These high-quality aeco ARP-4045G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with 10µ gold plating, ensuring both excellent conductivity and perfect resistance to oxidation. The insulation is made of glass-fibre reinforced nylon with a star shape for a firm connection, and the outer shell is made of brass for durability. The connectors have a short format with a reduced conductor size, limiting resistance, capacitance and inductance sensitivity during signal transmission. They also accept cables up to Ø10.5mm in diameter, which is held in place by a screw.
| Specifications | |
| Product type | Male RCA connectors |
| Contacts material | High purity tellurium copper |
| Contacts plating | Gold 10µ |
| Contacts resistance | < 0.3mΩ |
| Insulation material | Fibreglass-reinforced nylon POM |
| Connectors shell material | Brass |
| Max cable diameter | With reducer: Ø8.5mm Without reducer: Ø10.5mm |
| General | |
| Total dimensions | Ø13.7*46.4mm |
| Color | Silver |
| Quantity | 4 connectors (2 with red ring, 2 with white ring) |
| Max cable diameter (mm) | 10.5 |
| Mounting type | To weld |
| Connectic | Male |
| Contacts Material (Connector) | Tellurium Copper |
| Contacts Plating (Connector) | Gold |
