[GRADE B] DIY Case with Screen Cutout Aluminium 172x250x60mm Silver Front Panel
Refurbished product - Grade B
This brushed aluminum DIY case will allow you to dress and protect your modules, as for example for an amplifier. The front and back of the case have holes to facilitate the integration of your components (connectors and screen). The case is also delivered with its buttons.
Reference : 16182
Refurbished
39,90 €tax incl.
33,25 € tax excl.
Scratches on the top of the case
DIY Case
With Screen Cutout Aluminium 172x250x60mm Silver Front Panel
Boîtier DIY avec découpe pour afficheur aluminium 172x250x60mm façade argent
Product typeCase
MaterialAluminum
External dimensions172 x 250 x 60mm
Internal dimensions158 x 240 x 48mm
Panel thicknessFront panel : 8mm
Rear panel : 3mm
Sides : 2.5mm
ColorFront panel : Silver
Rest of the case : Black
RCA hole diametersØ11mm
Screen drilling dimensions64.7 x 15.5mm
Centre distances for screen mounting93 x 30mm
Package1x Case
1x ON/OFF Button
1x ON/OFF switch
1x Volume button
Insulation materialPTFE
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Contacts number3
Max panel thickness (mm)N/A
ConnectorXLR
Refurbished GradeGrade B
Refurbished product - Grade B This brushed aluminum DIY case will allow you to dress and protect your modules, as for example for an amplifier....
