Patrick H.
Peu à dire
Profitant du débit de la fibre et d'un dac de la même marque mon installation délivre un son bien supérieur à mes...
fabrice d.
pareil
Idem pour moi
Deux casses
Malheureusement une fois sous garantie et pas la deuxième
Dommage
Comme je l'écris...
Customers reviews - There are 19541 reviews.
Stanislav M.
LINDY CROMO LINE Digital Cable Coaxial SPDIF Copper Gold Plated 3m The Lindy Cromo Line SPDIF Coaxial cable benefits from a beautiful design quality. Its conductors are made of Copper for a very good conductivity and its connectors are plated...
Good build quality, excellent value!
Julien M.
Très beaux tubes
De très beaux tubes, soyeux, précis et naturels
Ils demandent effectivement beaucoup de temps pour s'ouvrir mais quel bonheur
Giannis K.
DAYTON BST -1
You must placed it firmly with a flat plate to feel all the frequencies. Also you have to isolate the sofa or your sim rig from the floor to have “louder feeling”
Peter R.
MUNDORF ACW115BK Wiring Cable Copper / Silver / Gold PTFE 1.8mm² This top-of-the-range Mundorf ACW115BK cabling wire offers excellent manufacturing quality for maximum conductivity. Its conductors are made of high-purity copper, silver and...
A great sounding wiring cable
I have implemented and tested a large number of jumper wires between my speakers and the SPEC real sound processors which I use. Different brands of silver and copper wires with different dimensions and designs by several brands have been tested, including all the various Neotech OCC-types available. The Mundorf ACW115BK wiring cable provides a large step forward regarding resolution, 3D dimesionality, organic presentation and low to high frequency response. This is the most musical jumper wire I have used for this purpose in my system. I am really impressed with the excellent resolution and silence offered by this Mundorf product.
Patrick D.
ATOHM WT-96123-G Isolated Built-in Terminal Block for Bi-Wiring Speakers Gold plated 123x96mm (Unit) The WT-96123-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold plating. It accepts cables with large...
Excellent, produit de qualité je recommande
Josef S.
Rapport qualité-prix TOP
Le déroulement de l'achat ainsi que l'envoi en Allemagne se sont déroulés sans problème.
Le sélecteur audio fonctionne très bien, on ne peut que le recommander.
Dommage que ce commutateur ne soit pas disponible sur le marché allemand.
Jean-Pierre D.
Transparent, détendu et superbement ouvert, à la fois bon en PCM et en DSD
Ce DAC excelle à tous les niveaux, la musique coule naturellement avec la vigueur nécessaire sur les temps forts des enregistrements. La spatialisation est excellente, beaucoup de largeur et de profondeur, les hautes fréquences sont sans dureté et bien étendues, belle restitution des timbres des instruments et voix. J’ai eu un Gustard R26, R2R comme ce Holo, c’est une progression en tous points, la musicalité est plus grande, cela me parait plus précis et hautement transparent, tout en conservant le caractère émotionnel. L’investissement vaut le coup, c’est un DAC qui s’insère parfaitement dans un ensemble haut de gamme, j’apprécie ses performances en termes de restitution sur tous les styles musicaux. J’utilise en coaxial pour la lecture de CD et en USB pour la musique dématérialisée jusqu’aux DSD, satisfait sur les différents formats.
Remerciements à Monsieur Aubert qui m’a permis de le sélectionner par rapport à d’autres options que j’envisageais. Je trouve que ce DAC a un excellent rapport prix qualité sonore vraiment bien, pour quelqu’un qui écoute tous les formats et souhaite écouter ses albums tant en format original que sur des fréquences plus élevées après suréchantillonnage jusqu’aux DSD.
yves R.
SIVGA ROBIN Dynamic Closed-Back Over-Ear Headphone Ø50mm 32Ω 105dB 20Hz-20kHz Rosewood Sivga offers with its Robin headphones a model that is both elegant and efficient, revealing a musical and dynamic sound reproduction within an ergonomic and modern design. The...
beau mais son catastrophique
beau casque
mais alors le son est mauvais
grave venant d'une mauvaise sono et aiguë qui fait saigner les oreilles
entre les 2 rien pas de medium.
je me suis fait avoir par les fameux testeurs influenceurs de YouTube .
passer votre chemin --
Antoine G.
