Laurent B.
Bonne upgrade
Hans B.
Patrice L.
Un produit bien conçu.
Customers reviews - There are 19358 reviews.
Utilisé pour un câble hx16 marche bien pour le prix
Permet de dérouler des bobines
Tiens bien
Emmanuel A.
Excellent sur les ampli gourmand
Pour vos appareils qui consomme beaucoup avec de grosse alimentation il est parfait
Très neutre meilleur que beaucoup d’autre plus Cher
Clarice C.
Giant Killer performance
This unit is a giant killer. At under 100€, you will have to spend 6 to 7 times more to top this. My first surprise, this DAC beats my SimAudio Moon CD-1 in clarity and is more lively. Wow.
By combining this unit with a Wiim Pro streamer, I have a streamer to play from my NAS. I use YouTube music for the moment and it does have some high resolution files: great.
I sang opera for over a decade and played an AIFF/MP3/and FLAC files and smiled so hard I nearly broke my ears.
The bass is firm and resolving: ECM recordings are sound fine on the unit. The timbre (native sound) of instruments is good.
At a higher price point, you pay foremost for a deeper and wider sound stage. That big tent feeling apparent on the Musician Draco R2R, Eversolo DAC Z-8 or the Pegasus DACs.
SU-1 is good but not 10x its price good. Draco is better. Draco is also R2R, but you are in the 650-800 € price range. Until recently I was thinking more in the Gustard A26 or R26 lines, but this little unit solves my problem for way less.
Dominique L.
Remarque Qobuz/Wiim Pro
Pour utiliser Qobuz en 24/192, il faut passer par Wiim Home, MConnect ou Bubbleup par exemple, sans utiliser Chromecast sinon on n'obtiendra que le 24/96.
L'appli Qobuz seule, ne trouve pas le Wiim Pro et doit passer par Chromecast soit maxi 24/96.
Pour ce qui me concerne, j'ai désactivé l'option Chromecast et je suis sur d'avoir ainsi le flux maxi.
Tomo Z.
Nice product from WBT ,well built could be a little bit cheaper but I still raccomand using this locking plugs
Jérémy b.
SHANLING UA1 PRO Adapter DAC USB-C ES9219C 32bit 384kHz DSD256 80mW 32 Ohm Silver Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones) or you simply want to improve the very average...
Petit prix, mais grosses prestations !
Après 3 jours d'utilisation, je peux laisser un commentaire avec un peu de recul.
Achat de ce DAC pour contourner un problème de carte son devenue capricieuse sur laptop gamer âgé de bientôt 12 ans.
Il est branché sur un port USB A 3.0 (je n'ai aucun port USB 2.0 sur la machine).
Petite chauffe du DAC, mais qui reste limitée, et non dérangeante.
Quel packaging, simple, mais élégant à la fois, on pense acheter un bijou, la finition du DAC couleur argent (en zinc apparemment) est splendide, on est loin du DAC en plastique ABS. Le cordeau en nylon tressé donne ce côté élégant et solide.
DAC utilisé uniquement sur Debian Sid (système Linux donc), avec Audacious pour la musique, et VLC pour les vidéos, aucun contrôleur de son installé (ni Pulseaudio, ni Jack, ni Pipewire), pas d'égaliseur, ni d'effets, lecteurs paramétrés pour du bitperfect absolu, le système a reconnu le DAC sans le moindre soucis.
Est utilisé des musiques en provenance de iTunes majoritairement (m4a 256 kbit/s, ALAC), et CD personnels.
Pas de bruits parasites, ni de bruit de fond, pas de déconnexion, ni de bugs quelconques à déclarer.
Est branché sur le DAC, une petite paire d'enceintes amplifiées en USB, et branchées en jack (Edifier r12u), le son prend beaucoup + d'ampleur, + d'aération, les micro-détails difficilement audibles le deviennent nettement mieux, les aigus filent + haut sans être agressifs, et un petit mieux subtil au niveau des basses (limitées par les capacités évidentes de ces enceintes qui n'ont aucune prétention ni vocation à rivaliser avec de la pure hifi évidemment), mais l'amélioration globale sonore est vraiment là, rendant les écoutes agréables malgré tout, et chose surprenante, les enregistrements de piètre qualité ne sont pas pardonnés !
Est aussi utilisé sur le DAC, un casque Beyerdynamic DT-240 Pro, là aussi l'amélioration globale est + qu'évidente, la musique prend une claque monumentale, c'est vivant à souhait, il y a foule de détails à n'en plus finir, la dynamique s'envole, les musiques type rock, ou les lives sont d'un délire absolu, ça part dans tous les sens, une sacrée réussite pour qui aime les médiums riches en micro-informations, des aigus qui montent haut sans devenir criards, et des basses généreuses mais sans trop en faire, un bon équilibre tonal.
