This product has been replaced by the new version, the Ultracapacitor Power Supply Module.
Ultracapacitor Power Supply Module Class A 3.3V / 15V
The Ian Canada UcPure is a supercapacitor power supply module. It uses a set of supercapacitors with a minimum capacity of 3000F to achieve a very high level of performance. Being a totally passive power supply, the module does not generate any feedback and does not integrate any active component. In pure output mode, only the pre-charged supercapacitor pack is applied to the load. It is also capable of delivering up to 1000A of dynamic current with an internal ESR less than 0.58mΩ (continuous output mode).
All in all, the UcPure module is an excellent low-noise, ultra-high dynamic range power supply, ideal for powering sensitive audio devices such as low jitter clocks, DACs or FIFO buffers.
Points clés :
| Specifications | |
| Product type | Ultracapacitor power supply module |
| Input voltage | 9-20VDC for a 3.3V output 18-20VDC for a 15V output |
| Output voltage | 3.3V (default) 15V |
| Dynamic output current | Up to 1000A (decided by ultracapacitors) |
| Output ESR | < 0.58mΩ (@ 3.3V configurations, decided by ultracapacitors) |
| Dimensions | 132 x 56mm |
| Input | Jack DC 5.5/2.5mm |
| Input | Solder pad |
| Output | Screw terminals |
| Output | PCB Connector |
| Output voltage (V) | 5.0 |
| Output voltage (V) | 15.0 |
| Output voltage (V) | 3.3 |
| Output current (A) | 1000.0 |
| Input voltage (V) | 18.0 |
| Input voltage (V) | 9.0 |
| Input voltage (V) | 20.0 |
| Power Supply | Ultracapacitor power supply |