L'affaire du siècle !
Ancien cablo-sceptique j'ai commençé mon éducation CS avec ce formidable câble.
Aujourd'hui j'ai des câbles plus chers, mieux "côtés", mais j'affirme haut et fort qu'il fait mieux que certains, que d'ailleurs je revends au fur et à mesure.
Bref c'est un mètre-étalon, et à ce prix il ne faut vraiment pas s'en priver.
testé sur des sources, sur des pré-amplis et des blocs de puissance, c'est bon partout !
Pour débuter, et même après pour continuer, c'est vraiment un produit terrible; Dynamique, ouvert, aéré, percutant, il à tout bon.
Merci Audiophonics, ne changez pas la recette svp !!!!!!!!!
Miguel O.
Après avoir fait jeu égal avec d'autres modèles valant plusieurs fois son prix, il a remplacé avec maestria, un câble USB haut-de-gamme, présent depuis des années, dans mon système...
Silence et propreté du signal font de lui un allié exceptionnel pour écouter la musique avec sérénité et plaisir !!!
Très hautement recommandable !
Frédéric B.
Du DMP-A6 au DMP-A8
Le DMP-A6 est un excellent produit et le DMP-A8 ...aussi... Est-ce que je regrette d'avoir vendu mon DMP-A6 pour acheter le A8?
En terme de qualité c'est dur à dire, le A8 est un peu plus "poli" un peu moins "dur" que le A6. Un peu plus équilibré aussi. Sans EQ, la réponse en fréquence est plus linéaire, il sort, me semble-t-il, un peu moins de grave. Mon avis reste subjectif car je n'ai pas eu les deux lecteurs en parallèle mais à quelques semaines d'écart.
En terme financier, entre la perte liée à la revente du DMP-A6 et le prix plus élevé du DMP-A8, cette dépense ne devrait pas être une priorité dans un système. Les plus de 1000 EUR de différence seront peut être mieux investis dans un changement d'enceintes. À vous de voir en fonction de votre système...
Les 5 étoiles ne se réfèrent pas cependant à Colissimo! Le colis est resté bloqué plus de 3 semaines au dédouanement! De nombreux emails avec Audiophonics ont été nécessaires pour débloquer la situation. Petit bémol pour Audiophonics tout de même car, aucun contact téléphonique n'a été possible et aucun dédommagement consenti. Audiophonics est resté cependant très actif par emails.
Le bon vieux "service à la clientèle" devient, en général, la possibilité d'intégré de l'IA dans l'entreprise plutôt que de gagner la satisfaction des ...humains.. qui restent des clients (ou l'inverse).
ABE
Sandy G.
TANG BAND W8-1772 Speaker Driver Full Range 30W 8Ω 95dB Ø22.38cm Tang Bang's W8-1772 full-range driver offers extensive sound reproduction thanks to its 22.38cm-diameter diaphragm. It has a power handling capacity of 30W, a paper diaphragm...
Très joli " TANG BAND"
Ce joli petit HP large bande donne envie de l'écouter, sur baffle plan pour le début. Après, je verrai : TQWT, Pavillon Arrière...voire Bass Reflex avec double résonnateur ?
belle finition en tous cas, et du plaisir avec ce Tang Band...
Sandy G.
ATOHM : DES HAUT PARLEURS !
belle sonorité naturelle et non artificielle .
le prix me semble justifié, c'est un produit de qualité, largement supérieur à quelques très bons Audax..(moins chers cependant)
Guillaume B.
ONE-TOUCH POLYMER
Un produit non agressif qui fonctionne très très bien, avec une brosse ou un produit pulvérisé on croit que le diamant est propre mais le polymer va plus loin, un voile sur les aigus est levé et tout y gagne, très bien.
Guillaume B.
OYAIDE HSR-AG Rhodium Plated 5N Silver Wires for Headshell (x4) Oyaide HSR-AG cell wiring wires feature a beautiful design, with pure 5N Silver conductors. These are manufactured using advanced processes and are stranded in 7 lines to ensure...
HSR-AG 5N
2 portes cellules que j'équipe avec les HSR-AG 5N, l'écoute est très agréable et vos bien des câbles Ag bien plus tarifés.
