Jochen M.
Tout n'est pas parfait
Richard M.
Bernard g.
Excellente Interface
Customers reviews - There are 19551 reviews.
Bartus G.
its do the job
as in the title its do the job, easy soldering
Bartus G.
IAN CANADA MONITORPI OLED Screen and Signal Analyzer Board for Raspberry Pi The Ian Canada MonitorPi is an OLED display that works for all types of audio applications with Raspberry Pi. Installation is very simple using the module's GPIO port....
plus 100HP
Ye, in my streamer its only plus 100HP :) informative, if you use for debug.
Bartus G.
IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi Ian Canada's ShieldPi Pro MKII is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO...
Makeing calm in the music
Makes the music more fluid
Bartus G.
Perfect for a PI streamer
No question, perfect for a Pi streamer with a good PSU
Bartus G.
Amazing streamer for the money
Amazing device, I use it with Accusilicon clocks (45 and 49). Super soundstage, calm, fantastic!
Jerome R.
CEN.GRAND DSDAC 1.0 SUPERCLOCK DAC FPGA XMOS XU208 Femtosecond Clock 32bit 384KHz DSD512 Black Created by CEN.GRAND, the DSDAC 1.0 SUPERCLOCK  is a DAC based on DSD technology. It is different from most DACs on the market, in fact the DSDAC 1.0 can increase the...
Un son sans défaut
Excellent DAC pour le prix. Comparé à mon MSB Diamond, il apporte une plus belle scène et des voix plus naturelles. Rien n'est agressif sans manquer de dynamisme ou de détail. Il n'y a peut être que dans les basses où ça tape un peu moins fort que MSB. Un DAC qui mérite d'être connu...et qui commence à l'être chez nos voisins anglosaxons.
Rui R.
Very good quality plug!
Raffaele V.
AUDIO-GD DA7 corretto
Not simple but not complicated either. You need to pay attention to the wiring and power supplies and I highly recommend the original ones.
One day of work, triple checking everything, It pretty much worked first time. The sound is basically excellent, but can be improved with some adjustments that I will install in the future. Non semplice ma neanche complicato. Bisogna porre attenzione ai cablaggi e alle alimentazioni che consiglio vivamente le sue originali.
Un giorno di lavoro, ricontrollando tutto tre volte, Ha praticamente funzionato al primo colpo. Il suono, di base ottimo, ma migliorabile con alcuni accorgimenti che intallerò in futuro.
ETI NEXUS Silver Plated Tellurium Copper Female 3 Poles XLR Connector Ø8.5mm (Pair) Nexus ETI XLR connectors offer a very good design quality, integrating copper machined contacts with a small quantity of Tellurium. In addition, there is a silver plating of the...
Cela sent la qualite
Tout est a vis !
Ne pas forcer les vis sur les 3 partie
Pour le reste cela vaut le prix
Jean-Charles O.
Bon produit, prix très correct.
Utilisé avec un casque Sennheiser HD660S. Ca fonctionne tres bien en symétrique et en asymétrique.
Sur smartphone j'ai eu besoin de mettre un player spécifique car le driver system d'Android ne fonctionne pas mais bon j'utilise e/os sur un Fairphone. De toute facon je pense que l'utilisation d'un player dédié est conseillé. Sinon de pas aussi hésiter à installer l'application de Tanchjim pour vérifier les settings du DAC et/ou les changer.
Claude R.
Excellent pour écouter sa chaine Hifi au casque Bluetooth
Acheté dans le but d'écouter une chaine hifi non équipée pour le sans-fil (Rega Apollo & Brio R) sur un casque Grado GW100x, le FiiO BTA30 PRO s'est montré étonnamment performant.
Bien sur le Bluetooth n'est pas à proprement parler un mode "Hifi" mais le son qu'il transmet est vraiment bon et n'engendre pas de frustration.
Par ailleurs le FiiO BTA30 PRO fonctionne très bien aussi pour écouter Qobuz ou Tidal sur la chaine à partir d'un smartphone.
L'installation et l'utilisation m'ont demandé un peu de patience pour m'y retrouver mais le résultat en vaut la peine.
