This Furutech DI-11 IEC connector uses the manufacturer's patented alpha cryogenic process and also demagnetizes the contact pins. It is a reference product at Furutech. Thus, the use of this high quality copper IEC connector allows the design of very high quality power supply cables, promoting efficient transmission of the electrical signal. In addition, it allows the use of thick cables that are easy to install.
| Max cable diameter (mm) | 18.0 |
| Mounting type | To screw |
| Connectic | Female |
| Connector | IEC C15 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
| Rated current (A) | 10.0 |
| Refurbished Grade | Grade S |