Il est vrai que l'insertion est une épreuve (un peu plus que d'autres marques + cher), ne pas hésiter a épater les cosses, mais une fois l'effort accomplis, la récompense auditive est superbe.
Je voulais tester une configuration pre ampli ampli
J'ai vu les bonnes critiques du musician le cote R2R la classe a/ab
J'ai acheté
Je l'utilise avec un ampli élément en vente ici avec la technologie ICE rock
Le couple joue fort bien et on a pas l'impression d'un son class D
Il mérite un bonne ampli de puissance
Richard P.
Son naturel
Câble naturel. Dynamique mais pas agressif. J'aime beaucoup. En remplacement de sommercable orbit 240 déjà très bien.
Sur mon système bien sûr.
5/5 ⭐
Mike F.
USB Dongle Bluetooth 5.2 Transmitter aptX / aptX HD / aptX LL / aptX Adaptive This Bluetooth 5.2 USB transmitter dongle will allow you to broadcast audio streams wirelessly, from a computer for example, and in high quality, thanks to the use of a Qualcomm...
Fonctionne très bien
Rien de particulier à dire sur ce dongle qui fonctionne sur mon PC en windows 10.
Julien G.
ELECAUDIO LI-23GB IEC C13 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of 5mm², which provides a very...
Good
Not so bad design. Except the m2 screws'print a little bit fragile. Good quality product.
Laurent M.
PSVANE KT88-Z Tetrode Tubes (Matched Pair) PSVANE's KT88-Z  power tube  offers a soft, warm sound, full and natural, with good balance and no background noise.  PSVANE  offers us a tube with a more...
Très bon tubes
Des tubes de très bonnes qualités tout est propre merci a l'équipe
Mark S.
FIIO K7 DAC Headphone Amplifier 2x AK4493S THX AAA-788+ 32bit 384kHz DSD256 FiiO's K7 is a high performance  desktop DAC and Headphone Amplifier combo , demonstrating an exemplary design for an audio reproduction marked by great transparency,...
An excellent dac-amp at this price
I use the Fiio K7 with Hifiman HE400se headphones and it drives them well (I usually listen with the volume on low gain and the knob between 1 and 3 o'clock). The volume control is done in the analogue domain, so changing it has no effect on the signal quality. Some people remark on a lag between turning the volume knob and the volume actually changing, but this has not been a problem at all. I especially notice the soundstage (instruments are easy to locate when listening) and the ability to reproduce a large dynamic range cleanly. I listen mostly using Roon upsampled to the dac's limit (on USB, 384kHz-32bit/DSD256), so adjusting the dac filters isn't really necessary, still it would be nice to be able to fiddle. Very happy with the purchase.
Au delà de mes espérances
J’ai endommagé de manière importante le câble d’origine de mon Sennheiser HD800s et le câble de remplacement est très cher.
J’ai commandé un câble chez Furutech mais ils ne sont plus disponibles…
J’ai demandé à Audiophonics de m’en confectionner un et ils ont refusé (c’est pas sympa !). J’ai donc pris mon courage à deux mains et j’ai confectionné moi même le câble de remplacement. Heureusement je suis bien outillé. Je comprends maintenant pourquoi Audiophonics ne veux pas m’en faire un …
C’est une galère ! Surtout au soudage car il faut attaquer à plus de 370• pour que la soudure accroche le fil. (Soudure argent 10%)
De plus les connecteurs de l’embout spécifique au HD800 sont minuscules. Si vous n’avez pas de loupe passez votre chemin.
Le cordon est souple et agréable. Coté Jack j’ai beaucoup moins galéré curieusement. Repérage obligatoire au testeur métrique. C’est pour ça que j’ai commencé par les embouts casque pour finir par le Jack 6,35.
Résultat : exceptionnel. J’ai un gain significatif dans tout les registres . J’ai ce caque depuis plus de 6 ans et je le connais très bien. Et là il dépasse tout. Après rodage la coquetterie dans les hautes fréquences disparaît et le grave est plus ferme. Les voix sont très centrées comme jamais. C’est confondant de naturel. Ampli casque CHORD Hugo2.
Je l’utilise entre mon amplificateur Cayin et mon sub REL .
C’est très simple ; une fois branché je n’entends plus mon sub. J’ai été obligé de vérifier qu’il était allumé ! Comme quoi un câble influence la restitution.
