Regulated Linear Power Supply Module Dual LME49710 / MJE15032 5-18VDC
This regulated linear power supply module takes advantage of a beautiful design quality to provide a clean electrical signal to your HiFi devices. It takes as input an electrical signal between 2x7V AC and 2x18V AC to output between 5VDC and 18VDC with a maximum output current of 2A.
Reference : 14560
29,90 €tax incl.
24,92 € tax excl.
Regulated Linear Power Supply Board
Module d'alimentation linéaire régulée Double LME49710 / MJE15032 5-18VDC
This regulated linear power supply module takes advantage of a beautiful design quality to provide a clean electrical signal to your HiFi devices. It takes as input an electrical signal between 2x7V AC and 2x18V AC to output between 5VDC and 18VDC with a maximum output current of 2A. (non continuous)
The module integrates low noise components to ensure very good performance, including two LME49710 operational amplifiers driving two MJE15032 transistors.
Product typeRegulated linear power supply board
Input voltage range2x7V AC - 2x18V AC
Output voltage range5V - 18V
Max output current2A (Continuous recommended < 500mA)
Operationnal amplifier2x LME49710
Transistors2x MJE15032
Dimensions81 x 61mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)10.0
Output voltage (V)15.0
Output voltage (V)18.0
Output voltage (V)5.0
Output current (A)0.5
Output current (A)2.0
Input voltage (V)10.0
Input voltage (V)18.0
Input voltage (V)7.0
Input voltage (V)15.0
Power SupplyRegulated Linear Power Supply
This regulated linear power supply module takes advantage of a beautiful design quality to provide a clean electrical signal to your HiFi devices....
