légende du Sony à la finesse et l'aération du DAC.
Un ensemble d'exception qui écrase tout à plusieurs fois son prix.
La précision et le détail obtenus permettent de facilement tester câbles de liaison et secteur pour aller encore plus loin.
Fiabilité d'Audiophonics assurée comme d'habitude.
Michel S.
Connexion défaillante
Soyons clair je n'ai pas pus testé ce dac, car je n'ai pas réussi à le connecter. Difficile à noter dans ces conditions, mais les pbs de connexion mérite au mieux un zéro. Explication; j'ai testé sur trois smartphones en Android 4 et 5, deux Samsung et un Sony, aucun des trois n'a pu le reconnaître. Ce n'est pas une surprise pour les Samsung, qui sont en délicatesse avec l'OTG, anormal avec le Sony C5, très robuste avec les périphériques OTG. Je suis passé sur unWindows 7 pro 64 bits parfaitement à jour,, un machine éprouvée et robuste, et là surprise le driver fournir par IMSL fait crasher la machine, arrêt système, lorsqu'on branche le DAC. Pour une première c'est une première! Je suis pas un novice en configuration d'outils informatique, j'ai insisté un peu, mais rien à faire, aucun contournement possible. On se croirait revenu quinze ans en arrière au démarrage de l'USB quand le branchement de tout nouveau périphérique était une petite aventure en soi. En 2017 le PnP n'est pas un lubie, ni un luxe, je démarre en dématérialisation pas envie de me coltiner ce genre de problèmes. Dommage, on reviendra, ou pas.
Nous devons avouer être surpris par les problèmes rencontrés.
Ce produit utilise une interface XMOS dorénavant universellement reconnue et utilisée sur la plupart des produits audio Moyen / Haut de gamme
Michel S.
Fait le job.
J'ai pris ce petit dac, sur la foi des bonnes critiques de son grand frère. Petit, léger, peu cher incontestablement il améliore grandement le rendu des format lossless. en écoute à partir d'un smartphone, sur enceinte type bluetooth, mais avec un câble, ou sur un casque. Passe difficilement sur ma châine hifi moyen de gamme, bonne dynamique, ton neutre, mais son quand même brouillon. Au final bon rapport qualité prix, pour une utilisation nomade.
Thomas R.
Un choix à prix raisonnable
Des "petites" fiches banne de réalisation légère mais correcte et à un petit prix (2€ l'unité).
Habillée d'une gaine rétractable, l'installation est propre.
Finalement, 4 bannes m'ont suffit, j'ai de quoi faire des essais de bi-câblages par exemple...
Une chose à noter tout de même elles sont en LAITON, et non en CUIVRE, comme leurs grandes sœurs, les SC03.
L'impact sur la qualité sonore? Je ne sais pas, le cuivre est meilleur conducteur, c'est tout (et plus cher).
Je recommande pour qui à besoin de 8 fiches sans ce ruiner et sans gaspiller son argent.
Pour qui 4 fiches suffisent, regardez dans les sets de 4 bannes au même tarif mais d'une gamme supérieur.
Salut !
Michel V.
Super son
Ce petit préamplificateur est sublime , le son est chaleureux sans aucune acidité , il se fait oublier pour laisser place à la musique.
Les basses profondes , le médium détaillé et les aigus justes comme il faut.
En un seul ; c'est un bijou ! et sa petite taille ne doit pas laisser croire qu'il ne peut pas rivaliser avec les grands
Et comme toujours le service ultra rapide Audiophonics
Aucun regret pour cet achat que du bonheur.
Eric v.
dynamique et un joli timbre très agréable sur un akm4490 double ou de plus les canaux sont bien équilibrés.
Guy H.
La solution !!!
Branché en USB entre un Ordinateur Intel NUC et un ampli Explorer 90 sII c'est vraiment la solution qu'il me fallait , Son splendide magnifié par les enceintes Q900 KEF . Je conseille sans retenue aucune .
gilles b.
Encore meilleur optimisé !
Depuis que je connais ce module d'amplificateur, j'ai arrêté de jeter mon argent par les fenêtres.
Je ne perd plus mon temps à acheter des amplis chers qui n'arrive pas à la cheville de ce Kit ampli en état d'origine.
Voilà je voulais partager mon expérience d'optimisation de ce Kit que j'ai fait évoluer en qualité en remplaçant simplement les 2 condensateurs de 3µf qui filtrent l'entrée audio.