Je le recommande chaudement car il est d'un excellent rapport qualité/prix.
Laurent z.
Grande Musicalité
Après avoir contacté le service clients Audiophonics afin de « déblayer le terrain » avant achat, j’ai décidé d’acquérir cette belle machine et je ne regrette rien. J’ai déjà un Gustard X26 PRO basé sur des puces Sabre. Je ne dirais pas qu’un est meilleur que l’autre, mais ne correspondent pas aux mêmes types de système. Sur mon ampli à tubes ou tout autres amplis a tendance douce, le X26 pro apporte un surcroît de définition, d’attaque. En revanche l’A26 a une coté plus neutre, plus de matière et d’espace. Il n’est surtout ni moue ni anémique, bien au contraire, mais le mariage avec mon gros transistor très vif est bien meilleur. Histoire de goût et de mariage. Il me rappelle beaucoup un dac très haut de gamme que j’ai possédé dans les années 90 ( Métronome Technologie). Vraiment très Musicale dans le sens premier du terme. Aucune partie du spectre n’est mis en avant. Tout est très bien dosé . En 2 mots : ça chante. Encore merci à audiophonics pour sa disponibilité, réactivité et ses bons conseils
Lotfi B.
Ce n'est pas du noir
Pointes de bonne qualité pour le prix, par contre ce n'est pas du noir et rien a voir avec la photo, c'est même pas anthracite et encore, je vais devoir les repeindre pour pouvoir les intégrer a mon projet.
Stéphane R.
Utilisé pour streamer Qobuz et Tidal en high res vers un DAC externe, le Wiim pro me donne entière satisfaction, facile à configurer et à utiliser grâce à l’appli Wiim. Plus la possibilité d’utiliser directement l’appli Tidal en Tidal Connect ou Spotify connect.
Excellent rapport qualité prix pour mon utilisation avec un DAC externe! Ravi de l’achat
Stéphane R.
Câbles d’excellente qualité de construction, utilisés entre un streamer et un DAC. Parfaits!
Pascal L.
DAYTON AUDIO SPA100-D Class D Amplifier for Subwoofer 100W 20Hz-200Hz The Dayton Audio SPA100-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in...
Parfait et de bonne facture
Très bonne carte pour remplacer celle d'un Sub Klipsch avec un peu de découpe quand même (côtes légèrement différentes) et une plaque support en mdf, mais rien de bien difficile.
La qualité de fabrication est sans comparaison avec la Klipsch (je suis d'ailleurs très en colère contre ce constructeur pour cette partie ampli, qui à rendu l'âme 3 mois après la fin de la garantie). J’aurai du rester sur du Focal (comme toutes mes enceintes), au moins c'est français et il y a un support accessible. La carte Klipsch est "cheap", les composants recouverts d'une pâte blanche .. pour éviter de les changer ? Bref un scandale. Obsolescence programmée ? En tous cas, cela me faisait mal au cœur de changer tout le sub !
Celle-ci est de très bonne facture. Deux remarques: moins puissante (mais j'ai augmenté le signal sub de l'ampli) et câble secteur "UK" ..
Pierre Z.
Correspond bien à ce que j’attendais - livraison rapide
RENE R.
AUDIOPHONICS HA B6120
Excellent ampli qui remplace avantageusement un ampli tubes qui manquait de puissance.
Rapidité d'envoi sur le site.
Sophie V.
[GRADE A] IEAST SOUNDSTREAM PRO M30 Media Player UPNP USB DLNA AirPlay Wifi RJ45 Multiroom ES9023 Refurbished product  - Grade A This compact WiFi audio streamer / receiver allows you to listen to music on your HiFi system directly from your Smartphone, tablet,...
ne supporte par .OGG
Les appareils IEAST ne supportent pas le format .OGG
dommage !!
Pierrick R.
Petit mais acec de la voix
Dac raccordé en Usb-c à une tablette Windows Pro et en coax sur mon ampli. Avec Qobuz en mode Wasapi exclusif le son est hyper defini et bien plus fort que celui de mon lecteur cd, j'ai du réglé le volume au 1/3 sur l'appli pour obtenir le meme niveau d'entrée ! De la clarté en plus, des basses bien mieux definies qu'en qualité cd et en plus il s'allume er s'eteint avec la tablette... Dac hyper discret et tres efficace.
