Socket/Phase and Electrical Safety Tester
This socket and circuit breaker tester allows you to test your installation safely. Among other things, this product can detect a lack of earth, phase reversal, or a lack of phase or neutral. This small tester can save lives and prevent fires, and should be included in every electrician's toolbox.
Reference : 21024
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 26-11-2026.
Socket/Phase and Electrical Safety Tester For 230V Main Power Supply
Socket/Phase and Electrical Safety Tester : 3/4 view
Caution: If the wall socket is connected to a residual current device, press the ‘LEAKAGE TEST’ button to test the function. When you press the button, the residual current device should trip. If it does not, check the installation.
Product typeSocket tester
TestMissing earth wire
Neutral wire missing
Missing phase wire
Neutral and inverted phase
Inverted earth and phase
Leakage current test 30mA
Voltage Rating250V 50 Hz/60 Hz
Temperature Range0°C~40°C
Dimensions56 x 56 x 45mm
PackageSold by unit
Socket / Phase and Electrical Safety Tester For 230V Main Power Supply
This socket and circuit breaker tester allows you to test your installation safely. Among other things, this product can detect a lack of earth,...