ATTENTION selon la qualité des condensateurs, ils ne sont plus de la même taille que ceux d'origines, ce qui nécessite de faire un déport avec un câblage pour monter sur une plaque à coté les 2 gros condos que l'on ne peut pas souder directement sur le circuit.
Sur ce module est monté en origine des MKT standards de 3µf, j'ai testé particulièrement 2 marques:Mundorf et Audyn Cap en tout premier prix :
_Mundorf Mcap 250v en 3,3µf (montage direct sur le circuit)
_Audyn Cap QS 630v en 3,9µf (montage à coté du circuit)
Difficile de choisir entre les 2 solutions, le Mundorf propose un aigu plus précis et un peu en avant avec une micro dynamique des basses en retrait, l'Audyn Cap est moins précis dans l'aigu mais propose une bande passante plus homogène que le Mundorf,
Ces 2 propositions d'amélioration permettent d'obtenir un meilleur rendu pour un prix dérisoire, mais ce MA-ST01 est capable de beaucoup mieux pour certes un investissement plus conséquent.
Pour des raisons de choix personnel et de qualité finale, je préfère les 2 autres solutions de modification plus coûteuses car j'obtiens un rendu sonore tout simplement plus réaliste.
Juste à titre d'information ceci dit le coût total de cette modification ne dépassent pas les 50 Euros et
reste abordable pour toute personne voulant passer à la vitesse supérieure en terme de reproduction.
Pour mes 2 autres propositions, je me suis référé à la marque Mundorf :
_Mundorf Mcap ZN 250v en 2,2µf (montage à coté du circuit)
_Mundorf Mcap Suprêmes 600v en 3,3µf (montage à coté du circuit)
Sachant que le MA-ST01 accepte des condos à partir de 2,2µf et que je me suis permis de le monter jusqu'à la valeur 5,5µf, attention à la source qui doit être hyper qualitative en 5,5µf sinon c'est l'ouverture vers la reproduction de micro détails qui risquent d'être mis en avant sur des enceintes à haut rendement, sur des Klipsch RF3 à 98db le résultat est parfait.
Mon conseil est de rester sur une valeur intermédiaire de 3,3µf qui reste la plus adapté aux sources et aux enceintes jointent au MA-ST01.
Ma préférence à l'écoute va en faveur des Suprêmes pour leurs reproductions holographiques des voix, ainsi qu'une micro dynamique endiablée qui fait vivre la musique dans les moindres détails.
Les ZN sont tout aussi performant et excellent mais avec les Klipsch RF3 l'aigu est légèrement plus ciselé ce qui rend les voix moins holographiques et plus directives, alors que les mêmes ZN avec des Dynaudio font merveille car l'aigu des Dynaudio est moins brillant et les ZN leurs donnent la touche de précision nécessaire et adéquate à leurs signatures sonores.
J'utilise autant les Suprêmes que les ZN, selon la paire d'enceintes que je met derrière le MA-ST01, je choisis la valeur et le type de condos le plus adapté pour obtenir le meilleur rendu.
En résumant simplement la chose, je dirais que les Suprêmes se marieront bien avec des enceintes précises et détaillées dans l'aigu, et que les ZN réveilleront l'aigu d'enceintes un peu terne et manquant de détails.
En conclusion, pour tout bricoleur ayant envie de faire évoluer le MA-ST01, le temps passé pour cette évolution et la somme investie est tout simplement dérisoire contenu de la métamorphose sonore de ce Kit MA-ST01 le rendant extrêmement attachant et musical.
Valentin C.
Fer qui chauffe assez rapidement et assez puissant pour des petites soudures. Le fait de pouvoir régler la température est vraiment appréciable.
Valentin C.
Super qualité
Connecteur de bonne qualité, costaud et facile à brancher. Pour le prix ça vaut le coup !
PS : pensez à sertir vos câbles avant serrage
Valentin C.
Fiable
Le résultat obtenu est le même que sur mon multimètre, par contre j'aurais aimé une notice expliquant le branchement soit : le fil noir sur le - et relier le blanc et le rouge sur la borne+
Valentin C.
Bien mais ressort inutile
Le ressort n'est pas très costaud et gêne plus qu'autre chose. Du coup une fois enlevée la coche coupe bien.
Valentin C.
Belle finition
Interrupteur de bonne finition et facile à installer.