Markos M.
Étonnant ...
Appareil simple avec fonctionnalités étendues devient un transport de haut niveau avec liaison optique ... élément minimaliste dans montage par éléments séparés minimalistes mais indispensable à recommander sans hésitation ... merci beaucoup à Audiophonics de le mettre à disposition.
Markos M.
FIIO K5 PRO ESS DAC Headphone Amplifier ES9038Q2M XMOS XUF208 32bit 768kHz DSD512 The FiiO K5 Pro is a high-performance desktop DAC and Headphone amplifier combo, featuring an exemplary design for audio reproduction characterized by high transparency,...
Fabuleux ..
Utilisant un casque audio-technica de bon niveau, le connecter le transforme complètement, nuit à jour ... à recommander sans hésitation ...
Kruno K.
Audiophonics Canare 110 Ohm AES/EBU Shielded Cable Gold plated 1m
The Canare AES/EBU 110 Ohm cable meets all my expectations. The whole service was very fast and accurate. I am satisfied!
Certainly, I would like the final price to be a little lower :)
J'ai eu pas mal de câbles jusqu'à des tarifs délirants.
Celui-ci est simplement parfait. Tout y est. Respect des textures, dynamique, scène sonore. Très facile à dénuder, je l'utilise sans terminaison....
Maxime R.
Concernant la commande :
envoi le 19 en journée, reçu le lendemain midi !
Une alim en 48V fournie, le must.
Concernant l'ampli :
Taille lilliputienne, comme la plupart du matos hifi chinois.
Bonne qualité de finition (borniers enceintes minuscules, exigeant des fiches bananes)
L'écoute : (sur des LS50 et des Wharfedale Evo 4.4)
Du détail ! Le premier point de satisfaction pour moi.
La définition et la spatialisation sont excellentes.
L'écoute est encore plus "déliée" sur mon Topping PA5, mais de peu, et le Fosi pourra par conséquent paraître moins fatigant à l'écoute.
Les registres (aigus/médiums/graves) sont restitués équitablement d'après moi.
Et la réserve de puissance est bienvenue sur les enceintes à faible rendement (mes LS50 ont gagné en souffle avec le Fosi!).
Bref, du tout bon !
Constantin N.
Constantin
Hands down the best amp there is.
The price.
The NCX-Performance
Clean 600 Watt RMS
Adjustable gain to fit any preamp
RCA and XLR switch without any ground loops.
This amp from Audiphonics is objectively the best there is where the stars align in terms of part, design and quality.
The ultimate bonus: About any parts can be replaced by yourself. It's a no brainer.
Just buy it already and don't look back :).
Superbe câble de modulation
Je dois reconnaître que ce câble RAMM Élite 8 est excellent. Après une période de rodage nécessaire, il est transparent avec de la matière, les instruments sont bien séparés, et l'image profonde.
Il remplace un câble Neotech nei 3004, qui demeure un très bon câble.
Carlos v.
TONEWINNER AD-8300PA Power Amplifier Class AB 11 Channels 3x515W + 8x205W 4 Ohm Tonewinner presents its AD-8300PA, an 11-channel power amplifier, allowing a home cinema integration, including Dolby Atmos systems. It delivers a consistent power with low...
Order this item before 11:00 and the next day in my house before 12:00, that's very nice!
Big amp and a nice design. The first sound impressions were good sound! The package was also very good, box in a box in a box!!!
bernard l.
Schuko Socket Timer / Countdown Programmer 230V 3680W This programmer for Schuko socket is easy to use, practical and energy saving. It allows a programming at 15min, 30min, 1h, 2h, 4h or 6h. It can be used with any device...
bien mais
je n'avais pas vu que c’était une prise speciale allemande et que la documentation était en allemand (même pas de version anglaise).
donc moins facile a faire fonctionner.
Mise à jour
AVIS MIS A JOUR
Conseils et rapidité exemplaire.