Le sub est beaucoup mieux intégré dans la restitution globale de mon système ; je n’ai plus qu’à peaufiner mes réglages.
Le service Audiophonics est toujours aussi - impeccable -
Gorazd K.
Nice look under the speaker stands and works well against vibrations, but had problems attaching with the included self-adhesive stickers, it didn't work at all. I had to buy better quality ones.
MATRIX ELEMENT P2 Power Amplifier Class D Stereo 2x230W / Mono 1x850W 4 Ohm Continuing the Element line's identity, the Matrix Audio Element P2 power amplifier inherits a sleek, modern design that integrates seamlessly with the other models in this...
Rodage
Il lui faut qq jour de rodage pour avoir plus d'ouverture mais les timbres sont la des le début
Utilisé avec un musician en pre ampli
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 12V 1A 25VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
La classe 5 étroite
produit super top avec des prise secteur furutech NCF rhodium
rapidité qualité l'image o rdv sans hésitation un vrai régal Netflix je note 5 étoile merci !
Ne sonne pas comme un class D
Belle découvert !
sonne comme un a/ab
Merci pour les -20%
Pascal J.
MP-H250S48 SMPS Switching Mode Power Supply Module 250W 48V 5A PFC This SMPS MP-H250S48 switch-mode power supply module is capable of delivering 48V, 5A current and 250W of power. It is also equipped with a PFC (Power...
Parfaite
Parfaite et suffisante pour réaliser un ampli 3E audio
efficace,fiable. Elle tourne avec l'ampli 12 à 16 par jour
depuis 1mois. Ne chauffe quasiment pas.
Pascal J.
Ne cherchez plus!
Si vous avez des Dynaudio emit 30 (en vente sur ce site) cet ampli est fait pour elles: une bande passante parfaite de haut en bas avec
une dynamique d'enfer , les timbres justes, et la transparence alors là un pur bonheur. Sur le lecteur cd Denon 110 anniversaire, pré -amplis FX tube 01 modifié tubes Voshkod avec symétriseur pro Sonifex ou Schiit Jotuheim phono.
Sami K.
EIZZ EZ-505 Banana Plugs 24K Gold Plated Copper Ø7mm (Pair) These high quality Eizz EZ-505 banana plugs are made of 24k gold plated copper contacts. They provide excellent conductivity and durability. The assembly is done simply by means...
Impeccable quality, very conductive
With these plugs the production quality is very good. The surface finish looks even better in reality than in the pictures. While the connector shells are all metal including the surface finish, so it is worth noticing that the only non-conducting part of the connector is the colour band. The connector shell is fully connected to the signal, so maybe not recommended to use these in applications with high voltages present while handling.
The spring structure of the golden part is rotating, which means the connector migh be less prone to breaking when twisted inside the mating connector. Robust double screws allow rather thick wires to be used and secure connections to be made. Overall rather decent quality/price ratio and very good build quality.
bernard g.
ATAUDIO SNOW SLEEK Balanced Signal Cable Silver Plated OCC Copper Ø8mm This balanced modulation cable sold by the meter consists of 12 silver plated OCC copper wires individually insulated with a PTFE sleeve. It ensures an excellent conductivity...
j ai fabriquer 3 alimentations secteur a triple cables de 6mm2 il faut faire du trèssage avec les 3 cables pour éviter les perturbations et avoir de bon connecteurs cuivre pur rodium et la dynamique est la le son glisse tout seul et encore il sont en rodage le son est de trés haut niveau c est super musicalement bernard
Anastasios O.
Exceptional!!!
This cable is a revelation for it's price... VERY natural without emphasizing any frequency... Silky smooth treble with plenty of air but never harsh, natural clear mids and tight deep bass with great extension...Also very articulate and dynamic. Mid/bass is not bloated but the cable never sounds thin... its full bodied with great homogeneity. It replaces my Tellurium Q Black II which it's bloated mid bass bleeded to other frequencies and muddy the sound... Also the soundstage of the Silenos is way better in all dimensions... WELL DONE LUDIC!
Uwe G.
Topp Kabel
Mit kupfer/vergoldeten Schukosteckern herrlich dynamisch auflösend bei kontouriertem Bass.