Là aussi attention aux mauvais enregistrements, ça saigne les oreilles.
Le changement d'avec la carte son d'origine complètement pourrie du PC est stratosphérique, et pourtant ce DAC est un entrée de gamme, idem pour le casque, et les enceintes USB n'ont aucune vocation musicale, bien sûr je préfère mon vrai système hifi, mais force est de constater que pour une somme modique, on peut avoir de belles surprises.
Comme mentionné de partout dans les commentaires, le service Audiophonics est parfait, emballage adapté, produit fonctionnel qui n'a aucun soucis, livraison rapide, prix attractif.
Je recommanderai à l'avenir lors de mon déménagement futur, très certainement des câbles.
Jérémy b.
DAC utilisé uniquement sur Debian Sid (système Linux donc), avec Audacious pour la musique, VLC pour les vidéos, et MPV pour un usage minimaliste, aucun contrôleur de son installé (ni Pulseaudio, ni Jack, ni Pipewire), pas d'égaliseur, ni d'effets, lecteurs paramétrés pour du bitperfect absolu, le système a reconnu le DAC sans le moindre soucis.
Est aussi utilisé sur le DAC, un casque Beyerdynamic DT-240 Pro, là aussi l'amélioration globale est + qu'évidente, la musique prend une claque monumentale, c'est vivant à souhait, il y a foule de détails à n'en plus finir, la dynamique s'envole, explose littéralement, les musiques type rock, ou les lives sont d'un délire absolu, ça part dans tous les sens, une sacrée réussite pour qui aime les médiums riches en micro-informations, des aigus qui montent haut sans devenir criards, et des basses généreuses mais sans trop en faire, un bon équilibre tonal.
la multiamplification démocratique
1l amp pour l aigu ruban amt pro 4 et un autre pour le suraigu fostex t 90..résultat fantastique.mieux que de bons vieux classe A.
Et en prime un look sympa et une très bonne finition.
Trop fort les chinois.
Un doute
Un peu comme un autre avis manque de précision et dynamique
A confirmer
Frédéric B.
Grande Qualité
Connecteur qualitatif, solide, facile à monter avec très bon maintien du câble.
NOTE importante de montage: la rondelle en plastique de l'embase peut s'enlever le temps du montage pour libérer la rondelle de caoutchouc de centrage du câble, pour qu'elle ne soit pas abimée quand on manipule le câble dans l'embase, lors de sa fixation.
Frédéric B.
Grande Qualité
bon rqp
Apporte de la propreté à l'écoute en positionnant les pointes vers le haut ou le bas vous pouvez jouer sur l'image sonore . bon produit.
marc g.
très bien pour un usage très particulier
franchement bluffant si collé à une plaque de plâtre. Assez décevant avec d' autres configuration, mais j'ai pas tout essayé. bonne bande passante, le son est très propre sans qu'on puisse parler de hifi. Rendement très très faible en revanche. Prévoir plusieurs exemplaires a répartir dans la pièce, avec un condo de 100uF en série pour couper les basses et monter en puissance. En complétant avec un petit caisson de basse genre pour ordi, c'est parfait. On sonorise le magasin avec, et tout le monde est content.
ETI BP-50C Speaker Terminal Gold Plated Pure Copper Ø19mm (Pair) The ETI BP-50C are very high performance speaker terminals at a contained price.  Made of a 1100 Series Hardened Copper conductor with an IAC of 102%...
Très bon bornier
Laisse tout passer
De très bonnes qualités
Davor F.
A Dac
This Dac wont impress you at the start that's for shure but give it a little time and you will be pleased with warm no fatigue sound.At first i thought it wont be my cup of tea sort of speak but when you play high quality music through d300 it becomes very satisfying and you just find yourself changing album after album and wasting your time in a positive way.
ELECAUDIO DCT-2.5G Male Jack DC 5.5/2.5mm Connector Tellurium Copper Gold Plated 3µ This DC 5.5/2.5mm Elecaudio DCT-2.5G connector will allow you to design high quality power cables, ensuring a clean transmission of the electrical signal to your HiFi device....
Pas mal du tout
Monter sur un câble Gotham beau son
Laurent P.
Magique et économique....
