ALLO USBRIDGE Aluminum - Audio Media Player Squeezelite DietPi ROON Interface for USB DAC
ALLO USBRIDGE Aluminium DIET PI ready for use
This aluminium case is dedicated to the ALLO Sparky and for the ALLO USBRIDGE. It provides passive dissipation for noise-free operation.
Strong point:
  • Aluminium housing AL6063 T5 quality
  • High quality passive dissipation
  • Insensitive to mechanical vibration
  • Laser engraved
Reference : 12574
189,00 €tax incl.
157,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
ALLO USBRIDGE Aluminium Version
ALLO SPARKY + ALLOUSBRIDGE + DIEPTI ALLO
Allo USBRIDGE
This version of the ALLO USBRIDGE includes a ready-to-use solution with an ALLO SPARKY+ an ALLO USBRIDGE+ an Aluminium Case+ an ALLO DIET PI version.
By its architecture in 3 pieces of an exemplary finish the aluminium box supplied with the bundle ALLO UBRIDGE ALLO SPARKY is the ideal tool of transport streamer HIFI. It serves as a natural heat sink and barrier against EMI waves in particular. it is particularly dedicated to a Hifi use offering a density and an insensitivity to mechanical vibrations.
Full integration with ALLO SPARKY and ALLO USBRIDGE
The ALLO aluminium bundle thus offers a turnkey solution with a stable high quality USB output without jitter harmful to use as a HIFI streamer server. A more explicit description of the qualities of this high precision USB module is available on this page: ALLOUSBRIDGE. Thus the ALLO Sparky and ALLO USBRIDGE set offers a high resolution module competing with AURALIC, SOTM, Linn or Aurender solutions. You can connect this set to a USB DAC with the highest possible USB transfer quality. (see screen below showing stable signal on USB output measured on Teledyne Lecroy system)
Integration with OS Diet Pi
In order to complement this powerful solution, the ALLO SPARKY and ALLO USBRIDGE + aluminium case are supplied with the OS DIET PI in a special ALLO version with a dedicated and ROON compatible interface. This gives you a real turnkey Streamer.
Components of choice
The module includes 6 Nichicon electrolytic capacitors 330µF 35V to ensure a constant power supply and high precision resistors for a very good signal-to-noise ratio.
All configuration information for DIET-PI is available here
Power connectorJack DC 5.5/2.5mm
Dimensions100 x 65 x 45mm
Weight800g
Package1x Allo Sparky
1x Allo USBridge board
1x Aluminium case
Diet Pi eMMC configuration Allo.com version
Allo Power Supply
Allo USBridge
Allo USBridge
InputMicro SD
InputRJ45
OutputUSB
Max sampling rate192kHz
4 reviews
Clean!
When you are driving an endpoint and all recommended dongels, etc, recommended for cleaning up the USB signal, is deteriorating it istead, you know you have a product delivering according the marketing. This one does. At a price that is infact ridiculous compared to other things purchased in the past. By it, buy a ROON license and start lastening to the music as is, instead of your gear. Highly recommended.
This review has been posted for ALLO USBRIDGE Aluminum - Audio Media Player Squeezelite DietPi ROON Interface for USB DAC
USBridge
Ce lecteur remplace un RaspDIGI AUDIOPHONIC connecté comme lui à une interface GUSTARD U12 XMOSI2S/SPDIF/AES EBU 32bit 384Khz. La comparaison ne porte que sur les SBC et la carte USB pour le ALLO. La différence s'entend, plus de dynamique et de relief avec le USBRIDGE. Pour l'OS, j'ai remplacé DIET PI par VOLUMIO sur carte micro SD plus facile à mettre en oeuvre pour connecter un NAS ou disque USB. A priori DIET PI, dans sa version native, n'exploite que les fichiers musicaux du répertoire de la carte eMMC soit au mieux 16 GB de stockage. Il faut sans doute entrer des lignes de commandes dans DIET PI pour identifier les stockages externes, mais le site Diet Pi .com ne dit pas grand chose sur le sujet. Cinq étoiles quand même pour la qualité audio.
USBridge
*I want to add to my review: I have posted my DSD problem on Computeraudiophile forum and Allo support has resolved my problem in less than a day!!! GREAT!
USBridge
I'm overall very happy with my purchase. I have managed to get all up and running, in short few days. I am running roon core on my desktop computer to roon bridge on USBridge. Allo GUI is very easy and useful. However I'm not able to play DSD files yet, since my DAC/Xmos is not supported with ALSA yet, but I believe I'll make it work in the end. PCM works flawlessly and sounds great! Alu box keeps system running on about 50C.
This aluminium case is dedicated to the ALLO Sparky and for the ALLO USBRIDGE. It provides passive dissipation for noise-free operation. Strong...