Valentin C.
Ce boitier est d'une qualité très convenable, me seul défaut est que les façades avant et arrières sont en aluminium, du coup c'est assez sensible aux rayures.
Par contre le boitier est fourni avec 4 pieds autocollant de bonne qualité, ce n'est pas précisé dans la description ce qui est dommage.
bastian r.
Non compatible Windows 10
juste faire attention que le modèle BT0015 de logilink n'est pas du tout compatible W10 (d'ailleurs le support logilink est totalement inexistant...). Voila Audiophonics pourrait le préciser, d'autant que c'est du matériel qui marche bien... quand c'est compatible (cas du BT0037 de la m^me marque).
Nous n'avons nous même pas rencontré de problème particuliers pour faire fonctionner ce dongle sous W10 (vous en trouverez d'autres témoignages chez les différents revendeurs)
Jan D.
Sounds great / Broke soon
While it worked this little amp board sounded great...
...unfortunately after about 100 hours of use, the amp gave up; only emitting a lound buzz/noise. Upon closer inspection, the two 4700 uf caps showed quite a bit of bulging.
Will contact the support dept. to see what's up with this.
DOGE 6210 MKII Hi-Fi Vacuum tube Headphone Amplifier Class A Avec le Doge 6210, même les casques 600 ohms auront un volume sonore très élevé et sans aucune distorsion.
Un ampli casque exceptionnel
J’utilise le DOGE 6210 MKII avec un casque Sennheiser HD600 et son câble d’origine. Je n’ai pas une grande expérience de l’écoute au casque, mais j’utilise des amplis à lampes depuis longtemps avec mon système principal. A ma grande surprise, le système DOGE + casque m’apporte, dans les conditions décrites ci-dessous, la même satisfaction que mes amplis « faits main » simple étage, à base de triode à chauffage direct VT25, associés à des Janus 70 !
La condition de cette réussite est, en tout cas pour moi, l’utilisation obligatoire d’un filtrage numérique entre le drive CD et le convertisseur numérique-analogique. Après des années d’essais « à l’oreille » - car, visiblement, les micros de mesure n’entendent pas la même chose que moi -, j’en suis arrivé à la conclusion suivante : pour supprimer une dureté (très nette sur les voix de sopranos (je précise que je n’écoute que de la musique baroque)) concomitante d’une impression très déplaisante de disparition de l’espace tridimensionnel, il m’a fallu faire un « trou » de -15dB sur un tiers d’octave et centré à 1200Hz. Ce qui est intéressant, c’est que l’effet positif très net de cette modification de la bande passante se vérifie quels que soient les haut-parleurs (Janus ou Fertin) et l’ampli (VT25 ou DOGE) utilisés et ne dépend pas de l’acoustique de la pièce puisque c’est aussi vrai pour l’écoute au casque.
Dans ces conditions, l’écoute du HD600 via le DOGE 6210 peut être qualifiée, à mon avis, d’exceptionnelle. Inutile de changer les tubes : les tubes d’origine sont excellents ! De plus, l’appareil est totalement silencieux, aussi bien quand on approche l’oreille de l’ampli lui-même qu’au casque. Enfin, mais ça n’engage que moi, je trouve son design très réussi et en accord avec une implantation très logique des composants qui fait que le trajet du signal, entre l’entrée et la sortie, peut difficilement être plus court.
Bravo à Audiophonics, non seulement pour une livraison dans des conditions parfaites, comme toujours, mais surtout pour avoir mis à la disposition du public français un ampli à lampe et à transformateur de sortie - ce qui est très rare sur le marché compte tenu du coût de ces composants et qui permet d’avoir le choix entre plusieurs impédances de sortie - d’une telle qualité, pour un prix aussi bas et avec une garantie de deux ans !
La seule réserve que je ferais est l’absence de temporisation. La fonction « odeum », dont j’avoue ne pas comprendre l’intérêt, serait, à mon avis, avantageusement remplacée par une temporisation (manuelle ou automatique) de l’application de la haute tension aux plaques des tubes, ce qui augmenterait la durée de vie de ces derniers.
Cool pour le prix
Produit très sympa, effectivement bien construit.
Pour l’écoute, je ne peux pas dire si ça améliore comparé à une multiprise lambda, peut-être un peu ?
