[GRADE B] DAYTON AUDIO BST-300EX Speaker Driver Exciter
-22%
Refurbished product - Grade B
Big brother to the BST-1, the BST-300EX offers 300W of power with its Ø18cm diameter. It lets you feel the low frequencies not perceptible to the human ear, creating an immersive, physical sound experience.
Reduced price!
Reference : 19335
Refurbished
Limited special offer
89,00 €tax incl.
-22%
69,00 €tax incl.
57,50 € tax excl.
Torn cardboard packaging. Impacts and paint chips on some fins and one edge.
Speaker Driver Exciter Bass Shaker 300W 4Ω
DAYTON AUDIO BST-300EX Speaker Driver Exciter Bass Shaker 300W 4Ω
This powerful Dayton Audio BST300EX speaker driver is an exciter bass shaker, meaning that it lets you feel low frequencies not perceptible by the human ear. Indeed, the human ear has the ability to hear a wide range of sounds, however, some sounds are simply too low to be heard and must be felt by the body. Feeling these extremely low-frequency sounds adds a new dimension to your listening, gaming and cinema experiences.
DAYTON AUDIO BST-300EX: an immersive sound experience
Big brother to the BST-1, the BST-300EX offers 300W of power with its Ø18cm diameter. Inside is a magnetic puck is suspended between 2 durable nylon spiders, all enclosed within a former wrapped with a powerful voicecoil. The BST-300-EX converts electrical signals into tangible waves of sound power that can be dispersed over any surface. This eliminates the need for an oversized subwoofer to create an immersive, physical sound experience.
Effortless mounting
The BST-300EX features 4 mounting holes for easy installation on any flat surface. This will enable you to quickly enjoy this audio engineering masterpiece. You can also decide to mount up to two BST-300EXs in series, which will increase the impedance of the configuration to 8 Ohms, or in parallel, which will lower the impedance of the installation to 2 Ohms. Mounting 4 speakers in series-parallel will keep the impedance of your installation at 4 Ohms. For your installation, it is recommended to use 12-14AWG speaker cables.
Additional notes and suggestions:
  • A 4Ω low-pass crossover of 80Hz or less is recommended to reduce unwanted high-frequency output.
  • Do not exceed 300 watts RMS per Bass Shaker multiplied by the number of Shakers (example: 300 x 4 = 1200 Watts RMS).
Product typeExciter (Bass Shaker)
Chassis materialAluminum
Impedance4Ω
Power300Wrms
Dimensions (LxHxP)18 x 18 x 6.35cm
Mounting holesCorner to corner : 17cm (6-11/16")
Side to side : 12cm (4-11/16")
Weight1.4kg
Package1x DAYTON AUDIO BST-300EX  Speaker Driver Exciter Bass Shaker 300W 4Ω
Speaker Power (W RMS)300.0
Speaker TypeExciter
Impedance (Ω)4
Loudspeaker diameter (mm)180.0
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
Refurbished GradeGrade B
[GRADE B] DAYTON AUDIO BST-300EX Speaker Driver Exciter Bass Shaker 300W 4Ω
Refurbished product - Grade B Big brother to the BST-1, the BST-300EX offers 300W of power with its Ø18cm diameter. It lets you feel...