Reçu aujourd'hui et monté avec Fiches Bananes BFA Plaquées Rhodium, une paire de câbles pas cher, et la qualité n'a rien à voir avec le prix... Je les avais commandé selon des recommandations d'un passionné, je n'y croyais pas trop, j'avais préféré me diriger vers des marques et des critiques sur les revues spécialisées... Mais une fois montés, j'ai voulu les tester sur ma chaine principale (Spendor D7 / Roksan) et là surprise ! Beaucoup de relief, de transparence, des basses profondes et rapides, pas envahissantes et le reste est tout à fait parfait, les instruments sont déliés les uns des autres, cela respire. J'ai eu pas mal de câbles, parfois 4 x plus chers, et au bout de quelques heures d'écoute, ils sont tous surclassés, je vais en commander d'autres, pour ne mettre que cela sur tous mes systèmes. Livrés super rapidement, merci Audiophonics...
Jean b.
C est trop mou
Ces pieds ne sont pas assz rigides pour une enceinte colonne, elle oscille et est tres instable
Bons câbles.
Ces câbles XLR sont très corrects en regard du tarif.
Fabrication sérieuse.
Je recommande.
Aurélien G.
DAYTON AUDIO UM12-22 Ultimax DVC Speaker Driver Subwoofer 600W 2x2 Ohm 87dB 20Hz - 1000Hz Ø30cm Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Discover the best price-to-market ratio!...
Démoniaque !
Ce 30cm est fabuleux dans son domaine !
J’en ai acheté une paire sans trop y croire voulant étendre la réponse de mon system hifi haut-rendement, et je dois dire que je suis resté bouché bée …
C’est ultra nerveux, avec une descente dans l’infra-grave et une tenue en puissance à faire pâlir les sub du commerce à la mode !
Je l’utilise en usage musical dans 80L clos et c’est sublime !
Rapide, nuancé, puissant avec un niveau sonore possible qui semble sans limite !
Vous pouvez y aller les yeux fermés !
Boris T.
EXICON ECW20N20 Transistor MOSFET Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
No anti-static packaging!
Exicon lateral MOSFETs are true audiophile parts, not available at many vendors. It is great that Audiophonics has added them to the stock.
They arrived in the paper box with more than enough of paper and bubble wrap for protection. After unwrapping ample protection, there was a real shocker. They were packed in a plain plastic bag.
MOSFETs are parts highly sensitive to any electrostatic discharge. Even 20 V between two specific pins can damage them. They should be packed in the ESD safe bags meant for electronic components and handled following ESD safe procedures.
Warehouse personnel should be provided with training and required accessories. Thankfully, all received parts check as good.
Très bons connecteurs
Connecteurs d'excellente qualité bénéficiant d'astuces intéressantes: le petit méplat au niveau de la brasure de masse, possibilité de rajouter de la gaine thermo au niveau des vis de la partie arrière, serrage sur l'embase châssis en vissant et non en dévissant (ce qui est plus logique). Diamètre externe encore acceptable. Tarif justifié.
Excellent en câblage interne
Fil utilisé en câblage interne, liaison embase XLR vers cartes de conversion Symétrique, asymétrique, et liaisons courtes signal asymétrique. Bonne section, facile à mettre en œuvre et bon compromis souplesse rigidité. Le modèle avec gaine diamètre 3 mm est très rigide, et d'une résistance à toute épreuve (utilisation différente)
Bonne qualité. Facile à mettre en œuvre
Cable qui respire la qualité, facile à raccorder à la plupart des fiches RCA. Masse et point chaud faciles à dénuder. Bonne section du point chaud. Bonne souplesse, Qualité d'écoute des plus satisfaisante. A conseiller. Plus facile à mettre en œuvre que le modèle VIABLUE NF-B.
Jacques B.
Résultat positif surprenant
Je confirme l'autre avis déposé pour ce produit.
Ces capuchons de borniers sont venus compléter les capuchons que j'utilise pour tous les connecteurs inutilisés de mes équipements (RCA, XLR, USB etc.).
Pas ou très peu d'effet sur la signature sonore ou la restitution des timbres, peut-être un tout petit peu plus de naturel. Par contre, nette augmentation de la transparence (= recul du bruit de fond), immédiatement perceptible sur des enregistrements familiers. Selon l'expression un peu galvaudée, "un voile est levé". Je ne m'y attendais pas avec cette intensité sur mes enceintes et borniers déjà très bien amortis et offrant à mon avis peu de prise aux perturbations RF/EMI.
A ce prix, environ 30 € (2 x 2pièces), tuning très efficace que je recommande.
Martin A.
Gustard r26
It's working straight out of the box- so far good
Yoann L.
fou !!
Le meilleur câble que j'ai écouté ! le secret est de le doublé ! ( 8 brin pour le + et 8 autres pour le -) ! comme ça, respect de l'impédance !
ainsi monté, la bande passante est incroyable !