Encore un bon produit
Après branchement de cette carte, je constate d’emblée une amélioration du rendu audio. Les aigus sont plus fins et ont davantage de matière, les silences paraissent plus vrais, j’ai une disparition de tous petits bruits parasites qui accompagnaient volontiers les aigus. Mon système est assez résolutif, donc à chaque fois qu’il existe une modification, j’entends facilement si ça dégrade ou si ça améliore (exemple le sens des prises secteur). Ce que je dis repose sur des impressions subjectives bien sûr.
Le fait que l’on puisse choisir du PCI ou du PCI express est un avantage, dans mon cas la carte est plus logeable dans ma tour sur le PCI express. On sait qu’elle fonctionne par une lumière bleue témoin à l’arrière.
Mon PC du coup commence à être assez performant pour la musique dématérialisée, grâce à ces plus. C’est vrai que d’un PC à l’autre on peut constater des différences marquées en application audio, sur des systèmes assez bons pour s’en rendre compte.
Merci à Audiophonics pour ses conseils, et pour distribuer des marques comme Elfidelity.
Laurent B.
Je suis passer d'un 2,5mm² a ce 4mm², déjà le son est plus clair, plus puissant (distance de câble de 8 mètres). L'écoute est plus douce, agréable. Sa ne change pas un système, mais on ne crache pas dessus. Pour 2x8 mètres, le rapport qualité/prix est très bon par rapport au prestation du câble. Bien robuste, on sens la qualité lors du "dénudage".
Merci à mon VDD pour le commentaire qui ma convaincu ;)
Je ne regrette pas l'achat, bien au contraires, je compte racheter 3 fois 8 mètres pour le reste de mon 5.1.
marie d.
parfait accepte du gros câble .
bornier solide .
Guillaume B.
Super materiel !
Utilisé en optique en remplacement du DAC interne d'une Airport express, la musique n'a plus rien a voir : on gagne en clarté, en dynamique, plus de mauvais jitter.
Petit plus pour ceux qui sont chez Denon, n'hésitez pas à alimenter le boitier avec l'USB de l'ampli (le 5V est en linéaire) en remplacement du transfo à découpage fourni.
On peut commencer à parler de HIFI :)
100% confiance ! Merci Audiophonics pour cette petite pépite !
DANIEL D.
MAUVAISE EVALUATION
Je reviens sur mon évaluation .
La position des câbles soit dessus ou dessous n' est pas bonne difficile de brancher les prises les câbles gènes l' entrée des fiches sur un revox a 78 c'est impossible.
il faudrait que le cable entre la ou il y a les vis ,donc derrière les connections + et -.
DONC TRÈS MAUVAIS PRODUIT
Sincèrement, nous pensons votre problème lié à l'espace disponible à l’arrière de votre appareil.
Dans l'immense majorité des cas, ces connecteurs DIN conviennent parfaitement.
Fabien M.
j'ai branché le Yarbo SP-8000PW derrière une barette LH Audio, par rapport a un câble basique net amélioration dans le haut du spectre, le message sonore délivré est plus détaillé, les instruments sont plus intelligibles, la scène sonore est plus large aussi, niveau dynamique je n'ai pas noté d'amélioration. très bon câble surtout à ce prix. Fabien.
Claude G.
Claude G.
En remplacement d une barrette audio video lambda,mon systeme est exploité maintenant à cent pour cent...super produit!
Pascal M.
petit mais énorme...
je vais pas détailler et faire de CR car d'autres le font bien mieux que moi...
Tout ce que peux dire c'est que je prie pour qu'il ne tombe jamais en panne tellement c''est le pied...J'avais jamais entendu mes enceintes chanter comme ça (monitor audio rx6).
Benoit G.
pas mal
Petit module qui fait bien sont boulot
Facilité de mise en oeuvre
Rendu sonore honnête
Ne pas oublié le radiateur adapté
DANIEL D.
EXCELLENT PRODUIT
Pour remplacer vos vieilles fiches DIN de connection
sur REVOX ET 3A et autrs.
Pas de bricolage câble 2,5 mm sans problème
serrage par vis
Intérêt réel
Cette carte usb apporte vraiment un plus en termes de rendu audio.
Dans mon cas particulier, l’installation d’un dac Audio-gd nfb-3 sur un PC moyen tour ne fonctionnait pas sur les sorties usb à l’arrière de la carte mère. Seul le port usb en façade était utilisable, avec un aigu perfectible dû à mon avis au câble interne de front panel du boitier PC.
