Refurbished product - Grade S
Cable drop of 2.6m.
Designed according to extremely strict specifications, the Amadeus 5 Mk2 cable is dedicated to wiring (& bi-wiring) loudspeakers and to power cables. This speaker cable / power offers superior performance thanks to the use of materials and manufacturing methods that are rare in this price range. The conductors are six core pure copper OCC and its insulating structure (Air Geometry Design) uses air with a pattern designed by the mark itself.
The connectors are arranged so that the wiring of your devices according can be "tuned" according to their strengths and their weaknesses. One can dedicate 2x2 conductors to the positive and 2x1 conductor to the negative to obtain a rich and balanced sound stage in a bi-wiring context. Conversely, less symmetrical arrangements may also be made for filter / crossover.
In addition to the six main strands of 16AWG there is a seventhdriver designed to connect the mass and thus avoid most noise.
Definitely audiophile, Amadeus cable 5 Mk2 offers pure performance through high quality multiple conductors and a protective screen shield Aluminum / PP / PVC.
All conditions are met for optimal resistance to interference with minimal distortion.
| Specifications | |
| Type | Cable sold by the meter |
| Conductors | Pure copper OCC 11AWG (4.17mm²) |
| Cores | 6 cores made from 6x7 conductors |
| Insulating | Designed by Ramm / air geometrical structure and polypropylene |
| Diameter per conductor | Approx. 2mm |
| Total Diamtètre | 16mm |
| Common use | Speaker câble / Double speaker cables / power cable |
| PVC body | Braided Nylon & PVC Body Blue |
| Diameter (mm) | 16.0 |
| Length (m) | 2.6 |
| Insulation material | PE |
| Shielding | Yes |
| Refurbished Grade | Grade S |
