Refurbished product - Grade S
New version of the TCXO I-Sabre, its architecture is designed to allow you to have all the outputs on the same side when the Raspberry Pi is coupled to the DAC.
Connectors have been added to make the integration of the various components of a DIY reader as simple as possible.
Brand new product.
DAC ES9023 TCXO Raspberry Pi 3 B / Pi 3 B+ / Pi 2 A+ B+ / I2S
New version of the I-Sabre TCXO, its architecture is designed to allow you to have all outputs on the same side when the Raspberry Pi is coupled to the DAC. Connectors have been added to make the integration of the various components of a DIY player as simple as possible.
I-Sabre is now equipped with an advanced power management (ATX type) for the clean shutdown of the software solution used. These functions are managed by a PIC and allow different shutdown modes according to the needs (software or hardware).
This converter with new features is ideal for turning a Raspberry Pi 2.0, A+ or B+ into a high-definition file reader. Equipped with the famous Sabre ES9023, a revised schematic, and OS-CON capacitors, this DAC will give you a musical, dynamic sound rich in micro details.
Intended for the many software solutions dedicated to audio playback on this platform, it allows an easier than ever implementation for an incomparable result in this price range.
Key Functions :
| Specifications | |
| Product type | DAC board |
| DAC Chip | ES9023 |
| Clocks | TCXO 0.5ppm ultra low jitter |
| Input | Raspberry Pi B+ / A+ 2.0 GPIO |
| Output | 1x Gold plated stereo RCA |
| Supported sampling rates | PCM up to 24bit 192kHz |
| I2S Driver | Hifiberry DAC |
| Volume | Fixed under Volumio in bitperfect (activation of the software volume control possible in the interface). |
| General | |
| Power supply | 7.5VDC via Jack DC 5.5 / 2.1mm |
| Dimensions | 85 x 56 x 33mm |
| Mounting holes spacing (HAT format) | 50 x 58mm |
| RCA connectors | Spacing : 20mm Cutout diameter : Ø12mm |
| Package | 1x Audiophonics I-Sabre V4 Screws and spacers |
The LED display and button are sold separately.
Power on process :
Press the button. The DAC turns on the Raspberry Pi. The LED flashes waiting for the "BOOT OK" signal from the Raspberry Pi (GPIO 22). This signal happens because a script changes the state of the pin once the Raspberry Pi is started. Once the signal is received, the LED stays on and the system is in a stable state.
Switching off from the button :
Press the button. The microcontroller detects the switch-off command. It sends a "Shutdown" signal to GPIO 17 to start the shutdown script. Once the Raspberry Pi is turned off, the button turns off waiting for a new power-up.
Switching off from Volumio :
Click on "Power OFF". The Raspberry Pi sends a "Shutdown" signal to GPIO 4 to start the shutdown script. Once the Raspberry Pi is turned off, the button will shut down waiting for a new turn on.
Reboot from Volumio :
Click on "Reboot". The Raspberry Pi sends a "Reboot" signal to GPIO 4 to run the reboot script. Once the Raspberry Pi is restarted, the "Boot OK" will come back and the button LED will be fixed.
| Input | I2S |
| Output | RCA |
| DAC / ADC Chip | ES9023 |
| Max sampling rate | 192kHz |
| Color | Black |
| Mounting type | To screw |
| Channel | 2 (Stereo) |
| Refurbished Grade | Grade S |
