Refurbished product - Grade A
Damaged / torn cardboard box. Product in perfect condition.
Ceiling Speaker Driver LCRS 15° Angled 35W 8 Ohm 88dB 50Hz - 20kHz Ø16.5cm + Ø 2.5cm
The DAYTON ME650C in-wall speakers offer quality sound along with a very modern finish thanks to their new Micro-Edge™ grille design. It is designed as an "all-in-one solution" for creating a sound system in a home.
The 15° angle allows the creation of a natural cinema effect sound. The silk dome tweeter reproduces clear and precise highs, and its exclusive mounting system allows for adjustment of its position to ensure the desired effect. The woofer, made of Kevlar, provides accurate bass and warm, tight mids.
| Specifications | |
| Product type | Speaker driver |
| Speaker driver type | Coaxial with pivoting tweeter |
| Impedance | 8Ω |
| Handling power | RMS : 35W Max : 70W |
| Frequency response | 50Hz - 20kHz |
| Sensitivity | 87dB 1W/1m |
| Woofer diameter | Ø152mm |
| Woofer cone | Kevlar |
| Tweeter diameter | Ø25mm |
| Tweeter diaphragm | Silk |
| Crossover | |
| Depth | 127mm |
| Cutout diameter | Ø203mm |
| Speaker Power (W RMS) | 35.0 |
| Speaker Type | Ceiling Speaker |
| Impedance (Ω) | 8 |
| Loudspeaker diameter (mm) | 165.0 |
| Diaphragm type | Silk |
| Diaphragm type | Kevlar |
| Efficiency / Sensitivity (dB) | 83.0 |
| Max Linear Excursion (Xmax) (mm) | N/A |
| Lowest frequency (Hz) | 50 |
| Highest frequency (Hz) | 20000 |
| Refurbished Grade | Grade S |
