Refurbished product - Grade S
Cable drop of 90cm.
Speaker cable OCC Copper 6x1.5mm² 6x16AWG 11AWG Ø16mm 90cm
Designed from an extremely strict specification, the Amadeus 5 Mk2 cable is dedicated to loudspeaker cabling (& bi-wiring) and power cables. This speaker/power cable offers superior performance thanks to the use of materials and manufacturing methods rare in this price range. The conductors are made of pure OCC copper with six bodies, and its insulating structure (Air Geometry Design) uses air according to a geometry registered by the brand itself.
The connectors are arranged so that you can truly "tune" the wiring of your devices according to their strengths and weaknesses. We can dedicate 2x2 cables to the positive and 2x1 cables to the negative in order to obtain a rich and balanced sound stage in a bi-wiring context. Conversely, less symmetrical assemblies can also be made for filtering/crossover. In addition to the six main wires of 1.5mm² (16AWG) there is a seventh thinner wire which will allow to connect the shielding and thus to avoid some parasitic noises.
Definitely audiophile, the Amadeus 5 Mk2 cable offers formidable performances thanks to very high quality conductors and a multiple shielding Aluminium / Polypropylene / PVC. All conditions are met for an optimal resistance to interference with a minimal distortion rate.
| Specifications | |
| Product type | Speaker cable |
| Conductors | OCC Copper |
| Section | 6x 1.5mm² (16AWG) |
| Insulation | Proprietary : geometric structure air and polypropylene |
| Conductor diameter | Approx. 2mm |
| Total diameter | Ø16mm |
| Common uses | Bi-amplificaton / Bi-wiring / power |
| Sleeve | PVC |
| Covering sheath | Nylon |
| Length | 90cm |
| Length (m) | Sold by length |
| Insulation material | PE |
| Shielding | Yes |
| Refurbished Grade | Grade S |