On m'a prêter souvent des câbles hors de prix, mais celui la est au dessous de tous ! foncé !!
Valeur sûre!
C'est du Neutrik et sans problème!!!!
Très bien!
Prise jack de très belle qualité pour un prix raisonnable! Le
résultat sonore est également convaincant!
Excellent!
C'est le meilleur câble au mètre que j'ai pu tester! Bande passante,
dynamique,définition,timbres et musicalité sont au sommet de ce
que je connais! Je n'ai pas tout testé et il y a sans doute encore
mieux,mais à quel prix???!!!
Emile M.
ARYLIC S50 PRO+ Network audio player DAC ES9023 ADC WiFi AirPlay Bluetooth 5.0 aptX HD Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception....
Je l'utilise avec des maudio bx8
J'ai baissé le niveau des bass à _2 aiguë _1
Dans l'ensemble fonctionne plus que bien en comparaison avec un nad c 326
La dynamique est bonne pas besoin de pousser à fond
Pas encore essayé la sortie sub
Pour l'instant écoute uniquement en streaming
La qualité du wifi bien qu'en étant éloigné ma box je n'ai pas de latence
Colis reçu dans les temps et en bon état
Le service à été très réactif
Pierre-Marin L.
Sublime
Partant d'un Allo Digione Signature avec alim Shanti c'est une amélioration incroyable, scène sonore en particulier mais tout est immensément amélioré, tenu des basses, précision, micro détail ! Je suis ravi, mon Audio GD Master 7 Singularity est métamorphosé, je suis passé en I2S. Ce streamer mérite sa réputation le RQP est hors norme, en plus j'ai pu installer sans soucis Gentoo Player / kernel RT CTLO avec Diretta, cette distrib est phénoménale par rapport à Red OS qui est déjà bonne. Je suis ravi, et le rouge un peu déroutant s'avère assez sympa...
Laurent P.
Superbe !
Franchement pour ce tarif vous n'aurez rien de mieux, j'en ai collé deux en sortie de mon DAC Myryad Z20, tout est devenu plus musical, pêchu, plus "rond", la musique s'enchaine sans fatigue.
Et ce pour 15 euros les deux !
Attention, ça surprend quand on a l'habitude des NE 5532 ou OPA 2604...2134 etc...Le seul qui pourrait lutter c'est le LT 1364 mais trop "sec".
Damien D.
What else
Je l’utilise uniquement en tant que preampli hifi et c’est une pépite.
J’ai entendu des preamp bien plus cher ne pas sonner comme ce little dot.Avec des tubes rtc par exemple il s’envole.
Ce preamp est vraiment à considerer meme avant achat de beaucoups plus hdg et peut s’intercaler dans des installes à pas de prix avec de très bon bloc de puissance derriere.
Fabuleux
J’ai monté ce câble avec des Elecaudio Tellurium S 85 avec soudure argent mundorff 10%
Il lui faut bien 30/40 heures de fonctionnement pour délivrer son savoir-faire.
Il est impossible dans cette gamme de prix de trouver une concurrence à la hauteur. C’est excellent partout et je pèse mes mots. Subtile mélange de finesse et de dynamisme.
Bref, faites vous plaisir en l’écoutant chez vous et vous regretterez de ne pas l’avoir connu plus tôt.
Merci audiophonics pour ces pépites qui ridiculisent bien souvent des câbles de marques prestigieuses.
Matthieu D.
Meilleur
Rachat du même modèle, sauf que le nouveau est bien plus performant, il y une nette préamplification que ce modèle n'avait pas vraiment avant, et la qualité du son est bien meilleure.
Je m'en sers pour contrôler le volume sur un signal ligne venant de mon PC avant l'entrée dans la console de mixage (pour avoir accès au volume à distance via la télécommande depuis la mezzanine).
Très satisfait.
MATTHIEU G.
waou
mini dac mais il fait le maximum
utilisé en entrée optique wiim et qobuz / web radio, waooo que peut on chercher de plus, tout y est. Et pour ceux qui cherchent une coloration regarder plutôt du coté des amplis ou des enceintes que de se fier aux retours des youtubeurs :)
Après avoir eu un smsl DO100, puis un topping E70 velvet, je peux vous dire que ce SU-1 est superbe.
Les + :
son détaillé, clair rien à dire avec un amp cambridge CXR 120 ( il fait mieux à l'écoute que la pile CXN embarquée.. c'est plus net, ciselé, les basses sont vraiment très propres, net même à faible volume )
tout petit
très faible conso en fonctionnement, et sans signal optique, avec la mini led clignotante ma prise connectée affiche 0 watt. Je ne l'éteins même pas en journée.
une réussite
Jan S.