Wer es softer klingend möchte verwendet rhodinierte Schukostecker
Jerome R.
LHY AUDIO UIP USB 2.0 Isolator 480Mbps OCXO PLL Black With its UIP, LHY Audio unveils a high-performance 480Mbps USB 2.0 isolator incorporating an internal OCXO + PLL clock system for perfect...
Pas convaincu
Utilisé entre un streamer Melco N100 et un DAC Cen Grand DSDAC Deluxe, le rendu ne m'a pas convaincu. Le son ne s'est pas amélioré voir s'est montré un peu plus agressif. J'ai lu qu'il fallait une longue période de rodage pour que le coté agressif disparaisse pour laisser place à plus de fluidité mais après une semaine je n'ai pas vu d'amélioration. J'ai préféré renvoyer le produit avant la fin de le période d'essai.
Bruno F.
SMSL A50 PRO Amplifier 2.1 Class D 2x MA12070 Bluetooth 5.0 HDMI ARC 2x70W 4 Ohm + 100W 2 Ohm The SMSL A50 PRO is a 2.1-channel Class D amplifier featuring two Infineon MA12070P amplifier chips. It is capable of developing power up to 2x 70W 4 Ohm + 100W 2 ohm. One of...
Good for the price, for 90 euros you can't ask for more. sub output a little weak, I thought the bass would be more present, I used a 4ohm bass unit, I think that with 2ohm subwoofers the bass is stronger.
Sandy G.
Brillantissime
superbe sonorité, sur mon système en baffle plan.
il donne une très belle scène sonore.
Couplé avec filtrage en 1er ordre, à un DAVIS 20 DE08
il s'accorde superbement. Rendement élevé vérifié.
Cyril C.
Je possède déjà un récepteur Fosi et il y a vraiment du bruit problématique, même sans appareil connecté.
Avec ce produit ci, aucun problème, le son est vraiment très clean et la connexion est rapide, le BT 5.3 c'est super, bref très content de mon achat. Je n'utilise que les sorties RCA (vers mon ampli Denon)
Richard L.
SHANLING ET3 CD Player Philips SAA7824 Sanyo HD850 WiFi DLNA AirPlay Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Silver The Shanling ET3 is a complete, powerful CD player with a modern design and excellent sound performance. Versatile, it offers full connectors and wireless connectivity, enabling...
Shanling ET3
Excellent service from Audiophonics! Well packaged en quick delivery. The Shanling is everything I hoped for.
Jean-Marc c.
AUDIOPHONICS CANARE Digital Coaxial Cable 75ohm RCA-RCA Sleeved 3m Here is our coaxial digital cable Audiophonics Canare in 75Ω version. Its particularity is to include CANARE C5F connectors, certified 75Ω and a cable CANARE L-5CFB.
Câble coaxial numérique
Parfait ,très belle finition et son excellent pour ce câble
Jean-Marc c.
Lecteur réseau wiim pro +
Reçu récemment ce pt lecteur réseau,très beau ,bien fini ,belle connectique,couteau suisse , télécommande incluse,app WIIM , branché en coaxial (cable superbe de audiophonics)sur DAC ext audio gd 38-28 , comment dire ce pt lecteur réseau fait le job radios ( attention certaines sont payantes !), quobuz, Spotify, Deezer ( q je n ai pas) ....le tout en unp/dlna , bluetooth,cast, multirom....
Donc de quoi faire , toute fois parlons du son et c est ce qui nous intéresse le plus : dans mon installation manque de profondeur ,de détails , de spacialisation....c assez déroutant mais toute fois peut comprendre puisque radio Spotify,ou autres ....par contre avec quobuz un léger mieux plus d ampleur ....mais toute fois ne rivalise pas du tout avec mon installation , lecteur réseau melco n 100 on est pas du tout dans la même catégorie !! Le n 100 est 10 fois plus précis et dynamique ....,
Conclusion : au départ pris le Wiim pro pour les radios spotify ,internet et fait le job sauf q son ben comme du MP3 reste en deçà !
Pour le reste j écoute sur mon installation qui est de haut vol et en suis ravis
Wiim pro est là pour avoir tout les gadgets q je n ai pas sur mon installation dans l ensemble ça fonctionne pas mal (wiim pro plus)mais pas assez précis et on dois jouer sur l app de l équaliseur !
