Refurbished product - Grade S
Cable drop of 1.9m
SOMMER CABLE - SC-ELEPHANT ROBUST SPM840
It is above all for the baroud on stage ... that we have further improved the cable stability of the 4.0 mm² EL seriesEphant. These cables are robust but flexible, resistant to crushing, easily rollable and support countless cycles of use. The surface of the outer sheath is even smoother and therefore easier to clean. The external diameters are also suitable for common multi-spindle speakers (CA-COM 8-pole, NL8, LKS 19, EP5), thus facilitating assembly or transformation. Themodel ELEPHANT SPM1640 is very interesting: with it, just one cable to connect eight lines of speakers with the central network. You will also find many other remarkable solutions in the chapter "equipped cables". ADVANTAGES:
USE:
| Length (m) | Sold by length |
| Number of conductors | 8 |
| Shielding | No |
| Section (mm²) | 4.00 |
| Refurbished Grade | Grade S |