I took about 100hour.
From the begining this preamp work and sounded well, but after approximately 100hour it was blooming. The sound widened, instruments found there right places on the recording. Paring it with audiophonics purifi, sparkos power amplifier.
Frédéric B.
1ère commande sur AUDIOPHONICS et j'en suis très satisfait. Au-delà du produit qui corresponds à mes attentes, le délai d'expédition a été très court d'autant plus que j'habite à La Réunion. Colis suffisamment bien emballé également. Je recommanderai.
Etienne L.
Du sérieux!!!
Je confirme la qualité de construction et c'est bien du cuivre...
Pour passer mes câble 2,5mm j'ai percé les fiches avec un forets et c'est parfait et toujours solide (il y a une surface plane assez large)
Pas besoin de se tracasser pour l'encoche ou le détrompeur il suffit de changer l'ordre des rondelles de couleurs...
La soudure est parfaite, un bon rapport qualité prix
Daniel C.
Module does not meet the specs!
Purchased the module, for use as regulated power supply at 32V.
But, unfortunately, the module cannot work at 32V, as the trimmer is running very hot when tuned at 32V, and on top, the electrolytic capacitors C3 and C4 are 25V types.
The operating voltage voltage at C4 is simply the output voltage.
When the VR trimmer is set at 32V, the voltage on VR is 27V, and VR is in that position abt 300 ohms : 2,5W dissipation is much too high...
To solve the problem, I adapted the module as follows:
Changed C3 and C4 by 64V types, and replaced R1 (50 Ohm) by 500 Ohm.
The module can now be easily tuned at the desired voltage, without burning the 5k trimmer, and blowing the elco's.
Daniel C. Hamme - Belgium
Rudolf P.
TUNG-SOL 6650 Power Tubes (Unit) The Tung-Sol 6650 tetrode tube was developed for applications in the amplifier output stages of high fidelity bass amplifiers. It respects the construction of the original 1960...
Test Strong, Great Tubes.
Bought 10 pieces, al test very strong and close. This Tungsol is a better choice compared to Svetlana =C=
Alain T.
Simple et fonctionnel
Sur le marché on trouve pléthore de convertisseurs HDMI vers optique ou coaxiale Je cherchais désespérément un convertisseur optique vers hdmi sans succès jusqu'à présent. Merci a Audiophonics d'avoir inventé ce produit.
Très simple à utiliser. Brancher, sélectionner la source optique ou RCA et ça marche parfaitement.
Paul D.
Gustard R26
Superbe produit, et merveilleuse restitution de la musique!
Au déballage, surprise: finition exceptionnelle, pour moi, c’est beau! On regarde la face arrière c’est la première fois que je découvre cet équipement, multitudes d’entrées et possibilités de sorties! Toutes possèdes un cache de protection, même l’entrée RJ45! Superbe! Une fois branché à la chaîne surprise: que la restitution musicale est remarquable! Je suis tellement surpris que j’ai envie d’écouter mes CD délaissés depuis plusieurs mois, stupéfaction! Ils sonnent d’une façon beaucoup plus analogique! Même constatation sur l’écoute de la musique dématérialisée enregistrée sur le NAS. La diffusion est presque holographique elle prend un relief, un placement, une profondeur spectaculaire! Je ne pensais pas découvrir cette musicalité! Je suis comblé! Un appareil exceptionnel! Merci Audiophonics et GUSTARD! SOMPTUEUX!
olivier G.
Apres un mois d'utilisation je suis extrêmement satisfait. S'accorde parfaitement a mes enceintes jbl es20. Le son est de meilleur qualité que mon ancien ampli, les aiguës et medium sont très détaillés. Je compléterai par un caisson de basse actif et ce sera grandiose en terme de profondeur de basse. Merci a l'équipe pour la qualité de vos sélections.
Tim E.
Unbelievable
What a quality Ethernet cable. The sound in my system changed positive. More relaxed 3D sound with blacker background
Gurvan B.
Super !
A ce prix il n’y a pas mieux, qualité du matériel au rdv, du vrai cuivre plaqué or.
Gurvan B.
Pas mieux pour le prix
Qualité super! Un des rares bornier avec une faible masse, de plus c’est du vrai cuivre sous le placage or. Le prix est 10x moins cher que certaine marque pour la même qualité du conducteur… Je vous le recommande pour tout type de haut parleur si vous avez prit un bon câble pour plus de transparence, ce bornier sera faire passer le signal parfaitement.
Gurvan B.
Super ! C’est le genre de pied qui avec les picots + le caoutchouc souple permette des micros mouvements donc élimine très bien la transmission de vibrations.
