Refurbished product - Grade S
Cable drop of 90cm length.
Silver Plated UP-OCC Copper Shielded Power Cable 90cm
The CIP power cable series uses high quality copper/silver conductors and excellent internal insulation in PVC CL3. This cable provides a clean electrical signal for high-end audio systems, for accurate sound reproduction and improved dynamics.
The NEP-3003 MKIII thus integrates 3 conductors, each insulated by a PVC CL3 sheath. The conductors are made of several strands of UP-OCC Copper and UP-OCC Silver plated Copper to ensure excellent conductivity of the electrical signal. In addition, the cable has a double shielding with braided OFC Copper Mylar foil for a significant reduction in interference. Finally, the cable is covered with a final insulating PVC sheath and then a grey and orange braided sheath.
| Specifications | |
| Product type | Power cable |
| Number of conductors | 3 |
| Conductors material | UP-OCC Copper + Silver plated UP-OCCCopper |
| Conductor material | 2mm (3.5mm with insulation) |
| Conductor section | 13AWG (2.62mm²) |
| Cable diameter | 11.4mm |
| Insulation material | PVC |
| Shielding | Mylar Foil + Braided OFC Copper |
| Color | Gray and orange |
| Length | 90cm |
| Length (m) | 0.9 |
| Shielding | Yes |
| Section (mm²) | 2.62 |
| Connector | N/A |
| Refurbished Grade | Grade S |
