Refurbished product - Grade S
Cable drop of 1.3m.
Interconnect cable UP-OCC silver triple shielding 1.3m
The Neotech NEI-1002 is a modulation cable consisting of two single crystal UP-OCC silver conductors. These conductors are maintained at equidistance thanks to the use of PE tubes and insulated with PE jackets. A triple shielding drastically limits the impact of interference, with a PTFE layer, an Al-Mylar foil and a silver-plated copper braid. The cable is finally covered by a PVC sheath and dressed with a Nylon braided sheath.
| specifications | |
| Product type | Interconnect cable |
| Conductors material | UP-OCC silver |
| Conductors section | 2x AWG22 (0,33mm²) |
| Shielding | Feuille Al-Mylar Braided silver plated copper PTFE foil |
| Sleeve | PVC |
| Covering sleeve | Braided nylon |
| external diameter | Ø11.5mm |
| Length | 1.3m |
| Diameter (mm) | 11.5 |
| Length (m) | 1.3 |
| Number of conductors | 3 |
| Shielding | Yes |
| Section (mm²) | 1.17 |
| Conductors material (Cable) | Silver |
| Conductors Plating (Cable) | None |
| Refurbished Grade | Grade S |
