[GRADE B] WIIM MINI Audio Streamer Bit-Perfect WiFi AirPlay 2 Multiroom Bluetooth 5.0 24bit 192kHz
Refurbished product - Grade B
The WiiM Mini is a small and extremely versatile network player, ideal for converting a conventional audio system into a connected system. It will allow you to stream your music remotely via WiFi, Airplay 2 or Bluetooth 5.0.
Reference : 18306
Refurbished
79,00 €tax incl.
65,83 € tax excl.
Slight scratches.
WiiM Mini
Streamer WiFi AirPlay 2 Multiroom Bluetooth 5.0 24bit 192kHz
WiiM Mini Lecteur Réseau WiFi Airplay 2 Multiroom Bluetooth 5.2 24bit 192kHz
WiiM Mini
WiiM Pro
WiiM Pro Plus
Ethernet
Yes
Yes
DAC
PCM5121
PCM5121
AKM AK4493SEQ
Analog Out SNR
106dB
106dB
121dB
Analog Out THD+N
-92dB (0.0025%)
-92dB (0.0025%)
-113dB (0.00023%)
ADC
Fixed 16bit 48kHz
Fixed 16bit 48kHz
Up to 24bit 192kHz
Chromecast audio
Yes
Yes
Group with Nest speakers and Display
Yes
Yes
Group with Echo speakers and Display
Yes
Yes
Yes
Alexa multiroom with UHD
Yes
Yes
Group with HomePods
Yes
Yes
Yes
Alexa support
Yes
Yes
Yes
Google support
Yes
Yes
Siri support
Yes
Yes
Yes
Group with WiiM or Linkplay devices
Yes
Yes
Yes
AirPlay 2
Yes
Yes
Yes
AirPlay Cast
Yes
Yes
DLNA
Yes
Yes
Yes
Roon
Yes
Yes
Spotify Connect
Yes
Yes
Yes
TIDAL Connect
Yes
Yes
Yes
Gapless playback
Yes
Yes
Yes
10-band graphic EQ
Yes
Yes
Yes
Linkplay music streaming platform
Yes
Yes
Yes
CPU
Dualcore A7
Quadcore A53
Quadcore A53
DRAM
128MB
512MB
512MB
Flash
128MB
512MB
512MB
Inputs
AUX
Line, Optical
Line, Optical
Outputs
AUX, Optical
Line, Optical, Coaxial
What is the Bit-Perfect ?
"Bit-perfect" is a term commonly used in audio. It is used to describe a player that can play a file without making any changes to it.
For example, if your player plays a 24bit/192kHz Hi-Res file on Qobuz, the Digital output will offer 24bit/192kHz. Just as if the music file played is a 16Bit/44.1kHz, the Digital output will offer 16Bit/44.1kHz, without any modification. A true 1:1 ratio (Input / Output).
This is what we call a real Bit-Perfect playback, the closest to the musical reality of the song played.
AirPlay 2
The WiiM Mini supports the Apple AirPlay2 wireless transmission protocol, allowing you to not only easily stream your music from an Apple device, but also stream your music to multiple audio devices at once.
Works with your voice assistant
The WiiM Mini is compatible with Amazon Alexa and Apple Siri voice assistants. This means you can easily control your network player via your voice assistant.
Multiroom
The WiiM Mini's built-in multiroom feature allows you to stream your music throughout your home in 3 different modes. If you use an Apple product, you can use Airplay 2 to set up your multiroom system. If you are using an Amazon product, you can use AVS Multiroom technology. Finally, WiiM also provides an application to easily control your multiroom installation from your smartphone.
Multiple audio sources
The WiiM Mini is compatible with many streaming services and web radios, such as Spotify, Tidal, Qobuz, Deezer, Amazon Music or TuneIn. You can enjoy your favorite music services and stream them wirelessly to your audio system. And if you want to connect other audio devices to your WiiM Mini, it has an auxiliary input.
Spotify Connect & Tidal Connect
With the WiiM Mini you can stream your music directly from the Spotify Connect and Tidal Connect streaming services, without using the WiiM Home application.
WiiM Home App
WiiM offers its free WiiM Home mobile app for iOS and Android to easily control all your WiiM devices connected to your network.
Product typeStreamer
InputsWiFi
Bluetooth 5.0
1x Jack 3.5mm
Outputs1x Jack 3.5mm
1x Optical Toslink
Wirelles connectivityWiFi EEE 802.11a/b/g/n/ac 2.4G
WiFi EEE 802.11a/n/ac 1x1 5G
Bluetooth 5.0
Line input level1Vrms
Output powerLine in to line out : 2Vrms
Bluetooth to line out : 2Vrms
Line in to SPDIF out: -3dBFS
Bluetooth to SPDIF out: 0dBFS
THD+NLine in to line out : 0.009%
Bluetooth to line out : 0.05%
Line in to SPDIF out : 0.005%
Bluetooth to SPDIF out : 0.005%
SNRLine in to line out : 102dB
Bluetooth to line out : 103dB
Line in to SPDIF out : 105dB
Bluetooth to SPDIF out : 297dB
CrosstalkLine in to line out : -106dB
Bluetooth to line out : -107dB
Line in to SPDIF out : -103dB
Bluetooth to SPDIF out : -364dB
Dynamic rangeLine in to line out : 96dB
Bluetooth to line out : 121dB
Entrée ligne vers sortie SPDIF : 97dB
Bluetooth to SPDIF out : 213dB
Supported audio codecsMP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Compatible streaming services, web radios and protocolsSpotify
Deezer
Qobuz
Amazon Music
Tidal
Pandora
Napster
Apple Music
TuneIn
iHeartRadio
LinkPlay Radio
Spotify Connect
Tidal Connect
Local Network Shares (NAS)
Compatible voice assistantsAlexa
Siri
Supply voltage5VDC 1A
Package1x WiiM Mini
1x USB-A to USB-C
1x Stereo RCA to Jack 3.5mm cable
1x Jack 3.5mm cable
1x Optical Toslink cable
InputJack 3.5mm
InputWiFi
OutputJack 3.5mm
OutputOptical Toslink
DAC / ADC ChipNC
Max sampling rate192kHz
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Refurbished GradeGrade B
Refurbished product - Grade B The WiiM Mini is a small and extremely versatile network player, ideal for converting a conventional audio system...