La carte Elfidelity se branche en interne sur les mêmes ports usb que pour la liaison au front panel, donc j’étais pratiquement certain de pouvoir faire fonctionner le dac nfb-3 dessus. J’utilise de l’usb 2. Le connecteur fourni par Elfidelity a un contact très ferme avec la prise de la carte mère.
L’amélioration de l’aigu est nette et c’était nécessaire. L’équilibre général est conservé, l’extrême grave et le grave n’appellent pour moi aucune critique. Le gain de qualité est global.
L’alimentation de la carte est pour l’instant en interne par un connecteur sata, je n’ai pas essayé d’alimentation externe 5v plus propre.
Gareth J.
Un must pour le démat
L'ancien XMOS U8 est une référence dans l'audio démat, réduisant très efficacement la gigue (jitter). Cette nouvelle XMOS 208 nous amène beaucoup plus loin dans la qualité audio, notamment dans la finesse et la douceur des timbres avec un fond plus noir. La différence avec l'ancien XMOS est nette et augmente encore avec le rodage.
Et quel plaisir pour les oreilles !
Fonctionne parfaitement avec JPLAY et Fidelizer Pro sous Windows 10.
Merci à Audiophonics de proposer ce bijou.
jacky e.
Très bon cable, naturel, transparent, équilibré, on ne voit pas quoi lui reprocher. Branché sur une chaîne déjà haut de gammele résultat est très bon. A prendre en considération avant tout achat, pour un budget raisonnable ce cable est bien meilleur que nombre de câbles aux prix stratosphérique
Simon R.
Very good module
Bought this one a while ago. Took a bit for burn in, but after a while it got better every day. I compared it to several other amps and it surprisingly outplayed quite some of them. Not quite on level with my KT88 Tubeamp, but surprisingly close. Good soundstage, good imaging, god natural timbre & texture of instruments an voices. I added a small vishay bypass cap to the coupling caps, helped improving a bit on micro detail which I consider to be a rewarding little mod. i can recommend this board without drawbacks.
Damien L.
Smsl ad 18
Bon petit amplificateur, rendu très clair sur des Quantum Edelstein.
D'après mes essais l'entrée la plus fidèle est celle en usb depuis un PC.
Par contre je n'arrive pas à connecter mon pc portable en bluetooth (dell e6400), y'aurait il des pilotes à installer?
En revanche pas de soucis avec un télephone sous android.
Un ampli/dac à ce prix c'est une affaire.
Thibault V.
Immédiatement reconnu, le jour et la nuit au niveau du son !!!
Bref on peut acheter ce petit DAC les yeux fermés....
Jerome G.
Très bonne interface.
Utilisée avec un NFB 27H un ampli casque Prautes et un casque Kennerton Odin en liaison I2S RJ 45. L'amélioration est audible : plus de détails, d'aération.
Florent R.
Le modèle que j'ai reçu est une évolution de celui sur cette photo, et il est d'excellente facture, simple à monter et très bonne tenue aux efforts, je recommanderai sans hésiter
Bernard L.
Attention qualité de fabrication déficiente
Sur quetre cartes achetées, seules deux fonctionnaient, en raison de soudures défectueuses. La qualité de fabrication laisse vraiment à désirer, traces résiduelles de flux de soudure, composants désalignés, soudures sèches.
Ceci étant, une fois réparées, le fonctionnement est nominal, rien à dire de ce côté là.
Gilles L.
fait le job
fait son boulot correctement, un peu bruyant quand on appuie dessus mais sous mon caisson(velodyne) pas un bruit, par contre j'en ai reçu une sur les quatre commandée qui n'est pas de la même couleur que les autres (plus claire), et qui est plus souple, l'lorsqu'on appuie dessus!!!! pas gênant a l'utilisation mais surprenant !
sinon livraison dans les temps, rien a redire la dessus.
Romain U.
Efficaces
J'utilises déjà des superspikes sous mes pieds d'enceintes , avec succés (précisions accrue, scene sonore plus précise, et basses plus franches)
J'ai commandé cette version pour mon caisson DIY. Beaucoup moins de vibrations, c'est plus sec et rapide.
Pas l’impression de perdre d'impact ou de niveau, à confirmer avec le temps.
J'aimerai bien les comparer sur un sub à un Sub Dude, ce genre de chose, mais audiophonics n'en propose pas
