[GRADE A] DAYTON AUDIO DSA215-8 Speaker Driver Woofer 80W 8 Ohm 89dB 35Hz - 7000Hz Ø20cm
-27%
Refurbished product - Grade A
Reduced price!
Reference : 22117
Refurbished
89,00 €tax incl.
-27%
64,90 €tax incl.
54,09 € tax excl.
Shipping date: 24-11-2026.
Torn cardboard box
Dayton Audio DSA215-8
Top woofer 20cm 80W 8Ω
This bass speaker belongs to the Designer Series from Dayton Audio. It is suitable for all construction projects / repair / modification speaker subject to space constraints and power. Its lightweight design allows it to integrate into speaker boxes at modest volume without significantly affecting the sound quality.
The DSA215-8 advantage of a smooth frequency response and well defined on the beaches 35 - 7000Hz, which will facilitate the establishment of an effective and relevant filtering in the design of the speakers. With a tolerated power 80W (RMS), a sensitivity of 89.2dB @ 2.83V / 1m and a maximum deviation of 5.5mm, this woofer deploys a powerful, accurate bass that lends itself to standard audio applications as more projects ambitious home theater.
Speaker TypeWoofer
Nominal Diameter8"
Power Handling (RMS)80 watts
Power Handling (max)160 watts
Impedance8 ohms
Sensitivity89.2 dB @ 2.83V/1m
Frequency Response35 - 7,000 Hz
Voice Coil Diameter38.5 mm
Magnet Weight49 oz.
DC Resistance (Re)5.9 ohms
Voice Coil Inductance (Le)1 mH @ 1 kHz
Resonant Frequency (Fs)35 Hz
Mechanical Q (Qms)1.87
Electromagnetic Q (Qes)0.40
Total Q (Qts)0.33
Diaphragm Mass Inc. Airload (Mms)34.6g
Mechanical Compliance of Suspension (Cms)0.6 mm/N
Surface Area Of Cone (Sd)211.2 cm²
Volume of Displacement (Vd)116.2 cm³
BL Product (BL)10.6 Tm
Compliance Equivalent Volume (Vas)37.4 liters
Maximum Linear Excursion (Xmax)5.5 mm
Cone / Diaphragm MaterialAluminum Cone
Surround MaterialRubber
Voice Coil Wire MaterialCopper
Voice Coil FormerAluminum
Basket/Frame MaterialSteel
Magnet MaterialFerrite
Overall Outside Diameter216 mm
Overall Depth95.5 mm
Baffle Cutout Diameter180 mm
Weight3.3kg
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume7.93L (0.28ft³)
Sealed F389Hz
Vented volume15.29L (0.54ft³)
Vented F355Hz
Speaker Power (W RMS)80.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)200.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)35
Highest frequency (Hz)7000
Refurbished GradeGrade A
