Refurbished product - Grade A
Damaged/ripped cardboard box. Product in perfect condition.
The DAYTON ME650C built-in speakers deliver high-quality sound and a modern finish with the new Micro-Edge ™ design of their grilles. It is designed as an "all in one solution" for creating a sound system in a home. The angle of 15 ° which characterizes it allows the creation of a natural cinema effect. The silk dome tweeter reproduces clear and precise treble, its exclusive fastening system allows to adjust its positioning to guarantee the desired effect.The woofer, consisting of Kevlar, provides precise bass and warm and tight mediums.
Features:
DATASHEET | |
| Speaker configuration | Coaxial |
| Input voltage | 8 ohms |
| Power handling (RMS) | 35 watts |
| Power handling (max) | 70 watts |
| Frequency response | 50 - 20.000 Hz |
| Sensitivity | 87 1W/1m |
| Type of subwoofer | Kevlar |
| Woofer diameter | 152mm-13mm |
| Tweeter type | Silk |
| Tweeter size | 25mm |
| Crossover | Yes |
| Special features | Pivoting tweeter |
| BUILDING MATERIALS | |
| Color | White |
| Grill Type | Metal |
| Mounting informations | |
| Product depth | 127mm-15mm |
| Cutout diameter | 203mm-6mm |
| Speaker Power (W RMS) | 35.0 |
| Speaker Type | Ceiling Speaker |
| Impedance (Ω) | 8 |
| Loudspeaker diameter (mm) | 165.0 |
| Diaphragm type | Silk |
| Diaphragm type | Kevlar |
| Efficiency / Sensitivity (dB) | 83.0 |
| Max Linear Excursion (Xmax) (mm) | N/A |
| Lowest frequency (Hz) | 50 |
| Highest frequency (Hz) | 20000 |
| Refurbished Grade | Grade A |
