Refurbished product - Grade S
Cable drop of 1m.
OFC Copper Speaker Cable 2x4.mm² Ø12mm 1m
Mogami W3103 is a high quality speaker cable designed to allow your audio devices and speakers to reach their full potential. Each conductor, with a cross-section of 4mm² (12AWG), is made from OFC Mogami Neglex Copper in a configuration designed to provide transparency and sound precision. The cable can be used both at home and for professional purposes.
| Specifications | |
| Product type | Speaker cable |
| Conductors number | 2 |
| Conductors material | OFC Copper |
| Conductors section | 4mm² (12AWG) |
| Conductors insulation diameter | Ø4.5mm |
| Insulation material | PVC |
| External diameter | Ø12mm |
| External sheath material | Flexible PVC |
| Weight / 100m | 20kg |
| DC resistance | 0.005Ω/m |
| Inductance @ 20°C 1kHz | 0.6µH/m |
| Capacitance @ 20°C | 100Hz : 106pF/m 1kHz : 93pF/m 10kHz : 83pF/m 50kHz : 76pF/m 100kHz : 74pF/m |
| Max. voltage | 500V DC (15s) |
| Working temperature min / max | -20°C / +70°C |
| Length | 1m |
| Diameter (mm) | 12.0 |
| Length (m) | 1.0 |
| Number of conductors | 2 |
| Shielding | No |
| Section (mm²) | 4.00 |
| Refurbished Grade | Grade S |