Bravo Audiophonics
Contexte /
Système monitoring pro NEUMANN
KH120a
HH750dsp - microphone de mesure Neumann
Carte son APOGEE Quartet
Cable XLR CANARE - L-4E6S STAR QUAD
Sur les conseils d’AUDIOPHONICS.
J’ai acheté 8m de ce câble CANARE pour refaire sur mesure mon installation qui était faite avec les câbles Vovox Sonorus.
J’ai pris du neutrik plaqué or.
Finalement devant le grave envahissant ; J’ai refait les mesures d’alignement du DSP qui du coup avec le changement de câble n’étaient plus bonnes. J’ai également fait un traitement acoustique simple d’un mur qui posait problème.
Conclusion :
Le résultat est parfait !
Je vous joint la courbe.
Attention ce câble semble généreux avec le grave. (Rodage?)
florian b.
DAYTON AUDIO MX12-22 Speaker Driver Subwoofer 600W 4 Ohm 89dB 23Hz-450Hz Ø30.5cm Designed to produce maximum output at an unbeatable price, this MX12-22 Max-X dual voice coil subwoofer from Dayton Audio has all the features you'd expect from a...
Reçu, hauts parleurs de qualité !
Pas encore tester, produits de bonne qualité je recommande!
Maciej B.
Great product. I’m using to power the switch before a streamer and improvement is massive.
Roland B.
DYNAVOX ASP1 Vinyl Adapter 45 RPM 20mm This ASP1 Dynavox vinyl adapter allows you to play 45-rpm (7") vinyl. Designed from a single piece of aluminium and universal, it will fit all vinyl decks. Its height is 20mm
Un petit manque
Là encore le problème vient de deux côtes qui ne sont pas bonnes et provoque en oscillation latéral avant/arrière du bras porte cellule.
le trou d'axe de l'adaptateur est de 7.46mm alors que l'axe du plateau est de 7.17mm. Le diamètre externe de l'adaptateur est de 37.98mm alors que sur le disque il est de 38.27mm, ce qui provoque double flottement.
Paulius S.
Excellent !!!
Very,Very good for the price.
Paulius S.
Review
For the price is very very good.
Paulius S.
ELECAUDIO LI-23GB IEC C13 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of 5mm², which provides a very...
Review
Terrible designe, but sounds good.
Hugues P.
Monté avec un adaptateur Type D xlr, revient moins cher que celui vendu sur le site.
Hugues P.
Très bon produit.
Très bon pris
Du plus bel effet.
Hugues P.
Anodized Aluminium Push Button with Orange Light Circle 2NO2NC 250V 5A Ø19mm Black This bistable switch (two positions) 250V 5A in anodised aluminium incorporates a beautiful orange LED. It is ideal for all your DIY projects and assemblies, especially as an...
Las d'avoir toujours du bleu ou du blanc. Ce produit est parfait couleur douce et apaisante. J'ai changé tous mes interrupteurs.
L'ancien interrupteur orange était meilleur.
Eric Q.
EVERSOLO BTR-12 IR / Bluetooth Remote Control for DMP-A6 / DMP-A6 Master / DMP-A6 Gen 2 / DMP-A6 Master Gen 2 This IR / Bluetooth BTR-12 remote control developed by Eversolo is designed to be paired with all their DMP series devices, i.e. the DMP-A6, DMP-A6 Master Edition, DMP-A6 Gen 2,...
Me permet de piloter mon DMP-A6 de façon plus rapide qu'avec un téléphone ou avec l'écran. La portée est suffisante pour mes besoins, la télécommande n'est pas inutilement trop grande ou trop fournie en boutons.
Eric Q.
AUDIOPHONICS Trigger 5V 110V/230V Slave Power Supply Device This accessory, made in France in our workshops, makes it easy to add an automatic ignition (trigger) function to your devices that don't have this feature natively.
Fonctionne parfaitement
Connecté avec une prise jack-usb, cet adaptateur allume et éteint un amplificateur et permet de ne pas laisser allumer inutilement un transformateur.
Roland B.
