Very silent (ripple
Regulated Linear Power Supply Module LT3045 LT3094 3x +/-15V
This quality regulated linear power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of 3x ±15V on 3 pin XH2.54mm connectors. The module embeds an 8VA sealed transformer, an LDO LT3045 regulator and a second LT3094 as well as two 2200µF filter capacitors, ensuring a clean and stable electrical signal. A heat sink allows to efficiently evacuate the heat released by the LDOs. The assembly is mounted on a transparent acrylic plate.
| Specifications | |
| Product type | Power supply module |
| Power supply type | Regulated linear power supply |
| LDO | 1x LT3045 1x LT3094 |
| Input voltage | 220V AC |
| Input connector | IEC C8 |
| Output voltage | 3x ±15V |
| Output | 3x 3 pins XH2.54mm connectors (3 pins to bare wires cable included) |
| Max output current | ±500mA |
| Output power | 8W |
| Ripple | < 1mV |
| Temperature range | -40°C - +85°C |
| Noise level | 0.8µVrms (10Hz, 100kHz) |
| PSRR | 76dB @ 1MHz |
| General | |
| Dimensions | 105 x 60 x 58mm |
| Weight | 355g |
| Input | IEC C8 |
| Output | PCB Connector |
| Output voltage (V) | 15.0 |
| Output current (A) | 0.5 |
| Input voltage (V) | 220.0 |
| Power Supply | Regulated Linear Power Supply |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
