[GRADE S] NEOTECH NC-P303G Connector IEC C13 UP-OCC Copper Gold Plated Ø24mm
-6%
Refurbished product - Grade S
This IEC C13 Neotech NC-P303G IEC C13 connector will allow you to design your own high performance power cables. It incorporates 99.99999% pure UP-OCC copper contacts with 24K gold plating, ensuring optimum conductivity and oxidation resistance. Assembly is simply done via a screw system.
Reduced price!
Reference : 20853
Refurbished
Limited special offer
79,00 €tax incl.
-6%
74,00 €tax incl.
61,67 € tax excl.
Last items in stock !
Shipping date: 25-07-2025.
Brand new product. First version
Neotech NC-P303G
Neotech NC-P303G Connecteur IEC C13 Cuivre UP-OCC Plaqué Or 24K Ø24mm
This IEC C13 Neotech NC-P303G IEC C13 connector will allow you to design your own high performance power cables. It incorporates 99.99999% pure UP-OCC copper contacts with 24K gold plating, ensuring optimum conductivity and oxidation resistance. Assembly is simply done via a screw system, without the need for soldering. The connector is delivered with reducers to effectively hold your cable.
Product typeIEC C13 connector
Contacts materialUP-OCC Copper
Contacts platingGold 24K
Max cable diameter (without reducer)Ø24mm
Diameters with reducersØ17mm
Ø14mm
Ø11mm
Max conductors section3.31mm² (12AWG)
Mounting typeTo screw
Total dimensionsØ43 x 84mm
Max cable diameter (mm)24.0
ConnecticFemale
ConnectorIEC C13
Rated current (A)N/A
Refurbished GradeGrade S
Refurbished product - Grade S This IEC C13 Neotech NC-P303G IEC C13 connector will allow you to design your own high performance power cables....