Plusieurs bémols, chaque pointe n'est pas vraiment identique en taille, moins de 10mm avec une échelle allant de moins 0.20 à 0.30 mm, pour une fabrication industrielle par machine à commande numérique!!!. Le deuxième point, inégalité du point de départ du filetage interne des pointes. Je les ai acheté pour mes deux Amplis et mon Pré-Ampli Hi-Fi.
Diego D.
ELECTRO HARMONIX 12AY7/6072A Tube Twin Triode (Unit) This Electro Harmonix 12AY7/6072A tube is a double triode with equipotential cathodes. It is mainly designed to amplify low frequency voltages in audio equipment.
UPGRADE DU CANAL GAin MARSHALL DSL 5 CR
Acheté pour remplacer la 12AX7 d'origine du préamp de canal ultra gain de mon marshall, afin de le rendre plus progressif : le résultat est notable, on retarde d'environ1.5 graduation la plage de réglage avant le durcissement typé "marshall" de la saturation. cela permet de trouver un réglage plus "crunchy" en début de course. (j'ai aussi testé une 12AT7 WA : effet moindre, pas suffisant)
Andris L.
WIIM REMOTE Bluetooth Remote Control for Wiim PRO / AMP The WiiM Remote, specially designed for the WiiM Pro and WiiM AMP, has a built-in microphone and an Alexa button for easy voice control of your network player or amplifier.
Nice
It feels good, the batteries last a very long time. There is no need to aim, because the remote control works on bluetooth. An ingenious product at a good price. I posted the pictures in disassembled form on the wiim site =D https://forum.wiimhome.com/threads/wiim-remote.495/post-7590
Christophe T.
Très simple à mettre en œuvre et d'excellente qualité.
Carte à relais ultra simple à mettre en œuvre. Je me suis fais un sélecteur pour 8 entrées et 4 sorties RCA stéréo, avec 3 cartes LITE 4CH. J'ai supprimé le pont de diodes et l'ai alimenté en 12VDC avec un petit bloc alim 230VAC/12 VDC, qui se branche directement dans une prise mural. Les relais sont de bonne qualité et on entend aucun brut de commutation dans le son. C'est très transparent, et vraiment abordable.
Jean T.
Rapide et efficace.
Comme à l'accoutumé : totale confiance. Je recommande.
Jean.
Laurent P.
HDMI 2.1 Optical Cable 8K 60Hz 48Gbps UHD HDR 10 DHCP 2.2 EDID CEC eARC 3D 3m This 3m-long optical HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps, and is compatible with CEC, 3D, HDR 10,...
Agréablement surpris
trés bon cable hdmi 2.1,passe en 4k 120hz la ou d'autre cables "certifier" n'étaient méme pas reconnue.
nicolas H.
TAD EL34-STR REDBASE Power Tube Pentode (Unit) The TAD EL34-STR Redbase is a pentode with a 25W heatsink plate and convection cooling. This tube is intended for power amplification in pentode, ultralinear or triode...
Excellent tube
j'avais un quad appairé et 1 tube a eu la bonne idée de me lacher. (apres 1.5 ans...) Au lieu de changer tout le quad, je suis parti sur l'idée de ne remplacer que le tube défectueux. Opération validée, valeurs du tube très proche du quad et à l'oreille c'est parfait !
A éviter
Apporte une "coloration" dans l'aigu qui peut être désagréable , en fait le terme exact serait plutôt distorsion , idem pour son pendant en shuko. Remplacée par des Furutech rhodium qui après rodage se sont révélées parfaites , pourtant vu ce qu'en disent certain le rhodium j'étais plutôt méfiant...Pour moins cher que les Fu rhodium , les Viborg plaquées Or-Ag sont beaucoup plus neutres
Christian D.
EVERSOLO H2 Balanced DAC Portable Headphone Amplifier ES9038Q2M 32bit 768kHz DSD512 EVERSOLO offers with the H2 a balanced DAC and  portable headphone amplifier  combo wich is compact and powerful. With a USB-C input, it is an ideal companion for...
excelent pour le prix
L audition symetrique du Dac est un plus par rapport aux autres appareils de ce prix
