[GRADE A] IBASSO DC04 Balanced Headphone Amplifier DAC Adapter USB-C Hi-Res 2x CS43131 32bit 384kHz DSD256 Silver
Refurbished product - Grade A
The DC04 from iBasso is an affordable and high-performance portable DAC and balanced headphone amplifier combo. Ideal for enjoying high quality sound reproduction with your smartphone or computer, the DC04 is equipped with a pair of DAC CS43131 chips ensuring a THD+N of 0.00032% (@ 300Ω), an SNR of 133dB and a background noise of only 0.9µV. It is also capable of developing a power of 2x 192mW (@ 32Ω). This integration also allows it to support high resolution files up to 32bit 384kHz PCM and DSD256 Native.
Reference : 17827
Refurbished
64,90 €tax incl.
54,09 € tax excl.
Product in perfect condition. Packaging box damaged.
iBasso DC04
iBasso DC04 DAC Amplificateur Casque Symétrique Portable OTG 32bit 384kHz DSD256
Balanced output & USB DAC
The DC04 has a balanced 4.4mm jack output connector. This output contributes to the sound quality of the DC04.
Supplied with a USB-C to USB-A adapter, the DC04 can also be used with a computer as a high-end sound card.
UAC Volume Control
A smartphone usually uses a software volume control with 10 levels, which does not allow for precise volume adjustment. The DC04 offers an output level of 4Vrms. The volume control is done via a proprietary application supporting UAC 2.0 offering 64 levels for precise hardware adjustment.
Product typeBalanced DAC & Headphone amplfiier
DAC Chip2x CS43131
Input1x Male USB-C
Output1x Female Balanced Jack 4.4mm
THD+N-110dB / 0.00032% @ 300Ω
-108dB / 0.00039% @ 32Ω
Output level4Vrms @ 300Ω
2.5Vrms @ 32Ω
Power output192mW @ 32Ω
SNR133dB
Frequency response20Hz - 40kHz ±0.5dB
Noise floor< 0.9µV
Output impedance< 0.12Ω
Native DSD up to DSD256
Dimensions110 x 43.5mm
Weight12g
ColorSilver
Package1x iBasso DC04
1x USB-C to USB-A adapter
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
Refurbished GradeGrade S
Refurbished product - Grade A The DC04 from iBasso is an affordable and high-performance portable DAC and balanced headphone amplifier combo....
