Heat-shrinkable tubing with a 2:1 ratio. Intermediate thickness designed to ensure excellent mechanical strength, while retaining a high degree of flexibility. Adapts to irregular shapes and provides a high degree of insulation and sealing. Halogen-free, flame-retardant and RoHS-certified.
A ratio of 2:1 means that the diameter of the sheath once heated will be divided by 2. For example, for a 12mm sheath, after being heated its diameter will be 6mm. Diameter: 9.0mm => approx. 4.5mm after shrinkage
Specifications:
Retractable Ratio: 2: 1
Longitudinal Retracting Ratio: ± 8%
Shrink Temperature: 70 - 115 ° C
Sheath Thickness Retractable : +/- 0.30mm
Sheath Thickness After Retraction: +/- 0.60mm
Temperature Resistance: -45 to + 125 ° C
Rigidity Dielectric: ≥15 Kv / mm (IEC243)
Certifications: RoHS
Diameter: 9mm
Length: 70cm
Color Red
Color
Red
Material
N/A
Length (m)
0.7
Max cable diameter (mm)
9.0
Refurbished Grade
Grade S
We deliver all over France, and internationally. To find out the amount of shipping costs, simply go to your cart once you have added the desired products. To discover our different services and delivery options, click on the following logos :
