This double linear power supply module offers many possibilities. It is equipped with two LT1083 type controllers and a large number of oversized diodes. The wide track tinned circuit (thickness 1.6mm on 2 ounces of copper) allows a higher than average current on this type of power supply module.
The two mini screw potentiometers will allow two different voltages to be output. This module is therefore particularly recommended for powering a DAC requiring average DC voltages of 3.3/5V and 12/15V.
Its integration is greatly simplified with the integrated coolers on the circuit. It can be perfectly suitable for DACs, preamplifiers, phono stages, line stages requiring a high average output current.
As many environments in which it contributes to improving sound quality, equipped with two potentiometers it is possible to adjust its voltage from 2.5 to 24V DC.
Caution: The average acceptable current level will be as a consequence of the size of the radiators and heatsinks mounted on the power supply modules.
Caution: The maximum amperage will depend on the input and output voltage on the power supply module. The current values given are theoretical.
Caracteristiques :
The transformer must be able to deliver at least 1.5x the output voltage to create a delta of 5 to 8V DC higher at the input).
Physical characteristics :
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 5.0 |
| Output voltage (V) | 20.0 |
| Output voltage (V) | 24.0 |
| Output voltage (V) | 10.0 |
| Output voltage (V) | 3.0 |
| Output voltage (V) | 15.0 |
| Output current (A) | 5.0 |
| Input voltage (V) | 25.0 |
| Input voltage (V) | 2.5 |
| Input voltage (V) | 10.0 |
| Input voltage (V) | 20.0 |
| Input voltage (V) | 30.0 |
| Input voltage (V) | 5.0 |
| Input voltage (V) | 15.0 |
| Power Supply | Regulated Linear Power Supply |
