Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Krzysztof K.
Fountek NeoX3.0
hello how long will it take to present the date of my order? Did the manufacturer send you the speakers? Maybe you have an...
Remi B.
Bouchons
Patrick K.
Sonic Master
This cable is sooooo good that i was shocked. I did not expect this level of warm neutral detailed rich, open and airy sound...
RCA Connectors
We offer a very wide range of RCA connectors. RCA plugs are essential in the audio industry, and are available depending on the material used, the plating applied, or the mode of use: crimp, solder, or clamp.
Among our many RCA connectors, discover the well-known brands such as Furutech, Elecaudio, Neotech, or 1877PHONO. A large choice of high quality RCA plugs, in OCC copper or pure silver.
