WBT 0110AG RCA Connectors NextGen Pure Silver 75 Ohm Ø9mm (Set x4)
-10%
These WBT 0110Ag connectors benefit from all the know-how of the brand as well as pure Silver conductors, allowing the design of cables of unbeatable quality!
4.0 / 5
Reduced price!
Reference : 2427
Limited time offer:
299,00 €tax incl.
-10%
269,10 €tax incl.
224,25 € tax excl.
Shipping date: 01-12-2026.
WBT 0110AG
WBT 0110AG Connecteurs RCA Nextgen Argent Pur 75 Ohm Ø9mm (Set x4)
In 1985, WBT designed the first one-piece machined connector with a progressive clamping device. Since then, the machining technique has been refined, with the eight lamellae of the outer contact being machined on high-precision machines using diamond drills.
The patented chuck clamping system has also benefited from this development and has become mechanically smoother thanks to the sleeve ring. The result: high clamping tension and therefore high contact pressure, all without damaging the lamellae. This patented design has the value of a symbol on the market. Today, WBT is synonymous with perfection in the field of audio connection and has a well established reputation.
In 2003, NextGen technology was introduced, pushing the conduction quality of WBT connectors even further. Today, this principle extends to the entire range. NextGen technology was developed by WBT as the ultimate solution to all connection problems. Thanks to the solutions implemented, the conductors used are absolutely pure.
The characteristic impedance of 75Ωsignifie that these connectors transmit not only superb analog signals but also outstanding audio, video and digital signals. The transmission bandwidth is 1GHz.
Eddy currents occur in metal components made from alternating currents. These currents can result in signal distortion. NextGen connectors are designed in such a way that eddy currents do not occur at all. The contact elements of the connectors are made of high-purity materials to ensure optimal signal transmission. The retaining mechanism functions like the chuck of a drill and holds the contact between the socket and the RCA firmly. The high retaining pressure ensures a flawless connection. The central contact element can be removed for easy cable soldering.
Product typeMale RCA connectors
Conductor materialPure silver
Impedance75Ω
Max. cable diameterØ9mm
Connection typeTo solder
Internal body materialFiberglass
Cable tighteningBy Torx T6 screw (key included)
Connector diameterØ13mm
Body length51mm
QuantitySold by set of 4 connectors
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Silver
2 reviews
Excellent !
Pour moi, question conductivité c'est la meilleur RCA comparée à la concurrence haut de gamme. Il y a des précautions à respecter au démontage pour réaliser proprement les soudures, les points d'ancrages plastique doivent être décrochés à l'aide de 2 mini tournevis afin de désolidarisé l'enveloppe plastifiée ; une double croche spécifique fournie avec la clef torx serait bienvenue.
This review has been posted for WBT 0110AG RCA Connectors NextGen Pure Silver 75 Ohm Ø9mm (Set x4)
BON WBT
Bon fiche rca argent WBT par contre pour le prix trop cher vue la qualité trop plastique merci
 (3)
 (7)
These WBT 0110Ag connectors benefit from all the know-how of the brand as well as pure Silver conductors, allowing the design of cables of...
