UcPure MkIII from Ian Canada is a pure ultracapacitor power supply. It uses 3000F or above capacity ultracapacitor pack to achieve ultimate power performance. Because this is a purely passive power supply, no feedback and no active components are involved when turned on. In pure output mode, only the pre-charged ultracapacitor pack will be applied to the load.
It is also capable of delivering up to 1000A of dynamic current with less than 0.58mΩ internal ESR (continuous output mode, decided by the 3000F ultracapacitor pack).
The UcPure MkIII could be the best low-noise, ultra-dynamic power supply yet. The sound quality of sensitive audio applications such as low jitter clock oscillators, DACs, FIFOs and many other circuits will benefit from this UcPure MkIII power supply.
The UcPure MkIII can be configured for 3.3V, 5V (default) and 15V configurations. It is also equipped with a SYNC charge function to be able to recharge the ultracapacitors during music stops.
Key points :
UcPure MkIII new features :
Product type | Ultracapacitor power supply module |
Input tension | 9-20VDC |
Output tension | 5V |
Dynamic output current | Up to 1000A (value decided by ultracapacitors) |
Output ESR | < 0.58mΩ |
Dimensions | 132*56mm |
Input | Jack DC 5.5/2.5mm |
Input | Screw terminals |
Output | Screw terminals |
Output | PCB Connector |
Output voltage (V) | 5.0 |
Output current (A) | 1000.0 |
Input voltage (V) | 9.0 |
Input voltage (V) | 20.0 |
Power Supply | Ultracapacitor power supply |