Merci a l équipe audiophonics
Duncan A.
Superb quality
Superb quality, beautifully made power amplifier,highly recommended
Florian G.
SMSL HO200 Balanced Headphone Amplifier / Preamplifier Compact and elegant headphone amplifier & preamplifier with output stage capable of delivering up to 6W under 16Ω (3W @ 32Ω). Constitutes an ideal solution to...
En fait non
Correction : tout va bien… (:
STEPHANE M.
Excellent câble secteur
Ce câble améliore tout !! Avec un recul du bruit de fond très net...
Fortement recommandé !!
STEPHANE M.
Vaut son pesant d'or...
J'étais cablo-sceptique....
Je ne le suis plus !!
Le câble Pangea AC14 SE mk2 améliore tout...
Un très net recul du bruit,
une clarté sonore inconnue sur mon système
auparavant. Les aigus
gagnent en détails, les voix
sont plus intelligibles, les
graves sont serrés et rapide. Ce câble secteur est un must !!
Sylvain G.
AUDIOPHONICS HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex...
Impressive and immersive sound details !
Now getting the full sound detail potential and precision of my dynaudio confidence 20 using the latest very powerful power amplifier from Audiophonics
The difference with the also very good 2 cyrus X power in mono is perceptible : in the Bass and medium: more refined and overall more immersive soundstage and no fatigue at all !
Excellent service from audiophonic all the way !
System :
-Denon avc 4800h with Dirac bass control
-2 subwoofers : B&W 610
- Source : quobuz with Octavio streamer and Denafrips Pontus 2 DAC
/ vinyl : project X2 ( ortofon 2M black ) with project Ds2 tube preamp
Franck M.
Incompatible sur ampli DENON PMA 520
Produit de bonne facture mais incompatible avec mon vieil ampli Denon PMA 520, le volume de sortie RCA du récepteurs est trop faible pour une écoute correcte. Bien dommage
Patrick C.
iFi Audio GO Bar Kensei Portable USB DAC Headphone Amplifier XMOS 32bit 384kHz DSD256 MQA K2HD With the Go Bar Kensei, iFi Audio offers its most powerful USB DAC and ultraportable headphone amplifier. With its particularly compact format, it...
Le meilleur !
Je possédais le précédent Go Bar et j’avoue être bluffé par cette version Kensei : le son est indéniablement plus délié, plus riche, plus réaliste quel que soit le type d’écouteurs (intra, casque) et surtout le type de musique. Les ingénieurs japonais ont réussi une belle amélioration par rapport à un produit déjà remarquable avec le traitement K2HD qui restaure des harmoniques naturelles et des harmoniques au-delà de 22 kHz, offrant une qualité audio proche du signal d'origine. Bravo !
Julio L.
Très efficaces
J'ai essayé ces pieds isolants pour mes enceintes colonnes après avoir utilisé des pointes de bonne qualité, et la différence est notable.
Bien que le prix puisse sembler élevé, leur efficacité est indéniable. Pas besoin de dépenser une « fortune » chez des marques concurrents..
Je les recommande vivement pour des colonnes avec de bonnes basses (Sonus Faber dans mon cas).. Le parquet vibre beaucoup moins, et le reste du spectre sonore reste extrêmement controlé. Excellent produit et prestation Audiophonics au top comme toujours.
RENE R.
Power Plug Adapter Female US NEMA 1-15 / C Type to Male FR C Type This power adapter allows you to use US format power cables on European, Schuko or French plugs. The female part of the adapter can also be used for Type C / Schuko.
ADAPTATEUR SECTEUR.
BON PRODUIT QUI ME PERMET LE BRANCHEMENT D'UN TUNER YAMAHA T7.
RENE R.
1877PHONO EVANJEL MK2 3.5-RCA Jack 3.5mm to RCA Modulation Cable 1.5m A remarkable evolution of its predecessor, the EVANJEL MK2 distinguishes itself by a choice of high quality materials and particularly meticulous finishes.
CABLE 1877 EVANJEL MK2
COMME D'HABITUDE AVEC CETTE MARQUE LA QUALITE EST EVIDENTE ET COMME TOUJOURS LE PRIX EST RAISONNABLE
